| 1 |
/* Copyright (c) 1986 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* readoct.c - routines to read octree information.
| 9 |
| 10 |
* 7/30/85
| 11 |
| 12 |
| 13 |
#include "standard.h"
| 14 |
| 15 |
#include "octree.h"
| 16 |
| 17 |
#include "object.h"
| 18 |
| 19 |
#include "otypes.h"
| 20 |
| 21 |
extern double atof();
| 22 |
static double getflt();
| 23 |
static long getint();
| 24 |
static char *getstr();
| 25 |
static OCTREE getfullnode(), gettree();
| 26 |
| 27 |
static char *infn; /* input file name */
| 28 |
static FILE *infp; /* input file stream */
| 29 |
static OBJECT objorig; /* zeroeth object */
| 30 |
static short otypmap[NUMOTYPE+8]; /* object type map */
| 31 |
| 32 |
| 33 |
int
| 34 |
readoct(fname, load, scene, ofn) /* read in octree from file */
| 35 |
char *fname;
| 36 |
int load;
| 37 |
CUBE *scene;
| 38 |
char *ofn[];
| 39 |
| 40 |
extern int fputs();
| 41 |
char sbuf[512];
| 42 |
int nf;
| 43 |
OBJECT fnobjects;
| 44 |
register int i;
| 45 |
| 46 |
if (fname == NULL) {
| 47 |
infn = "standard input";
| 48 |
infp = stdin;
| 49 |
} else {
| 50 |
infn = fname;
| 51 |
if ((infp = fopen(fname, "r")) == NULL) {
| 52 |
sprintf(errmsg, "cannot open octree file \"%s\"",
| 53 |
fname);
| 54 |
error(SYSTEM, errmsg);
| 55 |
| 56 |
| 57 |
/* get header */
| 58 |
if (checkheader(infp, OCTFMT, load&IO_INFO ? stdout : NULL) < 0)
| 59 |
octerror(USER, "not an octree");
| 60 |
/* check format */
| 61 |
if (getint(2) != OCTMAGIC)
| 62 |
octerror(USER, "incompatible octree format");
| 63 |
/* get boundaries */
| 64 |
if (load & IO_BOUNDS) {
| 65 |
for (i = 0; i < 3; i++)
| 66 |
scene->cuorg[i] = atof(getstr(sbuf));
| 67 |
scene->cusize = atof(getstr(sbuf));
| 68 |
} else {
| 69 |
for (i = 0; i < 4; i++)
| 70 |
getstr(sbuf);
| 71 |
| 72 |
objorig = nobjects; /* set object offset */
| 73 |
nf = 0; /* get object files */
| 74 |
while (*getstr(sbuf)) {
| 75 |
if (load & IO_SCENE)
| 76 |
readobj(sbuf);
| 77 |
if (load & IO_FILES)
| 78 |
ofn[nf] = savqstr(sbuf);
| 79 |
nf++;
| 80 |
| 81 |
| 82 |
ofn[nf] = NULL;
| 83 |
/* get number of objects */
| 84 |
fnobjects = getint(sizeof(OBJECT));
| 85 |
| 86 |
if (load & IO_TREE) {
| 87 |
/* get the octree */
| 88 |
scene->cutree = gettree();
| 89 |
/* get the scene */
| 90 |
if (nf == 0 && load & IO_SCENE) {
| 91 |
for (i = 0; *getstr(sbuf); i++)
| 92 |
if ((otypmap[i] = otype(sbuf)) < 0) {
| 93 |
sprintf(errmsg, "unknown type \"%s\"",
| 94 |
sbuf);
| 95 |
octerror(WARNING, errmsg);
| 96 |
| 97 |
while (getobj() != OVOID)
| 98 |
| 99 |
| 100 |
| 101 |
fclose(infp);
| 102 |
/* consistency checks */
| 103 |
if (load & IO_SCENE) {
| 104 |
/* check object count */
| 105 |
if (nobjects != objorig+fnobjects)
| 106 |
octerror(USER, "bad object count; octree stale?");
| 107 |
/* check for non-surfaces */
| 108 |
if (nonsurfinset(objorig, fnobjects))
| 109 |
octerror(USER, "non-surface in set; octree stale?");
| 110 |
| 111 |
return(nf);
| 112 |
| 113 |
| 114 |
| 115 |
static char *
| 116 |
getstr(s) /* get null-terminated string */
| 117 |
char *s;
| 118 |
| 119 |
register char *cp;
| 120 |
register int c;
| 121 |
| 122 |
cp = s;
| 123 |
while ((c = getc(infp)) != EOF)
| 124 |
if ((*cp++ = c) == '\0')
| 125 |
return(s);
| 126 |
| 127 |
octerror(USER, "truncated octree");
| 128 |
| 129 |
| 130 |
| 131 |
static OCTREE
| 132 |
getfullnode() /* get a set, return fullnode */
| 133 |
| 134 |
OBJECT set[MAXSET+1];
| 135 |
register int i;
| 136 |
| 137 |
set[0] = getint(sizeof(OBJECT));
| 138 |
if (set[0] > MAXSET)
| 139 |
octerror(USER, "bad set in getfullnode");
| 140 |
for (i = 1; i <= set[0]; i++)
| 141 |
set[i] = getint(sizeof(OBJECT)) + objorig;
| 142 |
return(fullnode(set));
| 143 |
| 144 |
| 145 |
| 146 |
static long
| 147 |
getint(siz) /* get a siz-byte integer */
| 148 |
register int siz;
| 149 |
| 150 |
register int c;
| 151 |
register long r;
| 152 |
| 153 |
if ((c = getc(infp)) == EOF)
| 154 |
goto end_file;
| 155 |
r = 0x80&c ? -1<<8|c : c; /* sign extend */
| 156 |
while (--siz > 0) {
| 157 |
| 158 |
goto end_file;
| 159 |
r <<= 8;
| 160 |
r |= c;
| 161 |
| 162 |
return(r);
| 163 |
end_file:
| 164 |
| 165 |
| 166 |
| 167 |
| 168 |
static double
| 169 |
getflt() /* get a floating point number */
| 170 |
| 171 |
extern double ldexp();
| 172 |
double d;
| 173 |
| 174 |
d = (double)getint(4)/0x7fffffff;
| 175 |
return(ldexp(d, (int)getint(1)));
| 176 |
| 177 |
| 178 |
| 179 |
static OCTREE
| 180 |
gettree() /* get a pre-ordered octree */
| 181 |
| 182 |
register OCTREE ot;
| 183 |
register int i;
| 184 |
| 185 |
switch (getc(infp)) {
| 186 |
case OT_EMPTY:
| 187 |
return(EMPTY);
| 188 |
case OT_FULL:
| 189 |
return(getfullnode());
| 190 |
case OT_TREE:
| 191 |
if ((ot = octalloc()) == EMPTY)
| 192 |
octerror(SYSTEM, "out of tree space in gettree");
| 193 |
for (i = 0; i < 8; i++)
| 194 |
octkid(ot, i) = gettree();
| 195 |
return(ot);
| 196 |
case EOF:
| 197 |
| 198 |
default:
| 199 |
octerror(USER, "damaged octree");
| 200 |
| 201 |
| 202 |
| 203 |
| 204 |
static
| 205 |
getobj() /* get next object */
| 206 |
| 207 |
char sbuf[MAXSTR];
| 208 |
int obj;
| 209 |
register int i;
| 210 |
register OBJREC *objp;
| 211 |
| 212 |
i = getint(1);
| 213 |
if (i == -1)
| 214 |
return(OVOID); /* terminator */
| 215 |
if ((obj = newobject()) == OVOID)
| 216 |
error(SYSTEM, "out of object space");
| 217 |
objp = objptr(obj);
| 218 |
if ((objp->otype = otypmap[i]) < 0)
| 219 |
octerror(USER, "reference to unknown type");
| 220 |
if ((objp->omod = getint(sizeof(OBJECT))) != OVOID)
| 221 |
objp->omod += objorig;
| 222 |
objp->oname = savqstr(getstr(sbuf));
| 223 |
if (objp->oargs.nsargs = getint(2)) {
| 224 |
objp->oargs.sarg = (char **)bmalloc
| 225 |
(objp->oargs.nsargs*sizeof(char *));
| 226 |
if (objp->oargs.sarg == NULL)
| 227 |
goto memerr;
| 228 |
for (i = 0; i < objp->oargs.nsargs; i++)
| 229 |
objp->oargs.sarg[i] = savestr(getstr(sbuf));
| 230 |
} else
| 231 |
objp->oargs.sarg = NULL;
| 232 |
#ifdef IARGS
| 233 |
if (objp->oargs.niargs = getint(2)) {
| 234 |
objp->oargs.iarg = (long *)bmalloc
| 235 |
(objp->oargs.niargs*sizeof(long));
| 236 |
if (objp->oargs.iarg == NULL)
| 237 |
goto memerr;
| 238 |
for (i = 0; i < objp->oargs.niargs; i++)
| 239 |
objp->oargs.iarg[i] = getint(4);
| 240 |
} else
| 241 |
objp->oargs.iarg = NULL;
| 242 |
#endif
| 243 |
if (objp->oargs.nfargs = getint(2)) {
| 244 |
objp->oargs.farg = (double *)bmalloc
| 245 |
(objp->oargs.nfargs*sizeof(double));
| 246 |
if (objp->oargs.farg == NULL)
| 247 |
goto memerr;
| 248 |
for (i = 0; i < objp->oargs.nfargs; i++)
| 249 |
objp->oargs.farg[i] = getflt();
| 250 |
} else
| 251 |
objp->oargs.farg = NULL;
| 252 |
/* initialize */
| 253 |
objp->os = NULL;
| 254 |
objp->lastrno = -1;
| 255 |
/* insert */
| 256 |
insertobject(obj);
| 257 |
return(obj);
| 258 |
memerr:
| 259 |
error(SYSTEM, "out of memory in getobj");
| 260 |
| 261 |
| 262 |
| 263 |
static
| 264 |
octerror(etyp, msg) /* octree error */
| 265 |
int etyp;
| 266 |
char *msg;
| 267 |
| 268 |
char msgbuf[128];
| 269 |
| 270 |
sprintf(msgbuf, "(%s): %s", infn, msg);
| 271 |
error(etyp, msgbuf);
| 272 |
