root/radiance/src/common/readoct.c
Revision: 2.38
Committed: Thu Nov 6 00:19:59 2025 UTC (2 days, 17 hours ago) by greg
fix: Fixed bug where reading from stdin gave seg fault
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.38 static const char RCSid[] = "$Id: readoct.c,v 2.37 2025/06/07 05:09:45 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * readoct.c - routines to read octree information.
6 greg 2.13 */
7
8 greg 2.14 #include "copyright.h"
9 greg 1.1
10 schorsch 2.17 #include <stdio.h>
11 greg 2.19 #include <time.h>
12 schorsch 2.17
13 greg 2.23 #include "platform.h"
14 greg 1.1 #include "standard.h"
15     #include "octree.h"
16     #include "object.h"
17     #include "otypes.h"
18 schorsch 2.17 #include "resolu.h"
19 greg 1.1
20 schorsch 2.20 static double ogetflt(void);
21     static long ogetint(int);
22     static char *ogetstr(char *);
23 greg 2.27 static int nonsurfintree(OCTREE ot);
24 schorsch 2.17 static void octerror(int etyp, char *msg);
25     static void skiptree(void);
26 schorsch 2.20 static OCTREE getfullnode(void), gettree(void);
27 greg 1.1
28 greg 2.13 static char *infn; /* input file specification */
29 greg 1.1 static FILE *infp; /* input file stream */
30 greg 1.14 static int objsize; /* size of stored OBJECT's */
31 greg 1.1 static OBJECT objorig; /* zeroeth object */
32 greg 2.12 static OBJECT fnobjects; /* number of objects in this file */
33 greg 1.1
34
35     int
36 greg 2.27 readoct( /* read in octree file or stream */
37     char *inpspec,
38     int load,
39     CUBE *scene,
40     char *ofn[]
41     )
42 greg 1.1 {
43 greg 2.33 time_t oct_t = 0;
44     time_t last_it = 0;
45 greg 1.11 char sbuf[512];
46 greg 1.1 int nf;
47 greg 2.15 int i;
48 greg 1.15 long m;
49 greg 1.1
50 greg 2.13 if (inpspec == NULL) {
51 greg 1.1 infn = "standard input";
52     infp = stdin;
53 greg 2.13 } else if (inpspec[0] == '!') {
54     infn = inpspec;
55     if ((infp = popen(inpspec+1, "r")) == NULL) {
56     sprintf(errmsg, "cannot execute \"%s\"", inpspec);
57     error(SYSTEM, errmsg);
58     }
59 greg 1.1 } else {
60 greg 2.13 infn = inpspec;
61     if ((infp = fopen(inpspec, "r")) == NULL) {
62 greg 1.1 sprintf(errmsg, "cannot open octree file \"%s\"",
63 greg 2.13 inpspec);
64 greg 1.1 error(SYSTEM, errmsg);
65     }
66 greg 2.33 oct_t = fddate(fileno(infp));
67 greg 1.1 }
68 greg 2.32 #ifdef getc_unlocked /* avoid stupid semaphores */
69     flockfile(infp);
70     #endif
71 schorsch 2.16 SET_FILE_BINARY(infp);
72 greg 1.1 /* get header */
73 greg 2.11 if (checkheader(infp, OCTFMT, load&IO_INFO ? stdout : (FILE *)NULL) < 0)
74 greg 1.12 octerror(USER, "not an octree");
75 greg 1.1 /* check format */
76 greg 2.4 if ((objsize = ogetint(2)-OCTMAGIC) <= 0 ||
77 greg 1.14 objsize > MAXOBJSIZ || objsize > sizeof(long))
78 greg 1.12 octerror(USER, "incompatible octree format");
79 greg 1.1 /* get boundaries */
80     if (load & IO_BOUNDS) {
81     for (i = 0; i < 3; i++)
82 greg 2.4 scene->cuorg[i] = atof(ogetstr(sbuf));
83     scene->cusize = atof(ogetstr(sbuf));
84 greg 1.1 } else {
85     for (i = 0; i < 4; i++)
86 greg 2.4 ogetstr(sbuf);
87 greg 1.1 }
88     objorig = nobjects; /* set object offset */
89     nf = 0; /* get object files */
90 greg 2.4 while (*ogetstr(sbuf)) {
91 greg 1.1 if (load & IO_SCENE)
92     readobj(sbuf);
93     if (load & IO_FILES)
94     ofn[nf] = savqstr(sbuf);
95 greg 2.33 if (oct_t > last_it) {
96     time_t t = fdate(sbuf);
97     if (t > last_it)
98     last_it = t;
99     }
100 greg 1.1 nf++;
101     }
102     if (load & IO_FILES)
103     ofn[nf] = NULL;
104 greg 1.8 /* get number of objects */
105 greg 2.4 fnobjects = m = ogetint(objsize);
106 greg 1.15 if (fnobjects != m)
107     octerror(USER, "too many objects");
108 greg 1.1
109 greg 2.13 if (load & IO_TREE) /* get the octree */
110 greg 1.1 scene->cutree = gettree();
111 greg 2.5 else if (load & IO_SCENE && nf == 0)
112     skiptree();
113
114 schorsch 2.21 if (load & IO_SCENE) { /* get the scene */
115 greg 2.5 if (nf == 0) {
116 greg 2.15 /* load binary scene data */
117     readscene(infp, objsize);
118
119 greg 2.5 } else { /* consistency checks */
120     /* check object count */
121     if (nobjects != objorig+fnobjects)
122     octerror(USER, "bad object count; octree stale?");
123     /* check for non-surfaces */
124 greg 2.33 if (oct_t <= last_it && nonsurfintree(scene->cutree))
125 greg 2.5 octerror(USER, "modifier in tree; octree stale?");
126     }
127 schorsch 2.21 }
128 greg 2.13 /* close the input */
129 greg 2.38 if (infn[0] == '!') {
130 greg 2.34 if (pclose(infp) != 0) {
131     sprintf(errmsg, "bad status from \"%s\"", inpspec);
132 greg 2.35 error(WARNING, errmsg);
133 greg 2.34 }
134     } else if (infp != stdin)
135 greg 2.13 fclose(infp);
136 greg 2.32 #ifdef getc_unlocked
137     else
138     funlockfile(infp);
139     #endif
140 greg 1.1 return(nf);
141     }
142
143
144     static char *
145 greg 2.27 ogetstr(char *s) /* get null-terminated string */
146 greg 1.1 {
147 greg 2.4 if (getstr(s, infp) == NULL)
148     octerror(USER, "truncated octree");
149     return(s);
150 greg 1.1 }
151
152
153     static OCTREE
154     getfullnode() /* get a set, return fullnode */
155     {
156 greg 2.7 OBJECT set[MAXSET+1];
157 greg 2.36 int i;
158     long m;
159 greg 1.1
160 greg 2.4 if ((set[0] = ogetint(objsize)) > MAXSET)
161 greg 1.1 octerror(USER, "bad set in getfullnode");
162 greg 1.14 for (i = 1; i <= set[0]; i++) {
163 greg 2.4 m = ogetint(objsize) + objorig;
164 greg 1.15 if ((set[i] = m) != m)
165 greg 1.14 octerror(USER, "too many objects");
166     }
167 greg 1.1 return(fullnode(set));
168     }
169
170
171     static long
172 greg 2.27 ogetint(int siz) /* get a siz-byte integer */
173 greg 1.1 {
174 greg 2.36 long r;
175 greg 1.1
176 greg 2.4 r = getint(siz, infp);
177     if (feof(infp))
178     octerror(USER, "truncated octree");
179 greg 1.1 return(r);
180     }
181
182
183     static double
184 greg 2.4 ogetflt() /* get a floating point number */
185 greg 1.1 {
186 greg 2.7 double r;
187 greg 1.1
188 greg 2.4 r = getflt(infp);
189     if (feof(infp))
190     octerror(USER, "truncated octree");
191     return(r);
192 greg 1.1 }
193
194
195     static OCTREE
196     gettree() /* get a pre-ordered octree */
197     {
198 greg 2.36 OCTREE ot;
199     int i;
200 greg 1.1
201     switch (getc(infp)) {
202     case OT_EMPTY:
203     return(EMPTY);
204     case OT_FULL:
205     return(getfullnode());
206     case OT_TREE:
207     if ((ot = octalloc()) == EMPTY)
208     octerror(SYSTEM, "out of tree space in gettree");
209     for (i = 0; i < 8; i++)
210     octkid(ot, i) = gettree();
211     return(ot);
212 greg 2.5 case EOF:
213     octerror(USER, "truncated octree");
214     default:
215     octerror(USER, "damaged octree");
216     }
217 greg 2.22 return EMPTY; /* pro forma return */
218 greg 2.12 }
219
220
221     static int
222 greg 2.27 nonsurfintree(OCTREE ot) /* check tree for modifiers */
223 greg 2.12 {
224 greg 2.27 OBJECT set[MAXSET+1];
225 greg 2.36 int i;
226 greg 2.12
227 greg 2.27 if (isempty(ot))
228     return(0);
229     if (istree(ot)) {
230     for (i = 0; i < 8; i++)
231     if (nonsurfintree(octkid(ot, i)))
232     return(1);
233     return(0);
234     }
235     objset(set, ot);
236 greg 2.28 for (i = set[0]; i > 0; i-- )
237 greg 2.27 if (ismodifier(objptr(set[i])->otype))
238 greg 2.12 return(1);
239     return(0);
240 greg 2.5 }
241
242
243 schorsch 2.17 static void
244     skiptree(void) /* skip octree on input */
245 greg 2.5 {
246 greg 2.36 int i;
247 greg 2.5
248     switch (getc(infp)) {
249     case OT_EMPTY:
250     return;
251     case OT_FULL:
252 greg 2.6 for (i = ogetint(objsize)*objsize; i-- > 0; )
253     if (getc(infp) == EOF)
254     octerror(USER, "truncated octree");
255 greg 2.5 return;
256     case OT_TREE:
257     for (i = 0; i < 8; i++)
258     skiptree();
259     return;
260 greg 1.1 case EOF:
261     octerror(USER, "truncated octree");
262     default:
263     octerror(USER, "damaged octree");
264     }
265     }
266
267
268 schorsch 2.17 static void
269 greg 2.27 octerror(int etyp, char *msg) /* octree error */
270 greg 1.1 {
271     char msgbuf[128];
272
273     sprintf(msgbuf, "(%s): %s", infn, msg);
274     error(etyp, msgbuf);
275     }
