root/radiance/src/common/pyradlib/pyrad_proc.py
Revision: 1.5
Committed: Wed Apr 27 16:29:48 2016 UTC (9 years, 5 months ago) by schorsch
Content type: text/x-python
CVS Tags: rad6R0, rad5R4, rad5R2, rad5R3, HEAD
Changes since 1.4: +3 -3 lines
yet some more robustness
# User Rev Content
1 schorsch 1.1 # -*- coding: utf-8 -*-
2     ''' pyrad_proc.py - Process and pipeline management for Python Radiance scripts
3     2016 - Georg Mischler
4
5     Use as:
6     from pyradlib.pyrad_proc import PIPE, Error, ProcMixin
7
8     For a single-file installation, include the contents of this file
9     at the same place (minus the __future__ import below).
10     '''
11     from __future__ import division, print_function, unicode_literals
12
13     import sys
14     import subprocess
15     PIPE = subprocess.PIPE
16
17
18     class Error(Exception): pass
19
20
21     class ProcMixin():
22     '''Process and pipeline management for Python Radiance scripts
23     '''
24     def raise_on_error(self, actstr, e):
25 schorsch 1.5 try: self._strtypes
26     except AttributeError: self.__configure_subprocess()
27 schorsch 1.3 if hasattr(e, 'strerror'): eb = e.strerror
28     elif isinstance(e, self._strtypes): eb = e
29     else: eb = e
30     if isinstance(eb, type(b'')):
31     estr = eb.decode(encoding='utf-8', errors='ignore')
32     else: estr = eb
33     raise Error('Unable to %s - %s' % (actstr, estr)) #
34 schorsch 1.1
35     def __configure_subprocess(self):
36     '''Prevent subprocess module failure in frozen scripts on Windows.
37     Prevent console windows from popping up when not console based.
38 schorsch 1.2 Make sure we use the version-specific string types.
39 schorsch 1.1 '''
40     # On Windows, sys.stdxxx may not be available when:
41     # - built as *.exe with "pyinstaller --noconsole"
42     # - invoked via CreateProcess() and stream not redirected
43     try:
44     sys.__stdin__.fileno()
45     self._stdin = sys.stdin
46     except: self._stdin = PIPE
47     try:
48     sys.__stdout__.fileno()
49     self._stdout = sys.stdout
50     except: self._stdout = PIPE
51     try:
52     sys.__stderr__.fileno()
53     self._stderr = sys.stderr
54     # keep subprocesses from opening their own console.
55     except: self._stderr = PIPE
56     if hasattr(subprocess, 'STARTUPINFO'):
57     si = subprocess.STARTUPINFO()
58     si.dwFlags |= subprocess.STARTF_USESHOWWINDOW
59     self._pipeargs = {'startupinfo':si}
60     else: self._pipeargs = {}
61     # type names vary between Py2.7 and 3.x
62     self._strtypes = (type(b''), type(u''))
63
64     def qjoin(self, sl):
65     '''Join a list with quotes around each element containing whitespace.
66     We only use this to display command lines on sys.stderr, the actual
67     Popen() calls are made with the original list.
68     '''
69     def _q(s):
70     if ' ' in s or '\t' in s or ';' in s:
71     return "'" + s + "'"
72     return s
73     return ' '.join([_q(s) for s in sl])
74
75 schorsch 1.2 def __parse_args(self, _in, out):
76 schorsch 1.5 try: self._strtypes
77 schorsch 1.2 except AttributeError: self.__configure_subprocess()
78     instr = ''
79     if _in == PIPE:
80     stdin = _in
81     elif isinstance(_in, self._strtypes):
82 schorsch 1.4 if not getattr(self, 'donothing', None):
83     stdin = open(_in, 'rb')
84     else: stdin = None
85 schorsch 1.2 instr = ' < "%s"' % _in
86     elif hasattr(_in, 'read'):
87     stdin = _in
88     instr = ' < "%s"' % _in.name
89     else: stdin = self._stdin
90     outstr = ''
91     if out == PIPE:
92     stdout = out
93     elif isinstance(out, self._strtypes):
94 schorsch 1.4 if not getattr(self, 'donothing', None):
95     stdout = open(out, 'wb')
96     else: stdout = None
97 schorsch 1.2 outstr = ' > "%s"' % out
98     elif hasattr(out, 'write'):
99     stdout = out
100     outstr = ' > "%s"' % out.name
101     else: stdout = self._stdout
102     return stdin, stdout, instr, outstr
103
104 schorsch 1.1 def call_one(self, cmdl, actstr, _in=None, out=None,
105     universal_newlines=False):
106     '''Create a single subprocess, possibly with an incoming and outgoing
107     pipe at each end.
108     - cmdl
109     A list of strings, leading with the name of the executable (without
110     the *.exe suffix), followed by individual arguments.
111     - actstr
112     A text string of the form "do something".
113     Used in verbose mode as "### do someting\\n### [command line]"
114     Used in error messages as "Scriptname: Unable to do something".
115     - _in / out
116     What to do with the input and output pipes of the process:
117     * a filename as string
118     Open file and use for reading/writing.
119     * a file like object
120     Use for reading/writing
121     * PIPE
122     Pipe will be available in returned object for reading/writing.
123     * None (default)
124     System stdin/stdout will be used if available
125     If _in or out is a PIPE, the caller should call p.wait() on the
126     returned Popen instance after writing to and closing it.
127     '''
128 schorsch 1.2 stdin, stdout, instr, outstr = self.__parse_args(_in, out)
129 schorsch 1.1 if getattr(self, 'verbose', None):
130     sys.stderr.write('### %s \n' % actstr)
131 schorsch 1.2 sys.stderr.write(self.qjoin(cmdl) + instr + outstr + '\n')
132 schorsch 1.1 if not getattr(self, 'donothing', None):
133 schorsch 1.2 try: p = subprocess.Popen(cmdl,
134     stdin=stdin, stdout=stdout, stderr=self._stderr,
135 schorsch 1.1 universal_newlines=universal_newlines, **self._pipeargs)
136     except Exception as e:
137 schorsch 1.3 self.raise_on_error(actstr, e)
138 schorsch 1.1 if stdin != PIPE and stdout != PIPE:
139     # caller needs to wait after reading or writing (else deadlock)
140     res = p.wait()
141     if res != 0:
142     self.raise_on_error(actstr,
143     'Nonzero exit (%d) from command [%s].'
144 schorsch 1.2 % (res, self.qjoin(cmdl)+instr+outstr+'\n'))
145 schorsch 1.1 return p
146
147     def call_two(self, cmdl_1, cmdl_2, actstr_1, actstr_2, _in=None, out=None,
148     universal_newlines=False):
149     '''Create two processes, chained via a pipe, possibly with an incoming
150     and outgoing pipe at each end.
151     Returns a tuple of two Popen instances.
152     Arguments are equivalent to call_one(), with _in and out applying
153     to the ends of the chain.
154     If _in or out is PIPE, the caller should call p.wait() on both
155     returned popen instances after writing to and closing the first on .
156     '''
157 schorsch 1.2 stdin, stdout, instr, outstr = self.__parse_args(_in, out)
158 schorsch 1.1 if getattr(self, 'verbose', None):
159     sys.stderr.write('### %s \n' % actstr_1)
160     sys.stderr.write('### %s \n' % actstr_2)
161 schorsch 1.2 sys.stderr.write(self.qjoin(cmdl_1) + instr + ' | ')
162 schorsch 1.1 if not getattr(self, 'donothing', None):
163 schorsch 1.2 try: p1 = subprocess.Popen(cmdl_1,
164     stdin=stdin, stdout=PIPE, stderr=self._stderr,
165     **self._pipeargs)
166 schorsch 1.1 except Exception as e:
167 schorsch 1.3 self.raise_on_error(actstr_1, e)
168 schorsch 1.1 if getattr(self, 'verbose', None):
169 schorsch 1.2 sys.stderr.write(self.qjoin(cmdl_2) + outstr + '\n')
170 schorsch 1.1 if not getattr(self, 'donothing', None):
171     try:
172 schorsch 1.2 p2 = subprocess.Popen(cmdl_2,
173     stdin=p1.stdout, stdout=stdout, stderr=self._stderr,
174 schorsch 1.1 universal_newlines=universal_newlines, **self._pipeargs)
175     p1.stdout.close()
176     except Exception as e:
177 schorsch 1.3 self.raise_on_error(actstr_2, e)
178 schorsch 1.1 if stdin != PIPE and stdout != PIPE:
179     # caller needs to wait after reading or writing (else deadlock)
180     res = p1.wait()
181     if res != 0:
182     self.raise_on_error(actstr_1,
183     'Nonzero exit (%d) from command [%s].'
184     % (res, self.qjoin(cmdl_1)))
185     res = p2.wait()
186     if res != 0:
187     self.raise_on_error(actstr_2,
188     'Nonzero exit (%d) from command [%s].'
189     % (res, self.qjoin(cmdl_2)))
190     return p1, p2
191
192     def call_many(self, cmdlines, actstr, _in=None, out=None,
193     universal_newlines=False):
194     '''Create a series of N processes, chained via pipes, possibly with an
195     incoming and outgoing pipe at each end.
196     Returns a tuple of N subprocess.Popen instances.
197     Depending on the values of _in and out, the first and last may be
198     available to write to or read from respectively.
199     Most arguments are equivalent to call_one(), with
200     - cmdlines
201     a list of N command argument lists
202     - _in / out
203     applying to the ends of the chain.
204     If _in or out is PIPE, the caller should call p.wait() on all
205     returned Popen instances after writing to and closing the first one.
206     '''
207     if len(cmdlines) == 1:
208     # other than direct call_one(), this returns a one-item tuple!
209     return (self.call_one(cmdlines[0], actstr, _in=_in, out=out,
210     universal_newlines=universal_newlines),)
211 schorsch 1.2 stdin, stdout, instr, outstr = self.__parse_args(_in, out)
212 schorsch 1.1 procs = []
213     if getattr(self, 'verbose', None):
214     sys.stderr.write('### %s \n' % actstr)
215 schorsch 1.2 sys.stderr.write(self.qjoin(cmdlines[0]) + instr + ' | ')
216 schorsch 1.1 if not getattr(self, 'donothing', None):
217     try:
218     prevproc = subprocess.Popen(cmdlines[0], stdin=stdin,
219     stdout=PIPE, stderr=self._stderr, **self._pipeargs)
220     procs.append(prevproc)
221     except Exception as e:
222 schorsch 1.3 self.raise_on_error(actstr, e)
223 schorsch 1.1
224     for cmdl in cmdlines[1:-1]:
225     if getattr(self, 'verbose', None):
226     sys.stderr.write(self.qjoin(cmdl) + ' | ')
227     if not getattr(self, 'donothing', None):
228     try:
229     nextproc = subprocess.Popen(cmdl, stdin=prevproc.stdout,
230     stdout=PIPE, stderr=self._stderr, **self._pipeargs)
231     procs.append(nextproc)
232     prevproc.stdout.close()
233     prevproc = nextproc
234     except Exception as e:
235 schorsch 1.3 self.raise_on_error(actstr, e)
236 schorsch 1.1
237     if getattr(self, 'verbose', None):
238 schorsch 1.2 sys.stderr.write(self.qjoin(cmdlines[-1]) + outstr + '\n')
239 schorsch 1.1 if not getattr(self, 'donothing', None):
240     try:
241     lastproc = subprocess.Popen(cmdlines[-1], stdin=prevproc.stdout,
242     stdout=stdout, stderr=self._stderr,
243     universal_newlines=universal_newlines, **self._pipeargs)
244     prevproc.stdout.close()
245     procs.append(lastproc)
246     prevproc.stdout.close()
247     except Exception as e:
248 schorsch 1.3 self.raise_on_error(actstr, e)
249 schorsch 1.1
250     if stdin != PIPE and stdout!= PIPE:
251     # caller needs to wait after reading or writing (else deadlock)
252     for proc, cmdl in zip(procs, cmdlines):
253     res = proc.wait()
254     if res != 0:
255     self.raise_on_error(actstr,
256     'Nonzero exit (%d) from command [%s].'
257     % (res, self.qjoin(cmdl)))
258     return procs
259
260
261     ### end of proc_mixin.py
