root/radiance/src/common/spec_rgb.c
Thu Aug 22 04:27:53 2024 UTC (13 months, 4 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.34: +4 -3 lines
Diff to previous 2.34 , to selected 2.29
refactor: Added scblack and changed cblack and cwhite to global const arrays
Wed Aug 14 20:05:23 2024 UTC (14 months ago) by greg
Changes since 2.33: +26 -26 lines
Diff to previous 2.33 , to selected 2.29
Mon Aug 12 18:57:00 2024 UTC (14 months, 1 week ago) by greg
Changes since 2.32: +31 -1 lines
Diff to previous 2.32 , to selected 2.29
fix(rpict): Fixed light source drawing in non-RGB color spaces
Wed Jan 17 17:36:20 2024 UTC (21 months ago) by greg
Changes since 2.31: +29 -1 lines
Diff to previous 2.31 , to selected 2.29
feat: Added convertscolorcol() to generate better RGB result
Fri Dec 8 18:48:09 2023 UTC (22 months, 1 week ago) by greg
Diff to previous 2.30 , to selected 2.29
fix(rmtxop,rmtxcomb): Eliminated truncation of RGB's in spec_rgb()
Mon Nov 27 21:00:14 2023 UTC (22 months, 3 weeks ago) by greg
Changes since 2.29: +40 -7 lines
Diff to previous 2.29
refactor: Added number of spectral samples and wavelength splits to arguments
Revision 2.29 - (view) (download) (annotate) - [selected]
Tue Nov 21 01:30:20 2023 UTC (22 months, 4 weeks ago) by greg
Changes since 2.28: +4 -4 lines
Diff to previous 2.28
Fri Nov 17 20:02:07 2023 UTC (23 months ago) by greg
Changes since 2.27: +4 -4 lines
Diff to previous 2.27 , to selected 2.29
Wed Nov 15 18:02:52 2023 UTC (23 months ago) by greg
Changes since 2.26: +301 -60 lines
Diff to previous 2.26 , to selected 2.29
Wed Sep 16 00:42:36 2020 UTC (5 years, 1 month ago) by greg
Diff to previous 2.25 , to selected 2.29
feat: Added functional check for XYZ color space to coloprimsOK()
Wed Aug 19 17:36:37 2020 UTC (5 years, 2 months ago) by greg
Changes since 2.24: +9 -9 lines
Diff to previous 2.24 , to selected 2.29
refactor: eliminated deprecated register keywords
Fri May 18 22:48:39 2012 UTC (13 years, 5 months ago) by greg
Diff to previous 2.23 , to selected 2.29
Even wider acceptance of whacky color primaries
Fri May 20 02:06:38 2011 UTC (14 years, 5 months ago) by greg
Diff to previous 2.22 , to selected 2.29
Tue Apr 13 01:48:52 2010 UTC (15 years, 6 months ago) by greg
Changes since 2.21: +5 -2 lines
Diff to previous 2.21 , to selected 2.29
Stricter check on white point
Mon Apr 12 21:24:07 2010 UTC (15 years, 6 months ago) by greg
Changes since 2.20: +6 -4 lines
Diff to previous 2.20 , to selected 2.29
Allow for even larger primary chromaticity range
Mon Jan 4 19:40:14 2010 UTC (15 years, 9 months ago) by greg
Changes since 2.19: +7 -2 lines
Diff to previous 2.19 , to selected 2.29
Improved chromaticity check
Fri Nov 20 17:51:47 2009 UTC (15 years, 11 months ago) by greg
Diff to previous 2.18 , to selected 2.29
Syntax error
Fri Nov 20 17:50:50 2009 UTC (15 years, 11 months ago) by greg
Diff to previous 2.17 , to selected 2.29
Made color primitive checker even more forgiving
Mon Nov 2 23:45:11 2009 UTC (15 years, 11 months ago) by greg
Changes since 2.16: +5 -3 lines
Diff to previous 2.16 , to selected 2.29
Made color primitives check a little more forgiving
Mon Oct 8 18:07:55 2007 UTC (18 years ago) by greg
Diff to previous 2.15 , to selected 2.29
Tue Sep 5 21:54:32 2006 UTC (19 years, 1 month ago) by greg
Changes since 2.14: +135 -64 lines
Diff to previous 2.14 , to selected 2.29
Added return values and colorprimsOK() function to check primary ranges
Thu Mar 23 22:01:43 2006 UTC (19 years, 7 months ago) by greg
Diff to previous 2.13 , to selected 2.29
Fixed problems with NaN and Inf floating point color values
Mon Jun 30 19:04:29 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 2.12 , to selected 2.29
Tue Feb 25 02:47:22 2003 UTC (22 years, 7 months ago) by greg
Changes since 2.11: +1 -56 lines
Diff to previous 2.11 , to selected 2.29
Sat Feb 22 02:07:22 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.10: +177 -11 lines
Diff to previous 2.10 , to selected 2.29
Wed Oct 7 17:11:40 1998 UTC (27 years ago) by gwlarson
Diff to previous 2.9 , to selected 2.29
added conservative measures to make sure clipgamut() kept in bounds
Thu Apr 17 15:42:02 1997 UTC (28 years, 6 months ago) by greg
Changes since 2.8: +7 -3 lines
Diff to previous 2.8 , to selected 2.29
fixed bug in colortrans() introduced in last change
Fri Jan 31 12:58:39 1997 UTC (28 years, 8 months ago) by greg
Changes since 2.7: +61 -12 lines
Diff to previous 2.7 , to selected 2.29
added clipgamut() routine for performing gamut mapping and clipping
Thu Jan 30 19:14:39 1997 UTC (28 years, 8 months ago) by greg
Changes since 2.6: +8 -5 lines
Diff to previous 2.6 , to selected 2.29
changed colortrans() to optionally allow negative results
Wed Oct 2 11:05:18 1996 UTC (29 years ago) by greg
Changes since 2.5: +16 -8 lines
Diff to previous 2.5 , to selected 2.29
made testing for stdprims more sensible
Sun Oct 15 14:08:01 1995 UTC (30 years ago) by greg
Changes since 2.4: +126 -22 lines
Diff to previous 2.4 , to selected 2.29
made changes for new 32-bit_rle_xyze picture type
Thu Jul 7 15:21:25 1994 UTC (31 years, 3 months ago) by greg
Changes since 2.3: +20 -0 lines
Diff to previous 2.3 , to selected 2.29
added rgb_cie() routine
Wed Jun 29 18:16:58 1994 UTC (31 years, 3 months ago) by greg
Changes since 2.2: +10 -12 lines
Diff to previous 2.2 , to selected 2.29
changed RGB primaries and went to true (i.e. equal-energy) white
Fri Mar 5 15:14:04 1993 UTC (32 years, 7 months ago) by greg
Diff to previous 2.1 , to selected 2.29
portability improvements
Tue Nov 12 16:54:40 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.3 , to selected 2.29
Fri Dec 14 12:48:32 1990 UTC (34 years, 10 months ago) by greg
Diff to previous 1.2 , to selected 2.29
added correct color transformations
Sat Dec 8 09:29:10 1990 UTC (34 years, 10 months ago) by greg
Changes since 1.1: +24 -8 lines
Diff to previous 1.1 , to selected 2.29
changed cie_rgb to use mapping for color monitor by default
Sat Sep 22 10:44:56 1990 UTC (35 years, 1 month ago) by greg
Diff to selected 2.29
