root/radiance/src/common/fvect.c
Revision: 1.3
Committed: Mon May 8 08:40:56 1989 UTC (36 years, 6 months ago) by greg
changed length test to absolute zero
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * fvect.c - routines for float vector calculations
9 *
10 * 8/14/85
11 */
12
13 #include "fvect.h"
14
15 #define FTINY 1e-7
16
17
18 double
19 fdot(v1, v2) /* return the dot product of two vectors */
20 register FVECT v1, v2;
21 {
22 return(DOT(v1,v2));
23 }
24
25
26 double
27 dist2(p1, p2) /* return square of distance between points */
28 register FVECT p1, p2;
29 {
30 static FVECT delta;
31
32 delta[0] = p2[0] - p1[0];
33 delta[1] = p2[1] - p1[1];
34 delta[2] = p2[2] - p1[2];
35 return(DOT(delta, delta));
36 }
37
38
39 double
40 dist2line(p, ep1, ep2) /* return square of distance to line */
41 FVECT p; /* the point */
42 FVECT ep1, ep2; /* points on the line */
43 {
44 static double d, d1, d2;
45
46 d = dist2(ep1, ep2);
47 d1 = dist2(ep1, p);
48 d2 = dist2(ep2, p);
49
50 return(d1 - (d+d1-d2)*(d+d1-d2)/d/4);
51 }
52
53
54 double
55 dist2lseg(p, ep1, ep2) /* return square of distance to line segment */
56 FVECT p; /* the point */
57 FVECT ep1, ep2; /* the end points */
58 {
59 static double d, d1, d2;
60
61 d = dist2(ep1, ep2);
62 d1 = dist2(ep1, p);
63 d2 = dist2(ep2, p);
64
65 if (d2 > d1) { /* check if past endpoints */
66 if (d2 - d1 > d)
67 return(d1);
68 } else {
69 if (d1 - d2 > d)
70 return(d2);
71 }
72
73 return(d1 - (d+d1-d2)*(d+d1-d2)/d/4); /* distance to line */
74 }
75
76
77 fcross(vres, v1, v2) /* vres = v1 X v2 */
78 register FVECT vres, v1, v2;
79 {
80 vres[0] = v1[1]*v2[2] - v1[2]*v2[1];
81 vres[1] = v1[2]*v2[0] - v1[0]*v2[2];
82 vres[2] = v1[0]*v2[1] - v1[1]*v2[0];
83 }
84
85
86 double
87 normalize(v) /* normalize a vector, return old magnitude */
88 register FVECT v;
89 {
90 static double len;
91
92 len = DOT(v, v);
93
94 if (len <= 0.0)
95 return(0.0);
96
97 /****** problematic
98 if (len >= (1.0-FTINY)*(1.0-FTINY) &&
99 len <= (1.0+FTINY)*(1.0+FTINY))
100 return(1.0);
101 ******/
102
103 len = sqrt(len);
104 v[0] /= len;
105 v[1] /= len;
106 v[2] /= len;
107 return(len);
108 }
