| Revision: | 2.5 |
| Committed: | Mon Oct 27 10:19:31 2003 UTC (22 years ago) by schorsch |
| Content type: | text/plain |
| Branch: | MAIN |
| CVS Tags: | rad5R0, rad4R2, rad3R7P2, rad3R7P1, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad4R2P2 |
| Changes since 2.4: | +2 -2 lines |
| Log Message: | Added gethomedir.c and various compatibility fixes. |
| # | User | Rev | Content |
| 1 | greg | 2.1 | #ifndef lint |
| 2 | schorsch | 2.5 | static const char RCSid[] = "$Id: fixargv0.c,v 2.4 2003/10/21 19:19:28 schorsch Exp $"; |
| 3 | greg | 2.1 | #endif |
| 4 | /* | ||
| 5 | * Fix argv[0] for DOS environments | ||
| 6 | greg | 2.2 | * |
| 7 | schorsch | 2.4 | * External symbols declared in paths.h |
| 8 | greg | 2.2 | */ |
| 9 | |||
| 10 | greg | 2.3 | #include "copyright.h" |
| 11 | greg | 2.1 | |
| 12 | schorsch | 2.4 | #include <ctype.h> |
| 13 | greg | 2.1 | |
| 14 | schorsch | 2.5 | extern char * |
| 15 | greg | 2.1 | fixargv0(av0) /* extract command name from full path */ |
| 16 | char *av0; | ||
| 17 | { | ||
| 18 | register char *cp = av0; | ||
| 19 | |||
| 20 | while (*cp) cp++; /* start from end */ | ||
| 21 | while (cp-- > av0) | ||
| 22 | switch (*cp) { /* fix up command name */ | ||
| 23 | case '.': /* remove extension */ | ||
| 24 | *cp = '\0'; | ||
| 25 | continue; | ||
| 26 | case '\\': /* remove directory */ | ||
| 27 | return(cp+1); | ||
| 28 | default: /* convert to lower case */ | ||
| 29 | *cp = tolower(*cp); | ||
| 30 | continue; | ||
| 31 | } | ||
| 32 | return(av0); | ||
| 33 | } | ||
| 34 | |||
| 35 |
