| 1 |
greg |
2.1 |
#ifndef lint |
| 2 |
greg |
2.8 |
static const char RCSid[] = "$Id: dircode.c,v 2.7 2003/06/27 06:53:21 greg Exp $"; |
| 3 |
greg |
2.1 |
#endif |
| 4 |
| 5 |
greg |
2.7 |
* Compute a 4-byte direction code (externals defined in rtmath.h). |
| 6 |
greg |
2.3 |
| 7 |
* Mean accuracy is 0.0022 degrees, with a maximum error of 0.0058 degrees. |
| 8 |
greg |
2.1 |
| 9 |
| 10 |
greg |
2.7 |
#include "rtmath.h" |
| 11 |
greg |
2.1 |
| 12 |
#define DCSCALE 11585.2 /* (1<<13)*sqrt(2) */ |
| 13 |
#define FXNEG 01 |
| 14 |
#define FYNEG 02 |
| 15 |
#define FZNEG 04 |
| 16 |
#define F1X 010 |
| 17 |
#define F2Z 020 |
| 18 |
#define F1SFT 5 |
| 19 |
#define F2SFT 18 |
| 20 |
#define FMASK 0x1fff |
| 21 |
| 22 |
greg |
2.5 |
int32 |
| 23 |
greg |
2.8 |
encodedir(FVECT dv) /* encode a normalized direction vector */ |
| 24 |
greg |
2.1 |
| 25 |
greg |
2.8 |
int32 dc = 0; |
| 26 |
greg |
2.1 |
int cd[3], cm; |
| 27 |
greg |
2.8 |
int i; |
| 28 |
greg |
2.1 |
| 29 |
for (i = 0; i < 3; i++) |
| 30 |
if (dv[i] < 0.) { |
| 31 |
schorsch |
2.4 |
cd[i] = (int)(dv[i] * -DCSCALE); |
| 32 |
greg |
2.1 |
dc |= FXNEG<<i; |
| 33 |
} else |
| 34 |
schorsch |
2.4 |
cd[i] = (int)(dv[i] * DCSCALE); |
| 35 |
greg |
2.6 |
if (!(cd[0] | cd[1] | cd[2])) |
| 36 |
return(0); /* zero normal */ |
| 37 |
greg |
2.1 |
if (cd[0] <= cd[1]) { |
| 38 |
dc |= F1X | cd[0] << F1SFT; |
| 39 |
cm = cd[1]; |
| 40 |
} else { |
| 41 |
dc |= cd[1] << F1SFT; |
| 42 |
cm = cd[0]; |
| 43 |
| 44 |
if (cd[2] <= cm) |
| 45 |
dc |= F2Z | cd[2] << F2SFT; |
| 46 |
else |
| 47 |
dc |= cm << F2SFT; |
| 48 |
greg |
2.6 |
if (!dc) /* don't generate 0 code normally */ |
| 49 |
greg |
2.2 |
dc = F1X; |
| 50 |
greg |
2.1 |
return(dc); |
| 51 |
| 52 |
| 53 |
| 54 |
void |
| 55 |
greg |
2.8 |
decodedir(FVECT dv, int32 dc) /* decode a normalized direction vector */ |
| 56 |
greg |
2.1 |
| 57 |
double d1, d2, der; |
| 58 |
| 59 |
greg |
2.6 |
if (!dc) { /* special code for zero normal */ |
| 60 |
dv[0] = dv[1] = dv[2] = 0.; |
| 61 |
return; |
| 62 |
| 63 |
greg |
2.1 |
d1 = ((dc>>F1SFT & FMASK)+.5)*(1./DCSCALE); |
| 64 |
d2 = ((dc>>F2SFT & FMASK)+.5)*(1./DCSCALE); |
| 65 |
der = sqrt(1. - d1*d1 - d2*d2); |
| 66 |
if (dc & F1X) { |
| 67 |
dv[0] = d1; |
| 68 |
if (dc & F2Z) { dv[1] = der; dv[2] = d2; } |
| 69 |
else { dv[1] = d2; dv[2] = der; } |
| 70 |
} else { |
| 71 |
dv[1] = d1; |
| 72 |
if (dc & F2Z) { dv[0] = der; dv[2] = d2; } |
| 73 |
else { dv[0] = d2; dv[2] = der; } |
| 74 |
| 75 |
if (dc & FXNEG) dv[0] = -dv[0]; |
| 76 |
if (dc & FYNEG) dv[1] = -dv[1]; |
| 77 |
if (dc & FZNEG) dv[2] = -dv[2]; |
| 78 |
| 79 |
| 80 |
| 81 |
double |
| 82 |
greg |
2.8 |
dir2diff(int32 dc1, int32 dc2) /* approx. radians^2 between directions */ |
| 83 |
greg |
2.1 |
| 84 |
FVECT v1, v2; |
| 85 |
| 86 |
decodedir(v1, dc1); |
| 87 |
decodedir(v2, dc2); |
| 88 |
| 89 |
return(2. - 2.*DOT(v1,v2)); |
| 90 |
| 91 |
| 92 |
| 93 |
double |
| 94 |
greg |
2.8 |
fdir2diff(int32 dc1, FVECT v2) /* approx. radians^2 between directions */ |
| 95 |
greg |
2.1 |
| 96 |
FVECT v1; |
| 97 |
| 98 |
| 99 |
| 100 |
| 101 |
