root/radiance/src/common/cone.c
Fri Sep 16 15:09:21 2016 UTC (9 years, 1 month ago) by greg
CVS Tags: HEAD, rad5R1, rad5R2, rad5R3, rad5R4, rad6R0
Changes since 2.10: +4 -3 lines
Added checks for illegal cones/rings/cylinders
Thu Apr 21 00:40:35 2016 UTC (9 years, 6 months ago) by greg
Changes since 2.9: +19 -16 lines
Made zero cone and ring radii non-fatal (degenerate -> ignore)
Sun Jul 27 22:12:01 2003 UTC (22 years, 2 months ago) by schorsch
Thu Jun 26 00:58:09 2003 UTC (22 years, 4 months ago) by schorsch
Sat Jun 7 12:50:20 2003 UTC (22 years, 4 months ago) by schorsch
Tue Feb 25 02:47:21 2003 UTC (22 years, 7 months ago) by greg
Sat Feb 22 02:07:22 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.4: +61 -7 lines
Thu Nov 19 21:32:48 1992 UTC (32 years, 11 months ago) by greg
insignificant change to freecone()
Fri Oct 2 16:01:06 1992 UTC (33 years ago) by greg
Changes since 2.2: +0 -2 lines
Sun Sep 6 11:53:47 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.1: +39 -33 lines
major aesthetic changes -- made R0 always smaller than R1
Tue Nov 12 16:55:03 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.6 , to selected 2.6
Wed Oct 23 13:43:12 1991 UTC (34 years ago) by greg
Diff to previous 1.5 , to selected 2.6
Wed Jul 17 14:10:16 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.4 , to selected 2.6
made call to free structures more robust
Wed May 22 16:51:12 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.3: +30 -6 lines
Diff to previous 1.3 , to selected 2.6
made getcone VERY forgiving of improper input --
negative radii now result in warnings and altered types
Sat Jan 19 13:43:28 1991 UTC (34 years, 9 months ago) by greg
Diff to previous 1.2 , to selected 2.6
changed error checking to allow for slightly negative radii
Tue Feb 21 14:39:51 1989 UTC (36 years, 8 months ago) by greg
Diff to previous 1.1 , to selected 2.6
portability fixes for SGI
Thu Feb 2 10:34:30 1989 UTC (36 years, 8 months ago) by greg
Diff to selected 2.6
