root/radiance/src/common/object.h
Revision: 1.5
Committed: Wed Oct 23 12:19:28 1991 UTC (34 years ago) by greg
added FLOAT definition for vectors and matrices
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * object.h - header file for routines using objects and object sets.
7 *
8 * 7/28/85
9 */
10
11 /*
12 * Object definitions require general specifications
13 * which may include a number of different argument types.
14 * The following structure aids in the storage of such
15 * argument lists.
16 */
17
18 typedef struct {
19 short nsargs; /* # of string arguments */
20 short nfargs; /* # of real arguments */
21 char **sarg; /* string arguments */
22 FLOAT *farg; /* real arguments */
23 #ifdef IARGS
24 short niargs; /* # of integer arguments */
25 long *iarg; /* integer arguments */
26 #endif
27 } FUNARGS;
28
29 #define MAXSTR 128 /* maximum string length */
30
31 /*
32 * An object is defined as an index into an array of
33 * structures containing the object type and specification
34 * and the modifier index.
35 */
36
37 #ifndef OBJECT
38 #ifdef BIGMEM
39 #define OBJECT int /* index to object array */
40 #else
41 #define OBJECT short /* index to object array */
42 #endif
43 #endif
44
45 typedef struct {
46 OBJECT omod; /* modifier number */
47 short otype; /* object type number */
48 char *oname; /* object name */
49 FUNARGS oargs; /* object specification */
50 char *os; /* object structure */
51 long lastrno; /* last ray this was used with */
52 } OBJREC;
53
54 #ifndef MAXOBJBLK
55 #ifdef BIGMEM
56 #define MAXOBJBLK 4095 /* maximum number of object blocks */
57 #else
58 #define MAXOBJBLK 511 /* maximum number of object blocks */
59 #endif
60 #endif
61
62 extern OBJREC *objblock[MAXOBJBLK]; /* the object blocks */
63 extern OBJECT nobjects; /* # of objects */
64
65 #define objptr(obj) (objblock[(obj)>>6]+((obj)&077))
66
67 #define OVOID (-1) /* void object */
68 #define VOIDID "void" /* void identifier */
69
70 /*
71 * Object sets begin with the number of objects and proceed with
72 * the objects in ascending order.
73 */
74
75 #define MAXSET 127 /* maximum object set size */
