root/radiance/src/common/ezxml.c
Revision: 2.9
Committed: Sun Mar 6 01:13:17 2016 UTC (9 years, 7 months ago) by schorsch
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R1, rad6R0, HEAD
Changes since 2.8: +6 -7 lines
# User Rev Content
1 greg 2.1 #ifndef lint
2 schorsch 2.9 static const char RCSid[] = "$Id: ezxml.c,v 2.8 2015/04/02 16:40:32 greg Exp $";
3 greg 2.1 #endif
4     /* ezxml.c
5     *
6     * Copyright 2004-2006 Aaron Voisine <[email protected]>
7     *
8     * Permission is hereby granted, free of charge, to any person obtaining
9     * a copy of this software and associated documentation files (the
10     * "Software"), to deal in the Software without restriction, including
11     * without limitation the rights to use, copy, modify, merge, publish,
12     * distribute, sublicense, and/or sell copies of the Software, and to
13     * permit persons to whom the Software is furnished to do so, subject to
14     * the following conditions:
15     *
16     * The above copyright notice and this permission notice shall be included
17     * in all copies or substantial portions of the Software.
18     *
19     * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
20     * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
21     * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
22     * IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY
23     * CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT,
24     * TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE
25     * SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
26     */
27
28 schorsch 2.9 #if defined(_WIN32) || defined(_WIN64)
29     #define EZXML_NOMMAP
30     #endif
31
32 greg 2.1 #include <stdlib.h>
33     #include <stdio.h>
34     #include <stdarg.h>
35     #include <string.h>
36     #include <ctype.h>
37     #include <sys/types.h>
38     #ifndef EZXML_NOMMAP
39     #include <unistd.h>
40     #include <sys/mman.h>
41 greg 2.2 #endif /* EZXML_NOMMAP */
42 greg 2.1 #include <sys/stat.h>
43     #include "ezxml.h"
44
45 schorsch 2.9 #include "platform.h"
46 greg 2.3
47 greg 2.2 #define EZXML_WS "\t\r\n " /* whitespace */
48     #define EZXML_ERRL 128 /* maximum error string length */
49 greg 2.1
50     typedef struct ezxml_root *ezxml_root_t;
51 greg 2.2 struct ezxml_root { /* additional data for the root tag */
52     struct ezxml xml; /* is a super-struct built on top of ezxml struct */
53     ezxml_t cur; /* current xml tree insertion point */
54     char *m; /* original xml string */
55     size_t len; /* length of allocated memory for mmap, -1 for malloc */
56     char *u; /* UTF-8 conversion of string if original was UTF-16 */
57     char *s; /* start of work area */
58     char *e; /* end of work area */
59     char **ent; /* general entities (ampersand sequences) */
60     char ***attr; /* default attributes */
61     char ***pi; /* processing instructions */
62     short standalone; /* non-zero if <?xml standalone="yes"?> */
63     char err[EZXML_ERRL]; /* error string */
64 greg 2.1 };
65
66 greg 2.2 char *EZXML_NIL[] = { NULL }; /* empty, null terminated array of strings */
67 greg 2.1
68 greg 2.2 /* returns the first child tag with the given name or NULL if not found */
69 greg 2.1 ezxml_t ezxml_child(ezxml_t xml, const char *name)
70     {
71     xml = (xml) ? xml->child : NULL;
72     while (xml && strcmp(name, xml->name)) xml = xml->sibling;
73     return xml;
74     }
75
76 greg 2.8 /* returns the given tag's character content or empty string if none */
77     char *ezxml_txt(ezxml_t xml)
78     {
79     if (xml == NULL)
80     return "";
81     return xml->txt;
82     }
83
84 greg 2.2 /* returns the Nth tag with the same name in the same subsection or NULL if not */
85     /* found */
86 greg 2.1 ezxml_t ezxml_idx(ezxml_t xml, int idx)
87     {
88     for (; xml && idx; idx--) xml = xml->next;
89     return xml;
90     }
91
92 greg 2.2 /* returns the value of the requested tag attribute or NULL if not found */
93 greg 2.1 const char *ezxml_attr(ezxml_t xml, const char *attr)
94     {
95     int i = 0, j = 1;
96     ezxml_root_t root = (ezxml_root_t)xml;
97
98     if (! xml || ! xml->attr) return NULL;
99     while (xml->attr[i] && strcmp(attr, xml->attr[i])) i += 2;
100 greg 2.2 if (xml->attr[i]) return xml->attr[i + 1]; /* found attribute */
101 greg 2.1
102 greg 2.2 while (root->xml.parent) root = (ezxml_root_t)root->xml.parent; /* root tag */
103 greg 2.1 for (i = 0; root->attr[i] && strcmp(xml->name, root->attr[i][0]); i++);
104 greg 2.2 if (! root->attr[i]) return NULL; /* no matching default attributes */
105 greg 2.1 while (root->attr[i][j] && strcmp(attr, root->attr[i][j])) j += 3;
106 greg 2.2 return (root->attr[i][j]) ? root->attr[i][j + 1] : NULL; /* found default */
107 greg 2.1 }
108
109 greg 2.2 /* same as ezxml_get but takes an already initialized va_list */
110 greg 2.1 ezxml_t ezxml_vget(ezxml_t xml, va_list ap)
111     {
112     char *name = va_arg(ap, char *);
113     int idx = -1;
114
115     if (name && *name) {
116     idx = va_arg(ap, int);
117     xml = ezxml_child(xml, name);
118     }
119     return (idx < 0) ? xml : ezxml_vget(ezxml_idx(xml, idx), ap);
120     }
121
122 greg 2.2 /* Traverses the xml tree to retrieve a specific subtag. Takes a variable */
123     /* length list of tag names and indexes. The argument list must be terminated */
124     /* by either an index of -1 or an empty string tag name. Example: */
125     /* title = ezxml_get(library, "shelf", 0, "book", 2, "title", -1); */
126     /* This retrieves the title of the 3rd book on the 1st shelf of library. */
127     /* Returns NULL if not found. */
128 greg 2.1 ezxml_t ezxml_get(ezxml_t xml, ...)
129     {
130     va_list ap;
131     ezxml_t r;
132
133     va_start(ap, xml);
134     r = ezxml_vget(xml, ap);
135     va_end(ap);
136     return r;
137     }
138
139 greg 2.2 /* returns a null terminated array of processing instructions for the given */
140     /* target */
141 greg 2.1 const char **ezxml_pi(ezxml_t xml, const char *target)
142     {
143     ezxml_root_t root = (ezxml_root_t)xml;
144     int i = 0;
145
146     if (! root) return (const char **)EZXML_NIL;
147 greg 2.2 while (root->xml.parent) root = (ezxml_root_t)root->xml.parent; /* root tag */
148     while (root->pi[i] && strcmp(target, root->pi[i][0])) i++; /* find target */
149 greg 2.1 return (const char **)((root->pi[i]) ? root->pi[i] + 1 : EZXML_NIL);
150     }
151
152 greg 2.2 /* set an error string and return root */
153 greg 2.1 ezxml_t ezxml_err(ezxml_root_t root, char *s, const char *err, ...)
154     {
155     va_list ap;
156     int line = 1;
157     char *t, fmt[EZXML_ERRL];
158
159     for (t = root->s; t < s; t++) if (*t == '\n') line++;
160 greg 2.4 sprintf(fmt, "[error near line %d]: %s", line, err);
161 greg 2.1
162     va_start(ap, err);
163     vsnprintf(root->err, EZXML_ERRL, fmt, ap);
164     va_end(ap);
165
166     return &root->xml;
167     }
168
169 greg 2.2 /* Recursively decodes entity and character references and normalizes new lines */
170     /* ent is a null terminated array of alternating entity names and values. set t */
171     /* to '&' for general entity decoding, '%' for parameter entity decoding, 'c' */
172     /* for cdata sections, ' ' for attribute normalization, or '*' for non-cdata */
173     /* attribute normalization. Returns s, or if the decoded string is longer than */
174     /* s, returns a malloced string that must be freed. */
175 greg 2.1 char *ezxml_decode(char *s, char **ent, char t)
176     {
177     char *e, *r = s, *m = s;
178     long b, c, d, l;
179
180 greg 2.5 for (; *s; s++) /* normalize line endings */
181     if (*s == '\r') {
182     char *s2 = s+1;
183     do {
184     while (*s2 == '\r')
185     ++s2;
186     *s++ = *s2;
187     } while (*s2++);
188     break;
189     }
190 greg 2.1
191     for (s = r; ; ) {
192     while (*s && *s != '&' && (*s != '%' || t != '%') && !isspace(*s)) s++;
193
194     if (! *s) break;
195 greg 2.2 else if (t != 'c' && ! strncmp(s, "&#", 2)) { /* character reference */
196     if (s[2] == 'x') c = strtol(s + 3, &e, 16); /* base 16 */
197     else c = strtol(s + 2, &e, 10); /* base 10 */
198     if (! c || *e != ';') { s++; continue; } /* not a character ref */
199
200     if (c < 0x80) *(s++) = c; /* US-ASCII subset */
201     else { /* multi-byte UTF-8 sequence */
202     for (b = 0, d = c; d; d /= 2) b++; /* number of bits in c */
203     b = (b - 2) / 5; /* number of bytes in payload */
204     *(s++) = (0xFF << (7 - b)) | (c >> (6 * b)); /* head */
205     while (b) *(s++) = 0x80 | ((c >> (6 * --b)) & 0x3F); /* payload */
206 greg 2.1 }
207
208     memmove(s, strchr(s, ';') + 1, strlen(strchr(s, ';')));
209     }
210     else if ((*s == '&' && (t == '&' || t == ' ' || t == '*')) ||
211 greg 2.2 (*s == '%' && t == '%')) { /* entity reference */
212 greg 2.1 for (b = 0; ent[b] && strncmp(s + 1, ent[b], strlen(ent[b]));
213 greg 2.2 b += 2); /* find entity in entity list */
214 greg 2.1
215 greg 2.2 if (ent[b++]) { /* found a match */
216 greg 2.1 if ((c = strlen(ent[b])) - 1 > (e = strchr(s, ';')) - s) {
217 greg 2.2 l = (d = (s - r)) + c + strlen(e); /* new length */
218 greg 2.1 r = (r == m) ? strcpy(malloc(l), r) : realloc(r, l);
219 greg 2.2 e = strchr((s = r + d), ';'); /* fix up pointers */
220 greg 2.1 }
221
222 greg 2.2 memmove(s + c, e + 1, strlen(e)); /* shift rest of string */
223     strncpy(s, ent[b], c); /* copy in replacement text */
224 greg 2.1 }
225 greg 2.2 else s++; /* not a known entity */
226 greg 2.1 }
227     else if ((t == ' ' || t == '*') && isspace(*s)) *(s++) = ' ';
228 greg 2.2 else s++; /* no decoding needed */
229 greg 2.1 }
230
231 greg 2.2 if (t == '*') { /* normalize spaces for non-cdata attributes */
232 greg 2.1 for (s = r; *s; s++) {
233     if ((l = strspn(s, " "))) memmove(s, s + l, strlen(s + l) + 1);
234     while (*s && *s != ' ') s++;
235     }
236 greg 2.2 if (--s >= r && *s == ' ') *s = '\0'; /* trim any trailing space */
237 greg 2.1 }
238     return r;
239     }
240
241 greg 2.2 /* called when parser finds start of new tag */
242 greg 2.1 void ezxml_open_tag(ezxml_root_t root, char *name, char **attr)
243     {
244     ezxml_t xml = root->cur;
245
246     if (xml->name) xml = ezxml_add_child(xml, name, strlen(xml->txt));
247 greg 2.2 else xml->name = name; /* first open tag */
248 greg 2.1
249     xml->attr = attr;
250 greg 2.2 root->cur = xml; /* update tag insertion point */
251 greg 2.1 }
252
253 greg 2.2 /* called when parser finds character content between open and closing tag */
254 greg 2.1 void ezxml_char_content(ezxml_root_t root, char *s, size_t len, char t)
255     {
256     ezxml_t xml = root->cur;
257     char *m = s;
258     size_t l;
259
260 greg 2.2 if (! xml || ! xml->name || ! len) return; /* sanity check */
261 greg 2.1
262 greg 2.2 s[len] = '\0'; /* null terminate text (calling functions anticipate this) */
263 greg 2.1 len = strlen(s = ezxml_decode(s, root->ent, t)) + 1;
264
265 greg 2.2 if (! *(xml->txt)) xml->txt = s; /* initial character content */
266     else { /* allocate our own memory and make a copy */
267     xml->txt = (xml->flags & EZXML_TXTM) /* allocate some space */
268 greg 2.1 ? realloc(xml->txt, (l = strlen(xml->txt)) + len)
269     : strcpy(malloc((l = strlen(xml->txt)) + len), xml->txt);
270 greg 2.2 strcpy(xml->txt + l, s); /* add new char content */
271     if (s != m) free(s); /* free s if it was malloced by ezxml_decode() */
272 greg 2.1 }
273
274     if (xml->txt != m) ezxml_set_flag(xml, EZXML_TXTM);
275     }
276
277 greg 2.2 /* called when parser finds closing tag */
278 greg 2.1 ezxml_t ezxml_close_tag(ezxml_root_t root, char *name, char *s)
279     {
280     if (! root->cur || ! root->cur->name || strcmp(name, root->cur->name))
281     return ezxml_err(root, s, "unexpected closing tag </%s>", name);
282
283     root->cur = root->cur->parent;
284     return NULL;
285     }
286
287 greg 2.2 /* checks for circular entity references, returns non-zero if no circular */
288     /* references are found, zero otherwise */
289 greg 2.1 int ezxml_ent_ok(char *name, char *s, char **ent)
290     {
291     int i;
292
293     for (; ; s++) {
294 greg 2.2 while (*s && *s != '&') s++; /* find next entity reference */
295 greg 2.1 if (! *s) return 1;
296 greg 2.2 if (! strncmp(s + 1, name, strlen(name))) return 0; /* circular ref. */
297 greg 2.1 for (i = 0; ent[i] && strncmp(ent[i], s + 1, strlen(ent[i])); i += 2);
298     if (ent[i] && ! ezxml_ent_ok(name, ent[i + 1], ent)) return 0;
299     }
300     }
301
302 greg 2.2 /* called when the parser finds a processing instruction */
303 greg 2.1 void ezxml_proc_inst(ezxml_root_t root, char *s, size_t len)
304     {
305     int i = 0, j = 1;
306     char *target = s;
307
308 greg 2.2 s[len] = '\0'; /* null terminate instruction */
309 greg 2.1 if (*(s += strcspn(s, EZXML_WS))) {
310 greg 2.2 *s = '\0'; /* null terminate target */
311     s += strspn(s + 1, EZXML_WS) + 1; /* skip whitespace after target */
312 greg 2.1 }
313
314 greg 2.2 if (! strcmp(target, "xml")) { /* <?xml ... ?> */
315 greg 2.1 if ((s = strstr(s, "standalone")) && ! strncmp(s + strspn(s + 10,
316     EZXML_WS "='\"") + 10, "yes", 3)) root->standalone = 1;
317     return;
318     }
319
320 greg 2.2 if (! root->pi[0]) *(root->pi = malloc(sizeof(char **))) = NULL; /*first pi */
321 greg 2.1
322 greg 2.2 while (root->pi[i] && strcmp(target, root->pi[i][0])) i++; /* find target */
323     if (! root->pi[i]) { /* new target */
324 greg 2.1 root->pi = realloc(root->pi, sizeof(char **) * (i + 2));
325     root->pi[i] = malloc(sizeof(char *) * 3);
326     root->pi[i][0] = target;
327 greg 2.2 root->pi[i][1] = (char *)(root->pi[i + 1] = NULL); /* terminate pi list */
328     root->pi[i][2] = strdup(""); /* empty document position list */
329 greg 2.1 }
330
331 greg 2.2 while (root->pi[i][j]) j++; /* find end of instruction list for this target */
332 greg 2.1 root->pi[i] = realloc(root->pi[i], sizeof(char *) * (j + 3));
333     root->pi[i][j + 2] = realloc(root->pi[i][j + 1], j + 1);
334     strcpy(root->pi[i][j + 2] + j - 1, (root->xml.name) ? ">" : "<");
335 greg 2.2 root->pi[i][j + 1] = NULL; /* null terminate pi list for this target */
336     root->pi[i][j] = s; /* set instruction */
337 greg 2.1 }
338
339 greg 2.2 /* called when the parser finds an internal doctype subset */
340 greg 2.1 short ezxml_internal_dtd(ezxml_root_t root, char *s, size_t len)
341     {
342     char q, *c, *t, *n = NULL, *v, **ent, **pe;
343     int i, j;
344
345     pe = memcpy(malloc(sizeof(EZXML_NIL)), EZXML_NIL, sizeof(EZXML_NIL));
346
347     for (s[len] = '\0'; s; ) {
348 greg 2.2 while (*s && *s != '<' && *s != '%') s++; /* find next declaration */
349 greg 2.1
350     if (! *s) break;
351 greg 2.2 else if (! strncmp(s, "<!ENTITY", 8)) { /* parse entity definitions */
352     c = s += strspn(s + 8, EZXML_WS) + 8; /* skip white space separator */
353     n = s + strspn(s, EZXML_WS "%"); /* find name */
354     *(s = n + strcspn(n, EZXML_WS)) = ';'; /* append ; to name */
355 greg 2.1
356 greg 2.2 v = s + strspn(s + 1, EZXML_WS) + 1; /* find value */
357     if ((q = *(v++)) != '"' && q != '\'') { /* skip externals */
358 greg 2.1 s = strchr(s, '>');
359     continue;
360     }
361
362     for (i = 0, ent = (*c == '%') ? pe : root->ent; ent[i]; i++);
363 greg 2.2 ent = realloc(ent, (i + 3) * sizeof(char *)); /* space for next ent */
364 greg 2.1 if (*c == '%') pe = ent;
365     else root->ent = ent;
366
367 greg 2.2 *(++s) = '\0'; /* null terminate name */
368     if ((s = strchr(v, q))) *(s++) = '\0'; /* null terminate value */
369     ent[i + 1] = ezxml_decode(v, pe, '%'); /* set value */
370     ent[i + 2] = NULL; /* null terminate entity list */
371     if (! ezxml_ent_ok(n, ent[i + 1], ent)) { /* circular reference */
372 greg 2.1 if (ent[i + 1] != v) free(ent[i + 1]);
373     ezxml_err(root, v, "circular entity declaration &%s", n);
374     break;
375     }
376 greg 2.2 else ent[i] = n; /* set entity name */
377 greg 2.1 }
378 greg 2.2 else if (! strncmp(s, "<!ATTLIST", 9)) { /* parse default attributes */
379     t = s + strspn(s + 9, EZXML_WS) + 9; /* skip whitespace separator */
380 greg 2.1 if (! *t) { ezxml_err(root, t, "unclosed <!ATTLIST"); break; }
381     if (*(s = t + strcspn(t, EZXML_WS ">")) == '>') continue;
382 greg 2.2 else *s = '\0'; /* null terminate tag name */
383 greg 2.1 for (i = 0; root->attr[i] && strcmp(n, root->attr[i][0]); i++);
384 greg 2.6 ++s;
385     while (*(n = s + strspn(s, EZXML_WS)) && *n != '>') {
386 greg 2.2 if (*(s = n + strcspn(n, EZXML_WS))) *s = '\0'; /* attr name */
387 greg 2.1 else { ezxml_err(root, t, "malformed <!ATTLIST"); break; }
388
389 greg 2.2 s += strspn(s + 1, EZXML_WS) + 1; /* find next token */
390     c = (strncmp(s, "CDATA", 5)) ? "*" : " "; /* is it cdata? */
391 greg 2.1 if (! strncmp(s, "NOTATION", 8))
392     s += strspn(s + 8, EZXML_WS) + 8;
393     s = (*s == '(') ? strchr(s, ')') : s + strcspn(s, EZXML_WS);
394     if (! s) { ezxml_err(root, t, "malformed <!ATTLIST"); break; }
395
396 greg 2.2 s += strspn(s, EZXML_WS ")"); /* skip white space separator */
397 greg 2.1 if (! strncmp(s, "#FIXED", 6))
398     s += strspn(s + 6, EZXML_WS) + 6;
399 greg 2.2 if (*s == '#') { /* no default value */
400 greg 2.1 s += strcspn(s, EZXML_WS ">") - 1;
401 greg 2.2 if (*c == ' ') continue; /* cdata is default, nothing to do */
402 greg 2.1 v = NULL;
403     }
404 greg 2.2 else if ((*s == '"' || *s == '\'') && /* default value */
405 greg 2.1 (s = strchr(v = s + 1, *s))) *s = '\0';
406     else { ezxml_err(root, t, "malformed <!ATTLIST"); break; }
407
408 greg 2.2 if (! root->attr[i]) { /* new tag name */
409 greg 2.1 root->attr = (! i) ? malloc(2 * sizeof(char **))
410     : realloc(root->attr,
411     (i + 2) * sizeof(char **));
412     root->attr[i] = malloc(2 * sizeof(char *));
413 greg 2.2 root->attr[i][0] = t; /* set tag name */
414 greg 2.1 root->attr[i][1] = (char *)(root->attr[i + 1] = NULL);
415     }
416
417 greg 2.2 for (j = 1; root->attr[i][j]; j += 3); /* find end of list */
418 greg 2.1 root->attr[i] = realloc(root->attr[i],
419     (j + 4) * sizeof(char *));
420
421 greg 2.2 root->attr[i][j + 3] = NULL; /* null terminate list */
422     root->attr[i][j + 2] = c; /* is it cdata? */
423 greg 2.1 root->attr[i][j + 1] = (v) ? ezxml_decode(v, root->ent, *c)
424     : NULL;
425 greg 2.2 root->attr[i][j] = n; /* attribute name */
426 greg 2.6 ++s;
427 greg 2.1 }
428     }
429 greg 2.2 else if (! strncmp(s, "<!--", 4)) s = strstr(s + 4, "-->"); /* comments */
430     else if (! strncmp(s, "<?", 2)) { /* processing instructions */
431 greg 2.1 if ((s = strstr(c = s + 2, "?>")))
432     ezxml_proc_inst(root, c, s++ - c);
433     }
434 greg 2.2 else if (*s == '<') s = strchr(s, '>'); /* skip other declarations */
435 greg 2.1 else if (*(s++) == '%' && ! root->standalone) break;
436     }
437
438     free(pe);
439     return ! *root->err;
440     }
441
442 greg 2.2 /* Converts a UTF-16 string to UTF-8. Returns a new string that must be freed */
443     /* or NULL if no conversion was needed. */
444 greg 2.1 char *ezxml_str2utf8(char **s, size_t *len)
445     {
446     char *u;
447     size_t l = 0, sl, max = *len;
448     long c, d;
449     int b, be = (**s == '\xFE') ? 1 : (**s == '\xFF') ? 0 : -1;
450
451 greg 2.2 if (be == -1) return NULL; /* not UTF-16 */
452 greg 2.1
453     u = malloc(max);
454     for (sl = 2; sl < *len - 1; sl += 2) {
455 greg 2.2 c = (be) ? (((*s)[sl] & 0xFF) << 8) | ((*s)[sl + 1] & 0xFF) /*UTF-16BE */
456     : (((*s)[sl + 1] & 0xFF) << 8) | ((*s)[sl] & 0xFF); /*UTF-16LE */
457     if (c >= 0xD800 && c <= 0xDFFF && (sl += 2) < *len - 1) { /* high-half */
458 greg 2.1 d = (be) ? (((*s)[sl] & 0xFF) << 8) | ((*s)[sl + 1] & 0xFF)
459     : (((*s)[sl + 1] & 0xFF) << 8) | ((*s)[sl] & 0xFF);
460     c = (((c & 0x3FF) << 10) | (d & 0x3FF)) + 0x10000;
461     }
462
463     while (l + 6 > max) u = realloc(u, max += EZXML_BUFSIZE);
464 greg 2.2 if (c < 0x80) u[l++] = c; /* US-ASCII subset */
465     else { /* multi-byte UTF-8 sequence */
466     for (b = 0, d = c; d; d /= 2) b++; /* bits in c */
467     b = (b - 2) / 5; /* bytes in payload */
468     u[l++] = (0xFF << (7 - b)) | (c >> (6 * b)); /* head */
469     while (b) u[l++] = 0x80 | ((c >> (6 * --b)) & 0x3F); /* payload */
470 greg 2.1 }
471     }
472     return *s = realloc(u, *len = l);
473     }
474
475 greg 2.2 /* frees a tag attribute list */
476 greg 2.1 void ezxml_free_attr(char **attr) {
477     int i = 0;
478     char *m;
479
480 greg 2.2 if (! attr || attr == EZXML_NIL) return; /* nothing to free */
481     while (attr[i]) i += 2; /* find end of attribute list */
482     m = attr[i + 1]; /* list of which names and values are malloced */
483 greg 2.1 for (i = 0; m[i]; i++) {
484     if (m[i] & EZXML_NAMEM) free(attr[i * 2]);
485     if (m[i] & EZXML_TXTM) free(attr[(i * 2) + 1]);
486     }
487     free(m);
488     free(attr);
489     }
490
491 greg 2.2 /* parse the given xml string and return an ezxml structure */
492 greg 2.1 ezxml_t ezxml_parse_str(char *s, size_t len)
493     {
494     ezxml_root_t root = (ezxml_root_t)ezxml_new(NULL);
495 greg 2.2 char q, e, *d, **attr, **a = NULL; /* initialize a to avoid compile warning */
496 greg 2.1 int l, i, j;
497
498     root->m = s;
499     if (! len) return ezxml_err(root, NULL, "root tag missing");
500 greg 2.2 root->u = ezxml_str2utf8(&s, &len); /* convert utf-16 to utf-8 */
501     root->e = (root->s = s) + len; /* record start and end of work area */
502 greg 2.1
503 greg 2.2 e = s[len - 1]; /* save end char */
504     s[len - 1] = '\0'; /* turn end char into null terminator */
505 greg 2.1
506 greg 2.2 while (*s && *s != '<') s++; /* find first tag */
507 greg 2.1 if (! *s) return ezxml_err(root, s, "root tag missing");
508
509     for (; ; ) {
510     attr = (char **)EZXML_NIL;
511     d = ++s;
512
513 greg 2.2 if (isalpha(*s) || *s == '_' || *s == ':' || *s < '\0') { /* new tag */
514 greg 2.1 if (! root->cur)
515     return ezxml_err(root, d, "markup outside of root element");
516
517     s += strcspn(s, EZXML_WS "/>");
518 greg 2.2 while (isspace(*s)) *(s++) = '\0'; /* null terminate tag name */
519 greg 2.1
520 greg 2.2 if (*s && *s != '/' && *s != '>') /* find tag in default attr list */
521 greg 2.1 for (i = 0; (a = root->attr[i]) && strcmp(a[0], d); i++);
522
523 greg 2.2 for (l = 0; *s && *s != '/' && *s != '>'; l += 2) { /* new attrib */
524 greg 2.1 attr = (l) ? realloc(attr, (l + 4) * sizeof(char *))
525 greg 2.2 : malloc(4 * sizeof(char *)); /* allocate space */
526 greg 2.1 attr[l + 3] = (l) ? realloc(attr[l + 1], (l / 2) + 2)
527 greg 2.2 : malloc(2); /* mem for list of maloced vals */
528     strcpy(attr[l + 3] + (l / 2), " "); /* value is not malloced */
529     attr[l + 2] = NULL; /* null terminate list */
530     attr[l + 1] = ""; /* temporary attribute value */
531     attr[l] = s; /* set attribute name */
532 greg 2.1
533     s += strcspn(s, EZXML_WS "=/>");
534     if (*s == '=' || isspace(*s)) {
535 greg 2.2 *(s++) = '\0'; /* null terminate tag attribute name */
536 greg 2.1 q = *(s += strspn(s, EZXML_WS "="));
537 greg 2.2 if (q == '"' || q == '\'') { /* attribute value */
538 greg 2.1 attr[l + 1] = ++s;
539     while (*s && *s != q) s++;
540 greg 2.2 if (*s) *(s++) = '\0'; /* null terminate attribute val */
541 greg 2.1 else {
542     ezxml_free_attr(attr);
543     return ezxml_err(root, d, "missing %c", q);
544     }
545
546     for (j = 1; a && a[j] && strcmp(a[j], attr[l]); j +=3);
547     attr[l + 1] = ezxml_decode(attr[l + 1], root->ent, (a
548     && a[j]) ? *a[j + 2] : ' ');
549     if (attr[l + 1] < d || attr[l + 1] > s)
550 greg 2.2 attr[l + 3][l / 2] = EZXML_TXTM; /* value malloced */
551 greg 2.1 }
552     }
553     while (isspace(*s)) s++;
554     }
555
556 greg 2.2 if (*s == '/') { /* self closing tag */
557 greg 2.1 *(s++) = '\0';
558     if ((*s && *s != '>') || (! *s && e != '>')) {
559     if (l) ezxml_free_attr(attr);
560     return ezxml_err(root, d, "missing >");
561     }
562     ezxml_open_tag(root, d, attr);
563     ezxml_close_tag(root, d, s);
564     }
565 greg 2.2 else if ((q = *s) == '>' || (! *s && e == '>')) { /* open tag */
566     *s = '\0'; /* temporarily null terminate tag name */
567 greg 2.1 ezxml_open_tag(root, d, attr);
568     *s = q;
569     }
570     else {
571     if (l) ezxml_free_attr(attr);
572     return ezxml_err(root, d, "missing >");
573     }
574     }
575 greg 2.2 else if (*s == '/') { /* close tag */
576 greg 2.1 s += strcspn(d = s + 1, EZXML_WS ">") + 1;
577     if (! (q = *s) && e != '>') return ezxml_err(root, d, "missing >");
578 greg 2.2 *s = '\0'; /* temporarily null terminate tag name */
579 greg 2.1 if (ezxml_close_tag(root, d, s)) return &root->xml;
580     if (isspace(*s = q)) s += strspn(s, EZXML_WS);
581     }
582 greg 2.2 else if (! strncmp(s, "!--", 3)) { /* xml comment */
583 greg 2.1 if (! (s = strstr(s + 3, "--")) || (*(s += 2) != '>' && *s) ||
584     (! *s && e != '>')) return ezxml_err(root, d, "unclosed <!--");
585     }
586 greg 2.2 else if (! strncmp(s, "![CDATA[", 8)) { /* cdata */
587 greg 2.1 if ((s = strstr(s, "]]>")))
588     ezxml_char_content(root, d + 8, (s += 2) - d - 10, 'c');
589     else return ezxml_err(root, d, "unclosed <![CDATA[");
590     }
591 greg 2.2 else if (! strncmp(s, "!DOCTYPE", 8)) { /* dtd */
592 greg 2.1 for (l = 0; *s && ((! l && *s != '>') || (l && (*s != ']' ||
593     *(s + strspn(s + 1, EZXML_WS) + 1) != '>')));
594     l = (*s == '[') ? 1 : l) s += strcspn(s + 1, "[]>") + 1;
595     if (! *s && e != '>')
596     return ezxml_err(root, d, "unclosed <!DOCTYPE");
597     d = (l) ? strchr(d, '[') + 1 : d;
598     if (l && ! ezxml_internal_dtd(root, d, s++ - d)) return &root->xml;
599     }
600 greg 2.2 else if (*s == '?') { /* <?...?> processing instructions */
601 greg 2.1 do { s = strchr(s, '?'); } while (s && *(++s) && *s != '>');
602     if (! s || (! *s && e != '>'))
603     return ezxml_err(root, d, "unclosed <?");
604     else ezxml_proc_inst(root, d + 1, s - d - 2);
605     }
606     else return ezxml_err(root, d, "unexpected <");
607
608     if (! s || ! *s) break;
609     *s = '\0';
610     d = ++s;
611 greg 2.2 if (*s && *s != '<') { /* tag character content */
612 greg 2.1 while (*s && *s != '<') s++;
613     if (*s) ezxml_char_content(root, d, s - d, '&');
614     else break;
615     }
616     else if (! *s) break;
617     }
618
619     if (! root->cur) return &root->xml;
620     else if (! root->cur->name) return ezxml_err(root, d, "root tag missing");
621     else return ezxml_err(root, d, "unclosed tag <%s>", root->cur->name);
622     }
623
624 greg 2.2 /* Wrapper for ezxml_parse_str() that accepts a file stream. Reads the entire */
625     /* stream into memory and then parses it. For xml files, use ezxml_parse_file() */
626     /* or ezxml_parse_fd() */
627 greg 2.1 ezxml_t ezxml_parse_fp(FILE *fp)
628     {
629     ezxml_root_t root;
630     size_t l, len = 0;
631     char *s;
632
633     if (! (s = malloc(EZXML_BUFSIZE))) return NULL;
634     do {
635     len += (l = fread((s + len), 1, EZXML_BUFSIZE, fp));
636     if (l == EZXML_BUFSIZE) s = realloc(s, len + EZXML_BUFSIZE);
637     } while (s && l == EZXML_BUFSIZE);
638
639     if (! s) return NULL;
640     root = (ezxml_root_t)ezxml_parse_str(s, len);
641 greg 2.2 root->len = -1; /* so we know to free s in ezxml_free() */
642 greg 2.1 return &root->xml;
643     }
644
645 greg 2.2 /* A wrapper for ezxml_parse_str() that accepts a file descriptor. First */
646     /* attempts to mem map the file. Failing that, reads the file into memory. */
647     /* Returns NULL on failure. */
648 greg 2.1 ezxml_t ezxml_parse_fd(int fd)
649     {
650     ezxml_root_t root;
651     struct stat st;
652     size_t l;
653     void *m;
654
655     if (fd < 0) return NULL;
656     fstat(fd, &st);
657
658     #ifndef EZXML_NOMMAP
659     l = (st.st_size + sysconf(_SC_PAGESIZE) - 1) & ~(sysconf(_SC_PAGESIZE) -1);
660     if ((m = mmap(NULL, l, PROT_READ|PROT_WRITE, MAP_PRIVATE, fd, 0))
661     != MAP_FAILED) {
662 greg 2.2 madvise(m, l, MADV_SEQUENTIAL); /* optimize for sequential access */
663 greg 2.1 root = (ezxml_root_t)ezxml_parse_str(m, st.st_size);
664 greg 2.2 madvise(m, root->len = l, MADV_NORMAL); /* put it back to normal */
665 greg 2.1 }
666 greg 2.2 else { /* mmap failed, read file into memory */
667     #endif /* EZXML_NOMMAP */
668 greg 2.1 l = read(fd, m = malloc(st.st_size), st.st_size);
669     root = (ezxml_root_t)ezxml_parse_str(m, l);
670 greg 2.2 root->len = -1; /* so we know to free s in ezxml_free() */
671 greg 2.1 #ifndef EZXML_NOMMAP
672     }
673 greg 2.2 #endif /* EZXML_NOMMAP */
674 greg 2.1 return &root->xml;
675     }
676
677 greg 2.2 /* a wrapper for ezxml_parse_fd that accepts a file name */
678 greg 2.1 ezxml_t ezxml_parse_file(const char *file)
679     {
680     int fd = open(file, O_RDONLY, 0);
681     ezxml_t xml = ezxml_parse_fd(fd);
682
683     if (fd >= 0) close(fd);
684     return xml;
685     }
686
687 greg 2.2 /* Encodes ampersand sequences appending the results to *dst, reallocating *dst */
688     /* if length excedes max. a is non-zero for attribute encoding. Returns *dst */
689 greg 2.1 char *ezxml_ampencode(const char *s, size_t len, char **dst, size_t *dlen,
690     size_t *max, short a)
691     {
692     const char *e;
693
694     for (e = s + len; s != e; s++) {
695     while (*dlen + 10 > *max) *dst = realloc(*dst, *max += EZXML_BUFSIZE);
696
697     switch (*s) {
698     case '\0': return *dst;
699     case '&': *dlen += sprintf(*dst + *dlen, "&amp;"); break;
700     case '<': *dlen += sprintf(*dst + *dlen, "&lt;"); break;
701     case '>': *dlen += sprintf(*dst + *dlen, "&gt;"); break;
702     case '"': *dlen += sprintf(*dst + *dlen, (a) ? "&quot;" : "\""); break;
703     case '\n': *dlen += sprintf(*dst + *dlen, (a) ? "&#xA;" : "\n"); break;
704     case '\t': *dlen += sprintf(*dst + *dlen, (a) ? "&#x9;" : "\t"); break;
705     case '\r': *dlen += sprintf(*dst + *dlen, "&#xD;"); break;
706     default: (*dst)[(*dlen)++] = *s;
707     }
708     }
709     return *dst;
710     }
711
712 greg 2.2 /* Recursively converts each tag to xml appending it to *s. Reallocates *s if */
713     /* its length excedes max. start is the location of the previous tag in the */
714     /* parent tag's character content. Returns *s. */
715 greg 2.1 char *ezxml_toxml_r(ezxml_t xml, char **s, size_t *len, size_t *max,
716     size_t start, char ***attr)
717     {
718     int i, j;
719     char *txt = (xml->parent) ? xml->parent->txt : "";
720     size_t off = 0;
721
722 greg 2.2 /* parent character content up to this tag */
723 greg 2.1 *s = ezxml_ampencode(txt + start, xml->off - start, s, len, max, 0);
724
725 greg 2.2 while (*len + strlen(xml->name) + 4 > *max) /* reallocate s */
726 greg 2.1 *s = realloc(*s, *max += EZXML_BUFSIZE);
727
728 greg 2.2 *len += sprintf(*s + *len, "<%s", xml->name); /* open tag */
729     for (i = 0; xml->attr[i]; i += 2) { /* tag attributes */
730 greg 2.1 if (ezxml_attr(xml, xml->attr[i]) != xml->attr[i + 1]) continue;
731 greg 2.2 while (*len + strlen(xml->attr[i]) + 7 > *max) /* reallocate s */
732 greg 2.1 *s = realloc(*s, *max += EZXML_BUFSIZE);
733
734     *len += sprintf(*s + *len, " %s=\"", xml->attr[i]);
735     ezxml_ampencode(xml->attr[i + 1], -1, s, len, max, 1);
736     *len += sprintf(*s + *len, "\"");
737     }
738
739     for (i = 0; attr[i] && strcmp(attr[i][0], xml->name); i++);
740 greg 2.2 for (j = 1; attr[i] && attr[i][j]; j += 3) { /* default attributes */
741 greg 2.1 if (! attr[i][j + 1] || ezxml_attr(xml, attr[i][j]) != attr[i][j + 1])
742 greg 2.2 continue; /* skip duplicates and non-values */
743     while (*len + strlen(attr[i][j]) + 7 > *max) /* reallocate s */
744 greg 2.1 *s = realloc(*s, *max += EZXML_BUFSIZE);
745
746     *len += sprintf(*s + *len, " %s=\"", attr[i][j]);
747     ezxml_ampencode(attr[i][j + 1], -1, s, len, max, 1);
748     *len += sprintf(*s + *len, "\"");
749     }
750     *len += sprintf(*s + *len, ">");
751
752 greg 2.2 *s = (xml->child) ? ezxml_toxml_r(xml->child, s, len, max, 0, attr) /*child */
753     : ezxml_ampencode(xml->txt, -1, s, len, max, 0); /*data */
754 greg 2.1
755 greg 2.2 while (*len + strlen(xml->name) + 4 > *max) /* reallocate s */
756 greg 2.1 *s = realloc(*s, *max += EZXML_BUFSIZE);
757
758 greg 2.2 *len += sprintf(*s + *len, "</%s>", xml->name); /* close tag */
759 greg 2.1
760 greg 2.2 while (txt[off] && off < xml->off) off++; /* make sure off is within bounds */
761 greg 2.1 return (xml->ordered) ? ezxml_toxml_r(xml->ordered, s, len, max, off, attr)
762     : ezxml_ampencode(txt + off, -1, s, len, max, 0);
763     }
764
765 greg 2.2 /* Converts an ezxml structure back to xml. Returns a string of xml data that */
766     /* must be freed. */
767 greg 2.1 char *ezxml_toxml(ezxml_t xml)
768     {
769     ezxml_t p = (xml) ? xml->parent : NULL, o = (xml) ? xml->ordered : NULL;
770     ezxml_root_t root = (ezxml_root_t)xml;
771     size_t len = 0, max = EZXML_BUFSIZE;
772     char *s = strcpy(malloc(max), ""), *t, *n;
773     int i, j, k;
774
775     if (! xml || ! xml->name) return realloc(s, len + 1);
776 greg 2.2 while (root->xml.parent) root = (ezxml_root_t)root->xml.parent; /* root tag */
777 greg 2.1
778 greg 2.2 for (i = 0; ! p && root->pi[i]; i++) { /* pre-root processing instructions */
779 greg 2.1 for (k = 2; root->pi[i][k - 1]; k++);
780     for (j = 1; (n = root->pi[i][j]); j++) {
781 greg 2.2 if (root->pi[i][k][j - 1] == '>') continue; /* not pre-root */
782 greg 2.1 while (len + strlen(t = root->pi[i][0]) + strlen(n) + 7 > max)
783     s = realloc(s, max += EZXML_BUFSIZE);
784     len += sprintf(s + len, "<?%s%s%s?>\n", t, *n ? " " : "", n);
785     }
786     }
787
788     xml->parent = xml->ordered = NULL;
789     s = ezxml_toxml_r(xml, &s, &len, &max, 0, root->attr);
790     xml->parent = p;
791     xml->ordered = o;
792
793 greg 2.2 for (i = 0; ! p && root->pi[i]; i++) { /* post-root processing instructions */
794 greg 2.1 for (k = 2; root->pi[i][k - 1]; k++);
795     for (j = 1; (n = root->pi[i][j]); j++) {
796 greg 2.2 if (root->pi[i][k][j - 1] == '<') continue; /* not post-root */
797 greg 2.1 while (len + strlen(t = root->pi[i][0]) + strlen(n) + 7 > max)
798     s = realloc(s, max += EZXML_BUFSIZE);
799     len += sprintf(s + len, "\n<?%s%s%s?>", t, *n ? " " : "", n);
800     }
801     }
802     return realloc(s, len + 1);
803     }
804
805 greg 2.2 /* free the memory allocated for the ezxml structure */
806 greg 2.1 void ezxml_free(ezxml_t xml)
807     {
808     ezxml_root_t root = (ezxml_root_t)xml;
809     int i, j;
810     char **a, *s;
811
812     if (! xml) return;
813     ezxml_free(xml->child);
814     ezxml_free(xml->ordered);
815
816 greg 2.2 if (! xml->parent) { /* free root tag allocations */
817     for (i = 10; root->ent[i]; i += 2) /* 0 - 9 are default entites (<>&"') */
818 greg 2.1 if ((s = root->ent[i + 1]) < root->s || s > root->e) free(s);
819 greg 2.2 free(root->ent); /* free list of general entities */
820 greg 2.1
821     for (i = 0; (a = root->attr[i]); i++) {
822 greg 2.2 for (j = 1; a[j++]; j += 2) /* free malloced attribute values */
823 greg 2.1 if (a[j] && (a[j] < root->s || a[j] > root->e)) free(a[j]);
824     free(a);
825     }
826 greg 2.2 if (root->attr[0]) free(root->attr); /* free default attribute list */
827 greg 2.1
828     for (i = 0; root->pi[i]; i++) {
829     for (j = 1; root->pi[i][j]; j++);
830     free(root->pi[i][j + 1]);
831     free(root->pi[i]);
832     }
833 greg 2.2 if (root->pi[0]) free(root->pi); /* free processing instructions */
834 greg 2.1
835 greg 2.2 if (root->len == -1) free(root->m); /* malloced xml data */
836 greg 2.1 #ifndef EZXML_NOMMAP
837 greg 2.2 else if (root->len) munmap(root->m, root->len); /* mem mapped xml data */
838     #endif /* EZXML_NOMMAP */
839     if (root->u) free(root->u); /* utf8 conversion */
840 greg 2.1 }
841
842 greg 2.2 ezxml_free_attr(xml->attr); /* tag attributes */
843     if ((xml->flags & EZXML_TXTM)) free(xml->txt); /* character content */
844     if ((xml->flags & EZXML_NAMEM)) free(xml->name); /* tag name */
845 greg 2.1 free(xml);
846     }
847
848 greg 2.2 /* return parser error message or empty string if none */
849 greg 2.1 const char *ezxml_error(ezxml_t xml)
850     {
851 greg 2.2 while (xml && xml->parent) xml = xml->parent; /* find root tag */
852 greg 2.1 return (xml) ? ((ezxml_root_t)xml)->err : "";
853     }
854
855 greg 2.2 /* returns a new empty ezxml structure with the given root tag name */
856 greg 2.1 ezxml_t ezxml_new(const char *name)
857     {
858     static char *ent[] = { "lt;", "&#60;", "gt;", "&#62;", "quot;", "&#34;",
859     "apos;", "&#39;", "amp;", "&#38;", NULL };
860     ezxml_root_t root = (ezxml_root_t)memset(malloc(sizeof(struct ezxml_root)),
861     '\0', sizeof(struct ezxml_root));
862     root->xml.name = (char *)name;
863     root->cur = &root->xml;
864     strcpy(root->err, root->xml.txt = "");
865     root->ent = memcpy(malloc(sizeof(ent)), ent, sizeof(ent));
866     root->attr = root->pi = (char ***)(root->xml.attr = EZXML_NIL);
867     return &root->xml;
868     }
869
870 greg 2.2 /* inserts an existing tag into an ezxml structure */
871 greg 2.1 ezxml_t ezxml_insert(ezxml_t xml, ezxml_t dest, size_t off)
872     {
873     ezxml_t cur, prev, head;
874
875     xml->next = xml->sibling = xml->ordered = NULL;
876     xml->off = off;
877     xml->parent = dest;
878
879 greg 2.2 if ((head = dest->child)) { /* already have sub tags */
880     if (head->off <= off) { /* not first subtag */
881 greg 2.1 for (cur = head; cur->ordered && cur->ordered->off <= off;
882     cur = cur->ordered);
883     xml->ordered = cur->ordered;
884     cur->ordered = xml;
885     }
886 greg 2.2 else { /* first subtag */
887 greg 2.1 xml->ordered = head;
888     dest->child = xml;
889     }
890
891     for (cur = head, prev = NULL; cur && strcmp(cur->name, xml->name);
892 greg 2.2 prev = cur, cur = cur->sibling); /* find tag type */
893     if (cur && cur->off <= off) { /* not first of type */
894 greg 2.1 while (cur->next && cur->next->off <= off) cur = cur->next;
895     xml->next = cur->next;
896     cur->next = xml;
897     }
898 greg 2.2 else { /* first tag of this type */
899     if (prev && cur) prev->sibling = cur->sibling; /* remove old first */
900     xml->next = cur; /* old first tag is now next */
901 greg 2.1 for (cur = head, prev = NULL; cur && cur->off <= off;
902 greg 2.2 prev = cur, cur = cur->sibling); /* new sibling insert point */
903 greg 2.1 xml->sibling = cur;
904     if (prev) prev->sibling = xml;
905     }
906     }
907 greg 2.2 else dest->child = xml; /* only sub tag */
908 greg 2.1
909     return xml;
910     }
911
912 greg 2.2 /* Adds a child tag. off is the offset of the child tag relative to the start */
913     /* of the parent tag's character content. Returns the child tag. */
914 greg 2.1 ezxml_t ezxml_add_child(ezxml_t xml, const char *name, size_t off)
915     {
916     ezxml_t child;
917
918     if (! xml) return NULL;
919     child = (ezxml_t)memset(malloc(sizeof(struct ezxml)), '\0',
920     sizeof(struct ezxml));
921     child->name = (char *)name;
922     child->attr = EZXML_NIL;
923     child->txt = "";
924
925     return ezxml_insert(child, xml, off);
926     }
927
928 greg 2.2 /* sets the character content for the given tag and returns the tag */
929 greg 2.1 ezxml_t ezxml_set_txt(ezxml_t xml, const char *txt)
930     {
931     if (! xml) return NULL;
932 greg 2.7 if (txt == xml->txt) return xml;
933 greg 2.2 if (xml->flags & EZXML_TXTM) free(xml->txt); /* existing txt was malloced */
934 greg 2.1 xml->flags &= ~EZXML_TXTM;
935     xml->txt = (char *)txt;
936     return xml;
937     }
938
939 greg 2.7 /* add text to the current character content, allocating memory as needed (GW) */
940     ezxml_t ezxml_add_txt(ezxml_t xml, const char *txt)
941     {
942     int len;
943     if (! xml) return NULL;
944     if (!*txt) return xml;
945     len = strlen(xml->txt) + strlen(txt) + 1;
946     if (xml->flags & EZXML_TXTM) {
947     xml->txt = (char *)realloc(xml->txt, len);
948     } else {
949     xml->txt = strcpy((char *)malloc(len), xml->txt);
950     xml->flags |= EZXML_TXTM;
951     }
952     strcat(xml->txt, txt);
953     return xml;
954     }
955
956 greg 2.2 /* Sets the given tag attribute or adds a new attribute if not found. A value */
957     /* of NULL will remove the specified attribute. Returns the tag given. */
958 greg 2.1 ezxml_t ezxml_set_attr(ezxml_t xml, const char *name, const char *value)
959     {
960     int l = 0, c;
961
962     if (! xml) return NULL;
963     while (xml->attr[l] && strcmp(xml->attr[l], name)) l += 2;
964 greg 2.2 if (! xml->attr[l]) { /* not found, add as new attribute */
965     if (! value) return xml; /* nothing to do */
966     if (xml->attr == EZXML_NIL) { /* first attribute */
967 greg 2.1 xml->attr = malloc(4 * sizeof(char *));
968 greg 2.2 xml->attr[1] = strdup(""); /* empty list of malloced names/vals */
969 greg 2.1 }
970     else xml->attr = realloc(xml->attr, (l + 4) * sizeof(char *));
971
972 greg 2.2 xml->attr[l] = (char *)name; /* set attribute name */
973     xml->attr[l + 2] = NULL; /* null terminate attribute list */
974 greg 2.1 xml->attr[l + 3] = realloc(xml->attr[l + 1],
975     (c = strlen(xml->attr[l + 1])) + 2);
976 greg 2.2 strcpy(xml->attr[l + 3] + c, " "); /* set name/value as not malloced */
977 greg 2.1 if (xml->flags & EZXML_DUP) xml->attr[l + 3][c] = EZXML_NAMEM;
978     }
979 greg 2.2 else if (xml->flags & EZXML_DUP) free((char *)name); /* name was strduped */
980 greg 2.1
981 greg 2.2 for (c = l; xml->attr[c]; c += 2); /* find end of attribute list */
982     if (xml->attr[c + 1][l / 2] & EZXML_TXTM) free(xml->attr[l + 1]); /*old val */
983 greg 2.1 if (xml->flags & EZXML_DUP) xml->attr[c + 1][l / 2] |= EZXML_TXTM;
984     else xml->attr[c + 1][l / 2] &= ~EZXML_TXTM;
985
986 greg 2.2 if (value) xml->attr[l + 1] = (char *)value; /* set attribute value */
987     else { /* remove attribute */
988 greg 2.1 if (xml->attr[c + 1][l / 2] & EZXML_NAMEM) free(xml->attr[l]);
989     memmove(xml->attr + l, xml->attr + l + 2, (c - l + 2) * sizeof(char*));
990     xml->attr = realloc(xml->attr, (c + 2) * sizeof(char *));
991     memmove(xml->attr[c + 1] + (l / 2), xml->attr[c + 1] + (l / 2) + 1,
992 greg 2.2 (c / 2) - (l / 2)); /* fix list of which name/vals are malloced */
993 greg 2.1 }
994 greg 2.2 xml->flags &= ~EZXML_DUP; /* clear strdup() flag */
995 greg 2.1 return xml;
996     }
997
998 greg 2.2 /* sets a flag for the given tag and returns the tag */
999 greg 2.1 ezxml_t ezxml_set_flag(ezxml_t xml, short flag)
1000     {
1001     if (xml) xml->flags |= flag;
1002     return xml;
1003     }
1004
1005 greg 2.2 /* removes a tag along with its subtags without freeing its memory */
1006 greg 2.1 ezxml_t ezxml_cut(ezxml_t xml)
1007     {
1008     ezxml_t cur;
1009
1010 greg 2.2 if (! xml) return NULL; /* nothing to do */
1011     if (xml->next) xml->next->sibling = xml->sibling; /* patch sibling list */
1012 greg 2.1
1013 greg 2.2 if (xml->parent) { /* not root tag */
1014     cur = xml->parent->child; /* find head of subtag list */
1015     if (cur == xml) xml->parent->child = xml->ordered; /* first subtag */
1016     else { /* not first subtag */
1017 greg 2.1 while (cur->ordered != xml) cur = cur->ordered;
1018 greg 2.2 cur->ordered = cur->ordered->ordered; /* patch ordered list */
1019 greg 2.1
1020 greg 2.2 cur = xml->parent->child; /* go back to head of subtag list */
1021     if (strcmp(cur->name, xml->name)) { /* not in first sibling list */
1022 greg 2.1 while (strcmp(cur->sibling->name, xml->name))
1023     cur = cur->sibling;
1024 greg 2.2 if (cur->sibling == xml) { /* first of a sibling list */
1025 greg 2.1 cur->sibling = (xml->next) ? xml->next
1026     : cur->sibling->sibling;
1027     }
1028 greg 2.2 else cur = cur->sibling; /* not first of a sibling list */
1029 greg 2.1 }
1030
1031     while (cur->next && cur->next != xml) cur = cur->next;
1032 greg 2.2 if (cur->next) cur->next = cur->next->next; /* patch next list */
1033 greg 2.1 }
1034     }
1035     xml->ordered = xml->sibling = xml->next = NULL;
1036     return xml;
1037     }
1038
1039 greg 2.2 #ifdef EZXML_TEST /* test harness */
1040 greg 2.1 int main(int argc, char **argv)
1041     {
1042     ezxml_t xml;
1043     char *s;
1044     int i;
1045
1046     if (argc != 2) return fprintf(stderr, "usage: %s xmlfile\n", argv[0]);
1047
1048     xml = ezxml_parse_file(argv[1]);
1049     printf("%s\n", (s = ezxml_toxml(xml)));
1050     free(s);
1051     i = fprintf(stderr, "%s", ezxml_error(xml));
1052     ezxml_free(xml);
1053     return (i) ? 1 : 0;
1054     }
1055 greg 2.2 #endif /* EZXML_TEST */
