root/radiance/src/common/readmesh.c
Revision: 2.19
Committed: Tue Feb 7 20:28:16 2023 UTC (2 years, 8 months ago) by greg
CVS Tags: rad5R4, rad6R0, HEAD
Changes since 2.18: +8 -1 lines
perf: added calls to flockfile()/funlockfile() for more efficient reading
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.19 static const char RCSid[] = "$Id: readmesh.c,v 2.18 2021/07/12 17:42:51 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Routines for reading a compiled mesh from a file
6     */
7 greg 2.7
8     #include <time.h>
9 greg 2.1
10 greg 2.10 #include "platform.h"
11 greg 2.1 #include "standard.h"
12     #include "octree.h"
13     #include "object.h"
14     #include "mesh.h"
15 schorsch 2.4 #include "resolu.h"
16 greg 2.1
17     static char *meshfn; /* input file name */
18     static FILE *meshfp; /* mesh file pointer */
19     static int objsize; /* sizeof(OBJECT) from writer */
20
21
22     static void
23     mesherror(etyp, msg) /* mesh read error */
24     int etyp;
25     char *msg;
26     {
27     char msgbuf[128];
28
29     sprintf(msgbuf, "(%s): %s", meshfn, msg);
30     error(etyp, msgbuf);
31     }
32
33
34     static long
35     mgetint(siz) /* get a siz-byte integer */
36     int siz;
37     {
38 greg 2.18 long r = getint(siz, meshfp);
39 greg 2.1
40 greg 2.18 if (r == EOF && feof(meshfp))
41 greg 2.1 mesherror(USER, "truncated mesh file");
42 greg 2.18
43 greg 2.1 return(r);
44     }
45
46
47     static double
48     mgetflt() /* get a floating point number */
49     {
50 greg 2.18 double r = getflt(meshfp);
51 greg 2.1
52 greg 2.18 if (r == (double)EOF && feof(meshfp))
53 greg 2.1 mesherror(USER, "truncated mesh file");
54 greg 2.18
55 greg 2.1 return(r);
56     }
57
58
59     static OCTREE
60     getfullnode() /* get a set, return fullnode */
61     {
62     OBJECT set[MAXSET+1];
63 greg 2.16 int i;
64 greg 2.1
65     if ((set[0] = mgetint(objsize)) > MAXSET)
66     mesherror(USER, "bad set in getfullnode");
67     for (i = 1; i <= set[0]; i++)
68     set[i] = mgetint(objsize);
69     return(fullnode(set));
70     }
71
72
73     static OCTREE
74     gettree() /* get a pre-ordered octree */
75     {
76 greg 2.16 OCTREE ot;
77     int i;
78 greg 2.1
79     switch (getc(meshfp)) {
80 schorsch 2.4 case OT_EMPTY:
81     return(EMPTY);
82     case OT_FULL:
83     return(getfullnode());
84     case OT_TREE:
85     if ((ot = octalloc()) == EMPTY)
86     mesherror(SYSTEM, "out of tree space in readmesh");
87     for (i = 0; i < 8; i++)
88     octkid(ot, i) = gettree();
89     return(ot);
90     case EOF:
91     mesherror(USER, "truncated mesh octree");
92     default:
93     mesherror(USER, "damaged mesh octree");
94 greg 2.1 }
95 greg 2.14 return (OCTREE)0; /* pro forma return */
96 greg 2.1 }
97
98
99     static void
100     skiptree() /* skip octree on input */
101     {
102 greg 2.16 int i;
103 greg 2.1
104     switch (getc(meshfp)) {
105     case OT_EMPTY:
106     return;
107     case OT_FULL:
108     for (i = mgetint(objsize)*objsize; i-- > 0; )
109     if (getc(meshfp) == EOF)
110     mesherror(USER, "truncated mesh octree");
111     return;
112     case OT_TREE:
113     for (i = 0; i < 8; i++)
114     skiptree();
115     return;
116     case EOF:
117     mesherror(USER, "truncated mesh octree");
118     default:
119     mesherror(USER, "damaged mesh octree");
120     }
121     }
122
123
124     static void
125     getpatch(pp) /* load a mesh patch */
126 greg 2.16 MESHPATCH *pp;
127 greg 2.1 {
128     int flags;
129     int i, j;
130     /* vertex flags */
131     flags = mgetint(1);
132     if (!(flags & MT_V) || flags & ~(MT_V|MT_N|MT_UV))
133     mesherror(USER, "bad patch flags");
134     /* allocate vertices */
135     pp->nverts = mgetint(2);
136 greg 2.16 if ((pp->nverts <= 0) | (pp->nverts > 256))
137 greg 2.1 mesherror(USER, "bad number of patch vertices");
138 greg 2.6 pp->xyz = (uint32 (*)[3])malloc(pp->nverts*3*sizeof(uint32));
139 greg 2.1 if (pp->xyz == NULL)
140     goto nomem;
141     if (flags & MT_N) {
142 greg 2.6 pp->norm = (int32 *)calloc(pp->nverts, sizeof(int32));
143 greg 2.1 if (pp->norm == NULL)
144     goto nomem;
145     } else
146     pp->norm = NULL;
147     if (flags & MT_UV) {
148 greg 2.11 pp->uv = (uint32 (*)[2])calloc(pp->nverts, 2*sizeof(uint32));
149 greg 2.1 if (pp->uv == NULL)
150     goto nomem;
151     } else
152     pp->uv = NULL;
153     /* vertex xyz locations */
154     for (i = 0; i < pp->nverts; i++)
155     for (j = 0; j < 3; j++)
156     pp->xyz[i][j] = mgetint(4);
157     /* vertex normals */
158     if (flags & MT_N)
159     for (i = 0; i < pp->nverts; i++)
160     pp->norm[i] = mgetint(4);
161     /* uv coordinates */
162     if (flags & MT_UV)
163     for (i = 0; i < pp->nverts; i++)
164     for (j = 0; j < 2; j++)
165 greg 2.11 pp->uv[i][j] = mgetint(4);
166 greg 2.1 /* local triangles */
167     pp->ntris = mgetint(2);
168 greg 2.16 if ((pp->ntris < 0) | (pp->ntris > 512))
169 greg 2.1 mesherror(USER, "bad number of local triangles");
170     if (pp->ntris) {
171     pp->tri = (struct PTri *)malloc(pp->ntris *
172     sizeof(struct PTri));
173     if (pp->tri == NULL)
174     goto nomem;
175     for (i = 0; i < pp->ntris; i++) {
176     pp->tri[i].v1 = mgetint(1);
177     pp->tri[i].v2 = mgetint(1);
178     pp->tri[i].v3 = mgetint(1);
179     }
180     } else
181     pp->tri = NULL;
182 greg 2.2 /* local triangle material(s) */
183     if (mgetint(2) > 1) {
184 greg 2.6 pp->trimat = (int16 *)malloc(pp->ntris*sizeof(int16));
185 greg 2.2 if (pp->trimat == NULL)
186     goto nomem;
187     for (i = 0; i < pp->ntris; i++)
188     pp->trimat[i] = mgetint(2);
189     } else {
190     pp->solemat = mgetint(2);
191     pp->trimat = NULL;
192     }
193 greg 2.1 /* joiner triangles */
194     pp->nj1tris = mgetint(2);
195 greg 2.16 if ((pp->nj1tris < 0) | (pp->nj1tris > 256))
196 greg 2.1 mesherror(USER, "bad number of joiner triangles");
197     if (pp->nj1tris) {
198     pp->j1tri = (struct PJoin1 *)malloc(pp->nj1tris *
199     sizeof(struct PJoin1));
200     if (pp->j1tri == NULL)
201     goto nomem;
202     for (i = 0; i < pp->nj1tris; i++) {
203     pp->j1tri[i].v1j = mgetint(4);
204     pp->j1tri[i].v2 = mgetint(1);
205     pp->j1tri[i].v3 = mgetint(1);
206 greg 2.2 pp->j1tri[i].mat = mgetint(2);
207 greg 2.1 }
208     } else
209     pp->j1tri = NULL;
210     /* double joiner triangles */
211     pp->nj2tris = mgetint(2);
212 greg 2.16 if ((pp->nj2tris < 0) | (pp->nj2tris > 256))
213 greg 2.1 mesherror(USER, "bad number of double joiner triangles");
214     if (pp->nj2tris) {
215     pp->j2tri = (struct PJoin2 *)malloc(pp->nj2tris *
216     sizeof(struct PJoin2));
217     if (pp->j2tri == NULL)
218     goto nomem;
219     for (i = 0; i < pp->nj2tris; i++) {
220     pp->j2tri[i].v1j = mgetint(4);
221     pp->j2tri[i].v2j = mgetint(4);
222     pp->j2tri[i].v3 = mgetint(1);
223 greg 2.2 pp->j2tri[i].mat = mgetint(2);
224 greg 2.1 }
225     } else
226     pp->j2tri = NULL;
227     return;
228     nomem:
229     error(SYSTEM, "out of mesh memory in getpatch");
230     }
231
232
233     void
234     readmesh(mp, path, flags) /* read in mesh structures */
235     MESH *mp;
236     char *path;
237     int flags;
238     {
239 greg 2.2 char *err;
240 greg 2.1 char sbuf[64];
241     int i;
242     /* check what's loaded */
243     flags &= (IO_INFO|IO_BOUNDS|IO_TREE|IO_SCENE) & ~mp->ldflags;
244     /* open input file */
245     if (path == NULL) {
246     meshfn = "standard input";
247     meshfp = stdin;
248     } else if ((meshfp = fopen(meshfn=path, "r")) == NULL) {
249     sprintf(errmsg, "cannot open mesh file \"%s\"", path);
250     error(SYSTEM, errmsg);
251     }
252 schorsch 2.3 SET_FILE_BINARY(meshfp);
253 greg 2.19 #ifdef getc_unlocked /* avoid stupid semaphores */
254     flockfile(meshfp);
255     #endif
256 greg 2.1 /* read header */
257     checkheader(meshfp, MESHFMT, flags&IO_INFO ? stdout : (FILE *)NULL);
258     /* read format number */
259     objsize = getint(2, meshfp) - MESHMAGIC;
260 greg 2.16 if ((objsize <= 0) | (objsize > MAXOBJSIZ) | (objsize > sizeof(long)))
261 greg 2.1 mesherror(USER, "incompatible mesh format");
262     /* read boundaries */
263     if (flags & IO_BOUNDS) {
264     for (i = 0; i < 3; i++)
265     mp->mcube.cuorg[i] = atof(getstr(sbuf, meshfp));
266     mp->mcube.cusize = atof(getstr(sbuf, meshfp));
267     for (i = 0; i < 2; i++) {
268     mp->uvlim[0][i] = mgetflt();
269     mp->uvlim[1][i] = mgetflt();
270     }
271     } else {
272     for (i = 0; i < 4; i++)
273     getstr(sbuf, meshfp);
274     for (i = 0; i < 4; i++)
275     mgetflt();
276     }
277     /* read the octree */
278     if (flags & IO_TREE)
279     mp->mcube.cutree = gettree();
280     else if (flags & IO_SCENE)
281     skiptree();
282 greg 2.2 /* read materials and patches */
283 greg 2.1 if (flags & IO_SCENE) {
284 greg 2.2 mp->mat0 = nobjects;
285     readscene(meshfp, objsize);
286     mp->nmats = nobjects - mp->mat0;
287 greg 2.1 mp->npatches = mgetint(4);
288     mp->patch = (MESHPATCH *)calloc(mp->npatches,
289     sizeof(MESHPATCH));
290     if (mp->patch == NULL)
291     mesherror(SYSTEM, "out of patch memory");
292     for (i = 0; i < mp->npatches; i++)
293     getpatch(&mp->patch[i]);
294     }
295     /* clean up */
296 greg 2.17 if (meshfp != stdin)
297     fclose(meshfp);
298 greg 2.19 #ifdef getc_unlocked
299     else
300     funlockfile(meshfp);
301     #endif
302 greg 2.1 mp->ldflags |= flags;
303 greg 2.2 /* verify data */
304     if ((err = checkmesh(mp)) != NULL)
305     mesherror(USER, err);
306 greg 2.1 }
