| 1 | /* Copyright (c) 1986 Regents of the University of California */ |
| 2 |  |
| 3 | #ifndef lint |
| 4 | static char SCCSid[] = "$SunId$ LBL"; |
| 5 | #endif |
| 6 |  |
| 7 | /* |
| 8 | *  Compute data values using expression parser |
| 9 | * |
| 10 | *  7/1/85  Greg Ward |
| 11 | * |
| 12 | *  11/11/85  Made channel input conditional with (INCHAN) compiles. |
| 13 | * |
| 14 | *  4/2/86  Added conditional compiles for function definitions (FUNCTION). |
| 15 | * |
| 16 | *  1/29/87  Made variables conditional (VARIABLE) |
| 17 | * |
| 18 | *  5/19/88  Added constant subexpression elimination (RCONST) |
| 19 | */ |
| 20 |  |
| 21 | #include  <stdio.h> |
| 22 |  |
| 23 | #include  <ctype.h> |
| 24 |  |
| 25 | #include  <errno.h> |
| 26 |  |
| 27 | #include  "calcomp.h" |
| 28 |  |
| 29 | #define  MAXLINE        256             /* maximum line length */ |
| 30 | #define  MAXWORD        64              /* maximum word length */ |
| 31 |  |
| 32 | #define  newnode()      (EPNODE *)ecalloc(1, sizeof(EPNODE)) |
| 33 |  |
| 34 | #define  isid(c)        (isalnum(c) || (c) == '_' || (c) == '.') |
| 35 |  |
| 36 | #define  isdecimal(c)   (isdigit(c) || (c) == '.') |
| 37 |  |
| 38 | extern double  atof(), pow(); |
| 39 | extern char  *fgets(), *savestr(); |
| 40 | extern char  *emalloc(), *ecalloc(); |
| 41 | extern EPNODE  *curfunc; |
| 42 | extern double  efunc(), evariable(), enumber(), euminus(), echannel(); |
| 43 | extern double  eargument(), eadd(), esubtr(), emult(), edivi(), epow(); |
| 44 | extern double  ebotch(); |
| 45 | extern int  errno; |
| 46 |  |
| 47 | int  nextc;                             /* lookahead character */ |
| 48 |  |
| 49 | double  (*eoper[])() = {                /* expression operations */ |
| 50 | ebotch, |
| 51 | #ifdef  VARIABLE |
| 52 | evariable, |
| 53 | #else |
| 54 | ebotch, |
| 55 | #endif |
| 56 | enumber, |
| 57 | euminus, |
| 58 | #ifdef  INCHAN |
| 59 | echannel, |
| 60 | #else |
| 61 | ebotch, |
| 62 | #endif |
| 63 | #ifdef  FUNCTION |
| 64 | efunc, |
| 65 | eargument, |
| 66 | #else |
| 67 | ebotch, |
| 68 | ebotch, |
| 69 | #endif |
| 70 | ebotch, |
| 71 | ebotch, |
| 72 | 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, |
| 73 | 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, |
| 74 | emult, |
| 75 | eadd, |
| 76 | 0, |
| 77 | esubtr, |
| 78 | 0, |
| 79 | edivi, |
| 80 | 0,0,0,0,0,0,0,0,0,0,0,0,0, |
| 81 | ebotch, |
| 82 | 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, |
| 83 | 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, |
| 84 | epow, |
| 85 | }; |
| 86 |  |
| 87 | static char  *infile;                   /* input file name */ |
| 88 | static FILE  *infp;                     /* input file pointer */ |
| 89 | static char  *linbuf;                   /* line buffer */ |
| 90 | static int  linepos;                    /* position in buffer */ |
| 91 |  |
| 92 |  |
| 93 | EPNODE * |
| 94 | eparse(expr)                    /* parse an expression string */ |
| 95 | char  *expr; |
| 96 | { |
| 97 | EPNODE  *ep; |
| 98 |  |
| 99 | initstr(NULL, expr); |
| 100 | #if  defined(VARIABLE) && defined(FUNCTION) |
| 101 | curfunc = NULL; |
| 102 | #endif |
| 103 | ep = getE1(); |
| 104 | if (nextc != EOF) |
| 105 | syntax("unexpected character"); |
| 106 | return(ep); |
| 107 | } |
| 108 |  |
| 109 |  |
| 110 | double |
| 111 | eval(expr)                      /* evaluate an expression string */ |
| 112 | char  *expr; |
| 113 | { |
| 114 | register EPNODE  *ep; |
| 115 | double  rval; |
| 116 |  |
| 117 | ep = eparse(expr); |
| 118 | rval = evalue(ep); |
| 119 | epfree(ep); |
| 120 | return(rval); |
| 121 | } |
| 122 |  |
| 123 |  |
| 124 | epfree(epar)                    /* free a parse tree */ |
| 125 | register EPNODE  *epar; |
| 126 | { |
| 127 | register EPNODE  *ep; |
| 128 |  |
| 129 | switch (epar->type) { |
| 130 |  |
| 131 | #if  defined(VARIABLE) || defined(FUNCTION) |
| 132 | case VAR: |
| 133 | varfree(epar->v.ln); |
| 134 | break; |
| 135 | #endif |
| 136 |  |
| 137 | case SYM: |
| 138 | freestr(epar->v.name); |
| 139 | break; |
| 140 |  |
| 141 | case NUM: |
| 142 | case CHAN: |
| 143 | case ARG: |
| 144 | case TICK: |
| 145 | break; |
| 146 |  |
| 147 | default: |
| 148 | for (ep = epar->v.kid; ep != NULL; ep = ep->sibling) |
| 149 | epfree(ep); |
| 150 | break; |
| 151 |  |
| 152 | } |
| 153 |  |
| 154 | efree((char *)epar); |
| 155 | } |
| 156 |  |
| 157 | /* the following used to be a switch */ |
| 158 | #ifdef  FUNCTION |
| 159 | static double |
| 160 | eargument(ep) |
| 161 | EPNODE  *ep; |
| 162 | { |
| 163 | return(argument(ep->v.chan)); |
| 164 | } |
| 165 | #endif |
| 166 |  |
| 167 | static double |
| 168 | enumber(ep) |
| 169 | EPNODE  *ep; |
| 170 | { |
| 171 | return(ep->v.num); |
| 172 | } |
| 173 |  |
| 174 | static double |
| 175 | euminus(ep) |
| 176 | EPNODE  *ep; |
| 177 | { |
| 178 | register EPNODE  *ep1 = ep->v.kid; |
| 179 |  |
| 180 | return(-evalue(ep1)); |
| 181 | } |
| 182 |  |
| 183 | #ifdef  INCHAN |
| 184 | static double |
| 185 | echannel(ep) |
| 186 | EPNODE  *ep; |
| 187 | { |
| 188 | return(chanvalue(ep->v.chan)); |
| 189 | } |
| 190 | #endif |
| 191 |  |
| 192 | static double |
| 193 | eadd(ep) |
| 194 | EPNODE  *ep; |
| 195 | { |
| 196 | register EPNODE  *ep1 = ep->v.kid; |
| 197 |  |
| 198 | return(evalue(ep1) + evalue(ep1->sibling)); |
| 199 | } |
| 200 |  |
| 201 | static double |
| 202 | esubtr(ep) |
| 203 | EPNODE  *ep; |
| 204 | { |
| 205 | register EPNODE  *ep1 = ep->v.kid; |
| 206 |  |
| 207 | return(evalue(ep1) - evalue(ep1->sibling)); |
| 208 | } |
| 209 |  |
| 210 | static double |
| 211 | emult(ep) |
| 212 | EPNODE  *ep; |
| 213 | { |
| 214 | register EPNODE  *ep1 = ep->v.kid; |
| 215 |  |
| 216 | return(evalue(ep1) * evalue(ep1->sibling)); |
| 217 | } |
| 218 |  |
| 219 | static double |
| 220 | edivi(ep) |
| 221 | EPNODE  *ep; |
| 222 | { |
| 223 | register EPNODE  *ep1 = ep->v.kid; |
| 224 | double  d; |
| 225 |  |
| 226 | d = evalue(ep1->sibling); |
| 227 | if (d == 0.0) { |
| 228 | wputs("Division by zero\n"); |
| 229 | errno = ERANGE; |
| 230 | return(0.0); |
| 231 | } |
| 232 | return(evalue(ep1) / d); |
| 233 | } |
| 234 |  |
| 235 | static double |
| 236 | epow(ep) |
| 237 | EPNODE  *ep; |
| 238 | { |
| 239 | register EPNODE  *ep1 = ep->v.kid; |
| 240 | double  d; |
| 241 | int  lasterrno; |
| 242 |  |
| 243 | lasterrno = errno; |
| 244 | errno = 0; |
| 245 | d = pow(evalue(ep1), evalue(ep1->sibling)); |
| 246 | #ifdef  IEEE |
| 247 | if (!finite(d)) |
| 248 | errno = EDOM; |
| 249 | #endif |
| 250 | if (errno) { |
| 251 | wputs("Illegal power\n"); |
| 252 | return(0.0); |
| 253 | } |
| 254 | errno = lasterrno; |
| 255 | return(d); |
| 256 | } |
| 257 |  |
| 258 | static double |
| 259 | ebotch(ep) |
| 260 | EPNODE  *ep; |
| 261 | { |
| 262 | eputs("Bad expression!\n"); |
| 263 | quit(1); |
| 264 | } |
| 265 |  |
| 266 |  |
| 267 | EPNODE * |
| 268 | ekid(ep, n)                     /* return pointer to a node's nth kid */ |
| 269 | register EPNODE  *ep; |
| 270 | register int  n; |
| 271 | { |
| 272 |  |
| 273 | for (ep = ep->v.kid; ep != NULL; ep = ep->sibling) |
| 274 | if (--n < 0) |
| 275 | break; |
| 276 |  |
| 277 | return(ep); |
| 278 | } |
| 279 |  |
| 280 |  |
| 281 | int |
| 282 | nekids(ep)                      /* return # of kids for node ep */ |
| 283 | register EPNODE  *ep; |
| 284 | { |
| 285 | register int  n = 0; |
| 286 |  |
| 287 | for (ep = ep->v.kid; ep != NULL; ep = ep->sibling) |
| 288 | n++; |
| 289 |  |
| 290 | return(n); |
| 291 | } |
| 292 |  |
| 293 |  |
| 294 | initfile(file, fp)              /* prepare input file */ |
| 295 | char  *file; |
| 296 | FILE  *fp; |
| 297 | { |
| 298 | static char  inpbuf[MAXLINE]; |
| 299 |  |
| 300 | infile = file; |
| 301 | infp = fp; |
| 302 | linbuf = inpbuf; |
| 303 | linepos = 0; |
| 304 | inpbuf[0] = '\0'; |
| 305 | scan(); |
| 306 | } |
| 307 |  |
| 308 |  |
| 309 | initstr(file, s)                /* prepare input string */ |
| 310 | char  *file; |
| 311 | char  *s; |
| 312 | { |
| 313 | infile = file; |
| 314 | infp = NULL; |
| 315 | linbuf = s; |
| 316 | linepos = 0; |
| 317 | scan(); |
| 318 | } |
| 319 |  |
| 320 |  |
| 321 | scan()                          /* scan next character */ |
| 322 | { |
| 323 | do { |
| 324 | if (linbuf[linepos] == '\0') |
| 325 | if (infp == NULL || fgets(linbuf, MAXLINE, infp) == NULL) |
| 326 | nextc = EOF; |
| 327 | else { |
| 328 | nextc = linbuf[0]; |
| 329 | linepos = 1; |
| 330 | } |
| 331 | else |
| 332 | nextc = linbuf[linepos++]; |
| 333 | if (nextc == '{') { |
| 334 | scan(); |
| 335 | while (nextc != '}') |
| 336 | if (nextc == EOF) |
| 337 | syntax("'}' expected"); |
| 338 | else |
| 339 | scan(); |
| 340 | scan(); |
| 341 | } |
| 342 | } while (isspace(nextc)); |
| 343 | } |
| 344 |  |
| 345 |  |
| 346 | syntax(err)                     /* report syntax error and quit */ |
| 347 | char  *err; |
| 348 | { |
| 349 | register int  i; |
| 350 |  |
| 351 | eputs(linbuf); |
| 352 | if (linbuf[0] == '\0' || linbuf[strlen(linbuf)-1] != '\n') |
| 353 | eputs("\n"); |
| 354 | for (i = 0; i < linepos-1; i++) |
| 355 | eputs(linbuf[i] == '\t' ? "\t" : " "); |
| 356 | eputs("^ "); |
| 357 | if (infile != NULL) { |
| 358 | eputs(infile); |
| 359 | eputs(": "); |
| 360 | } |
| 361 | eputs(err); |
| 362 | eputs("\n"); |
| 363 | quit(1); |
| 364 | } |
| 365 |  |
| 366 |  |
| 367 | addekid(ep, ekid)                       /* add a child to ep */ |
| 368 | register EPNODE  *ep; |
| 369 | EPNODE  *ekid; |
| 370 | { |
| 371 | if (ep->v.kid == NULL) |
| 372 | ep->v.kid = ekid; |
| 373 | else { |
| 374 | for (ep = ep->v.kid; ep->sibling != NULL; ep = ep->sibling) |
| 375 | ; |
| 376 | ep->sibling = ekid; |
| 377 | } |
| 378 | ekid->sibling = NULL; |
| 379 | } |
| 380 |  |
| 381 |  |
| 382 | char * |
| 383 | getname()                       /* scan an identifier */ |
| 384 | { |
| 385 | static char  str[MAXWORD+1]; |
| 386 | register int  i; |
| 387 |  |
| 388 | for (i = 0; i < MAXWORD && isid(nextc); i++, scan()) |
| 389 | str[i] = nextc; |
| 390 | str[i] = '\0'; |
| 391 |  |
| 392 | return(str); |
| 393 | } |
| 394 |  |
| 395 |  |
| 396 | int |
| 397 | getinum()                       /* scan a positive integer */ |
| 398 | { |
| 399 | register int  n; |
| 400 |  |
| 401 | n = 0; |
| 402 | while (isdigit(nextc)) { |
| 403 | n = n * 10 + nextc - '0'; |
| 404 | scan(); |
| 405 | } |
| 406 | return(n); |
| 407 | } |
| 408 |  |
| 409 |  |
| 410 | double |
| 411 | getnum()                        /* scan a positive float */ |
| 412 | { |
| 413 | register int  i; |
| 414 | char  str[MAXWORD+1]; |
| 415 |  |
| 416 | i = 0; |
| 417 | while (isdigit(nextc) && i < MAXWORD) { |
| 418 | str[i++] = nextc; |
| 419 | scan(); |
| 420 | } |
| 421 | if (nextc == '.' && i < MAXWORD) { |
| 422 | str[i++] = nextc; |
| 423 | scan(); |
| 424 | while (isdigit(nextc) && i < MAXWORD) { |
| 425 | str[i++] = nextc; |
| 426 | scan(); |
| 427 | } |
| 428 | } |
| 429 | if ((nextc == 'e' || nextc == 'E') && i < MAXWORD) { |
| 430 | str[i++] = nextc; |
| 431 | scan(); |
| 432 | if ((nextc == '-' || nextc == '+') && i < MAXWORD) { |
| 433 | str[i++] = nextc; |
| 434 | scan(); |
| 435 | } |
| 436 | while (isdigit(nextc) && i < MAXWORD) { |
| 437 | str[i++] = nextc; |
| 438 | scan(); |
| 439 | } |
| 440 | } |
| 441 | str[i] = '\0'; |
| 442 |  |
| 443 | return(atof(str)); |
| 444 | } |
| 445 |  |
| 446 |  |
| 447 | EPNODE * |
| 448 | getE1()                         /* E1 -> E1 ADDOP E2 */ |
| 449 | /*       E2 */ |
| 450 | { |
| 451 | register EPNODE  *ep1, *ep2; |
| 452 |  |
| 453 | ep1 = getE2(); |
| 454 | while (nextc == '+' || nextc == '-') { |
| 455 | ep2 = newnode(); |
| 456 | ep2->type = nextc; |
| 457 | scan(); |
| 458 | addekid(ep2, ep1); |
| 459 | addekid(ep2, getE2()); |
| 460 | #ifdef  RCONST |
| 461 | if (ep1->type == NUM && ep1->sibling->type == NUM) |
| 462 | ep2 = rconst(ep2); |
| 463 | #endif |
| 464 | ep1 = ep2; |
| 465 | } |
| 466 | return(ep1); |
| 467 | } |
| 468 |  |
| 469 |  |
| 470 | EPNODE * |
| 471 | getE2()                         /* E2 -> E2 MULOP E3 */ |
| 472 | /*       E3 */ |
| 473 | { |
| 474 | register EPNODE  *ep1, *ep2; |
| 475 |  |
| 476 | ep1 = getE3(); |
| 477 | while (nextc == '*' || nextc == '/') { |
| 478 | ep2 = newnode(); |
| 479 | ep2->type = nextc; |
| 480 | scan(); |
| 481 | addekid(ep2, ep1); |
| 482 | addekid(ep2, getE3()); |
| 483 | #ifdef  RCONST |
| 484 | if (ep1->type == NUM && ep1->sibling->type == NUM) |
| 485 | ep2 = rconst(ep2); |
| 486 | #endif |
| 487 | ep1 = ep2; |
| 488 | } |
| 489 | return(ep1); |
| 490 | } |
| 491 |  |
| 492 |  |
| 493 | EPNODE * |
| 494 | getE3()                         /* E3 -> E3 ^ E4 */ |
| 495 | /*       E4 */ |
| 496 | { |
| 497 | register EPNODE  *ep1, *ep2; |
| 498 |  |
| 499 | ep1 = getE4(); |
| 500 | while (nextc == '^') { |
| 501 | ep2 = newnode(); |
| 502 | ep2->type = nextc; |
| 503 | scan(); |
| 504 | addekid(ep2, ep1); |
| 505 | addekid(ep2, getE4()); |
| 506 | #ifdef  RCONST |
| 507 | if (ep1->type == NUM && ep1->sibling->type == NUM) |
| 508 | ep2 = rconst(ep2); |
| 509 | #endif |
| 510 | ep1 = ep2; |
| 511 | } |
| 512 | return(ep1); |
| 513 | } |
| 514 |  |
| 515 |  |
| 516 | EPNODE * |
| 517 | getE4()                         /* E4 -> ADDOP E5 */ |
| 518 | /*       E5 */ |
| 519 | { |
| 520 | register EPNODE  *ep1; |
| 521 |  |
| 522 | if (nextc == '-') { |
| 523 | scan(); |
| 524 | ep1 = newnode(); |
| 525 | #ifndef  RCONST |
| 526 | if (isdecimal(nextc)) { |
| 527 | ep1->type = NUM; |
| 528 | ep1->v.num = -getnum(); |
| 529 | return(ep1); |
| 530 | } |
| 531 | #endif |
| 532 | ep1->type = UMINUS; |
| 533 | addekid(ep1, getE5()); |
| 534 | #ifdef  RCONST |
| 535 | if (ep1->v.kid->type == NUM) |
| 536 | ep1 = rconst(ep1); |
| 537 | #endif |
| 538 | return(ep1); |
| 539 | } |
| 540 | if (nextc == '+') |
| 541 | scan(); |
| 542 | return(getE5()); |
| 543 | } |
| 544 |  |
| 545 |  |
| 546 | EPNODE * |
| 547 | getE5()                         /* E5 -> (E1) */ |
| 548 | /*       VAR */ |
| 549 | /*       NUM */ |
| 550 | /*       $N */ |
| 551 | /*       FUNC(E1,..) */ |
| 552 | /*       ARG */ |
| 553 | { |
| 554 | int  i; |
| 555 | register EPNODE  *ep1, *ep2; |
| 556 |  |
| 557 | if (nextc == '(') { |
| 558 | scan(); |
| 559 | ep1 = getE1(); |
| 560 | if (nextc != ')') |
| 561 | syntax("')' expected"); |
| 562 | scan(); |
| 563 | return(ep1); |
| 564 | } |
| 565 |  |
| 566 | #ifdef  INCHAN |
| 567 | if (nextc == '$') { |
| 568 | scan(); |
| 569 | ep1 = newnode(); |
| 570 | ep1->type = CHAN; |
| 571 | ep1->v.chan = getinum(); |
| 572 | return(ep1); |
| 573 | } |
| 574 | #endif |
| 575 |  |
| 576 | #if  defined(VARIABLE) || defined(FUNCTION) |
| 577 | if (isalpha(nextc)) { |
| 578 | ep1 = newnode(); |
| 579 | ep1->type = VAR; |
| 580 | ep1->v.ln = varinsert(getname()); |
| 581 |  |
| 582 | #if  defined(VARIABLE) && defined(FUNCTION) |
| 583 | if (curfunc != NULL) |
| 584 | for (i = 1, ep2 = curfunc->v.kid->sibling; |
| 585 | ep2 != NULL; i++, ep2 = ep2->sibling) |
| 586 | if (!strcmp(ep2->v.name, ep1->v.ln->name)) { |
| 587 | epfree(ep1); |
| 588 | ep1 = newnode(); |
| 589 | ep1->type = ARG; |
| 590 | ep1->v.chan = i; |
| 591 | break; |
| 592 | } |
| 593 | #endif |
| 594 | #ifdef  FUNCTION |
| 595 | if (nextc == '(') { |
| 596 | ep2 = newnode(); |
| 597 | ep2->type = FUNC; |
| 598 | addekid(ep2, ep1); |
| 599 | ep1 = ep2; |
| 600 | do { |
| 601 | scan(); |
| 602 | addekid(ep1, getE1()); |
| 603 | } while (nextc == ','); |
| 604 | if (nextc != ')') |
| 605 | syntax("')' expected"); |
| 606 | scan(); |
| 607 | } |
| 608 | #ifndef  VARIABLE |
| 609 | else |
| 610 | syntax("'(' expected"); |
| 611 | #endif |
| 612 | #endif |
| 613 | return(ep1); |
| 614 | } |
| 615 | #endif |
| 616 |  |
| 617 | if (isdecimal(nextc)) { |
| 618 | ep1 = newnode(); |
| 619 | ep1->type = NUM; |
| 620 | ep1->v.num = getnum(); |
| 621 | return(ep1); |
| 622 | } |
| 623 | syntax("unexpected character"); |
| 624 | } |
| 625 |  |
| 626 |  |
| 627 | #ifdef  RCONST |
| 628 | EPNODE * |
| 629 | rconst(epar)                    /* reduce a constant expression */ |
| 630 | register EPNODE  *epar; |
| 631 | { |
| 632 | register EPNODE  *ep; |
| 633 |  |
| 634 | ep = newnode(); |
| 635 | ep->type = NUM; |
| 636 | errno = 0; |
| 637 | ep->v.num = evalue(epar); |
| 638 | if (errno) |
| 639 | syntax("bad constant expression"); |
| 640 | epfree(epar); |
| 641 |  |
| 642 | return(ep); |
| 643 | } |
| 644 | #endif |
