| 1 | greg | 2.1 | #ifndef lint |
| 2 | greg | 2.13 | static const char RCSid[] = "$Id: readmesh.c,v 2.12 2004/04/29 14:36:49 greg Exp $"; |
| 3 | greg | 2.1 | #endif |
| 4 |  |  | /* |
| 5 |  |  | *  Routines for reading a compiled mesh from a file |
| 6 |  |  | */ |
| 7 | greg | 2.7 |  |
| 8 |  |  | #include  <time.h> |
| 9 | greg | 2.1 |  |
| 10 | greg | 2.10 | #include  "platform.h" |
| 11 | greg | 2.1 | #include  "standard.h" |
| 12 |  |  | #include  "octree.h" |
| 13 |  |  | #include  "object.h" |
| 14 |  |  | #include  "mesh.h" |
| 15 | schorsch | 2.4 | #include  "resolu.h" |
| 16 | greg | 2.1 |  |
| 17 | greg | 2.12 | #ifdef getc_unlocked            /* avoid horrendous overhead of flockfile */ |
| 18 | greg | 2.13 | #undef getc |
| 19 | greg | 2.12 | #define getc    getc_unlocked |
| 20 |  |  | #endif |
| 21 |  |  |  |
| 22 | greg | 2.1 | static char     *meshfn;        /* input file name */ |
| 23 |  |  | static FILE     *meshfp;        /* mesh file pointer */ |
| 24 |  |  | static int      objsize;        /* sizeof(OBJECT) from writer */ |
| 25 |  |  |  |
| 26 |  |  |  |
| 27 |  |  | static void |
| 28 |  |  | mesherror(etyp, msg)                    /* mesh read error */ |
| 29 |  |  | int  etyp; |
| 30 |  |  | char  *msg; |
| 31 |  |  | { |
| 32 |  |  | char  msgbuf[128]; |
| 33 |  |  |  |
| 34 |  |  | sprintf(msgbuf, "(%s): %s", meshfn, msg); |
| 35 |  |  | error(etyp, msgbuf); |
| 36 |  |  | } |
| 37 |  |  |  |
| 38 |  |  |  |
| 39 |  |  | static long |
| 40 |  |  | mgetint(siz)                            /* get a siz-byte integer */ |
| 41 |  |  | int  siz; |
| 42 |  |  | { |
| 43 |  |  | register long  r; |
| 44 |  |  |  |
| 45 |  |  | r = getint(siz, meshfp); |
| 46 |  |  | if (feof(meshfp)) |
| 47 |  |  | mesherror(USER, "truncated mesh file"); |
| 48 |  |  | return(r); |
| 49 |  |  | } |
| 50 |  |  |  |
| 51 |  |  |  |
| 52 |  |  | static double |
| 53 |  |  | mgetflt()                               /* get a floating point number */ |
| 54 |  |  | { |
| 55 |  |  | double  r; |
| 56 |  |  |  |
| 57 |  |  | r = getflt(meshfp); |
| 58 |  |  | if (feof(meshfp)) |
| 59 |  |  | mesherror(USER, "truncated mesh file"); |
| 60 |  |  | return(r); |
| 61 |  |  | } |
| 62 |  |  |  |
| 63 |  |  |  |
| 64 |  |  | static OCTREE |
| 65 |  |  | getfullnode()                           /* get a set, return fullnode */ |
| 66 |  |  | { |
| 67 |  |  | OBJECT  set[MAXSET+1]; |
| 68 |  |  | register int  i; |
| 69 |  |  |  |
| 70 |  |  | if ((set[0] = mgetint(objsize)) > MAXSET) |
| 71 |  |  | mesherror(USER, "bad set in getfullnode"); |
| 72 |  |  | for (i = 1; i <= set[0]; i++) |
| 73 |  |  | set[i] = mgetint(objsize); |
| 74 |  |  | return(fullnode(set)); |
| 75 |  |  | } |
| 76 |  |  |  |
| 77 |  |  |  |
| 78 |  |  | static OCTREE |
| 79 |  |  | gettree()                               /* get a pre-ordered octree */ |
| 80 |  |  | { |
| 81 |  |  | register OCTREE  ot; |
| 82 |  |  | register int  i; |
| 83 |  |  |  |
| 84 |  |  | switch (getc(meshfp)) { |
| 85 | schorsch | 2.4 | case OT_EMPTY: |
| 86 |  |  | return(EMPTY); |
| 87 |  |  | case OT_FULL: |
| 88 |  |  | return(getfullnode()); |
| 89 |  |  | case OT_TREE: |
| 90 |  |  | if ((ot = octalloc()) == EMPTY) |
| 91 |  |  | mesherror(SYSTEM, "out of tree space in readmesh"); |
| 92 |  |  | for (i = 0; i < 8; i++) |
| 93 |  |  | octkid(ot, i) = gettree(); |
| 94 |  |  | return(ot); |
| 95 |  |  | case EOF: |
| 96 |  |  | mesherror(USER, "truncated mesh octree"); |
| 97 |  |  | default: |
| 98 |  |  | mesherror(USER, "damaged mesh octree"); |
| 99 | greg | 2.1 | } |
| 100 | schorsch | 2.8 | return (OCTREE)NULL; /* pro forma return */ |
| 101 | greg | 2.1 | } |
| 102 |  |  |  |
| 103 |  |  |  |
| 104 |  |  | static void |
| 105 |  |  | skiptree()                              /* skip octree on input */ |
| 106 |  |  | { |
| 107 |  |  | register int  i; |
| 108 |  |  |  |
| 109 |  |  | switch (getc(meshfp)) { |
| 110 |  |  | case OT_EMPTY: |
| 111 |  |  | return; |
| 112 |  |  | case OT_FULL: |
| 113 |  |  | for (i = mgetint(objsize)*objsize; i-- > 0; ) |
| 114 |  |  | if (getc(meshfp) == EOF) |
| 115 |  |  | mesherror(USER, "truncated mesh octree"); |
| 116 |  |  | return; |
| 117 |  |  | case OT_TREE: |
| 118 |  |  | for (i = 0; i < 8; i++) |
| 119 |  |  | skiptree(); |
| 120 |  |  | return; |
| 121 |  |  | case EOF: |
| 122 |  |  | mesherror(USER, "truncated mesh octree"); |
| 123 |  |  | default: |
| 124 |  |  | mesherror(USER, "damaged mesh octree"); |
| 125 |  |  | } |
| 126 |  |  | } |
| 127 |  |  |  |
| 128 |  |  |  |
| 129 |  |  | static void |
| 130 |  |  | getpatch(pp)                            /* load a mesh patch */ |
| 131 |  |  | register MESHPATCH      *pp; |
| 132 |  |  | { |
| 133 |  |  | int     flags; |
| 134 |  |  | int     i, j; |
| 135 |  |  | /* vertex flags */ |
| 136 |  |  | flags = mgetint(1); |
| 137 |  |  | if (!(flags & MT_V) || flags & ~(MT_V|MT_N|MT_UV)) |
| 138 |  |  | mesherror(USER, "bad patch flags"); |
| 139 |  |  | /* allocate vertices */ |
| 140 |  |  | pp->nverts = mgetint(2); |
| 141 |  |  | if (pp->nverts <= 0 || pp->nverts > 256) |
| 142 |  |  | mesherror(USER, "bad number of patch vertices"); |
| 143 | greg | 2.6 | pp->xyz = (uint32 (*)[3])malloc(pp->nverts*3*sizeof(uint32)); |
| 144 | greg | 2.1 | if (pp->xyz == NULL) |
| 145 |  |  | goto nomem; |
| 146 |  |  | if (flags & MT_N) { |
| 147 | greg | 2.6 | pp->norm = (int32 *)calloc(pp->nverts, sizeof(int32)); |
| 148 | greg | 2.1 | if (pp->norm == NULL) |
| 149 |  |  | goto nomem; |
| 150 |  |  | } else |
| 151 |  |  | pp->norm = NULL; |
| 152 |  |  | if (flags & MT_UV) { |
| 153 | greg | 2.11 | pp->uv = (uint32 (*)[2])calloc(pp->nverts, 2*sizeof(uint32)); |
| 154 | greg | 2.1 | if (pp->uv == NULL) |
| 155 |  |  | goto nomem; |
| 156 |  |  | } else |
| 157 |  |  | pp->uv = NULL; |
| 158 |  |  | /* vertex xyz locations */ |
| 159 |  |  | for (i = 0; i < pp->nverts; i++) |
| 160 |  |  | for (j = 0; j < 3; j++) |
| 161 |  |  | pp->xyz[i][j] = mgetint(4); |
| 162 |  |  | /* vertex normals */ |
| 163 |  |  | if (flags & MT_N) |
| 164 |  |  | for (i = 0; i < pp->nverts; i++) |
| 165 |  |  | pp->norm[i] = mgetint(4); |
| 166 |  |  | /* uv coordinates */ |
| 167 |  |  | if (flags & MT_UV) |
| 168 |  |  | for (i = 0; i < pp->nverts; i++) |
| 169 |  |  | for (j = 0; j < 2; j++) |
| 170 | greg | 2.11 | pp->uv[i][j] = mgetint(4); |
| 171 | greg | 2.1 | /* local triangles */ |
| 172 |  |  | pp->ntris = mgetint(2); |
| 173 |  |  | if (pp->ntris < 0 || pp->ntris > 512) |
| 174 |  |  | mesherror(USER, "bad number of local triangles"); |
| 175 |  |  | if (pp->ntris) { |
| 176 |  |  | pp->tri = (struct PTri *)malloc(pp->ntris * |
| 177 |  |  | sizeof(struct PTri)); |
| 178 |  |  | if (pp->tri == NULL) |
| 179 |  |  | goto nomem; |
| 180 |  |  | for (i = 0; i < pp->ntris; i++) { |
| 181 |  |  | pp->tri[i].v1 = mgetint(1); |
| 182 |  |  | pp->tri[i].v2 = mgetint(1); |
| 183 |  |  | pp->tri[i].v3 = mgetint(1); |
| 184 |  |  | } |
| 185 |  |  | } else |
| 186 |  |  | pp->tri = NULL; |
| 187 | greg | 2.2 | /* local triangle material(s) */ |
| 188 |  |  | if (mgetint(2) > 1) { |
| 189 | greg | 2.6 | pp->trimat = (int16 *)malloc(pp->ntris*sizeof(int16)); |
| 190 | greg | 2.2 | if (pp->trimat == NULL) |
| 191 |  |  | goto nomem; |
| 192 |  |  | for (i = 0; i < pp->ntris; i++) |
| 193 |  |  | pp->trimat[i] = mgetint(2); |
| 194 |  |  | } else { |
| 195 |  |  | pp->solemat = mgetint(2); |
| 196 |  |  | pp->trimat = NULL; |
| 197 |  |  | } |
| 198 | greg | 2.1 | /* joiner triangles */ |
| 199 |  |  | pp->nj1tris = mgetint(2); |
| 200 |  |  | if (pp->nj1tris < 0 || pp->nj1tris > 512) |
| 201 |  |  | mesherror(USER, "bad number of joiner triangles"); |
| 202 |  |  | if (pp->nj1tris) { |
| 203 |  |  | pp->j1tri = (struct PJoin1 *)malloc(pp->nj1tris * |
| 204 |  |  | sizeof(struct PJoin1)); |
| 205 |  |  | if (pp->j1tri == NULL) |
| 206 |  |  | goto nomem; |
| 207 |  |  | for (i = 0; i < pp->nj1tris; i++) { |
| 208 |  |  | pp->j1tri[i].v1j = mgetint(4); |
| 209 |  |  | pp->j1tri[i].v2 = mgetint(1); |
| 210 |  |  | pp->j1tri[i].v3 = mgetint(1); |
| 211 | greg | 2.2 | pp->j1tri[i].mat = mgetint(2); |
| 212 | greg | 2.1 | } |
| 213 |  |  | } else |
| 214 |  |  | pp->j1tri = NULL; |
| 215 |  |  | /* double joiner triangles */ |
| 216 |  |  | pp->nj2tris = mgetint(2); |
| 217 |  |  | if (pp->nj2tris < 0 || pp->nj2tris > 256) |
| 218 |  |  | mesherror(USER, "bad number of double joiner triangles"); |
| 219 |  |  | if (pp->nj2tris) { |
| 220 |  |  | pp->j2tri = (struct PJoin2 *)malloc(pp->nj2tris * |
| 221 |  |  | sizeof(struct PJoin2)); |
| 222 |  |  | if (pp->j2tri == NULL) |
| 223 |  |  | goto nomem; |
| 224 |  |  | for (i = 0; i < pp->nj2tris; i++) { |
| 225 |  |  | pp->j2tri[i].v1j = mgetint(4); |
| 226 |  |  | pp->j2tri[i].v2j = mgetint(4); |
| 227 |  |  | pp->j2tri[i].v3 = mgetint(1); |
| 228 | greg | 2.2 | pp->j2tri[i].mat = mgetint(2); |
| 229 | greg | 2.1 | } |
| 230 |  |  | } else |
| 231 |  |  | pp->j2tri = NULL; |
| 232 |  |  | return; |
| 233 |  |  | nomem: |
| 234 |  |  | error(SYSTEM, "out of mesh memory in getpatch"); |
| 235 |  |  | } |
| 236 |  |  |  |
| 237 |  |  |  |
| 238 |  |  | void |
| 239 |  |  | readmesh(mp, path, flags)               /* read in mesh structures */ |
| 240 |  |  | MESH    *mp; |
| 241 |  |  | char    *path; |
| 242 |  |  | int     flags; |
| 243 |  |  | { |
| 244 | greg | 2.2 | char    *err; |
| 245 | greg | 2.1 | char    sbuf[64]; |
| 246 |  |  | int     i; |
| 247 |  |  | /* check what's loaded */ |
| 248 |  |  | flags &= (IO_INFO|IO_BOUNDS|IO_TREE|IO_SCENE) & ~mp->ldflags; |
| 249 |  |  | /* open input file */ |
| 250 |  |  | if (path == NULL) { |
| 251 |  |  | meshfn = "standard input"; |
| 252 |  |  | meshfp = stdin; |
| 253 |  |  | } else if ((meshfp = fopen(meshfn=path, "r")) == NULL) { |
| 254 |  |  | sprintf(errmsg, "cannot open mesh file \"%s\"", path); |
| 255 |  |  | error(SYSTEM, errmsg); |
| 256 |  |  | } |
| 257 | schorsch | 2.3 | SET_FILE_BINARY(meshfp); |
| 258 | greg | 2.1 | /* read header */ |
| 259 |  |  | checkheader(meshfp, MESHFMT, flags&IO_INFO ? stdout : (FILE *)NULL); |
| 260 |  |  | /* read format number */ |
| 261 |  |  | objsize = getint(2, meshfp) - MESHMAGIC; |
| 262 |  |  | if (objsize <= 0 || objsize > MAXOBJSIZ || objsize > sizeof(long)) |
| 263 |  |  | mesherror(USER, "incompatible mesh format"); |
| 264 |  |  | /* read boundaries */ |
| 265 |  |  | if (flags & IO_BOUNDS) { |
| 266 |  |  | for (i = 0; i < 3; i++) |
| 267 |  |  | mp->mcube.cuorg[i] = atof(getstr(sbuf, meshfp)); |
| 268 |  |  | mp->mcube.cusize = atof(getstr(sbuf, meshfp)); |
| 269 |  |  | for (i = 0; i < 2; i++) { |
| 270 |  |  | mp->uvlim[0][i] = mgetflt(); |
| 271 |  |  | mp->uvlim[1][i] = mgetflt(); |
| 272 |  |  | } |
| 273 |  |  | } else { |
| 274 |  |  | for (i = 0; i < 4; i++) |
| 275 |  |  | getstr(sbuf, meshfp); |
| 276 |  |  | for (i = 0; i < 4; i++) |
| 277 |  |  | mgetflt(); |
| 278 |  |  | } |
| 279 |  |  | /* read the octree */ |
| 280 |  |  | if (flags & IO_TREE) |
| 281 |  |  | mp->mcube.cutree = gettree(); |
| 282 |  |  | else if (flags & IO_SCENE) |
| 283 |  |  | skiptree(); |
| 284 | greg | 2.2 | /* read materials and patches */ |
| 285 | greg | 2.1 | if (flags & IO_SCENE) { |
| 286 | greg | 2.2 | mp->mat0 = nobjects; |
| 287 |  |  | readscene(meshfp, objsize); |
| 288 |  |  | mp->nmats = nobjects - mp->mat0; |
| 289 | greg | 2.1 | mp->npatches = mgetint(4); |
| 290 |  |  | mp->patch = (MESHPATCH *)calloc(mp->npatches, |
| 291 |  |  | sizeof(MESHPATCH)); |
| 292 |  |  | if (mp->patch == NULL) |
| 293 |  |  | mesherror(SYSTEM, "out of patch memory"); |
| 294 |  |  | for (i = 0; i < mp->npatches; i++) |
| 295 |  |  | getpatch(&mp->patch[i]); |
| 296 |  |  | } |
| 297 |  |  | /* clean up */ |
| 298 |  |  | fclose(meshfp); |
| 299 |  |  | mp->ldflags |= flags; |
| 300 | greg | 2.2 | /* verify data */ |
| 301 |  |  | if ((err = checkmesh(mp)) != NULL) |
| 302 |  |  | mesherror(USER, err); |
| 303 | greg | 2.1 | } |
