root/radiance/src/common/header.c
Revision: 2.42
Committed: Thu Mar 3 15:43:04 2022 UTC (3 years, 7 months ago) by greg
Changes since 2.41: +5 -3 lines
feat: Added alignment times to fputformat()
2 static const char RCSid[] = "$Id: header.c,v 2.41 2022/03/03 03:55:12 greg Exp $";
5 * header.c - routines for reading and writing information headers.
6 *
7 * Externals declared in rtio.h
8 *
9 * newheader(t,fp) start new information header identified by string t
10 * headidval(r,s) copy header identifier value in s to r
11 * dateval(t,s) get capture date value as UTC
12 * gmtval(t,s) get GMT as UTC
13 * fputdate(t,fp) put out the given UTC
14 * fputnow(fp) put out the current date and time
15 * printargs(ac,av,fp) print an argument list to fp, followed by '\n'
16 * formatval(r,s) copy the format value in s to r
17 * fputformat(s,fp) write "FORMAT=%s" to fp
18 * nativebigendian() are we native on big-endian machine?
19 * isbigendian(s) header line matches "BigEndian=1" (-1 if irrelevant)
20 * fputendian(fp) write native endianness in BigEndian= line
21 * getheader(fp,f,p) read header from fp, calling f(s,p) on each line
22 * globmatch(pat, str) check for glob match of str against pat
23 * checkheader(i,p,o) check header format from i against p and copy to o
24 *
25 * To copy header from input to output, use getheader(fin, fputs, fout)
26 */
27
28 #include "copyright.h"
29
30 #include <ctype.h>
31
32 #include "tiff.h" /* for int32 */
33 #include "rtio.h"
34 #include "resolu.h"
35
36 #define MAXLINE 2048
37
38 extern time_t timegm(struct tm *tm);
39
40 const char HDRSTR[] = "#?"; /* information header magic number */
41
42 const char FMTSTR[] = "FORMAT="; /* format identifier */
43
44 const char TMSTR[] = "CAPDATE="; /* capture date identifier */
45 const char GMTSTR[] = "GMT="; /* GMT identifier */
46
47 const char BIGEND[] = "BigEndian="; /* big-endian variable */
48
49 static gethfunc mycheck;
50
51
52 void
53 newheader( /* identifying line of information header */
54 const char *s,
55 FILE *fp
56 )
57 {
58 fputs(HDRSTR, fp);
59 fputs(s, fp);
60 fputc('\n', fp);
61 }
62
63
64 int
65 headidval( /* get header id (return true if is id) */
66 char *r,
67 const char *s
68 )
69 {
70 const char *cp = HDRSTR;
71
72 while (*cp) if (*cp++ != *s++) return(0);
73 if (r == NULL) return(1);
74 while (*s && !isspace(*s)) *r++ = *s++;
75 *r = '\0';
76 return(1);
77 }
78
79
80 int
81 dateval( /* convert capture date line to UTC */
82 time_t *tloc,
83 const char *s
84 )
85 {
86 struct tm tms;
87 const char *cp = TMSTR;
88
89 while (*cp) if (*cp++ != *s++) return(0);
90 while (isspace(*s)) s++;
91 if (!*s) return(0);
92 if (sscanf(s, "%d:%d:%d %d:%d:%d",
93 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
94 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
95 return(0);
96 if (tloc == NULL)
97 return(1);
98 tms.tm_mon--;
99 tms.tm_year -= 1900;
100 tms.tm_isdst = -1; /* ask mktime() to figure out DST */
101 *tloc = mktime(&tms);
102 return(1);
103 }
104
105
106 int
107 gmtval( /* convert GMT date line to UTC */
108 time_t *tloc,
109 const char *s
110 )
111 {
112 struct tm tms;
113 const char *cp = GMTSTR;
114
115 while (*cp) if (*cp++ != *s++) return(0);
116 while (isspace(*s)) s++;
117 if (!*s) return(0);
118 if (sscanf(s, "%d:%d:%d %d:%d:%d",
119 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
120 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
121 return(0);
122 if (tloc == NULL)
123 return(1);
124 tms.tm_mon--;
125 tms.tm_year -= 1900;
126 *tloc = timegm(&tms);
127 return(1);
128 }
129
130
131 void
132 fputdate( /* write out the given time value (local & GMT) */
133 time_t tv,
134 FILE *fp
135 )
136 {
137 struct tm *tms;
138
139 tms = localtime(&tv);
140 if (tms != NULL)
141 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR,
142 tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday,
143 tms->tm_hour, tms->tm_min, tms->tm_sec);
144 tms = gmtime(&tv);
145 if (tms != NULL)
146 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", GMTSTR,
147 tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday,
148 tms->tm_hour, tms->tm_min, tms->tm_sec);
149 }
150
151
152 void
153 fputnow( /* write out the current time */
154 FILE *fp
155 )
156 {
157 time_t tv;
158 time(&tv);
159 fputdate(tv, fp);
160 }
161
162
163 void
164 printargs( /* print arguments to a file */
165 int ac,
166 char **av,
167 FILE *fp
168 )
169 {
170 #if defined(_WIN32) || defined(_WIN64)
171 extern char *fixargv0(char *arg0);
172 char myav0[128];
173 /* clean up Windows executable path */
174 if (ac-- <= 0) return;
175 fputs(fixargv0(strcpy(myav0, *av++)), fp);
176 fputc(ac ? ' ' : '\n', fp);
177 #endif
178 while (ac-- > 0) {
179 fputword(*av++, fp);
180 fputc(ac ? ' ' : '\n', fp);
181 }
182 }
183
184
185 int
186 formatval( /* get format value (return true if format) */
187 char fmt[MAXFMTLEN],
188 const char *s
189 )
190 {
191 const char *cp = FMTSTR;
192 char *r = fmt;
193
194 while (*cp) if (*cp++ != *s++) return(0);
195 while (isspace(*s)) s++;
196 if (!*s) return(0);
197 if (r == NULL) return(1);
198 do
199 *r++ = *s++;
200 while (*s && !isspace(*s) && r-fmt < MAXFMTLEN-1);
201 *r = '\0';
202 return(1);
203 }
204
205
206 void
207 fputformat( /* put out a format value */
208 const char *s,
209 FILE *fp
210 )
211 {
212 int align = 0;
213
214 fputs(FMTSTR, fp);
215 fputs(s, fp);
216 /* pad to align binary type for mmap() */
217 if (!strncmp(s, "16-bit", 6))
218 align = 2;
219 else if (!strcmp(s, "float") || !strncmp(s, "32-bit", 6))
220 align = 4;
221 else if (!strcmp(s, "double") || !strncmp(s, "64-bit", 6))
222 align = 8;
223 if (align) {
224 long pos = ftell(fp);
225 if (pos >= 0) {
226 pos = (pos + 2) % align;
227 if (pos) align -= pos;
228 else align = 0;
229 } else
230 align = 0;
231 }
232 while (align-- > 0)
233 putc(' ', fp);
234 fputc('\n', fp);
235 }
236
237
238 int
239 nativebigendian() /* are we native on a big-endian machine? */
240 {
241 union { int32 i; char c[4]; } u;
242
243 u.i = 1;
244
245 return(u.c[0] == 0);
246 }
247
248
249 int
250 isbigendian( /* header line says "BigEndian=1" (-1 if irrelevant) */
251 const char *s
252 )
253 {
254 const char *be = BIGEND;
255
256 while ((*s != '\0') & (*be != '=') && *s++ == *be)
257 ++be;
258 if (*be != '=')
259 return(-1); /* irrelevant */
260 while (isspace(*s))
261 s++;
262 if (*s++ != '=')
263 return(-1);
264 while (isspace(*s))
265 s++;
266 return(*s == '1');
267 }
268
269
270 void
271 fputendian( /* write native endianness in BigEndian= line */
272 FILE *fp
273 )
274 {
275 fputs(BIGEND, fp);
276 if (nativebigendian())
277 fputs("1\n", fp);
278 else
279 fputs("0\n", fp);
280 }
281
282
283 int
284 getheader( /* get header from file */
285 FILE *fp,
286 gethfunc *f,
287 void *p
288 )
289 {
290 int rtotal = 0;
291 char buf[MAXLINE];
292 int firstc = fgetc(fp);
293
294 if (!isprint(firstc))
295 return(-1); /* messed up */
296 ungetc(firstc, fp);
297 for ( ; ; ) {
298 int rval = 0;
299 buf[MAXLINE-2] = '\n';
300 if (fgets(buf, MAXLINE, fp) == NULL)
301 return(-1);
302 if (buf[buf[0]=='\r'] == '\n') /* end of header? */
303 return(rtotal);
304 if (buf[MAXLINE-2] != '\n') {
305 ungetc(buf[MAXLINE-2], fp); /* prevent false end */
306 buf[MAXLINE-2] = '\0';
307 }
308 if (f != NULL && (rval = (*f)(buf, p)) < 0)
309 return(-1);
310 rtotal += rval;
311 }
312 }
313
314
315 struct check {
316 FILE *fp;
317 char fs[MAXFMTLEN];
318 };
319
320
321 static int
322 mycheck( /* check a header line for format info. */
323 char *s,
324 void *cp
325 )
326 {
327 struct check *scp = (struct check *)cp;
328
329 if (!formatval(scp->fs, s) && scp->fp != NULL)
330 return(fputs(s, scp->fp));
331
332 return(0);
333 }
334
335
336 int
337 globmatch( /* check for match of s against pattern p */
338 const char *p,
339 const char *s
340 )
341 {
342 int setmatch;
343
344 do {
345 switch (*p) {
346 case '?': /* match any character */
347 if (!*s++)
348 return(0);
349 break;
350 case '*': /* match any string */
351 while (p[1] == '*') p++;
352 do
353 if ( (p[1]=='?') | (p[1]==*s) &&
354 globmatch(p+1,s) )
355 return(1);
356 while (*s++);
357 return(0);
358 case '[': /* character set */
359 setmatch = *s == *++p;
360 if (!*p)
361 return(0);
362 while (*++p != ']') {
363 if (!*p)
364 return(0);
365 if (*p == '-') {
366 setmatch += (p[-1] <= *s && *s <= p[1]);
367 if (!*++p)
368 break;
369 } else
370 setmatch += (*p == *s);
371 }
372 if (!setmatch)
373 return(0);
374 s++;
375 break;
376 case '\\': /* literal next */
377 p++;
378 /* fall through */
379 default: /* normal character */
380 if (*p != *s)
381 return(0);
382 s++;
383 break;
384 }
385 } while (*p++);
386 return(1);
387 }
388
389
390 /*
391 * Checkheader(fin,fmt,fout) returns a value of 1 if the input format
392 * matches the specification in fmt, 0 if no input format was found,
393 * and -1 if the input format does not match or there is an
394 * error reading the header. If fmt is empty, then -1 is returned
395 * if any input format is found (or there is an error), and 0 otherwise.
396 * If fmt contains any '*' or '?' characters, then checkheader
397 * does wildcard expansion and copies a matching result into fmt.
398 * Be sure that fmt is big enough to hold the match in such cases,
399 * and that it is not a static, read-only string!
400 * The input header (minus any format lines) is copied to fout
401 * if fout is not NULL.
402 */
403
404 int
405 checkheader(
406 FILE *fin,
407 char fmt[MAXFMTLEN],
408 FILE *fout
409 )
410 {
411 struct check cdat;
412 char *cp;
413
414 cdat.fp = fout;
415 cdat.fs[0] = '\0';
416 if (getheader(fin, mycheck, &cdat) < 0)
417 return(-1);
418 if (!cdat.fs[0])
419 return(0);
420 for (cp = fmt; *cp; cp++) /* check for globbing */
421 if ((*cp == '?') | (*cp == '*')) {
422 if (globmatch(fmt, cdat.fs)) {
423 strcpy(fmt, cdat.fs);
424 return(1);
425 } else
426 return(-1);
427 }
428 return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */
429 }
