root/radiance/src/common/object.h
Revision: 2.10
Committed: Mon Mar 10 17:13:29 2003 UTC (22 years, 7 months ago) by greg
Changes since 2.9: +11 -11 lines
1 /* RCSid $Id$ */
2 /*
3 * object.h - header file for routines using objects and object sets.
4 */
5
6 #include "copyright.h"
7
8 #ifndef OCTREE
9 #define OCTREE int
10 #endif
11
12 /*
13 * Object definitions require general specifications
14 * which may include a number of different argument types.
15 * The following structure aids in the storage of such
16 * argument lists.
17 */
18
19 typedef struct {
20 short nsargs; /* # of string arguments */
21 short nfargs; /* # of real arguments */
22 char **sarg; /* string arguments */
23 FLOAT *farg; /* real arguments */
24 #ifdef IARGS
25 short niargs; /* # of integer arguments */
26 long *iarg; /* integer arguments */
27 #endif
28 } FUNARGS;
29
30 #define MAXSTR 128 /* maximum string length */
31
32 /*
33 * An object is defined as an index into an array of
34 * structures containing the object type and specification
35 * and the modifier index.
36 */
37
38 #ifndef OBJECT
39 #ifdef BIGMEM
40 #define OBJECT int4 /* index to object array */
41 #else
42 #define OBJECT int2 /* index to object array */
43 #endif
44 #endif
45
46 typedef struct {
47 OBJECT omod; /* modifier number */
48 short otype; /* object type number */
49 char *oname; /* object name */
50 FUNARGS oargs; /* object specification */
51 char *os; /* object structure */
52 } OBJREC;
53
54 #ifndef MAXOBJBLK
55 #ifdef BIGMEM
56 #define MAXOBJBLK 65535 /* maximum number of object blocks */
57 #else
58 #define MAXOBJBLK 63 /* maximum number of object blocks */
59 #endif
60 #endif
61
62 extern OBJREC *objblock[MAXOBJBLK]; /* the object blocks */
63 extern OBJECT nobjects; /* # of objects */
64
65 #define OBJBLKSHFT 9
66 #define OBJBLKSIZ (1<<OBJBLKSHFT) /* object block size */
67 #define objptr(obj) (objblock[(obj)>>OBJBLKSHFT]+((obj)&(OBJBLKSIZ-1)))
68
69 #define OVOID (-1) /* void object */
70 #define VOIDID "void" /* void identifier */
71
72 /*
73 * Object sets begin with the number of objects and proceed with
74 * the objects in ascending order.
75 */
76
77 #define MAXSET 127 /* maximum object set size */
78
79 #define setfree(os) free((void *)(os))
80
81 extern void (*addobjnotify[])(); /* people to notify of new objects */
82
83 #ifdef NOPROTO
84
85 extern OBJECT objndx();
86 extern OBJECT lastmod();
87 extern OBJECT modifier();
88 extern OBJECT object();
89 extern void insertobject();
90 extern void clearobjndx();
91 extern void insertelem();
92 extern void deletelem();
93 extern int inset();
94 extern int setequal();
95 extern void setcopy();
96 extern OBJECT * setsave();
97 extern void setunion();
98 extern void setintersect();
99 extern OCTREE fullnode();
100 extern void objset();
101 extern int dosets();
102 extern void donesets();
103 extern int otype();
104 extern void objerror();
105 extern int readfargs();
106 extern void freefargs();
107 extern void readobj();
108 extern void getobject();
109 extern OBJECT newobject();
110 extern void freeobjects();
111 extern int free_os();
112
113 #else
114 /* defined in modobject.c */
115 extern OBJECT objndx(OBJREC *op);
116 extern OBJECT lastmod(OBJECT obj, char *mname);
117 extern OBJECT modifier(char *name);
118 extern OBJECT object(char *oname);
119 extern void insertobject(OBJECT obj);
120 extern void clearobjndx(void);
121 /* defined in objset.c */
122 extern void insertelem(OBJECT *os, OBJECT obj);
123 extern void deletelem(OBJECT *os, OBJECT obj);
124 extern int inset(OBJECT *os, OBJECT obj);
125 extern int setequal(OBJECT *os1, OBJECT *os2);
126 extern void setcopy(OBJECT *os1, OBJECT *os2);
127 extern OBJECT * setsave(OBJECT *os);
128 extern void setunion(OBJECT *osr, OBJECT *os1, OBJECT *os2);
129 extern void setintersect(OBJECT *osr, OBJECT *os1, OBJECT *os2);
130 extern OCTREE fullnode(OBJECT *oset);
131 extern void objset(OBJECT *oset, OCTREE ot);
132 extern int dosets(int (*f)());
133 extern void donesets(void);
134
135 /* defined in otypes.c */
136 extern int otype(char *ofname);
137 extern void objerror(OBJREC *o, int etyp, char *msg);
138 /* defined in readfargs.c */
139 extern int readfargs(FUNARGS *fa, FILE *fp);
140 extern void freefargs(FUNARGS *fa);
141 /* defined in readobj.c */
142 extern void readobj(char *inpspec);
143 extern void getobject(char *name, FILE *fp);
144 extern OBJECT newobject();
145 extern void freeobjects(int firstobj, int nobjs);
146 /* defined in free_os.c */
147 extern int free_os(OBJREC *op);
148
149 #endif /* NOPROTO */
