| 1 |
greg |
2.15 |
/* RCSid $Id: mesh.h,v 2.14 2011/05/20 02:06:38 greg Exp $ */ |
| 2 |
greg |
2.1 |
| 3 |
 * Header for compact triangle mesh geometry |
| 4 |
| 5 |
 *  Include after standard.h, object.h and octree.h |
| 6 |
| 7 |
schorsch |
2.5 |
#ifndef _RAD_MESH_H_ |
| 8 |
#define _RAD_MESH_H_ |
| 9 |
schorsch |
2.9 |
| 10 |
#include "lookup.h" |
| 11 |
| 12 |
schorsch |
2.5 |
#ifdef __cplusplus |
| 13 |
extern "C" { |
| 14 |
#endif |
| 15 |
greg |
2.3 |
| 16 |
greg |
2.14 |
#ifndef uby8 |
| 17 |
#define uby8    unsigned char |
| 18 |
greg |
2.1 |
#endif |
| 19 |
| 20 |
| 21 |
 * Vertex space is minimized without compromising accuracy by using a |
| 22 |
 * 4-byte unsigned int to indicate position in the enclosing octree cube. |
| 23 |
 * The same trick is used for any local (u,v) coordinates, whose limits |
| 24 |
 * are recorded separately in the parent MESH structure.  The uvlimit's |
| 25 |
 * in the MESH structure are set such that (0,0) is out of range, so |
| 26 |
 * we use this to indicate an unspecified local coordinate. |
| 27 |
 * A vertex normal, if specified, is stored in a single 4-byte |
| 28 |
 * integer using the codec in dircode.c.  The encodedir() function |
| 29 |
 * never generates 0, so we can use this for unspecified normals. |
| 30 |
| 31 |
 * Vertex ID's are encoded using the bottom 8 bits of a 4-byte integer |
| 32 |
greg |
2.2 |
 * to index a vertex in a patch indicated by the 22 bits above (8-29). |
| 33 |
greg |
2.13 |
 * For triangle ID's, the top 22 bits (10-31) indicate the parent patch, |
| 34 |
 * and the 10th bit (0x200) indicates whether the triangle joins patches. |
| 35 |
greg |
2.1 |
 * If not, then the bottom 9 bits index into the local PTri array. |
| 36 |
greg |
2.13 |
 * If it's a joiner, then the 9th bit indicates whether the triangle joins |
| 37 |
greg |
2.1 |
 * two patches, in which case the bottom 8 bits index the PJoin2 array. |
| 38 |
 * Otherwise, the bottom 8 bits index the PJoin1 array. |
| 39 |
| 40 |
 * These shenanigans minimize vertex reference memory requirements |
| 41 |
 * in compiled mesh structures, where the octree leaves contain sets  |
| 42 |
 * of triangle ID's rather than the more usual objects.  It seems like |
| 43 |
 * a lot of effort, but it can reduce mesh storage by a factor of 3 |
| 44 |
 * or more.  This is important, as the whole point is to model very |
| 45 |
 * complicated geometry with this structure, and memory is the main |
| 46 |
greg |
2.13 |
 * limitation.  (This representation is so efficient, that the octree |
| 47 |
 * structure ends up dominating memory for most compiled meshes.) |
| 48 |
greg |
2.1 |
| 49 |
| 50 |
/* A triangle mesh patch */ |
| 51 |
typedef struct { |
| 52 |
greg |
2.6 |
        uint32          (*xyz)[3];      /* up to 256 patch vertices */ |
| 53 |
        int32           *norm;          /* vertex normals */ |
| 54 |
greg |
2.12 |
        uint32          (*uv)[2];       /* vertex local coordinates */ |
| 55 |
greg |
2.1 |
        struct PTri { |
| 56 |
greg |
2.14 |
                uby8            v1, v2, v3;     /* local vertices */ |
| 57 |
greg |
2.1 |
        }               *tri;           /* local triangles */ |
| 58 |
greg |
2.3 |
        short           solemat;        /* sole material */ |
| 59 |
greg |
2.6 |
        int16           *trimat;        /* or local material indices */ |
| 60 |
greg |
2.1 |
        struct PJoin1 { |
| 61 |
greg |
2.6 |
                int32           v1j;            /* non-local vertex */ |
| 62 |
                int16           mat;            /* material index */ |
| 63 |
greg |
2.14 |
                uby8            v2, v3;         /* local vertices */ |
| 64 |
greg |
2.1 |
        }               *j1tri;         /* joiner triangles */ |
| 65 |
        struct PJoin2 { |
| 66 |
greg |
2.6 |
                int32           v1j, v2j;       /* non-local vertices */ |
| 67 |
| 68 |
greg |
2.14 |
                uby8            v3;             /* local vertex */ |
| 69 |
greg |
2.1 |
        }               *j2tri;         /* double joiner triangles */ |
| 70 |
        short           nverts;         /* vertex count */ |
| 71 |
greg |
2.10 |
        short           ntris;          /* local triangle count */ |
| 72 |
greg |
2.1 |
        short           nj1tris;        /* joiner triangle count */ |
| 73 |
        short           nj2tris;        /* double joiner triangle count */ |
| 74 |
} MESHPATCH; |
| 75 |
| 76 |
/* A loaded mesh */ |
| 77 |
typedef struct mesh { |
| 78 |
        char            *name;          /* mesh file name */ |
| 79 |
        int             nref;           /* reference count */ |
| 80 |
        int             ldflags;        /* what we've loaded */ |
| 81 |
        CUBE            mcube;          /* bounds and octree */ |
| 82 |
schorsch |
2.7 |
        RREAL           uvlim[2][2];    /* local coordinate extrema */ |
| 83 |
greg |
2.3 |
        OBJECT          mat0;           /* base material index */ |
| 84 |
        OBJECT          nmats;          /* number of materials */ |
| 85 |
greg |
2.13 |
        MESHPATCH       *patch;         /* allocated mesh patch array */ |
| 86 |
greg |
2.1 |
        int             npatches;       /* number of mesh patches */ |
| 87 |
greg |
2.3 |
        OBJREC          *pseudo;        /* mesh pseudo objects */ |
| 88 |
        LUTAB           lut;            /* vertex lookup table */ |
| 89 |
greg |
2.1 |
        struct mesh     *next;          /* next mesh in list */ |
| 90 |
} MESH; |
| 91 |
| 92 |
/* A mesh instance */ |
| 93 |
typedef struct { |
| 94 |
        FULLXF          x;              /* forward and backward transforms */ |
| 95 |
        MESH            *msh;           /* mesh object reference */ |
| 96 |
} MESHINST; |
| 97 |
| 98 |
                                /* vertex flags */ |
| 99 |
#define MT_V            01 |
| 100 |
#define MT_N            02 |
| 101 |
#define MT_UV           04 |
| 102 |
#define MT_ALL          07 |
| 103 |
| 104 |
/* A mesh vertex */ |
| 105 |
typedef struct { |
| 106 |
        int             fl;             /* setting flags */ |
| 107 |
        FVECT           v;              /* vertex location */ |
| 108 |
        FVECT           n;              /* vertex normal */ |
| 109 |
schorsch |
2.7 |
        RREAL           uv[2];          /* local coordinates */ |
| 110 |
greg |
2.1 |
} MESHVERT; |
| 111 |
| 112 |
                                /* mesh format identifier */ |
| 113 |
#define MESHFMT         "Radiance_tmesh" |
| 114 |
                                /* magic number for mesh files */ |
| 115 |
greg |
2.12 |
#define MESHMAGIC       ( 1 *MAXOBJSIZ+311)     /* increment first value */ |
| 116 |
greg |
2.1 |
| 117 |
| 118 |
extern MESH     *getmesh(char *mname, int flags); |
| 119 |
extern MESHINST *getmeshinst(OBJREC *o, int flags); |
| 120 |
greg |
2.15 |
extern int      nextmeshtri(OBJECT *tip, MESH *mp); |
| 121 |
greg |
2.6 |
extern int      getmeshtrivid(int32 tvid[3], OBJECT *mo, |
| 122 |
greg |
2.3 |
                                MESH *mp, OBJECT ti); |
| 123 |
greg |
2.6 |
extern int      getmeshvert(MESHVERT *vp, MESH *mp, int32 vid, int what); |
| 124 |
greg |
2.3 |
extern int      getmeshtri(MESHVERT tv[3], OBJECT *mo, |
| 125 |
                                MESH *mp, OBJECT ti, int what); |
| 126 |
extern OBJREC   *getmeshpseudo(MESH *mp, OBJECT mo); |
| 127 |
greg |
2.6 |
extern int32    addmeshvert(MESH *mp, MESHVERT *vp); |
| 128 |
greg |
2.3 |
extern OBJECT   addmeshtri(MESH *mp, MESHVERT tv[3], OBJECT mo); |
| 129 |
extern char     *checkmesh(MESH *mp); |
| 130 |
greg |
2.1 |
extern void     printmeshstats(MESH *ms, FILE *fp); |
| 131 |
extern void     freemesh(MESH *ms); |
| 132 |
extern void     freemeshinst(OBJREC *o); |
| 133 |
extern void     readmesh(MESH *mp, char *path, int flags); |
| 134 |
extern void     writemesh(MESH *mp, FILE *fp); |
| 135 |
| 136 |
schorsch |
2.5 |
| 137 |
| 138 |
| 139 |
#endif |
| 140 |
#endif /* _RAD_MESH_H_ */ |
