| 1 |
#ifndef lint |
| 2 |
static const char RCSid[] = "$Id: getpath.c,v 2.16 2003/11/14 17:22:06 schorsch Exp $"; |
| 3 |
#endif |
| 4 |
| 5 |
* getpath.c - function to search for file in a list of directories |
| 6 |
| 7 |
* External symbols declared in standard.h |
| 8 |
| 9 |
| 10 |
#include "copyright.h" |
| 11 |
| 12 |
#include <string.h> |
| 13 |
#include <ctype.h> |
| 14 |
| 15 |
#include "rtio.h" |
| 16 |
#include "paths.h" |
| 17 |
| 18 |
| 19 |
#ifdef _WIN32 |
| 20 |
static char * |
| 21 |
core_getpath /* wrapped below: expand fname, return full path */ |
| 22 |
#else |
| 23 |
char * |
| 24 |
getpath /* expand fname, return full path */ |
| 25 |
#endif |
| 26 |
| 27 |
register char *fname, |
| 28 |
register char *searchpath, |
| 29 |
int mode |
| 30 |
| 31 |
| 32 |
static char pname[PATH_MAX]; |
| 33 |
char uname[512]; |
| 34 |
register char *cp; |
| 35 |
int i; |
| 36 |
| 37 |
if (fname == NULL) { return(NULL); } |
| 38 |
| 39 |
pname[0] = '\0'; /* check for full specification */ |
| 40 |
| 41 |
if (ISABS(fname)) { /* absolute path */ |
| 42 |
strncpy(pname, fname, sizeof(pname)-1); |
| 43 |
} else { |
| 44 |
switch (*fname) { |
| 45 |
case '.': /* relative to cwd */ |
| 46 |
| 47 |
break; |
| 48 |
case '~': /* relative to home directory */ |
| 49 |
fname++; |
| 50 |
cp = uname; |
| 51 |
for (i=0;i<sizeof(uname)&&*fname!='\0'&&!ISDIRSEP(*fname);i++) |
| 52 |
*cp++ = *fname++; |
| 53 |
*cp = '\0'; |
| 54 |
cp = gethomedir(uname, pname, sizeof(pname)); |
| 55 |
if(cp == NULL) return NULL; |
| 56 |
strncat(pname, fname, sizeof(pname)-strlen(pname)-1); |
| 57 |
break; |
| 58 |
| 59 |
| 60 |
if (pname[0]) /* got it, check access if search requested */ |
| 61 |
return(searchpath==NULL||access(pname,mode)==0 ? pname : NULL); |
| 62 |
| 63 |
if (searchpath == NULL) { /* don't search */ |
| 64 |
| 65 |
return(pname); |
| 66 |
| 67 |
/* check search path */ |
| 68 |
do { |
| 69 |
cp = pname; |
| 70 |
while (*searchpath && (*cp = *searchpath++) != PATHSEP) { |
| 71 |
cp++; |
| 72 |
| 73 |
if (cp > pname && !ISDIRSEP(cp[-1])) { |
| 74 |
*cp++ = DIRSEP; |
| 75 |
| 76 |
strncpy(cp, fname, sizeof(pname)-strlen(pname)-1); |
| 77 |
if (access(pname, mode) == 0) /* file accessable? */ |
| 78 |
return(pname); |
| 79 |
} while (*searchpath); |
| 80 |
/* not found */ |
| 81 |
return(NULL); |
| 82 |
| 83 |
| 84 |
| 85 |
#ifdef _WIN32 |
| 86 |
/* This is a wrapper around the above, "emulating" access mode X_OK, |
| 87 |
which is not supported on Windows. |
| 88 |
If we see X_OK and the filename has no extension, then we'll remove |
| 89 |
the X_OK from the mode, append ".exe" to the file name, and search |
| 90 |
with the resulting string. If that fails, we'll try again with ".bat". |
| 91 |
Theoretically, we might still not have execute rights on a file we find |
| 92 |
like this, but that's rare enough not to be worth checking the ACLs. |
| 93 |
| 94 |
char * |
| 95 |
getpath( /* expand fname, return full path */ |
| 96 |
register char *ffname, |
| 97 |
| 98 |
int mode |
| 99 |
| 100 |
| 101 |
| 102 |
char fname[PATH_MAX]; |
| 103 |
| 104 |
if (ffname == NULL) |
| 105 |
return(NULL); |
| 106 |
| 107 |
/* if we have a dot in the string, we assume there is a file name |
| 108 |
extension present */ |
| 109 |
/* XXX We'd better test for .exe/.bat/.etc explicitly */ |
| 110 |
if (!(mode & X_OK) || (strrchr(ffname, '.') != NULL)) { |
| 111 |
return core_getpath(ffname, searchpath, mode); |
| 112 |
| 113 |
| 114 |
/* We're looking for an executable, Windows doesn't have X_OK. */ |
| 115 |
mode &= ~X_OK; |
| 116 |
/* Append .exe */ |
| 117 |
strncpy(fname, ffname, sizeof(fname)-5); |
| 118 |
strcat(fname, ".exe"); |
| 119 |
cp = core_getpath(fname, searchpath, mode); |
| 120 |
if (cp != NULL) return cp; |
| 121 |
| 122 |
/* Try with .bat this time... */ |
| 123 |
| 124 |
strcat(fname, ".bat"); |
| 125 |
| 126 |
return cp; |
| 127 |
| 128 |
#endif /* _WIN32 */ |
| 129 |
| 130 |
| 131 |
#ifdef TEST_MODULE |
| 132 |
int main() |
| 133 |
| 134 |
char * fp; |
| 135 |
char fmt[] = "%15s %-10s %s: %s\n"; |
| 136 |
| 137 |
fp = getpath("rayinit.cal", getenv("RAYPATH"), R_OK); |
| 138 |
printf(fmt, "rayinit.cal", "RAYPATH", "R_OK", fp); |
| 139 |
fp = getpath("mkillum", getenv("PATH"), X_OK); |
| 140 |
printf(fmt, "mkillum", "PATH", "X_OK", fp); |
| 141 |
fp = getpath("/", getenv("PATH"), W_OK); |
| 142 |
printf(fmt, "/", "PATH", "W_OK", fp); |
| 143 |
fp = getpath("~", getenv("PATH"), F_OK); |
| 144 |
printf(fmt, "~", "PATH", "F_OK", fp); |
| 145 |
printf("Undefining HOME and HOMEPATH\n"); |
| 146 |
unsetenv("HOME"); |
| 147 |
unsetenv("HOMEPATH"); |
| 148 |
| 149 |
| 150 |
fp = getpath("~lp/blah", getenv("PATH"), F_OK); |
| 151 |
printf(fmt, "~lp/blah", "PATH", "F_OK", fp); |
| 152 |
| 153 |
#endif |
| 154 |
