| 1 |
/* RCSid $Id: ezxml.h,v 2.3 2015/02/14 00:34:43 greg Exp $ */ |
| 2 |
/* ezxml.h |
| 3 |
| 4 |
* Copyright 2004-2006 Aaron Voisine <[email protected]> |
| 5 |
| 6 |
* Permission is hereby granted, free of charge, to any person obtaining |
| 7 |
* a copy of this software and associated documentation files (the |
| 8 |
* "Software"), to deal in the Software without restriction, including |
| 9 |
* without limitation the rights to use, copy, modify, merge, publish, |
| 10 |
* distribute, sublicense, and/or sell copies of the Software, and to |
| 11 |
* permit persons to whom the Software is furnished to do so, subject to |
| 12 |
* the following conditions: |
| 13 |
| 14 |
* The above copyright notice and this permission notice shall be included |
| 15 |
* in all copies or substantial portions of the Software. |
| 16 |
| 17 |
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, |
| 18 |
* EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF |
| 19 |
* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. |
| 20 |
* IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY |
| 21 |
* CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, |
| 22 |
* TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE |
| 23 |
* SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. |
| 24 |
| 25 |
| 26 |
#ifndef _EZXML_H |
| 27 |
#define _EZXML_H |
| 28 |
| 29 |
#include <stdlib.h> |
| 30 |
#include <stdio.h> |
| 31 |
#include <stdarg.h> |
| 32 |
#include <fcntl.h> |
| 33 |
| 34 |
#ifdef __cplusplus |
| 35 |
extern "C" { |
| 36 |
#endif |
| 37 |
| 38 |
/* disable MMAP on CYGWIN, seems to cause problems... */ |
| 39 |
#ifdef CYGWIN |
| 40 |
#define EZXML_NOMMAP |
| 41 |
#endif |
| 42 |
| 43 |
#define EZXML_BUFSIZE 1024 /* size of internal memory buffers */ |
| 44 |
#define EZXML_NAMEM 0x80 /* name is malloced */ |
| 45 |
#define EZXML_TXTM 0x40 /* txt is malloced */ |
| 46 |
#define EZXML_DUP 0x20 /* attribute name and value are strduped */ |
| 47 |
| 48 |
typedef struct ezxml *ezxml_t; |
| 49 |
struct ezxml { |
| 50 |
char *name; /* tag name */ |
| 51 |
char **attr; /* tag attributes { name, value, name, value, ... NULL } */ |
| 52 |
char *txt; /* tag character content, empty string if none */ |
| 53 |
size_t off; /* tag offset from start of parent tag character content */ |
| 54 |
ezxml_t next; /* next tag with same name in this section at this depth */ |
| 55 |
ezxml_t sibling; /* next tag with different name in same section and depth */ |
| 56 |
ezxml_t ordered; /* next tag, same section and depth, in original order */ |
| 57 |
ezxml_t child; /* head of sub tag list, NULL if none */ |
| 58 |
ezxml_t parent; /* parent tag, NULL if current tag is root tag */ |
| 59 |
short flags; /* additional information */ |
| 60 |
| 61 |
| 62 |
/* Given a string of xml data and its length, parses it and creates an ezxml */ |
| 63 |
/* structure. For efficiency, modifies the data by adding null terminators */ |
| 64 |
/* and decoding ampersand sequences. If you don't want this, copy the data and */ |
| 65 |
/* pass in the copy. Returns NULL on failure. */ |
| 66 |
ezxml_t ezxml_parse_str(char *s, size_t len); |
| 67 |
| 68 |
/* A wrapper for ezxml_parse_str() that accepts a file descriptor. First */ |
| 69 |
/* attempts to mem map the file. Failing that, reads the file into memory. */ |
| 70 |
/* Returns NULL on failure. */ |
| 71 |
ezxml_t ezxml_parse_fd(int fd); |
| 72 |
| 73 |
/* a wrapper for ezxml_parse_fd() that accepts a file name */ |
| 74 |
ezxml_t ezxml_parse_file(const char *file); |
| 75 |
| 76 |
/* Wrapper for ezxml_parse_str() that accepts a file stream. Reads the entire */ |
| 77 |
/* stream into memory and then parses it. For xml files, use ezxml_parse_file() */ |
| 78 |
/* or ezxml_parse_fd() */ |
| 79 |
ezxml_t ezxml_parse_fp(FILE *fp); |
| 80 |
| 81 |
/* returns the first child tag (one level deeper) with the given name or NULL */ |
| 82 |
/* if not found */ |
| 83 |
ezxml_t ezxml_child(ezxml_t xml, const char *name); |
| 84 |
| 85 |
/* returns the next tag of the same name in the same section and depth or NULL */ |
| 86 |
| 87 |
#define ezxml_next(xml) ((xml) ? xml->next : NULL) |
| 88 |
| 89 |
/* Returns the Nth tag with the same name in the same section at the same depth */ |
| 90 |
/* or NULL if not found. An index of 0 returns the tag given. */ |
| 91 |
ezxml_t ezxml_idx(ezxml_t xml, int idx); |
| 92 |
| 93 |
/* returns the name of the given tag */ |
| 94 |
#define ezxml_name(xml) ((xml) ? xml->name : NULL) |
| 95 |
| 96 |
/* returns the given tag's character content or empty string if none */ |
| 97 |
char *ezxml_txt(ezxml_t xml); |
| 98 |
| 99 |
/* returns the value of the requested tag attribute, or NULL if not found */ |
| 100 |
const char *ezxml_attr(ezxml_t xml, const char *attr); |
| 101 |
| 102 |
/* Traverses the ezxml sturcture to retrieve a specific subtag. Takes a */ |
| 103 |
/* variable length list of tag names and indexes. The argument list must be */ |
| 104 |
/* terminated by either an index of -1 or an empty string tag name. Example: */ |
| 105 |
/* title = ezxml_get(library, "shelf", 0, "book", 2, "title", -1); */ |
| 106 |
/* This retrieves the title of the 3rd book on the 1st shelf of library. */ |
| 107 |
/* Returns NULL if not found. */ |
| 108 |
ezxml_t ezxml_get(ezxml_t xml, ...); |
| 109 |
| 110 |
/* Converts an ezxml structure back to xml. Returns a string of xml data that */ |
| 111 |
/* must be freed. */ |
| 112 |
char *ezxml_toxml(ezxml_t xml); |
| 113 |
| 114 |
/* returns a NULL terminated array of processing instructions for the given */ |
| 115 |
/* target */ |
| 116 |
const char **ezxml_pi(ezxml_t xml, const char *target); |
| 117 |
| 118 |
/* frees the memory allocated for an ezxml structure */ |
| 119 |
void ezxml_free(ezxml_t xml); |
| 120 |
| 121 |
/* returns parser error message or empty string if none */ |
| 122 |
const char *ezxml_error(ezxml_t xml); |
| 123 |
| 124 |
/* returns a new empty ezxml structure with the given root tag name */ |
| 125 |
ezxml_t ezxml_new(const char *name); |
| 126 |
| 127 |
/* wrapper for ezxml_new() that strdup()s name */ |
| 128 |
#define ezxml_new_d(name) ezxml_set_flag(ezxml_new(strdup(name)), EZXML_NAMEM) |
| 129 |
| 130 |
/* Adds a child tag. off is the offset of the child tag relative to the start */ |
| 131 |
/* of the parent tag's character content. Returns the child tag. */ |
| 132 |
ezxml_t ezxml_add_child(ezxml_t xml, const char *name, size_t off); |
| 133 |
| 134 |
/* wrapper for ezxml_add_child() that strdup()s name */ |
| 135 |
#define ezxml_add_child_d(xml, name, off) \ |
| 136 |
ezxml_set_flag(ezxml_add_child(xml, strdup(name), off), EZXML_NAMEM) |
| 137 |
| 138 |
/* sets the character content for the given tag and returns the tag */ |
| 139 |
ezxml_t ezxml_set_txt(ezxml_t xml, const char *txt); |
| 140 |
| 141 |
/* wrapper for ezxml_set_txt() that strdup()s txt */ |
| 142 |
#define ezxml_set_txt_d(xml, txt) \ |
| 143 |
ezxml_set_flag(ezxml_set_txt(xml, strdup(txt)), EZXML_TXTM) |
| 144 |
| 145 |
/* add text to the current character content, allocating memory as needed */ |
| 146 |
ezxml_t ezxml_add_txt(ezxml_t xml, const char *txt); |
| 147 |
| 148 |
/* Sets the given tag attribute or adds a new attribute if not found. A value */ |
| 149 |
/* of NULL will remove the specified attribute. Returns the tag given. */ |
| 150 |
ezxml_t ezxml_set_attr(ezxml_t xml, const char *name, const char *value); |
| 151 |
| 152 |
/* Wrapper for ezxml_set_attr() that strdup()s name/value. Value cannot be NULL */ |
| 153 |
#define ezxml_set_attr_d(xml, name, value) \ |
| 154 |
ezxml_set_attr(ezxml_set_flag(xml, EZXML_DUP), strdup(name), strdup(value)) |
| 155 |
| 156 |
/* sets a flag for the given tag and returns the tag */ |
| 157 |
ezxml_t ezxml_set_flag(ezxml_t xml, short flag); |
| 158 |
| 159 |
/* removes a tag along with its subtags without freeing its memory */ |
| 160 |
ezxml_t ezxml_cut(ezxml_t xml); |
| 161 |
| 162 |
/* inserts an existing tag into an ezxml structure */ |
| 163 |
ezxml_t ezxml_insert(ezxml_t xml, ezxml_t dest, size_t off); |
| 164 |
| 165 |
/* Moves an existing tag to become a subtag of dest at the given offset from */ |
| 166 |
/* the start of dest's character content. Returns the moved tag. */ |
| 167 |
#define ezxml_move(xml, dest, off) ezxml_insert(ezxml_cut(xml), dest, off) |
| 168 |
| 169 |
/* removes a tag along with all its subtags */ |
| 170 |
#define ezxml_remove(xml) ezxml_free(ezxml_cut(xml)) |
| 171 |
| 172 |
| 173 |
| 174 |
#endif |
| 175 |
| 176 |
#endif /* _EZXML_H */ |
