| 1 | greg | 2.14 | /* RCSid $Id: lookup.h,v 2.13 2004/05/25 06:30:46 greg Exp $ */ |
| 2 | greg | 2.1 | /* |
| 3 |  |  | * Header file for general associative table lookup routines |
| 4 |  |  | */ |
| 5 | schorsch | 2.8 | #ifndef _RAD_LOOKUP_H_ |
| 6 |  |  | #define _RAD_LOOKUP_H_ |
| 7 | schorsch | 2.10 |  |
| 8 | schorsch | 2.8 | #ifdef __cplusplus |
| 9 |  |  | extern "C" { |
| 10 |  |  | #endif |
| 11 | greg | 2.6 |  |
| 12 | schorsch | 2.12 | typedef void lut_free_t(void *p); |
| 13 | greg | 2.14 | typedef unsigned long lut_hashf_t(const void *); |
| 14 |  |  | typedef int lut_keycmpf_t(const void *, const void *); |
| 15 | schorsch | 2.11 |  |
| 16 | greg | 2.1 | typedef struct { |
| 17 | gwlarson | 2.5 | char    *key;                   /* key name */ |
| 18 |  |  | unsigned long   hval;           /* key hash value (for efficiency) */ |
| 19 |  |  | char    *data;                  /* pointer to client data */ |
| 20 | greg | 2.1 | } LUENT; |
| 21 |  |  |  |
| 22 |  |  | typedef struct { |
| 23 | schorsch | 2.12 | lut_hashf_t *hashf;     /* key hash function */ |
| 24 |  |  | lut_keycmpf_t *keycmp;  /* key comparison function */ |
| 25 | schorsch | 2.11 | lut_free_t *freek;              /* free a key */ |
| 26 |  |  | lut_free_t *freed;              /* free the data */ |
| 27 | gwlarson | 2.5 | int     tsiz;                   /* current table size */ |
| 28 |  |  | LUENT   *tabl;                  /* table, if allocated */ |
| 29 |  |  | int     ndel;                   /* number of deleted entries */ |
| 30 | greg | 2.1 | } LUTAB; |
| 31 |  |  |  |
| 32 |  |  |  |
| 33 |  |  | /* |
| 34 |  |  | * The lu_init routine is called to initialize a table.  The number of |
| 35 |  |  | * elements passed is not a limiting factor, as a table can grow to |
| 36 |  |  | * any size permitted by memory.  However, access will be more efficient |
| 37 |  |  | * if this number strikes a reasonable balance between default memory use |
| 38 |  |  | * and the expected (minimum) table size.  The value returned is the |
| 39 |  |  | * actual allocated table size (or zero if there was insufficient memory). |
| 40 |  |  | * |
| 41 |  |  | * The hashf, keycmp, freek and freed member functions must be assigned |
| 42 |  |  | * separately.  If the hash value is sufficient to guarantee equality |
| 43 |  |  | * between keys, then the keycmp pointer may be NULL.  Otherwise, it |
| 44 |  |  | * should return 0 if the two passed keys match.  If it is not necessary |
| 45 |  |  | * (or possible) to free the key and/or data values, then the freek and/or |
| 46 |  |  | * freed member functions may be NULL. |
| 47 |  |  | * |
| 48 |  |  | * It isn't fully necessary to call lu_init to initialize the LUTAB structure. |
| 49 |  |  | * If tsiz is 0, then the first call to lu_find will allocate a minimal table. |
| 50 |  |  | * The LU_SINIT macro provides a convenient static declaration for character |
| 51 |  |  | * string keys. |
| 52 |  |  | * |
| 53 |  |  | * The lu_find routine returns the entry corresponding to the given |
| 54 |  |  | * key.  If the entry does not exist, the corresponding key field will |
| 55 |  |  | * be NULL.  If the entry has been previously deleted but not yet freed, |
| 56 |  |  | * then only the data field will be NULL.  It is the caller's |
| 57 |  |  | * responsibility to (allocate and) assign the key and data fields when |
| 58 |  |  | * creating a new entry.  The only case where lu_find returns NULL is when |
| 59 |  |  | * the system has run out of memory. |
| 60 |  |  | * |
| 61 |  |  | * The lu_delete routine frees an entry's data (if any) by calling |
| 62 |  |  | * the freed member function, but does not free the key field.  This |
| 63 |  |  | * will be freed later during (or instead of) table reallocation. |
| 64 | greg | 2.2 | * It is therefore an error to reuse or do anything with the key |
| 65 |  |  | * field after calling lu_delete. |
| 66 | greg | 2.1 | * |
| 67 | gwlarson | 2.4 | * The lu_doall routine loops through every filled table entry, calling |
| 68 |  |  | * the given function once on each entry.  If a NULL pointer is passed |
| 69 |  |  | * for this function, then lu_doall simply returns the total number of |
| 70 |  |  | * active entries.  Otherwise, it returns the sum of all the function |
| 71 |  |  | * evaluations. |
| 72 |  |  | * |
| 73 | greg | 2.1 | * The lu_done routine calls the given free function once for each |
| 74 |  |  | * assigned table entry (i.e. each entry with an assigned key value). |
| 75 |  |  | * The user must define these routines to free the key and the data |
| 76 |  |  | * in the LU_TAB structure.  The final action of lu_done is to free the |
| 77 |  |  | * allocated table itself. |
| 78 |  |  | */ |
| 79 | greg | 2.6 |  |
| 80 | greg | 2.14 | typedef int lut_doallf_t(const LUENT *e, void *p); |
| 81 | schorsch | 2.12 |  |
| 82 |  |  | extern lut_keycmpf_t lu_strcmp; |
| 83 | greg | 2.6 | extern int      lu_init(LUTAB *tbl, int nel); |
| 84 | greg | 2.14 | extern unsigned long    lu_shash(const void *s); |
| 85 |  |  | extern LUENT    *lu_find(LUTAB *tbl, const char *key); |
| 86 |  |  | extern void     lu_delete(LUTAB *tbl, const char *key); |
| 87 |  |  | extern int      lu_doall(const LUTAB *tbl, lut_doallf_t *f, void *p); |
| 88 | greg | 2.6 | extern void     lu_done(LUTAB *tbl); |
| 89 |  |  |  |
| 90 | schorsch | 2.12 | #define LU_SINIT(fk,fd) {lu_shash,lu_strcmp,fk,fd,0,NULL,0} |
| 91 | schorsch | 2.8 |  |
| 92 |  |  | #ifdef __cplusplus |
| 93 |  |  | } |
| 94 | greg | 2.6 | #endif |
| 95 | schorsch | 2.8 | #endif /* _RAD_LOOKUP_H_ */ |
| 96 |  |  |  |
