| 1 | /* RCSid $Id: normcodec.h,v 2.3 2019/08/14 21:00:14 greg Exp $ */ |
| 2 | /* |
| 3 | * Definitions and declarations for 32-bit vector normal encode/decode |
| 4 | * |
| 5 | *  Include after rtio.h and fvect.h |
| 6 | *  Includes resolu.h |
| 7 | */ |
| 8 |  |
| 9 | #ifndef _RAD_NORMALCODEC_H_ |
| 10 | #define _RAD_NORMALCODEC_H_ |
| 11 |  |
| 12 | #include "resolu.h" |
| 13 |  |
| 14 | #ifdef __cplusplus |
| 15 | extern "C" { |
| 16 | #endif |
| 17 |  |
| 18 | #define NORMAL32FMT     "32-bit_encoded_normal" |
| 19 |  |
| 20 | #define HF_HEADIN       0x1                     /* expect input header */ |
| 21 | #define HF_HEADOUT      0x2                     /* write header to stdout */ |
| 22 | #define HF_RESIN        0x4                     /* expect resolution string */ |
| 23 | #define HF_RESOUT       0x8                     /* write resolution to stdout */ |
| 24 | #define HF_STDERR       0x10                    /* report errors to stderr */ |
| 25 | #define HF_ALL          0x1f                    /* all flags above */ |
| 26 | #define HF_ENCODE       0x20                    /* we are encoding */ |
| 27 |  |
| 28 | /* Structure for encoding/decoding normals */ |
| 29 | typedef struct { |
| 30 | FILE            *finp;                  /* input stream */ |
| 31 | const char      *inpname;               /* input name */ |
| 32 | short           format;                 /* decoded format */ |
| 33 | short           swapped;                /* byte-swapped input */ |
| 34 | long            dstart;                 /* start of data */ |
| 35 | long            curpos;                 /* current input position */ |
| 36 | short           hdrflags;               /* header i/o flags */ |
| 37 | char            inpfmt[MAXFMTLEN];      /* format from header */ |
| 38 | RESOLU          res;                    /* input resolution */ |
| 39 | } NORMCODEC; |
| 40 |  |
| 41 | /* Set codec defaults */ |
| 42 | extern void     set_nc_defaults(NORMCODEC *ncp); |
| 43 |  |
| 44 | /* Load/copy header */ |
| 45 | extern int      process_nc_header(NORMCODEC *ncp, int ac, char *av[]); |
| 46 |  |
| 47 | /* Check that we have what we need to decode normals */ |
| 48 | extern int      check_decode_normals(NORMCODEC *ncp); |
| 49 |  |
| 50 | /* Decode next normal from input */ |
| 51 | extern int      decode_normal_next(FVECT nrm, NORMCODEC *ncp); |
| 52 |  |
| 53 | /* Seek to the indicated pixel position */ |
| 54 | extern int      seek_nc_pix(NORMCODEC *ncp, int x, int y); |
| 55 |  |
| 56 | /* Read and decode normal for the given pixel */ |
| 57 | extern int      decode_normal_pix(FVECT nrm, NORMCODEC *ncp, int x, int y); |
| 58 |  |
| 59 | extern char     *progname;      /* global argv[0] (set by main) */ |
| 60 |  |
| 61 | #ifdef __cplusplus |
| 62 | } |
| 63 | #endif |
| 64 | #endif          /* _RAD_NORMALCODEC_H_ */ |
