root/radiance/src/common/radogl.h
Revision: 3.5
Committed: Tue Feb 25 02:47:21 2003 UTC (22 years, 8 months ago) by greg
Changes since 3.4: +2 -57 lines
1 /* RCSid $Id$ */
2 /*
3 * Header file for Radiance - OpenGL routines.
4 */
5
6 #include "copyright.h"
7
8 #include "standard.h"
9 #include <GL/glu.h>
10 #include "color.h"
11 #include "object.h"
12 #include "otypes.h"
13 #include "lookup.h"
14
15 #define MAXLIGHTS 8 /* number of OGL light sources */
16
17 #define MAXSPECEXP 128. /* maximum allowed specular exponent */
18 #define UNKSPECEXP 25. /* value to use when exponent unknown */
19
20 typedef struct {
21 short type; /* material type (from otypes.h) */
22 short nlinks; /* number of links to this material */
23 union {
24 struct {
25 COLOR ambdiff; /* ambient and diffuse color */
26 COLOR specular; /* specular color */
27 GLfloat specexp; /* specular exponent */
28 } m; /* regular material */
29 struct {
30 COLOR emission; /* emitting component */
31 GLfloat spotdir[3]; /* spot direction */
32 GLfloat spotang; /* spot cutoff angle */
33 } l; /* light source */
34 } u; /* union of types */
35 } MATREC; /* OGL material properties */
36
37 extern double expval; /* global exposure value */
38 extern COLOR ambval; /* global ambient value */
39 extern int glightid[MAXLIGHTS]; /* OpenGL GL_LIGHTi values */
40 extern int dolights; /* are we outputting light sources? */
41 extern int domats; /* are we doing materials? */
42
43 extern LUTAB mtab; /* material/modifier lookup table */
44
45 #define issrcmat(m) ((m) != NULL && islight((m)->type) && \
46 (m)->type != MAT_GLOW)
47
48 #ifdef NOPROTO
49
50 extern void domatobj();
51 extern void domatvert();
52 extern int newglist();
53 extern void rgl_checkerr();
54 extern int rgl_filelist();
55 extern int rgl_octlist();
56 extern void rgl_load();
57 extern void rgl_object();
58 extern int o_instance();
59 extern int loadoctrees();
60 extern double checkoct();
61 extern int loadoct();
62 extern void rgl_matclear();
63 extern MATREC *getmatp();
64 extern int o_default();
65 extern MATREC *newmaterial();
66 extern void freemtl();
67 extern int m_normal();
68 extern int m_aniso();
69 extern int m_glass();
70 extern int m_brdf();
71 extern int m_brdf2();
72 extern int m_light();
73 extern int m_mirror();
74 extern int m_prism();
75 extern void lightinit();
76 extern void lightclean();
77 extern void lightdefs();
78 extern int o_source();
79 extern int doflatsrc();
80 extern int dosphsrc();
81 extern void setmaterial();
82 extern double polyarea();
83 extern int o_face();
84 extern void surfclean();
85 extern int o_sphere();
86 extern int o_cone();
87 extern int o_ring();
88
89 #else
90 /* defined in rgldomat.c */
91 extern void domatobj(MATREC *mp, FVECT cent);
92 extern void domatvert(MATREC *mp, FVECT v, FVECT n);
93 /* defined in rglfile.c */
94 extern int newglist(void);
95 extern void rgl_checkerr(char *where);
96 extern int rgl_filelist(int ic, char **inp, int *nl);
97 extern int rgl_octlist(char *fname, FVECT cent, FLOAT *radp, int *nl);
98 extern void rgl_load(char *inpspec);
99 extern void rgl_object(char *name, FILE *fp);
100 /* defined in rglinst.c */
101 extern int o_instance(OBJREC *o);
102 extern int loadoctrees(void);
103 extern double checkoct(char *fname, FVECT cent);
104 extern int loadoct(char *fname);
105 /* defined in rglmat.c */
106 extern void rgl_matclear(void);
107 extern MATREC *getmatp(char *nam);
108 extern int o_default(OBJREC *o);
109 extern MATREC *newmaterial(char *nam);
110 extern void freemtl(MATREC *mp);
111 extern int m_normal(OBJREC *o);
112 extern int m_aniso(OBJREC *o);
113 extern int m_glass(OBJREC *o);
114 extern int m_brdf(OBJREC *o);
115 extern int m_brdf2(OBJREC *o);
116 extern int m_light(OBJREC *o);
117 extern int m_mirror(OBJREC *o);
118 extern int m_prism(OBJREC *o);
119 /* defined in rglsrc.c */
120 extern void lightinit(void);
121 extern void lightclean(void);
122 extern void lightdefs(void);
123 extern int o_source(OBJREC *o);
124 extern int doflatsrc(MATREC *m, FVECT pos, FVECT norm, double area);
125 extern int dosphsrc(MATREC *m, FVECT pos, double area);
126 /* defined in rglsurf.c */
127 extern void setmaterial(MATREC *mp, FVECT cent, int ispoly);
128 extern double polyarea(FVECT cent, FVECT norm, int n, FVECT v[]);
129 extern int o_face(OBJREC *o);
130 extern void surfclean(void);
131 extern int o_sphere(OBJREC *o);
132 extern int o_cone(OBJREC *o);
133 extern int o_ring(OBJREC *o);
134
135 #endif
