root/radiance/src/common/ezxml.h
Revision: 2.2
Committed: Wed Jun 1 00:29:40 2011 UTC (14 years, 5 months ago) by greg
CVS Tags: rad4R2P2, rad4R2P1, rad4R2, rad4R1
Changes since 2.1: +64 -64 lines
1 /* RCSid $Id: ezxml.h,v 2.1 2009/06/17 20:41:47 greg Exp $ */
2 /* ezxml.h
3 *
4 * Copyright 2004-2006 Aaron Voisine <[email protected]>
5 *
6 * Permission is hereby granted, free of charge, to any person obtaining
7 * a copy of this software and associated documentation files (the
8 * "Software"), to deal in the Software without restriction, including
9 * without limitation the rights to use, copy, modify, merge, publish,
10 * distribute, sublicense, and/or sell copies of the Software, and to
11 * permit persons to whom the Software is furnished to do so, subject to
12 * the following conditions:
13 *
14 * The above copyright notice and this permission notice shall be included
15 * in all copies or substantial portions of the Software.
16 *
17 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
18 * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
19 * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
20 * IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY
21 * CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT,
22 * TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE
23 * SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
24 */
25
26 #ifndef _EZXML_H
27 #define _EZXML_H
28
29 #include <stdlib.h>
30 #include <stdio.h>
31 #include <stdarg.h>
32 #include <fcntl.h>
33
34 #ifdef __cplusplus
35 extern "C" {
36 #endif
37
38 /* disable MMAP on CYGWIN, seems to cause problems... */
39 #ifdef CYGWIN
40 #define EZXML_NOMMAP
41 #endif
42
43 #define EZXML_BUFSIZE 1024 /* size of internal memory buffers */
44 #define EZXML_NAMEM 0x80 /* name is malloced */
45 #define EZXML_TXTM 0x40 /* txt is malloced */
46 #define EZXML_DUP 0x20 /* attribute name and value are strduped */
47
48 typedef struct ezxml *ezxml_t;
49 struct ezxml {
50 char *name; /* tag name */
51 char **attr; /* tag attributes { name, value, name, value, ... NULL } */
52 char *txt; /* tag character content, empty string if none */
53 size_t off; /* tag offset from start of parent tag character content */
54 ezxml_t next; /* next tag with same name in this section at this depth */
55 ezxml_t sibling; /* next tag with different name in same section and depth */
56 ezxml_t ordered; /* next tag, same section and depth, in original order */
57 ezxml_t child; /* head of sub tag list, NULL if none */
58 ezxml_t parent; /* parent tag, NULL if current tag is root tag */
59 short flags; /* additional information */
60 };
61
62 /* Given a string of xml data and its length, parses it and creates an ezxml */
63 /* structure. For efficiency, modifies the data by adding null terminators */
64 /* and decoding ampersand sequences. If you don't want this, copy the data and */
65 /* pass in the copy. Returns NULL on failure. */
66 ezxml_t ezxml_parse_str(char *s, size_t len);
67
68 /* A wrapper for ezxml_parse_str() that accepts a file descriptor. First */
69 /* attempts to mem map the file. Failing that, reads the file into memory. */
70 /* Returns NULL on failure. */
71 ezxml_t ezxml_parse_fd(int fd);
72
73 /* a wrapper for ezxml_parse_fd() that accepts a file name */
74 ezxml_t ezxml_parse_file(const char *file);
75
76 /* Wrapper for ezxml_parse_str() that accepts a file stream. Reads the entire */
77 /* stream into memory and then parses it. For xml files, use ezxml_parse_file() */
78 /* or ezxml_parse_fd() */
79 ezxml_t ezxml_parse_fp(FILE *fp);
80
81 /* returns the first child tag (one level deeper) with the given name or NULL */
82 /* if not found */
83 ezxml_t ezxml_child(ezxml_t xml, const char *name);
84
85 /* returns the next tag of the same name in the same section and depth or NULL */
86 /* if not found */
87 #define ezxml_next(xml) ((xml) ? xml->next : NULL)
88
89 /* Returns the Nth tag with the same name in the same section at the same depth */
90 /* or NULL if not found. An index of 0 returns the tag given. */
91 ezxml_t ezxml_idx(ezxml_t xml, int idx);
92
93 /* returns the name of the given tag */
94 #define ezxml_name(xml) ((xml) ? xml->name : NULL)
95
96 /* returns the given tag's character content or empty string if none */
97 #define ezxml_txt(xml) ((xml) ? xml->txt : "")
98
99 /* returns the value of the requested tag attribute, or NULL if not found */
100 const char *ezxml_attr(ezxml_t xml, const char *attr);
101
102 /* Traverses the ezxml sturcture to retrieve a specific subtag. Takes a */
103 /* variable length list of tag names and indexes. The argument list must be */
104 /* terminated by either an index of -1 or an empty string tag name. Example: */
105 /* title = ezxml_get(library, "shelf", 0, "book", 2, "title", -1); */
106 /* This retrieves the title of the 3rd book on the 1st shelf of library. */
107 /* Returns NULL if not found. */
108 ezxml_t ezxml_get(ezxml_t xml, ...);
109
110 /* Converts an ezxml structure back to xml. Returns a string of xml data that */
111 /* must be freed. */
112 char *ezxml_toxml(ezxml_t xml);
113
114 /* returns a NULL terminated array of processing instructions for the given */
115 /* target */
116 const char **ezxml_pi(ezxml_t xml, const char *target);
117
118 /* frees the memory allocated for an ezxml structure */
119 void ezxml_free(ezxml_t xml);
120
121 /* returns parser error message or empty string if none */
122 const char *ezxml_error(ezxml_t xml);
123
124 /* returns a new empty ezxml structure with the given root tag name */
125 ezxml_t ezxml_new(const char *name);
126
127 /* wrapper for ezxml_new() that strdup()s name */
128 #define ezxml_new_d(name) ezxml_set_flag(ezxml_new(strdup(name)), EZXML_NAMEM)
129
130 /* Adds a child tag. off is the offset of the child tag relative to the start */
131 /* of the parent tag's character content. Returns the child tag. */
132 ezxml_t ezxml_add_child(ezxml_t xml, const char *name, size_t off);
133
134 /* wrapper for ezxml_add_child() that strdup()s name */
135 #define ezxml_add_child_d(xml, name, off) \
136 ezxml_set_flag(ezxml_add_child(xml, strdup(name), off), EZXML_NAMEM)
137
138 /* sets the character content for the given tag and returns the tag */
139 ezxml_t ezxml_set_txt(ezxml_t xml, const char *txt);
140
141 /* wrapper for ezxml_set_txt() that strdup()s txt */
142 #define ezxml_set_txt_d(xml, txt) \
143 ezxml_set_flag(ezxml_set_txt(xml, strdup(txt)), EZXML_TXTM)
144
145 /* Sets the given tag attribute or adds a new attribute if not found. A value */
146 /* of NULL will remove the specified attribute. Returns the tag given. */
147 ezxml_t ezxml_set_attr(ezxml_t xml, const char *name, const char *value);
148
149 /* Wrapper for ezxml_set_attr() that strdup()s name/value. Value cannot be NULL */
150 #define ezxml_set_attr_d(xml, name, value) \
151 ezxml_set_attr(ezxml_set_flag(xml, EZXML_DUP), strdup(name), strdup(value))
152
153 /* sets a flag for the given tag and returns the tag */
154 ezxml_t ezxml_set_flag(ezxml_t xml, short flag);
155
156 /* removes a tag along with its subtags without freeing its memory */
157 ezxml_t ezxml_cut(ezxml_t xml);
158
159 /* inserts an existing tag into an ezxml structure */
160 ezxml_t ezxml_insert(ezxml_t xml, ezxml_t dest, size_t off);
161
162 /* Moves an existing tag to become a subtag of dest at the given offset from */
163 /* the start of dest's character content. Returns the moved tag. */
164 #define ezxml_move(xml, dest, off) ezxml_insert(ezxml_cut(xml), dest, off)
165
166 /* removes a tag along with all its subtags */
167 #define ezxml_remove(xml) ezxml_free(ezxml_cut(xml))
168
169 #ifdef __cplusplus
170 }
171 #endif
172
173 #endif /* _EZXML_H */
