root/radiance/src/common/normcodec.c
Revision: 2.10
Committed: Sat Jun 7 05:09:45 2025 UTC (4 months, 2 weeks ago) by greg
CVS Tags: rad6R0, HEAD
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.10 static const char RCSid[] = "$Id: normcodec.c,v 2.9 2022/09/22 21:47:13 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Routines to encode/decode 32-bit normals
6     */
7
8     #include "copyright.h"
9
10     #include "rtio.h"
11 greg 2.10 #include "paths.h"
12 greg 2.1 #include "rtmath.h"
13     #include "normcodec.h"
14
15
16     /* Set codec defaults */
17     void
18     set_nc_defaults(NORMCODEC *ncp)
19     {
20     memset(ncp, 0, sizeof(NORMCODEC));
21     ncp->finp = stdin;
22     ncp->inpname = "<stdin>";
23     ncp->format = 'a';
24     ncp->res.rt = PIXSTANDARD;
25     if (!progname) progname = "norm_codec";
26     }
27
28
29     /* process header line */
30     static int
31     headline(char *s, void *p)
32     {
33     NORMCODEC *ncp = (NORMCODEC *)p;
34 greg 2.3 int rv;
35 greg 2.1
36     if (formatval(ncp->inpfmt, s)) /* don't pass format */
37     return 0;
38
39 greg 2.3 if ((rv = isbigendian(s)) >= 0) {
40     ncp->swapped = (nativebigendian() != rv);
41     return 0;
42     }
43 greg 2.8 if (!strncmp(s, "NCOMP=", 6)) {
44     if (atoi(s+6) != 3) {
45     if (ncp->hdrflags & HF_STDERR) {
46     fputs(ncp->inpname, stderr);
47     fputs(": NCOMP must equal 3\n", stderr);
48     }
49     return -1;
50     }
51     return 0;
52     }
53     if (!strncmp(s, "NROWS=", 6)) {
54     ncp->res.yr = atoi(s+6);
55     return 0;
56     }
57     if (!strncmp(s, "NCOLS=", 6)) {
58     ncp->res.xr = atoi(s+6);
59     return 0;
60     }
61 greg 2.1 if (ncp->hdrflags & HF_HEADOUT)
62     fputs(s, stdout); /* copy to standard output */
63     return 1;
64     }
65
66
67     /* Load/copy header */
68     int
69     process_nc_header(NORMCODEC *ncp, int ac, char *av[])
70     {
71     if (ncp->hdrflags & HF_HEADIN &&
72     getheader(ncp->finp, headline, ncp) < 0) {
73 greg 2.2 if (ncp->hdrflags & HF_STDERR) {
74     fputs(ncp->inpname, stderr);
75     fputs(": bad header\n", stderr);
76     }
77     return 0;
78 greg 2.1 }
79 greg 2.6 /* get resolution string? */
80 greg 2.8 if (ncp->hdrflags & HF_RESIN &&
81     (ncp->res.xr <= 0) | (ncp->res.yr <= 0) &&
82     !fgetsresolu(&ncp->res, ncp->finp)) {
83 greg 2.6 if (ncp->hdrflags & HF_STDERR) {
84     fputs(ncp->inpname, stderr);
85     fputs(": bad resolution string\n", stderr);
86     }
87     return 0;
88     }
89 greg 2.1 if (ncp->hdrflags & HF_HEADOUT) { /* finish header */
90     if (!(ncp->hdrflags & HF_HEADIN))
91     newheader("RADIANCE", stdout);
92     if (ac > 0)
93     printargs(ac, av, stdout);
94     if (ncp->hdrflags & HF_ENCODE) {
95     fputformat(NORMAL32FMT, stdout);
96 greg 2.6 } else {
97     fputs("NCOMP=3\n", stdout);
98     if ((ncp->hdrflags & (HF_RESIN|HF_RESOUT)) == HF_RESIN)
99     printf("NCOLS=%d\nNROWS=%d\n",
100     scanlen(&ncp->res),
101     numscans(&ncp->res));
102 greg 2.1 switch (ncp->format) {
103     case 'a':
104     fputformat("ascii", stdout);
105     break;
106     case 'f':
107 greg 2.3 fputendian(stdout);
108 greg 2.1 fputformat("float", stdout);
109     break;
110     case 'd':
111 greg 2.3 fputendian(stdout);
112 greg 2.1 fputformat("double", stdout);
113     break;
114     }
115 greg 2.6 }
116 greg 2.1 fputc('\n', stdout);
117     }
118 greg 2.6 if (ncp->hdrflags & HF_RESOUT) /* put resolution string? */
119 greg 2.1 fputsresolu(&ncp->res, stdout);
120
121 greg 2.7 ncp->dstart = ftell(ncp->finp);
122 greg 2.1 return 1;
123     }
124
125
126     /* Check that we have what we need to decode normals */
127     int
128     check_decode_normals(NORMCODEC *ncp)
129     {
130     if (ncp->hdrflags & HF_ENCODE) {
131 greg 2.2 if (ncp->hdrflags & HF_STDERR) {
132     fputs(progname, stderr);
133     fputs(": wrong header mode for decode\n", stderr);
134     }
135 greg 2.1 return 0;
136     }
137     if (ncp->inpfmt[0] && strcmp(ncp->inpfmt, NORMAL32FMT)) {
138 greg 2.2 if (ncp->hdrflags & HF_STDERR) {
139     fputs(ncp->inpname, stderr);
140     fputs(": unexpected input format: ", stderr);
141     fputs(ncp->inpfmt, stderr);
142     fputc('\n', stderr);
143     }
144 greg 2.1 return 0;
145     }
146     return 1;
147     }
148
149
150     /* Decode next normal from input */
151     int
152     decode_normal_next(FVECT nrm, NORMCODEC *ncp)
153     {
154 greg 2.5 static int32 lastc;
155     static FVECT lastv;
156     int32 c = getint(4, ncp->finp);
157 greg 2.1
158     if (c == EOF && feof(ncp->finp))
159     return -1;
160
161 greg 2.4 if (c == lastc) { /* optimization */
162     VCOPY(nrm, lastv);
163     } else {
164     decodedir(nrm, c);
165     if (c) {
166     lastc = c;
167     VCOPY(lastv, nrm);
168     }
169     }
170 greg 2.1 return (c != 0);
171     }
172
173
174     /* Seek to the indicated pixel position */
175     int
176     seek_nc_pix(NORMCODEC *ncp, int x, int y)
177     {
178     if ((ncp->res.xr <= 0) | (ncp->res.yr <= 0)) {
179 greg 2.2 if (ncp->hdrflags & HF_STDERR) {
180     fputs(progname, stderr);
181     fputs(": need map resolution to seek\n", stderr);
182     }
183 greg 2.1 return -1;
184     }
185     if ((x < 0) | (y < 0) ||
186     (x >= scanlen(&ncp->res)) | (y >= numscans(&ncp->res))) {
187 greg 2.2 if (ncp->hdrflags & HF_STDERR) {
188     fputs(ncp->inpname, stderr);
189     fputs(": warning - pixel index off map\n", stderr);
190     }
191 greg 2.1 return 0;
192     }
193 greg 2.7 if (fseek(ncp->finp, ncp->dstart + 4*((long)y*scanlen(&ncp->res) + x),
194     SEEK_SET) == EOF) {
195 greg 2.2 if (ncp->hdrflags & HF_STDERR) {
196     fputs(ncp->inpname, stderr);
197     fputs(": seek error\n", stderr);
198     }
199 greg 2.1 return -1;
200     }
201     return 1;
202     }
203
204
205     /* Read and decode normal for the given pixel */
206     int
207     decode_normal_pix(FVECT nrm, NORMCODEC *ncp, int x, int y)
208     {
209     int rval = seek_nc_pix(ncp, x, y);
210
211     if (rval < 0)
212     return -1;
213
214     if (!rval) {
215     nrm[0] = nrm[1] = nrm[2] = .0;
216     return 0;
217     }
218     return decode_normal_next(nrm, ncp);
219     }
