root/radiance/src/common/getpath.c
Revision: 2.9
Committed: Sat Feb 22 02:07:22 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.8: +60 -4 lines
5 * getpath.c - function to search for file in a list of directories
6 *
7 * External symbols declared in standard.h
8 */
9
10 /* ====================================================================
11 * The Radiance Software License, Version 1.0
12 *
13 * Copyright (c) 1990 - 2002 The Regents of the University of California,
14 * through Lawrence Berkeley National Laboratory. All rights reserved.
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 *
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 *
23 * 2. Redistributions in binary form must reproduce the above copyright
24 * notice, this list of conditions and the following disclaimer in
25 * the documentation and/or other materials provided with the
26 * distribution.
27 *
28 * 3. The end-user documentation included with the redistribution,
29 * if any, must include the following acknowledgment:
30 * "This product includes Radiance software
31 * (http://radsite.lbl.gov/)
32 * developed by the Lawrence Berkeley National Laboratory
33 * (http://www.lbl.gov/)."
34 * Alternately, this acknowledgment may appear in the software itself,
35 * if and wherever such third-party acknowledgments normally appear.
36 *
37 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
38 * and "The Regents of the University of California" must
39 * not be used to endorse or promote products derived from this
40 * software without prior written permission. For written
41 * permission, please contact [email protected].
42 *
43 * 5. Products derived from this software may not be called "Radiance",
44 * nor may "Radiance" appear in their name, without prior written
45 * permission of Lawrence Berkeley National Laboratory.
46 *
47 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
48 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
49 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
50 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
51 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
52 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
53 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
54 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
55 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
56 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
57 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
58 * SUCH DAMAGE.
59 * ====================================================================
60 *
61 * This software consists of voluntary contributions made by many
62 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
63 * information on Lawrence Berkeley National Laboratory, please see
64 * <http://www.lbl.gov/>.
65 */
66
67 #include "standard.h"
68
69 #include "paths.h"
70
71 #ifndef NIX
72 #include <pwd.h>
73 extern struct passwd *getpwnam();
74 #endif
75
76
77 char *
78 getpath(fname, searchpath, mode) /* expand fname, return full path */
79 register char *fname;
80 register char *searchpath;
81 int mode;
82 {
83 #ifndef NIX
84 struct passwd *pwent;
85 #endif
86 static char pname[MAXPATH];
87 register char *cp;
88
89 if (fname == NULL)
90 return(NULL);
91
92 pname[0] = '\0'; /* check for full specification */
93 switch (*fname) {
94 CASEDIRSEP: /* relative to root */
95 case '.': /* relative to cwd */
96 strcpy(pname, fname);
97 break;
98 #ifndef NIX
99 case '~': /* relative to home directory */
100 fname++;
101 if (*fname == '\0' || ISDIRSEP(*fname)) { /* ours */
102 if ((cp = getenv("HOME")) == NULL)
103 return(NULL);
104 strcpy(pname, cp);
105 strcat(pname, fname);
106 break;
107 }
108 cp = pname; /* user */
109 do
110 *cp++ = *fname++;
111 while (*fname && !ISDIRSEP(*fname));
112 *cp = '\0';
113 if ((pwent = getpwnam(pname)) == NULL)
114 return(NULL);
115 strcpy(pname, pwent->pw_dir);
116 strcat(pname, fname);
117 break;
118 #endif
119 }
120 if (pname[0]) /* got it, check access if search requested */
121 return(searchpath==NULL||access(pname,mode)==0 ? pname : NULL);
122
123 if (searchpath == NULL) { /* don't search */
124 strcpy(pname, fname);
125 return(pname);
126 }
127 /* check search path */
128 do {
129 cp = pname;
130 while (*searchpath && (*cp = *searchpath++) != PATHSEP)
131 cp++;
132 if (cp > pname && !ISDIRSEP(cp[-1]))
133 *cp++ = DIRSEP;
134 strcpy(cp, fname);
135 if (access(pname, mode) == 0) /* file accessable? */
136 return(pname);
137 } while (*searchpath);
138 /* not found */
139 return(NULL);
140 }
