root/radiance/src/common/rglsrc.c
Revision: 3.6
Committed: Fri Nov 14 17:22:06 2003 UTC (21 years, 10 months ago) by schorsch
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad3R7P2, rad3R7P1, rad6R0, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad4R2P2, HEAD
Changes since 3.5: +1 -4 lines
2 static const char RCSid[] = "$Id: rglsrc.c,v 3.5 2003/07/17 09:21:29 schorsch Exp $";
5 * Routines for handling OpenGL light sources
6 */
7
8 #include "copyright.h"
9
10 #include "radogl.h"
11
12 double expval = 0.; /* global exposure value */
13
14 COLOR ambval = {0.2, 0.2, 0.2}; /* global ambient value */
15
16 int dolights = MAXLIGHTS; /* do how many more light sources? */
17
18 int glightid[MAXLIGHTS] = {GL_LIGHT0, GL_LIGHT1, GL_LIGHT2,
19 GL_LIGHT3, GL_LIGHT4, GL_LIGHT5, GL_LIGHT6, GL_LIGHT7};
20
21 static int lightlist; /* light list id */
22
23 /* source types */
24 #define L_NONE 0
25 #define L_SOURCE 1
26 #define L_FLAT 2
27 #define L_SPHERE 3
28
29 static struct {
30 int type; /* light type (0 if none) */
31 MATREC *m; /* light material */
32 FVECT pos; /* light position (or direction) */
33 FVECT norm; /* flat source normal */
34 double area; /* source area (or solid angle) */
35 } lightrec[MAXLIGHTS]; /* light source list */
36
37 static int nlights; /* number of defined lights */
38
39 static void l_flatsrc(int), l_sphsrc(int), l_source(int);
40
41
42 void
43 lightinit() /* initialize lighting */
44 {
45 GLfloat ambv[4];
46
47 if (!dolights)
48 return;
49 glPushAttrib(GL_LIGHTING_BIT);
50 if (expval <= FTINY && bright(ambval) > FTINY)
51 expval = 0.2/bright(ambval);
52 ambv[0] = expval*colval(ambval,RED);
53 ambv[1] = expval*colval(ambval,GRN);
54 ambv[2] = expval*colval(ambval,BLU);
55 ambv[3] = 1.;
56 glLightModelfv(GL_LIGHT_MODEL_AMBIENT, ambv);
57 glCallList(lightlist = newglist());
58 rgl_checkerr("in lightinit");
59 nlights = 0;
60 }
61
62
63 void
64 lightclean() /* clean up light source commands */
65 {
66 if ((dolights += nlights) <= 0)
67 return;
68 glPopAttrib();
69 }
70
71
72 void
73 lightdefs() /* define light source list */
74 {
75 if (!nlights)
76 return;
77 glNewList(lightlist, GL_COMPILE);
78 while (nlights--) {
79 switch (lightrec[nlights].type) {
80 case L_FLAT:
81 l_flatsrc(nlights);
82 break;
83 case L_SPHERE:
84 l_sphsrc(nlights);
85 break;
86 case L_SOURCE:
87 l_source(nlights);
88 break;
89 default:
90 error(CONSISTENCY, "botched light type in lightdefs");
91 }
92 freemtl(lightrec[nlights].m);
93 lightrec[nlights].type = L_NONE;
94 }
95 glEndList();
96 rgl_checkerr("defining lights");
97 }
98
99
100 int
101 o_source(o) /* record a distant source */
102 register OBJREC *o;
103 {
104 if (!dolights || !issrcmat((MATREC *)o->os))
105 return(0);
106 if (o->oargs.nfargs != 4)
107 objerror(o, USER, "bad # real arguments");
108 /* record type & material */
109 lightrec[nlights].type = L_SOURCE;
110 (lightrec[nlights].m = (MATREC *)o->os)->nlinks++;
111 /* assign direction */
112 VCOPY(lightrec[nlights].pos, o->oargs.farg);
113 /* compute solid angle */
114 if (o->oargs.farg[3] <= FTINY)
115 objerror(o, USER, "zero size");
116 lightrec[nlights].area = 2.*PI*(1. - cos(PI/180./2.*o->oargs.farg[3]));
117 nlights++; dolights--;
118 return(1);
119 }
120
121
122 int
123 doflatsrc(m, pos, norm, area) /* record a flat source */
124 MATREC *m;
125 FVECT pos, norm;
126 double area;
127 {
128 if (!dolights || !issrcmat(m) || area <= FTINY)
129 return(0);
130 /* record type & material */
131 lightrec[nlights].type = L_FLAT;
132 (lightrec[nlights].m = m)->nlinks++;
133 /* assign geometry */
134 VCOPY(lightrec[nlights].pos, pos);
135 VCOPY(lightrec[nlights].norm, norm);
136 lightrec[nlights].area = area;
137 nlights++; dolights--;
138 return(1);
139 }
140
141
142 int
143 dosphsrc(m, pos, area) /* record a spherical source */
144 register MATREC *m;
145 FVECT pos;
146 double area;
147 {
148 if (!dolights || !issrcmat(m) || area <= FTINY)
149 return(0);
150 /* record type & material */
151 lightrec[nlights].type = L_SPHERE;
152 (lightrec[nlights].m = m)->nlinks++;
153 /* assign geometry */
154 VCOPY(lightrec[nlights].pos, pos);
155 lightrec[nlights].area = area;
156 nlights++; dolights--;
157 return(1);
158 }
159
160
161 static void
162 l_source(n) /* convert a distant source */
163 register int n;
164 {
165 register MATREC *m = lightrec[n].m;
166 int thislight = glightid[n];
167 GLfloat vec[4];
168 /* assign direction */
169 VCOPY(vec, lightrec[n].pos);
170 vec[3] = 0.;
171 glLightfv(thislight, GL_POSITION, vec);
172 /* assign color */
173 vec[0] = expval*lightrec[n].area*colval(m->u.l.emission,RED);
174 vec[1] = expval*lightrec[n].area*colval(m->u.l.emission,GRN);
175 vec[2] = expval*lightrec[n].area*colval(m->u.l.emission,BLU);
176 vec[3] = 1.;
177 glLightfv(thislight, GL_SPECULAR, vec);
178 glLightfv(thislight, GL_DIFFUSE, vec);
179 vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.;
180 glLightfv(thislight, GL_AMBIENT, vec);
181 glEnable(thislight);
182 }
183
184
185 static void
186 l_flatsrc(n) /* convert a flat source */
187 register int n;
188 {
189 GLfloat vec[4];
190 register MATREC *m = lightrec[n].m;
191 int thislight = glightid[n];
192 /* assign position */
193 VCOPY(vec, lightrec[n].pos); vec[3] = 1.;
194 glLightfv(thislight, GL_POSITION, vec);
195 /* assign color */
196 vec[0] = expval*lightrec[n].area*colval(m->u.l.emission,RED);
197 vec[1] = expval*lightrec[n].area*colval(m->u.l.emission,GRN);
198 vec[2] = expval*lightrec[n].area*colval(m->u.l.emission,BLU);
199 vec[3] = 1.;
200 glLightfv(thislight, GL_SPECULAR, vec);
201 glLightfv(thislight, GL_DIFFUSE, vec);
202 vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.;
203 glLightfv(thislight, GL_AMBIENT, vec);
204 glLightf(thislight, GL_SPOT_EXPONENT, 1.);
205 glLightf(thislight, GL_CONSTANT_ATTENUATION, 0.);
206 glLightf(thislight, GL_LINEAR_ATTENUATION, 0.);
207 glLightf(thislight, GL_QUADRATIC_ATTENUATION, 1.);
208 if (m->type == MAT_SPOT && m->u.l.spotang < 90.) {
209 glLightf(thislight, GL_SPOT_CUTOFF, m->u.l.spotang);
210 glLightfv(thislight, GL_SPOT_DIRECTION, m->u.l.spotdir);
211 } else {
212 glLightf(thislight, GL_SPOT_CUTOFF, 90.);
213 VCOPY(vec, lightrec[n].norm);
214 glLightfv(thislight, GL_SPOT_DIRECTION, vec);
215 }
216 glEnable(thislight);
217 }
218
219
220 static void
221 l_sphsrc(n) /* convert a spherical source */
222 register int n;
223 {
224 GLfloat vec[4];
225 register MATREC *m = lightrec[n].m;
226 int thislight = glightid[n];
227 /* assign position */
228 VCOPY(vec, lightrec[n].pos); vec[3] = 1.;
229 glLightfv(thislight, GL_POSITION, vec);
230 /* assign color */
231 vec[0] = expval*lightrec[n].area*colval(m->u.l.emission,RED);
232 vec[1] = expval*lightrec[n].area*colval(m->u.l.emission,GRN);
233 vec[2] = expval*lightrec[n].area*colval(m->u.l.emission,BLU);
234 vec[3] = 1.;
235 glLightfv(thislight, GL_SPECULAR, vec);
236 glLightfv(thislight, GL_DIFFUSE, vec);
237 vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.;
238 glLightfv(thislight, GL_AMBIENT, vec);
239 glLightf(thislight, GL_SPOT_EXPONENT, 0.);
240 glLightf(thislight, GL_CONSTANT_ATTENUATION, 0.);
241 glLightf(thislight, GL_LINEAR_ATTENUATION, 0.);
242 glLightf(thislight, GL_QUADRATIC_ATTENUATION, 1.);
243 if (m->type == MAT_SPOT && m->u.l.spotang <= 90.) {
244 glLightf(thislight, GL_SPOT_CUTOFF, m->u.l.spotang);
245 glLightfv(thislight, GL_SPOT_DIRECTION, m->u.l.spotdir);
246 } else
247 glLightf(thislight, GL_SPOT_CUTOFF, 180.);
248 glEnable(thislight);
249 }
