root/radiance/src/common/modobject.c
Revision: 2.14
Committed: Sun Dec 8 18:59:53 2013 UTC (11 years, 10 months ago) by greg
Changes since 2.13: +57 -1 lines
2 static const char RCSid[] = "$Id: modobject.c,v 2.13 2013/03/09 18:53:05 greg Exp $";
5 * Routines for tracking object modifiers
6 *
7 * External symbols declared in object.h
8 */
9
10 #include "copyright.h"
11
12 #include "standard.h"
13
14 #include "object.h"
15
16 #include "otypes.h"
17
18
19 static struct ohtab {
20 int hsiz; /* current table size */
21 OBJECT *htab; /* table, if allocated */
22 } modtab = {100, NULL}, objtab = {1000, NULL}; /* modifiers and objects */
23
24 static int otndx(char *, struct ohtab *);
25
26
27 OBJECT
28 objndx( /* get object number from pointer */
29 OBJREC *op
30 )
31 {
32 int i, j;
33
34 for (i = nobjects>>OBJBLKSHFT; i >= 0; i--) {
35 j = op - objblock[i];
36 if ((j >= 0) & (j < OBJBLKSIZ))
37 return((i<<OBJBLKSHFT) + j);
38 }
39 return(OVOID);
40 }
41
42
43 OBJECT
44 lastmod( /* find modifier definition before obj */
45 OBJECT obj,
46 char *mname
47 )
48 {
49 OBJREC *op;
50 int i;
51
52 i = modifier(mname); /* try hash table first */
53 if ((obj == OVOID) | (i < obj))
54 return(i);
55 for (i = obj; i-- > 0; ) { /* need to search */
56 op = objptr(i);
57 if (ismodifier(op->otype) && op->oname[0] == mname[0] &&
58 !strcmp(op->oname, mname))
59 return(i);
60 }
61 return(OVOID);
62 }
63
64
65 OBJECT
66 modifier( /* get a modifier number from its name */
67 char *mname
68 )
69 {
70 int ndx;
71
72 ndx = otndx(mname, &modtab);
73 return(modtab.htab[ndx]);
74 }
75
76
77 #ifdef GETOBJ
78 OBJECT
79 object( /* get an object number from its name */
80 char *oname
81 )
82 {
83 int ndx;
84
85 ndx = otndx(oname, &objtab);
86 return(objtab.htab[ndx]);
87 }
88 #endif
89
90
91 static int
92 eqreal( /* are two real values close enough to equal? */
93 double d1,
94 double d2
95 )
96 {
97 if (d2 != 0.0)
98 d1 = d1/d2 - 1.0;
99 return((-FTINY <= d1) & (d1 <= FTINY));
100 }
101
102
103 int
104 eqobjects( /* check if two objects are equal */
105 OBJECT obj1,
106 OBJECT obj2
107 )
108 {
109 OBJREC *op1, *op2;
110 int i;
111
112 if (obj1 == OVOID)
113 return(obj2 == OVOID);
114 if (obj2 == OVOID)
115 return(0);
116 op1 = objptr(obj1);
117 op2 = objptr(obj2);
118 if (op1->omod != op2->omod)
119 return(0);
120 if (op1->otype != op2->otype)
121 return(0);
122 if (strcmp(op1->oname, op2->oname))
123 return(0);
124 if (op1->oargs.nsargs != op2->oargs.nsargs)
125 return(0);
126 if (op1->oargs.nfargs != op2->oargs.nfargs)
127 return(0);
128 #ifdef IARGS
129 if (op1->oargs.niargs != op2->oargs.niargs)
130 return(0);
131 for (i = op1->oargs.niargs; i-- > 0; )
132 if (op1->oargs.iarg[i] != op2->oargs.iarg[i])
133 return(0);
134 #endif
135 for (i = op1->oargs.nfargs; i-- > 0; )
136 if (!eqreal(op1->oargs.farg[i], op2->oargs.farg[i]))
137 return(0);
138 for (i = op1->oargs.nsargs; i-- > 0; )
139 if (strcmp(op1->oargs.sarg[i], op2->oargs.sarg[i]))
140 return(0);
141 return(1);
142 }
143
144
145 void
146 insertobject( /* insert new object into our list */
147 OBJECT obj
148 )
149 {
150 int i;
151
152 if (ismodifier(objptr(obj)->otype)) {
153 i = otndx(objptr(obj)->oname, &modtab);
154 if (eqobjects(obj, modtab.htab[i]))
155 return;
156 modtab.htab[i] = obj;
157 }
158 #ifdef GETOBJ
159 else {
160 i = otndx(objptr(obj)->oname, &objtab);
161 objtab.htab[i] = obj;
162 }
163 #endif
164 for (i = 0; addobjnotify[i] != NULL; i++)
165 (*addobjnotify[i])(obj);
166 }
167
168
169 void
170 clearobjndx(void) /* clear object hash tables */
171 {
172 if (modtab.htab != NULL) {
173 free((void *)modtab.htab);
174 modtab.htab = NULL;
175 modtab.hsiz = 100;
176 }
177 if (objtab.htab != NULL) {
178 free((void *)objtab.htab);
179 objtab.htab = NULL;
180 objtab.hsiz = 100;
181 }
182 }
183
184
185 static int
186 nexthsiz( /* return next hash table size */
187 int oldsiz
188 )
189 {
190 static int hsiztab[] = {
191 251, 509, 1021, 2039, 4093, 8191, 16381, 0
192 };
193 int *hsp;
194
195 for (hsp = hsiztab; *hsp; hsp++)
196 if (*hsp > oldsiz)
197 return(*hsp);
198 return(oldsiz*2 + 1); /* not always prime */
199 }
200
201
202 static int
203 otndx( /* get object table index for name */
204 char *name,
205 struct ohtab *tab
206 )
207 {
208 OBJECT *oldhtab;
209 int hval, i;
210 int ndx;
211
212 if (tab->htab == NULL) { /* new table */
213 tab->hsiz = nexthsiz(tab->hsiz);
214 tab->htab = (OBJECT *)malloc(tab->hsiz*sizeof(OBJECT));
215 if (tab->htab == NULL)
216 error(SYSTEM, "out of memory in otndx");
217 ndx = tab->hsiz;
218 while (ndx--) /* empty it */
219 tab->htab[ndx] = OVOID;
220 }
221 /* look up object */
222 hval = shash(name);
223 tryagain:
224 for (i = 0; i < tab->hsiz; i++) {
225 ndx = (hval + (unsigned long)i*i) % tab->hsiz;
226 if (tab->htab[ndx] == OVOID ||
227 !strcmp(objptr(tab->htab[ndx])->oname, name))
228 return(ndx);
229 }
230 /* table is full, reallocate */
231 oldhtab = tab->htab;
232 ndx = tab->hsiz;
233 tab->htab = NULL;
234 while (ndx--)
235 if (oldhtab[ndx] != OVOID) {
236 i = otndx(objptr(oldhtab[ndx])->oname, tab);
237 tab->htab[i] = oldhtab[ndx];
238 }
239 free((void *)oldhtab);
240 goto tryagain; /* should happen only once! */
241 }
