root/radiance/src/common/muc_randvar.c
Revision: 2.1
Committed: Thu Jul 14 17:32:12 2016 UTC (9 years, 2 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R1, rad6R0, HEAD
Changes to evalglare by Jan Wienold
# User Rev Content
1 greg 2.1 #ifndef lint
2     static const char RCSid[] = "$Id$";
3     #endif
4     #include <stdio.h>
5     #include <stdlib.h>
6
7     #include "fvect.h"
8     #include "muc_randvar.h"
9
10     int muc_rvar_init(struct muc_rvar* rv)
11     {
12     rv->n = 0;
13     rv->w = 0.0;
14     if (!(rv->samples = g3fl_create(1)))
15     return 0;
16     rv->sum = NULL;
17     rv->sum_sqr = NULL;
18     rv->min = NULL;
19     rv->max = NULL;
20     rv->save_samp = 1;
21     return muc_rvar_set_dim(rv,1);
22     }
23
24     struct muc_rvar* muc_rvar_create()
25     {
26     struct muc_rvar* res;
27
28     if (!(res = (struct muc_rvar*) malloc(sizeof(struct muc_rvar))))
29     return NULL;
30     if (!(muc_rvar_init(res))) {
31     free(res);
32     return NULL;
33     }
34     return res;
35     }
36
37     void muc_rvar_free(struct muc_rvar* rv)
38     {
39     free(rv->sum);
40     free(rv->sum_sqr);
41     free(rv->min);
42     free(rv->max);
43     g3fl_free(rv->samples);
44     free(rv);
45     }
46
47     int muc_rvar_set_dim(struct muc_rvar* rv,int dim)
48     {
49     if (rv->n != 0) {
50     fprintf(stderr,"muc_rvar_set_dim: variable not cleared\n");
51     return 0;
52     }
53     if (!(rv->sum = realloc(rv->sum,dim*sizeof(double))))
54     return 0;
55     if (!(rv->sum_sqr = realloc(rv->sum_sqr,dim*sizeof(double))))
56     return 0;
57     if (!(rv->min = realloc(rv->min,dim*sizeof(double))))
58     return 0;
59     if (!(rv->max = realloc(rv->max,dim*sizeof(double))))
60     return 0;
61     rv->samples->comp_size = dim;
62     muc_rvar_clear(rv);
63     return 1;
64     }
65
66     void muc_rvar_clear(struct muc_rvar* rv)
67     {
68     int i;
69
70     rv->samples->size=0;
71     rv->w = 0.0;
72     rv->n = 0;
73     for(i=0;i<muc_rvar_get_dim(rv);i++) {
74     rv->sum[i] = 0.0;
75     rv->sum_sqr[i] = 0.0;
76     rv->min[i] = FHUGE;
77     rv->max[i] = -FHUGE;
78     }
79     }
80
81     void muc_rvar_no_samples(struct muc_rvar* rv)
82     {
83     rv->samples->size = 0;
84     rv->save_samp = 0;
85     }
86
87     int muc_rvar_store_sample(struct muc_rvar* rv, int on)
88     {
89     if (rv->n != 0) {
90     fprintf(stderr,"muc_rvar_store_sample: clear samples first\n");
91     return 0;
92     }
93     rv->save_samp = on;
94     return 1;
95     }
96
97     int muc_rvar_add_sample(struct muc_rvar* rv,double* s)
98     {
99     return muc_rvar_add_weighted_sample(rv,1.0,s);
100     }
101
102     int muc_rvar_add_weighted_sample(struct muc_rvar* rv,double w,double* s)
103     {
104     int i;
105     double val;
106
107     if (rv->save_samp)
108     if (!(g3fl_append(rv->samples,s)))
109     return 0;
110     for(i=0;i<muc_rvar_get_dim(rv);i++) {
111     val = s[i]*w;
112     rv->sum[i] += val;
113     rv->sum_sqr[i] += s[i]*s[i]*w;
114     if (rv->min[i] > val)
115     rv->min[i] = val;
116     if (rv->max[i] < val)
117     rv->max[i] = val;
118     }
119     rv->w += w;
120     rv->n++;
121     return 1;
122     }
123
124     int muc_rvar_get_vx(struct muc_rvar* rv,double* vx)
125     {
126     int i;
127     double ex,ex2;
128
129     if (rv->w == 0.0) {
130     return 0;
131     }
132     for(i=0;i<muc_rvar_get_dim(rv);i++) {
133     ex = rv->sum[i]/rv->w;
134     ex2 = rv->sum_sqr[i]/rv->w;
135     vx[i] = ex2 - ex*ex;
136     }
137     return 1;
138     }
139
140     int muc_rvar_get_ex(struct muc_rvar* rv,double* ex)
141     {
142     int i;
143
144     if (rv->w == 0.0) {
145     return 0;
146     }
147     for(i=0;i<muc_rvar_get_dim(rv);i++) {
148     ex[i] = rv->sum[i]/rv->w;
149     }
150     return 1;
151     }
152     int muc_rvar_get_sum(struct muc_rvar* rv,double* sum2)
153     {
154     int i;
155
156     for(i=0;i<muc_rvar_get_dim(rv);i++) {
157     sum2[i] = rv->sum[i];
158     }
159     return 1;
160     }
161
162     int muc_rvar_get_median(struct muc_rvar* rv, double* median)
163     {
164     double val;
165     int i;
166
167     if (!(rv->save_samp)) {
168     fprintf(stderr,"muc_rvar_get_median: samples are not stored\n");
169     return 0;
170     }
171     for(i=0;i<muc_rvar_get_dim(rv);i++) {
172     g3fl_sort(rv->samples, i);
173     val = g3fl_get(rv->samples, rv->n/2)[i];
174
175     if (rv->n % 2 == 0) {
176     val += g3fl_get(rv->samples,rv->n/2 - 1)[i];
177     val /= 2.0;
178     }
179     median[i] = val;
180     }
181     return 1;
182     }
183     int muc_rvar_get_percentile(struct muc_rvar* rv, double* median, double percentile)
184     {
185     double val;
186     int i;
187
188     if (!(rv->save_samp)) {
189     fprintf(stderr,"muc_rvar_get_median: samples are not stored\n");
190     return 0;
191     }
192     for(i=0;i<muc_rvar_get_dim(rv);i++) {
193     g3fl_sort(rv->samples, i);
194     val = g3fl_get(rv->samples, rv->n*percentile)[i];
195
196     if (rv->n % 1/percentile == 0) {
197     val += g3fl_get(rv->samples,rv->n*percentile - 1)[i];
198     val /= 2.0;
199     }
200     median[i] = val;
201     }
202     return 1;
203     }
204
205     int muc_rvar_get_bounding_box(struct muc_rvar* rv, double* bounds)
206     {
207     int i;
208
209     if (rv->n == 0)
210     return 0;
211     for(i=0;i<muc_rvar_get_dim(rv);i++) {
212     bounds[2*i] = rv->min[i];
213     bounds[2*i + 1] = rv->max[i];
214     }
215     return 1;
216     }
217
