root/radiance/src/common/lookup.h
Fri Feb 18 00:40:25 2011 UTC (14 years, 8 months ago) by greg
CVS Tags: HEAD, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4, rad6R0
Changes since 2.14: +7 -8 lines
Diff to previous 2.14
Tue May 25 22:04:13 2004 UTC (21 years, 4 months ago) by greg
Changes since 2.13: +8 -10 lines
Diff to previous 2.13
Tue May 25 06:30:46 2004 UTC (21 years, 4 months ago) by greg
Diff to previous 2.12
Added argument for client data to lu_doall()
Sun Mar 28 20:33:12 2004 UTC (21 years, 6 months ago) by schorsch
Changes since 2.11: +12 -9 lines
Wed Jul 30 10:11:06 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 2.10: +10 -8 lines
Mon Jul 14 22:23:59 2003 UTC (22 years, 3 months ago) by schorsch
Fri Jun 27 06:53:21 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.8: +1 -4 lines
Fri Jun 6 16:38:47 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 2.7: +13 -13 lines
*** empty log message ***
Tue Feb 25 02:47:21 2003 UTC (22 years, 7 months ago) by greg
Changes since 2.6: +2 -57 lines
Sat Feb 22 02:07:22 2003 UTC (22 years, 7 months ago) by greg
Changes since 2.5: +72 -5 lines
Wed Sep 2 18:42:11 1998 UTC (27 years, 1 month ago) by gwlarson
Changes since 2.4: +13 -13 lines
changed lookup routines to use unsigned long hash values
Tue Jun 2 15:01:43 1998 UTC (27 years, 4 months ago) by gwlarson
Changes since 2.3: +7 -0 lines
added lu_doall() function to loop through table entries
Wed Sep 17 14:46:48 1997 UTC (28 years, 1 month ago) by gregl
undefined strcmp for systems (AIX) that define it as a macro
Thu Jul 7 14:02:31 1994 UTC (31 years, 3 months ago) by greg
added comment about reusing key field following lu_delete
Wed Jul 6 15:14:16 1994 UTC (31 years, 3 months ago) by greg
