| 1 |
greg |
2.2 |
/* RCSid $Id$ */ |
| 2 |
greg |
2.1 |
| 3 |
**      Author: Christian Reetz ([email protected]) |
| 4 |
| 5 |
#ifndef __G3VECTOR_H |
| 6 |
#define __G3VECTOR_H |
| 7 |
| 8 |
#ifdef __cplusplus |
| 9 |
extern "C" { |
| 10 |
#endif |
| 11 |
| 12 |
| 13 |
#include <stdio.h> |
| 14 |
| 15 |
#include "gbasic.h" |
| 16 |
#include "fvect.h" |
| 17 |
| 18 |
typedef g3Float*        g3Vec; |
| 19 |
| 20 |
#define g3v_angle(v1,v2)        (acos(g3v_dot((v1),(v2)))) |
| 21 |
| 22 |
| 23 |
g3Vec   g3v_create(); |
| 24 |
void    g3v_free(g3Vec v); |
| 25 |
g3Vec   g3v_copy(g3Vec dest,g3Vec src); |
| 26 |
g3Vec   g3v_zero(g3Vec v); |
| 27 |
| 28 |
g3Vec   g3v_set(g3Vec v,g3Float x,g3Float y,g3Float z); |
| 29 |
g3Vec   g3v_sane(g3Vec v); |
| 30 |
| 31 |
g3Vec   g3v_fromrad(g3Vec v,FVECT rv); |
| 32 |
void    g3v_torad(FVECT rv,g3Vec v); |
| 33 |
| 34 |
| 35 |
**      Orderering is done component wise, with decreasing significance |
| 36 |
**      Returns -1, 0 or 1 if v1 is less, equal or greater than v2 |
| 37 |
| 38 |
int             g3v_epsorder(g3Vec v1,g3Vec v2); |
| 39 |
| 40 |
| 41 |
**      Returns true if v1 and v2 are epsilon equal  |
| 42 |
| 43 |
int             g3v_epseq(g3Vec v1,g3Vec v2); |
| 44 |
| 45 |
int             g3v_epszero(g3Vec v); |
| 46 |
| 47 |
/* Euclidean length of vector */ |
| 48 |
g3Float g3v_length(g3Vec v); |
| 49 |
| 50 |
| 51 |
**      Common operations on vectors. All routines returns zero on errors or |
| 52 |
**      the result as a g3Float |
| 53 |
| 54 |
g3Float g3v_dot(g3Vec v1,g3Vec v2); |
| 55 |
g3Vec   g3v_scale(g3Vec res,g3Vec v,g3Float sc); |
| 56 |
g3Vec   g3v_normalize(g3Vec v); |
| 57 |
g3Vec   g3v_cross(g3Vec res,g3Vec v1,g3Vec v2); |
| 58 |
g3Vec   g3v_sub(g3Vec res,g3Vec v1,g3Vec v2); |
| 59 |
g3Vec   g3v_add(g3Vec res,g3Vec v1,g3Vec v2); |
| 60 |
| 61 |
g3Vec   g3v_rotate(g3Vec res,g3Vec v,g3Vec rnorm,g3Float ang); |
| 62 |
| 63 |
g3Vec   g3v_print(g3Vec v,FILE* fp); |
| 64 |
int             g3v_read(g3Vec v,FILE* fp); |
| 65 |
| 66 |
| 67 |
| 68 |
#endif |
| 69 |
| 70 |
#endif |
