root/radiance/src/common/disk2square.c
Revision: 3.2
Committed: Fri Feb 18 18:41:04 2011 UTC (14 years, 8 months ago) by greg
Changes since 3.1: +3 -0 lines
Added missing RCS tags
5 * Disk2Square.c
6 *
7 * Code by Peter Shirley and Kenneth Chiu
8 *
9 * Associated paper in ~/Documents/Others/Shirley+Chiu_JGT-97.pdf
10 *
11 * Modified interface slightly (G. Ward)
12 */
13
14 #include <math.h>
15
16 /*
17 This transforms points on [0,1]^2 to points on unit disk centered at
18 origin. Each "pie-slice" quadrant of square is handled as a seperate
19 case. The bad floating point cases are all handled appropriately.
20 The regions for (a,b) are:
21
22 phi = pi/2
23 -----*-----
24 |\ /|
25 | \ 2 / |
26 | \ / |
27 phi=pi* 3 * 1 *phi = 0
28 | / \ |
29 | / 4 \ |
30 |/ \|
31 -----*-----
32 phi = 3pi/2
33
34 change log:
35 26 feb 2004. bug fix in computation of phi (now this matches the paper,
36 which is correct). thanks to Atilim Cetin for catching this.
37 */
38
39
40 /* Map a [0,1]^2 square to a unit radius disk */
41 void
42 SDsquare2disk(double ds[2], double seedx, double seedy)
43 {
44
45 double phi, r;
46 double a = 2.*seedx - 1; /* (a,b) is now on [-1,1]^2 */
47 double b = 2.*seedy - 1;
48
49 if (a > -b) { /* region 1 or 2 */
50 if (a > b) { /* region 1, also |a| > |b| */
51 r = a;
52 phi = (M_PI/4.) * (b/a);
53 }
54 else { /* region 2, also |b| > |a| */
55 r = b;
56 phi = (M_PI/4.) * (2. - (a/b));
57 }
58 }
59 else { /* region 3 or 4 */
60 if (a < b) { /* region 3, also |a| >= |b|, a != 0 */
61 r = -a;
62 phi = (M_PI/4.) * (4. + (b/a));
63 }
64 else { /* region 4, |b| >= |a|, but a==0 and b==0 could occur. */
65 r = -b;
66 if (b != 0.)
67 phi = (M_PI/4.) * (6. - (a/b));
68 else
69 phi = 0.;
70 }
71 }
72
73 ds[0] = r * cos(phi);
74 ds[1] = r * sin(phi);
75
76 }
77
78 /* Map point on unit disk to a unit square in [0,1]^2 range */
79 void
80 SDdisk2square(double sq[2], double diskx, double disky)
81 {
82 double r = sqrt( diskx*diskx + disky*disky );
83 double phi = atan2( disky, diskx );
84 double a, b;
85
86 if (phi < -M_PI/4) phi += 2*M_PI; /* in range [-pi/4,7pi/4] */
87 if ( phi < M_PI/4) { /* region 1 */
88 a = r;
89 b = phi * a / (M_PI/4);
90 }
91 else if ( phi < 3*M_PI/4 ) { /* region 2 */
92 b = r;
93 a = -(phi - M_PI/2) * b / (M_PI/4);
94 }
95 else if ( phi < 5*M_PI/4 ) { /* region 3 */
96 a = -r;
97 b = (phi - M_PI) * a / (M_PI/4);
98 }
99 else { /* region 4 */
100 b = -r;
101 a = -(phi - 3*M_PI/2) * b / (M_PI/4);
102 }
103
104 sq[0] = (a + 1) * 0.5;
105 sq[1] = (b + 1) * 0.5;
106 }
