| 1 |
/* RCSid $Id: mesh.h,v 2.7 2003/06/26 00:58:09 schorsch Exp $ */
| 2 |
| 3 |
* Header for compact triangle mesh geometry
| 4 |
| 5 |
* Include after standard.h, object.h and octree.h
| 6 |
| 7 |
#ifndef _RAD_MESH_H_
| 8 |
#define _RAD_MESH_H_
| 9 |
#ifdef __cplusplus
| 10 |
extern "C" {
| 11 |
#endif
| 12 |
| 13 |
#include "lookup.h"
| 14 |
| 15 |
#ifndef BYTE
| 16 |
#define BYTE unsigned char
| 17 |
#endif
| 18 |
| 19 |
| 20 |
* Vertex space is minimized without compromising accuracy by using a
| 21 |
* 4-byte unsigned int to indicate position in the enclosing octree cube.
| 22 |
* The same trick is used for any local (u,v) coordinates, whose limits
| 23 |
* are recorded separately in the parent MESH structure. The uvlimit's
| 24 |
* in the MESH structure are set such that (0,0) is out of range, so
| 25 |
* we use this to indicate an unspecified local coordinate.
| 26 |
* A vertex normal, if specified, is stored in a single 4-byte
| 27 |
* integer using the codec in dircode.c. The encodedir() function
| 28 |
* never generates 0, so we can use this for unspecified normals.
| 29 |
| 30 |
* Vertex ID's are encoded using the bottom 8 bits of a 4-byte integer
| 31 |
* to index a vertex in a patch indicated by the 22 bits above (8-29).
| 32 |
* For triangle ID's, the top 22 bits (10-31) indicate the patch, and
| 33 |
* the bit 9 (0x200) indicates whether the triangle joins patches.
| 34 |
* If not, then the bottom 9 bits index into the local PTri array.
| 35 |
* If it's a joiner, then the 8th bit indicates whether the triangle joins
| 36 |
* two patches, in which case the bottom 8 bits index the PJoin2 array.
| 37 |
* Otherwise, the bottom 8 bits index the PJoin1 array.
| 38 |
| 39 |
* These shenanigans minimize vertex reference memory requirements
| 40 |
* in compiled mesh structures, where the octree leaves contain sets
| 41 |
* of triangle ID's rather than the more usual objects. It seems like
| 42 |
* a lot of effort, but it can reduce mesh storage by a factor of 3
| 43 |
* or more. This is important, as the whole point is to model very
| 44 |
* complicated geometry with this structure, and memory is the main
| 45 |
* limitation.
| 46 |
| 47 |
| 48 |
/* A triangle mesh patch */
| 49 |
typedef struct {
| 50 |
uint32 (*xyz)[3]; /* up to 256 patch vertices */
| 51 |
int32 *norm; /* vertex normals */
| 52 |
uint32 (*uv)[2]; /* vertex local coordinates */
| 53 |
struct PTri {
| 54 |
BYTE v1, v2, v3; /* local vertices */
| 55 |
} *tri; /* local triangles */
| 56 |
short solemat; /* sole material */
| 57 |
int16 *trimat; /* or local material indices */
| 58 |
struct PJoin1 {
| 59 |
int32 v1j; /* non-local vertex */
| 60 |
int16 mat; /* material index */
| 61 |
BYTE v2, v3; /* local vertices */
| 62 |
} *j1tri; /* joiner triangles */
| 63 |
struct PJoin2 {
| 64 |
int32 v1j, v2j; /* non-local vertices */
| 65 |
| 66 |
BYTE v3; /* local vertex */
| 67 |
} *j2tri; /* double joiner triangles */
| 68 |
short nverts; /* vertex count */
| 69 |
short ntris; /* triangle count */
| 70 |
short nj1tris; /* joiner triangle count */
| 71 |
short nj2tris; /* double joiner triangle count */
| 72 |
} MESHPATCH;
| 73 |
| 74 |
/* A loaded mesh */
| 75 |
typedef struct mesh {
| 76 |
char *name; /* mesh file name */
| 77 |
int nref; /* reference count */
| 78 |
int ldflags; /* what we've loaded */
| 79 |
CUBE mcube; /* bounds and octree */
| 80 |
RREAL uvlim[2][2]; /* local coordinate extrema */
| 81 |
OBJECT mat0; /* base material index */
| 82 |
OBJECT nmats; /* number of materials */
| 83 |
MESHPATCH *patch; /* mesh patch list */
| 84 |
int npatches; /* number of mesh patches */
| 85 |
OBJREC *pseudo; /* mesh pseudo objects */
| 86 |
LUTAB lut; /* vertex lookup table */
| 87 |
struct mesh *next; /* next mesh in list */
| 88 |
} MESH;
| 89 |
| 90 |
/* A mesh instance */
| 91 |
typedef struct {
| 92 |
FULLXF x; /* forward and backward transforms */
| 93 |
MESH *msh; /* mesh object reference */
| 94 |
} MESHINST;
| 95 |
| 96 |
/* vertex flags */
| 97 |
#define MT_V 01
| 98 |
#define MT_N 02
| 99 |
#define MT_UV 04
| 100 |
#define MT_ALL 07
| 101 |
| 102 |
/* A mesh vertex */
| 103 |
typedef struct {
| 104 |
int fl; /* setting flags */
| 105 |
FVECT v; /* vertex location */
| 106 |
FVECT n; /* vertex normal */
| 107 |
RREAL uv[2]; /* local coordinates */
| 108 |
} MESHVERT;
| 109 |
| 110 |
/* mesh format identifier */
| 111 |
#define MESHFMT "Radiance_tmesh"
| 112 |
/* magic number for mesh files */
| 113 |
#define MESHMAGIC ( 1 *MAXOBJSIZ+311) /* increment first value */
| 114 |
| 115 |
| 116 |
extern MESH *getmesh(char *mname, int flags);
| 117 |
extern MESHINST *getmeshinst(OBJREC *o, int flags);
| 118 |
extern int getmeshtrivid(int32 tvid[3], OBJECT *mo,
| 119 |
MESH *mp, OBJECT ti);
| 120 |
extern int getmeshvert(MESHVERT *vp, MESH *mp, int32 vid, int what);
| 121 |
extern int getmeshtri(MESHVERT tv[3], OBJECT *mo,
| 122 |
MESH *mp, OBJECT ti, int what);
| 123 |
extern OBJREC *getmeshpseudo(MESH *mp, OBJECT mo);
| 124 |
extern int32 addmeshvert(MESH *mp, MESHVERT *vp);
| 125 |
extern OBJECT addmeshtri(MESH *mp, MESHVERT tv[3], OBJECT mo);
| 126 |
extern char *checkmesh(MESH *mp);
| 127 |
extern void printmeshstats(MESH *ms, FILE *fp);
| 128 |
extern void freemesh(MESH *ms);
| 129 |
extern void freemeshinst(OBJREC *o);
| 130 |
extern void readmesh(MESH *mp, char *path, int flags);
| 131 |
extern void writemesh(MESH *mp, FILE *fp);
| 132 |
| 133 |
| 134 |
#ifdef __cplusplus
| 135 |
| 136 |
#endif
| 137 |
#endif /* _RAD_MESH_H_ */
| 138 |
