root/radiance/src/common/ezxml.h
Revision: 2.4
Committed: Thu Apr 2 16:40:32 2015 UTC (10 years, 6 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad6R0, HEAD
Support for color BSDF rendering using Klems representation
# User Rev Content
1 greg 2.4 /* RCSid $Id: ezxml.h,v 2.3 2015/02/14 00:34:43 greg Exp $ */
2 greg 2.1 /* ezxml.h
3     *
4     * Copyright 2004-2006 Aaron Voisine <[email protected]>
5     *
6     * Permission is hereby granted, free of charge, to any person obtaining
7     * a copy of this software and associated documentation files (the
8     * "Software"), to deal in the Software without restriction, including
9     * without limitation the rights to use, copy, modify, merge, publish,
10     * distribute, sublicense, and/or sell copies of the Software, and to
11     * permit persons to whom the Software is furnished to do so, subject to
12     * the following conditions:
13     *
14     * The above copyright notice and this permission notice shall be included
15     * in all copies or substantial portions of the Software.
16     *
17     * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
18     * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
19     * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
20     * IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY
21     * CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT,
22     * TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE
23     * SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
24     */
25
26     #ifndef _EZXML_H
27     #define _EZXML_H
28
29     #include <stdlib.h>
30     #include <stdio.h>
31     #include <stdarg.h>
32     #include <fcntl.h>
33
34     #ifdef __cplusplus
35     extern "C" {
36     #endif
37
38     /* disable MMAP on CYGWIN, seems to cause problems... */
39     #ifdef CYGWIN
40     #define EZXML_NOMMAP
41     #endif
42
43 greg 2.2 #define EZXML_BUFSIZE 1024 /* size of internal memory buffers */
44     #define EZXML_NAMEM 0x80 /* name is malloced */
45     #define EZXML_TXTM 0x40 /* txt is malloced */
46     #define EZXML_DUP 0x20 /* attribute name and value are strduped */
47 greg 2.1
48     typedef struct ezxml *ezxml_t;
49     struct ezxml {
50 greg 2.2 char *name; /* tag name */
51     char **attr; /* tag attributes { name, value, name, value, ... NULL } */
52     char *txt; /* tag character content, empty string if none */
53     size_t off; /* tag offset from start of parent tag character content */
54     ezxml_t next; /* next tag with same name in this section at this depth */
55     ezxml_t sibling; /* next tag with different name in same section and depth */
56     ezxml_t ordered; /* next tag, same section and depth, in original order */
57     ezxml_t child; /* head of sub tag list, NULL if none */
58     ezxml_t parent; /* parent tag, NULL if current tag is root tag */
59     short flags; /* additional information */
60 greg 2.1 };
61
62 greg 2.2 /* Given a string of xml data and its length, parses it and creates an ezxml */
63     /* structure. For efficiency, modifies the data by adding null terminators */
64     /* and decoding ampersand sequences. If you don't want this, copy the data and */
65     /* pass in the copy. Returns NULL on failure. */
66 greg 2.1 ezxml_t ezxml_parse_str(char *s, size_t len);
67
68 greg 2.2 /* A wrapper for ezxml_parse_str() that accepts a file descriptor. First */
69     /* attempts to mem map the file. Failing that, reads the file into memory. */
70     /* Returns NULL on failure. */
71 greg 2.1 ezxml_t ezxml_parse_fd(int fd);
72
73 greg 2.2 /* a wrapper for ezxml_parse_fd() that accepts a file name */
74 greg 2.1 ezxml_t ezxml_parse_file(const char *file);
75
76 greg 2.2 /* Wrapper for ezxml_parse_str() that accepts a file stream. Reads the entire */
77     /* stream into memory and then parses it. For xml files, use ezxml_parse_file() */
78     /* or ezxml_parse_fd() */
79 greg 2.1 ezxml_t ezxml_parse_fp(FILE *fp);
80
81 greg 2.2 /* returns the first child tag (one level deeper) with the given name or NULL */
82     /* if not found */
83 greg 2.1 ezxml_t ezxml_child(ezxml_t xml, const char *name);
84
85 greg 2.2 /* returns the next tag of the same name in the same section and depth or NULL */
86     /* if not found */
87 greg 2.1 #define ezxml_next(xml) ((xml) ? xml->next : NULL)
88
89 greg 2.2 /* Returns the Nth tag with the same name in the same section at the same depth */
90     /* or NULL if not found. An index of 0 returns the tag given. */
91 greg 2.1 ezxml_t ezxml_idx(ezxml_t xml, int idx);
92
93 greg 2.2 /* returns the name of the given tag */
94 greg 2.1 #define ezxml_name(xml) ((xml) ? xml->name : NULL)
95
96 greg 2.2 /* returns the given tag's character content or empty string if none */
97 greg 2.4 char *ezxml_txt(ezxml_t xml);
98 greg 2.1
99 greg 2.2 /* returns the value of the requested tag attribute, or NULL if not found */
100 greg 2.1 const char *ezxml_attr(ezxml_t xml, const char *attr);
101
102 greg 2.2 /* Traverses the ezxml sturcture to retrieve a specific subtag. Takes a */
103     /* variable length list of tag names and indexes. The argument list must be */
104     /* terminated by either an index of -1 or an empty string tag name. Example: */
105     /* title = ezxml_get(library, "shelf", 0, "book", 2, "title", -1); */
106     /* This retrieves the title of the 3rd book on the 1st shelf of library. */
107     /* Returns NULL if not found. */
108 greg 2.1 ezxml_t ezxml_get(ezxml_t xml, ...);
109
110 greg 2.2 /* Converts an ezxml structure back to xml. Returns a string of xml data that */
111     /* must be freed. */
112 greg 2.1 char *ezxml_toxml(ezxml_t xml);
113
114 greg 2.2 /* returns a NULL terminated array of processing instructions for the given */
115     /* target */
116 greg 2.1 const char **ezxml_pi(ezxml_t xml, const char *target);
117
118 greg 2.2 /* frees the memory allocated for an ezxml structure */
119 greg 2.1 void ezxml_free(ezxml_t xml);
120
121 greg 2.2 /* returns parser error message or empty string if none */
122 greg 2.1 const char *ezxml_error(ezxml_t xml);
123
124 greg 2.2 /* returns a new empty ezxml structure with the given root tag name */
125 greg 2.1 ezxml_t ezxml_new(const char *name);
126
127 greg 2.2 /* wrapper for ezxml_new() that strdup()s name */
128 greg 2.1 #define ezxml_new_d(name) ezxml_set_flag(ezxml_new(strdup(name)), EZXML_NAMEM)
129
130 greg 2.2 /* Adds a child tag. off is the offset of the child tag relative to the start */
131     /* of the parent tag's character content. Returns the child tag. */
132 greg 2.1 ezxml_t ezxml_add_child(ezxml_t xml, const char *name, size_t off);
133
134 greg 2.2 /* wrapper for ezxml_add_child() that strdup()s name */
135 greg 2.1 #define ezxml_add_child_d(xml, name, off) \
136     ezxml_set_flag(ezxml_add_child(xml, strdup(name), off), EZXML_NAMEM)
137
138 greg 2.2 /* sets the character content for the given tag and returns the tag */
139 greg 2.1 ezxml_t ezxml_set_txt(ezxml_t xml, const char *txt);
140
141 greg 2.2 /* wrapper for ezxml_set_txt() that strdup()s txt */
142 greg 2.1 #define ezxml_set_txt_d(xml, txt) \
143     ezxml_set_flag(ezxml_set_txt(xml, strdup(txt)), EZXML_TXTM)
144
145 greg 2.3 /* add text to the current character content, allocating memory as needed */
146     ezxml_t ezxml_add_txt(ezxml_t xml, const char *txt);
147
148 greg 2.2 /* Sets the given tag attribute or adds a new attribute if not found. A value */
149     /* of NULL will remove the specified attribute. Returns the tag given. */
150 greg 2.1 ezxml_t ezxml_set_attr(ezxml_t xml, const char *name, const char *value);
151
152 greg 2.2 /* Wrapper for ezxml_set_attr() that strdup()s name/value. Value cannot be NULL */
153 greg 2.1 #define ezxml_set_attr_d(xml, name, value) \
154     ezxml_set_attr(ezxml_set_flag(xml, EZXML_DUP), strdup(name), strdup(value))
155
156 greg 2.2 /* sets a flag for the given tag and returns the tag */
157 greg 2.1 ezxml_t ezxml_set_flag(ezxml_t xml, short flag);
158
159 greg 2.2 /* removes a tag along with its subtags without freeing its memory */
160 greg 2.1 ezxml_t ezxml_cut(ezxml_t xml);
161
162 greg 2.2 /* inserts an existing tag into an ezxml structure */
163 greg 2.1 ezxml_t ezxml_insert(ezxml_t xml, ezxml_t dest, size_t off);
164
165 greg 2.2 /* Moves an existing tag to become a subtag of dest at the given offset from */
166     /* the start of dest's character content. Returns the moved tag. */
167 greg 2.1 #define ezxml_move(xml, dest, off) ezxml_insert(ezxml_cut(xml), dest, off)
168
169 greg 2.2 /* removes a tag along with all its subtags */
170 greg 2.1 #define ezxml_remove(xml) ezxml_free(ezxml_cut(xml))
171
172     #ifdef __cplusplus
173     }
174     #endif
175
176 greg 2.2 #endif /* _EZXML_H */
