| 1 |
/* Copyright (c) 1986 Regents of the University of California */
| 2 |
| 3 |
/* SCCSid "$SunId$ LBL" */
| 4 |
| 5 |
| 6 |
* octree.h - header file for routines using octrees.
| 7 |
| 8 |
* 7/28/85
| 9 |
| 10 |
| 11 |
| 12 |
* An octree is expressed as an integer which is either
| 13 |
* an index to eight other nodes, the empty tree, or an index
| 14 |
* to a set of objects. If the octree has a value:
| 15 |
| 16 |
* > -1: it is an index to eight other nodes.
| 17 |
| 18 |
* -1: it is empty
| 19 |
| 20 |
* < -1: it is an index to a set of objects
| 21 |
| 22 |
| 23 |
#ifndef OCTREE
| 24 |
#define OCTREE int
| 25 |
#endif
| 26 |
| 27 |
#define EMPTY (-1)
| 28 |
| 29 |
#define isempty(ot) ((ot) == EMPTY)
| 30 |
#define isfull(ot) ((ot) < EMPTY)
| 31 |
#define istree(ot) ((ot) > EMPTY)
| 32 |
| 33 |
#define oseti(ot) (-(ot)-2) /* object set index */
| 34 |
#define octbi(ot) ((ot)>>8) /* octree block index */
| 35 |
#define octti(ot) (((ot)&0377)<<3)/* octree index in block */
| 36 |
| 37 |
#ifndef MAXOBLK
| 38 |
#ifdef BIGMEM
| 39 |
#define MAXOBLK 16383 /* maximum octree block */
| 40 |
#else
| 41 |
#define MAXOBLK 4095 /* maximum octree block */
| 42 |
#endif
| 43 |
#endif
| 44 |
| 45 |
extern OCTREE *octblock[MAXOBLK]; /* octree blocks */
| 46 |
| 47 |
#define octkid(ot,br) (octblock[octbi(ot)][octti(ot)+br])
| 48 |
| 49 |
extern OCTREE octalloc(), combine(), fullnode();
| 50 |
| 51 |
| 52 |
* The cube structure is used to hold an octree and its cubic
| 53 |
* boundaries.
| 54 |
| 55 |
| 56 |
typedef struct {
| 57 |
OCTREE cutree; /* the octree for this cube */
| 58 |
FVECT cuorg; /* the cube origin */
| 59 |
double cusize; /* the cube size */
| 60 |
} CUBE;
| 61 |
| 62 |
extern CUBE thescene; /* the main scene */
| 63 |
| 64 |
/* flags for reading and writing octrees */
| 65 |
#define IO_CHECK 0 /* verify file type */
| 66 |
#define IO_INFO 01 /* information header */
| 67 |
#define IO_SCENE 02 /* objects */
| 68 |
#define IO_TREE 04 /* octree */
| 69 |
#define IO_FILES 010 /* object file names */
| 70 |
#define IO_BOUNDS 020 /* octree boundary */
| 71 |
#define IO_ALL (~0) /* everything */
| 72 |
/* octree format identifier */
| 73 |
#define OCTFMT "Radiance_octree"
| 74 |
/* magic number for octree files */
| 75 |
#define MAXOBJSIZ 8 /* maximum sizeof(OBJECT) */
| 76 |
#define OCTMAGIC ( 4 *MAXOBJSIZ+251) /* increment first value */
| 77 |
/* octree node types */
| 78 |
#define OT_EMPTY 0
| 79 |
#define OT_FULL 1
| 80 |
#define OT_TREE 2
| 81 |
/* return values for surface functions */
| 82 |
#define O_MISS 0 /* no intersection */
| 83 |
#define O_HIT 1 /* intersection */
| 84 |
#define O_IN 2 /* cube contained entirely */
