root/radiance/src/common/g3affine.h
Revision: 2.2
Committed: Tue Aug 18 15:02:53 2015 UTC (10 years, 2 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad6R0, HEAD
Added RCCS id's to new source files (forgotten during initial check-in)
# User Rev Content
1 greg 2.2 /* RCSid $Id$ */
2 greg 2.1 /*
3     ** Author: Christian Reetz ([email protected])
4     */
5     #ifndef __G3AFFINE_H
6     #define __G3AFFINE_H
7
8
9
10     #ifdef __cplusplus
11     extern "C" {
12     #endif
13
14     #include "g3vector.h"
15
16     #ifdef GL_CONVERSIONS
17     #include "GL/gl.h"
18     #endif
19
20
21     typedef g3Float g3AVec[4];
22     typedef g3Float g3ATrans[4][4];
23
24
25     void g3av_copy(g3AVec res,g3AVec v);
26     void g3at_tounit(g3ATrans t);
27     void g3av_vectohom(g3AVec res,g3Vec v);
28     void g3av_homtovec(g3Vec res,g3AVec h);
29     int g3av_tonorm(g3AVec v);
30
31     #ifdef GL_CONVERSIONS
32     void g3at_get_openGL(g3ATrans t,GLdouble* glm);
33     void g3at_from_openGL(g3ATrans t,GLdouble* glm);
34     #endif
35
36
37     void g3at_copy(g3ATrans t,g3ATrans tsrc);
38     void g3at_print(g3ATrans t,FILE* outf);
39     void g3at_comb(g3ATrans t,g3ATrans tf);
40     void g3at_comb_to(g3ATrans res,g3ATrans t,g3ATrans tf);
41     void g3at_translate(g3ATrans t,g3Vec tv);
42     void g3at_add_trans(g3ATrans t,g3Vec tv);
43     void g3at_prepend_trans(g3ATrans t,g3Vec tv);
44     void g3at_rotate(g3ATrans t,g3Vec rnorm,g3Float ang);
45     void g3at_add_rot(g3ATrans t,g3Vec rnorm,g3Float ang);
46     void g3at_prepend_rot(g3ATrans t,g3Vec rnorm,g3Float ang);
47
48     void g3at_btrans(g3ATrans t,g3Vec xv,g3Vec yv,g3Vec zv);
49     int g3at_sph_ctrans(g3ATrans t,g3Vec vdir,g3Vec vup);
50     int g3at_ctrans(g3ATrans t,g3Vec vdir,g3Vec vup);
51     int g3at_inverse(g3ATrans t);
52     void g3at_apply_h(g3ATrans t,g3AVec v);
53     void g3at_iapply_h(g3Vec v,g3ATrans t);
54     void g3at_apply(g3ATrans t,g3Vec v);
55     void g3at_iapply(g3Vec v,g3ATrans t);
56
57     #ifdef __cplusplus
58     }
59     #endif
60
61
62     #endif
