root/radiance/src/common/dircode.c
Fri Jun 27 06:53:21 2003 UTC (22 years, 3 months ago) by greg
Sat Jun 21 14:48:53 2003 UTC (22 years, 4 months ago) by greg
Handling of zero vectors in dircode.c and long long lseek fixes for holodecks
Fri Jun 20 00:25:49 2003 UTC (22 years, 4 months ago) by greg
Sat Jun 7 12:50:20 2003 UTC (22 years, 4 months ago) by schorsch
Wed Mar 12 04:59:04 2003 UTC (22 years, 7 months ago) by greg
Tue Mar 4 19:02:47 2003 UTC (22 years, 7 months ago) by greg
Diff to previous 2.1
Changed encodedir() so it never generates 0
Tue Mar 4 05:49:21 2003 UTC (22 years, 7 months ago) by greg
