root/radiance/src/common/readobj.c
Tue Jun 24 21:04:16 2025 UTC (3 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.30: +6 -6 lines
Diff to previous 2.30 , to selected 1.3
perf: Turned off OBJMEMOPT by default as it seemed to do little in practice
Mon Jun 23 19:56:47 2025 UTC (3 months, 3 weeks ago) by greg
Changes since 2.29: +107 -7 lines
Diff to previous 2.29 , to selected 1.3
perf: Consolidate object block memory to reduce malloc() fragmentation/overhead
Sat Jun 7 05:09:45 2025 UTC (4 months, 1 week ago) by greg
Changes since 2.28: +1 -2 lines
Diff to previous 2.28 , to selected 1.3
Tue Apr 22 14:51:29 2025 UTC (5 months, 4 weeks ago) by greg
Diff to previous 2.27 , to selected 1.3
fix: Changed some errors to warnings for pclose()
Tue Apr 22 04:45:25 2025 UTC (5 months, 4 weeks ago) by greg
Changes since 2.26: +7 -4 lines
Diff to previous 2.26 , to selected 1.3
fix: Added check to return value of pclose() in several tools
Sat Dec 7 02:05:30 2024 UTC (10 months, 1 week ago) by greg
Changes since 2.25: +11 -7 lines
Diff to previous 2.25 , to selected 1.3
perf: Skip pointless pass-through aliases during scene file load
Tue Feb 7 20:28:16 2023 UTC (2 years, 8 months ago) by greg
Changes since 2.24: +8 -1 lines
Diff to previous 2.24 , to selected 1.3
perf: added calls to flockfile()/funlockfile() for more efficient reading
Sat Oct 17 16:39:23 2020 UTC (5 years ago) by greg
Changes since 2.23: +4 -3 lines
Diff to previous 2.23 , to selected 1.3
fix: freeing *some* objects now preserves valid modifier lookups
Sat May 4 00:36:58 2019 UTC (6 years, 5 months ago) by greg
Diff to previous 2.22 , to selected 1.3
Eliminated cases where stdin was being closed
Sat Apr 8 03:56:44 2017 UTC (8 years, 6 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.21: +19 -15 lines
Diff to previous 2.21 , to selected 1.3
ANSIficatation
Tue Feb 2 18:02:32 2016 UTC (9 years, 8 months ago) by greg
Diff to previous 2.20 , to selected 1.3
Tue Mar 30 12:42:33 2010 UTC (15 years, 6 months ago) by greg
Changes since 2.19: +11 -1 lines
Diff to previous 2.19 , to selected 1.3
Added check against tab in modifier or identifier, which breaks rtrace
Fri Jul 2 16:45:32 2004 UTC (21 years, 3 months ago) by greg
Diff to previous 2.18 , to selected 1.3
Increased buffer size for long commands/comments in Radiance scenes
Mon Oct 27 10:19:31 2003 UTC (21 years, 11 months ago) by schorsch
Diff to previous 2.17 , to selected 1.3
Wed Oct 22 02:06:34 2003 UTC (22 years ago) by greg
Diff to previous 2.16 , to selected 1.3
Mon Jun 30 14:59:11 2003 UTC (22 years, 3 months ago) by schorsch
Diff to previous 2.15 , to selected 1.3
Fri Jun 20 00:25:49 2003 UTC (22 years, 4 months ago) by greg
Diff to previous 2.14 , to selected 1.3
Sun Jun 8 12:03:09 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 2.13: +3 -5 lines
Diff to previous 2.13 , to selected 1.3
Sat Jun 7 12:50:20 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 2.12: +8 -4 lines
Diff to previous 2.12 , to selected 1.3
Tue May 13 17:58:32 2003 UTC (22 years, 5 months ago) by greg
Diff to previous 2.11 , to selected 1.3
Tue Mar 11 19:29:04 2003 UTC (22 years, 7 months ago) by greg
Changes since 2.10: +24 -10 lines
Diff to previous 2.10 , to selected 1.3
Mon Mar 10 17:13:29 2003 UTC (22 years, 7 months ago) by greg
Diff to previous 2.9 , to selected 1.3
Tue Feb 25 02:47:21 2003 UTC (22 years, 7 months ago) by greg
Diff to previous 2.8 , to selected 1.3
Sat Feb 22 02:07:22 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.7: +96 -10 lines
Diff to previous 2.7 , to selected 1.3
Thu Nov 5 16:51:26 1998 UTC (26 years, 11 months ago) by gwlarson
Diff to previous 2.6 , to selected 1.3
fixed problem with new object block sizing
Mon Aug 24 16:42:46 1998 UTC (27 years, 2 months ago) by gwlarson
Diff to previous 2.5 , to selected 1.3
changed object block size and increased object limit to 32 million
Thu Jul 18 17:58:01 1996 UTC (29 years, 3 months ago) by greg
Diff to previous 2.4 , to selected 1.3
increased buffer size for in-line commands from 512 to 1024
Sat Jan 1 09:18:47 1994 UTC (31 years, 9 months ago) by greg
Changes since 2.3: +18 -12 lines
Diff to previous 2.3 , to selected 1.3
added warning about empty input
Fri Jun 4 15:08:20 1993 UTC (32 years, 4 months ago) by greg
Diff to previous 2.2 , to selected 1.3
removed fgets() declaration
Mon Jan 25 12:41:24 1993 UTC (32 years, 9 months ago) by greg
Diff to previous 2.1 , to selected 1.3
removed lastrno from object structure
Tue Nov 12 16:55:11 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.7 , to selected 1.3
Mon Jul 22 11:48:04 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.6: +10 -4 lines
Diff to previous 1.6 , to selected 1.3
eliminated calls to scanf()
Fri Jul 19 09:25:43 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.5: +5 -55 lines
Diff to previous 1.5 , to selected 1.3
added separate readfargs() and freefargs() routines
Tue Sep 18 09:53:35 1990 UTC (35 years, 1 month ago) by greg
Diff to previous 1.4 , to selected 1.3
changed bmalloc() to call sbrk() since malloc() allocated
16K when asked for less than 8K and that's what octalloc() used before
Thu Sep 6 23:32:43 1990 UTC (35 years, 1 month ago) by greg
Diff to previous 1.3
added consistency checks to detect stale octrees
Revision 1.3 - (view) (download) (annotate) - [selected]
Thu Jan 18 23:58:57 1990 UTC (35 years, 9 months ago) by greg
Diff to previous 1.2
Wed Oct 4 16:32:04 1989 UTC (36 years ago) by greg
Changes since 1.1: +3 -6 lines
Diff to previous 1.1 , to selected 1.3
Added multi-line commands.
Thu Feb 2 10:34:39 1989 UTC (36 years, 8 months ago) by greg
Diff to selected 1.3
