root/radiance/src/common/calexpr.c
Revision: 1.11
Committed: Tue Apr 23 16:56:39 1991 UTC (34 years, 6 months ago) by greg
Changes since 1.10: +25 -12 lines
added isconstfun() to find constant functions passed as arguments
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Compute data values using expression parser
9 *
10 * 7/1/85 Greg Ward
11 *
12 * 11/11/85 Made channel input conditional with (INCHAN) compiles.
13 *
14 * 4/2/86 Added conditional compiles for function definitions (FUNCTION).
15 *
16 * 1/29/87 Made variables conditional (VARIABLE)
17 *
18 * 5/19/88 Added constant subexpression elimination (RCONST)
19 */
20
21 #include <stdio.h>
22
23 #include <ctype.h>
24
25 #include <errno.h>
26
27 #include "calcomp.h"
28
29 #define MAXLINE 256 /* maximum line length */
30 #define MAXWORD 64 /* maximum word length */
31
32 #define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE))
33
34 #define isid(c) (isalnum(c) || (c) == '_' || (c) == '.')
35
36 #define isdecimal(c) (isdigit(c) || (c) == '.')
37
38 extern double atof(), pow();
39 extern char *fgets(), *savestr();
40 extern char *emalloc(), *ecalloc();
41 extern EPNODE *curfunc;
42 extern double efunc(), evariable();
43 static double euminus(), echannel(), eargument(), enumber();
44 static double eadd(), esubtr(), emult(), edivi(), epow();
45 static double ebotch();
46 extern int errno;
47
48 int nextc; /* lookahead character */
49
50 double (*eoper[])() = { /* expression operations */
51 ebotch,
52 #ifdef VARIABLE
53 evariable,
54 #else
55 ebotch,
56 #endif
57 enumber,
58 euminus,
59 #ifdef INCHAN
60 echannel,
61 #else
62 ebotch,
63 #endif
64 #ifdef FUNCTION
65 efunc,
66 eargument,
67 #else
68 ebotch,
69 ebotch,
70 #endif
71 ebotch,
72 ebotch,
73 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
74 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
75 emult,
76 eadd,
77 0,
78 esubtr,
79 0,
80 edivi,
81 0,0,0,0,0,0,0,0,0,0,
82 ebotch,
83 0,0,
84 ebotch,
85 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
86 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
87 epow,
88 };
89
90 static FILE *infp; /* input file pointer */
91 static char *linbuf; /* line buffer */
92 static char *infile; /* input file name */
93 static int lineno; /* input line number */
94 static int linepos; /* position in buffer */
95
96
97 EPNODE *
98 eparse(expr) /* parse an expression string */
99 char *expr;
100 {
101 EPNODE *ep;
102
103 initstr(expr, NULL, 0);
104 #if defined(VARIABLE) && defined(FUNCTION)
105 curfunc = NULL;
106 #endif
107 ep = getE1();
108 if (nextc != EOF)
109 syntax("unexpected character");
110 return(ep);
111 }
112
113
114 double
115 eval(expr) /* evaluate an expression string */
116 char *expr;
117 {
118 register EPNODE *ep;
119 double rval;
120
121 ep = eparse(expr);
122 rval = evalue(ep);
123 epfree(ep);
124 return(rval);
125 }
126
127
128 epfree(epar) /* free a parse tree */
129 register EPNODE *epar;
130 {
131 register EPNODE *ep;
132
133 switch (epar->type) {
134
135 #if defined(VARIABLE) || defined(FUNCTION)
136 case VAR:
137 varfree(epar->v.ln);
138 break;
139 #endif
140
141 case SYM:
142 freestr(epar->v.name);
143 break;
144
145 case NUM:
146 case CHAN:
147 case ARG:
148 case TICK:
149 break;
150
151 default:
152 for (ep = epar->v.kid; ep != NULL; ep = ep->sibling)
153 epfree(ep);
154 break;
155
156 }
157
158 efree((char *)epar);
159 }
160
161 /* the following used to be a switch */
162 #ifdef FUNCTION
163 static double
164 eargument(ep)
165 EPNODE *ep;
166 {
167 return(argument(ep->v.chan));
168 }
169 #endif
170
171 static double
172 enumber(ep)
173 EPNODE *ep;
174 {
175 return(ep->v.num);
176 }
177
178 static double
179 euminus(ep)
180 EPNODE *ep;
181 {
182 register EPNODE *ep1 = ep->v.kid;
183
184 return(-evalue(ep1));
185 }
186
187 #ifdef INCHAN
188 static double
189 echannel(ep)
190 EPNODE *ep;
191 {
192 return(chanvalue(ep->v.chan));
193 }
194 #endif
195
196 static double
197 eadd(ep)
198 EPNODE *ep;
199 {
200 register EPNODE *ep1 = ep->v.kid;
201
202 return(evalue(ep1) + evalue(ep1->sibling));
203 }
204
205 static double
206 esubtr(ep)
207 EPNODE *ep;
208 {
209 register EPNODE *ep1 = ep->v.kid;
210
211 return(evalue(ep1) - evalue(ep1->sibling));
212 }
213
214 static double
215 emult(ep)
216 EPNODE *ep;
217 {
218 register EPNODE *ep1 = ep->v.kid;
219
220 return(evalue(ep1) * evalue(ep1->sibling));
221 }
222
223 static double
224 edivi(ep)
225 EPNODE *ep;
226 {
227 register EPNODE *ep1 = ep->v.kid;
228 double d;
229
230 d = evalue(ep1->sibling);
231 if (d == 0.0) {
232 wputs("Division by zero\n");
233 errno = ERANGE;
234 return(0.0);
235 }
236 return(evalue(ep1) / d);
237 }
238
239 static double
240 epow(ep)
241 EPNODE *ep;
242 {
243 register EPNODE *ep1 = ep->v.kid;
244 double d;
245 int lasterrno;
246
247 lasterrno = errno;
248 errno = 0;
249 d = pow(evalue(ep1), evalue(ep1->sibling));
250 #ifdef IEEE
251 if (!finite(d))
252 errno = EDOM;
253 #endif
254 if (errno) {
255 wputs("Illegal power\n");
256 return(0.0);
257 }
258 errno = lasterrno;
259 return(d);
260 }
261
262 static double
263 ebotch(ep)
264 EPNODE *ep;
265 {
266 eputs("Bad expression!\n");
267 quit(1);
268 }
269
270
271 EPNODE *
272 ekid(ep, n) /* return pointer to a node's nth kid */
273 register EPNODE *ep;
274 register int n;
275 {
276
277 for (ep = ep->v.kid; ep != NULL; ep = ep->sibling)
278 if (--n < 0)
279 break;
280
281 return(ep);
282 }
283
284
285 int
286 nekids(ep) /* return # of kids for node ep */
287 register EPNODE *ep;
288 {
289 register int n = 0;
290
291 for (ep = ep->v.kid; ep != NULL; ep = ep->sibling)
292 n++;
293
294 return(n);
295 }
296
297
298 initfile(fp, fn, ln) /* prepare input file */
299 FILE *fp;
300 char *fn;
301 int ln;
302 {
303 static char inpbuf[MAXLINE];
304
305 infp = fp;
306 linbuf = inpbuf;
307 infile = fn;
308 lineno = ln;
309 linepos = 0;
310 inpbuf[0] = '\0';
311 scan();
312 }
313
314
315 initstr(s, fn, ln) /* prepare input string */
316 char *s;
317 char *fn;
318 int ln;
319 {
320 infp = NULL;
321 infile = fn;
322 lineno = ln;
323 linbuf = s;
324 linepos = 0;
325 scan();
326 }
327
328
329 scan() /* scan next character */
330 {
331 do {
332 if (linbuf[linepos] == '\0')
333 if (infp == NULL || fgets(linbuf, MAXLINE, infp) == NULL)
334 nextc = EOF;
335 else {
336 nextc = linbuf[0];
337 lineno++;
338 linepos = 1;
339 }
340 else
341 nextc = linbuf[linepos++];
342 if (nextc == '{') {
343 scan();
344 while (nextc != '}')
345 if (nextc == EOF)
346 syntax("'}' expected");
347 else
348 scan();
349 scan();
350 }
351 } while (isspace(nextc));
352 }
353
354
355 char *
356 ltoa(l) /* convert long to ascii */
357 long l;
358 {
359 static char buf[16];
360 register char *cp;
361 int neg = 0;
362
363 if (l == 0)
364 return("0");
365 if (l < 0) {
366 l = -l;
367 neg++;
368 }
369 cp = buf + sizeof(buf);
370 *--cp = '\0';
371 while (l) {
372 *--cp = l % 10 + '0';
373 l /= 10;
374 }
375 if (neg)
376 *--cp = '-';
377 return(cp);
378 }
379
380
381 syntax(err) /* report syntax error and quit */
382 char *err;
383 {
384 register int i;
385
386 if (infile != NULL || lineno != 0) {
387 if (infile != NULL) eputs(infile);
388 if (lineno != 0) {
389 eputs(infile != NULL ? ", line " : "line ");
390 eputs(ltoa((long)lineno));
391 }
392 eputs(": syntax error:\n");
393 }
394 eputs(linbuf);
395 if (linbuf[strlen(linbuf)-1] != '\n')
396 eputs("\n");
397 for (i = 0; i < linepos-1; i++)
398 eputs(linbuf[i] == '\t' ? "\t" : " ");
399 eputs("^ ");
400 eputs(err);
401 eputs("\n");
402 quit(1);
403 }
404
405
406 addekid(ep, ekid) /* add a child to ep */
407 register EPNODE *ep;
408 EPNODE *ekid;
409 {
410 if (ep->v.kid == NULL)
411 ep->v.kid = ekid;
412 else {
413 for (ep = ep->v.kid; ep->sibling != NULL; ep = ep->sibling)
414 ;
415 ep->sibling = ekid;
416 }
417 ekid->sibling = NULL;
418 }
419
420
421 char *
422 getname() /* scan an identifier */
423 {
424 static char str[MAXWORD+1];
425 register int i;
426
427 for (i = 0; i < MAXWORD && isid(nextc); i++, scan())
428 str[i] = nextc;
429 str[i] = '\0';
430
431 return(str);
432 }
433
434
435 int
436 getinum() /* scan a positive integer */
437 {
438 register int n;
439
440 n = 0;
441 while (isdigit(nextc)) {
442 n = n * 10 + nextc - '0';
443 scan();
444 }
445 return(n);
446 }
447
448
449 double
450 getnum() /* scan a positive float */
451 {
452 register int i;
453 char str[MAXWORD+1];
454
455 i = 0;
456 while (isdigit(nextc) && i < MAXWORD) {
457 str[i++] = nextc;
458 scan();
459 }
460 if (nextc == '.' && i < MAXWORD) {
461 str[i++] = nextc;
462 scan();
463 while (isdigit(nextc) && i < MAXWORD) {
464 str[i++] = nextc;
465 scan();
466 }
467 }
468 if ((nextc == 'e' || nextc == 'E') && i < MAXWORD) {
469 str[i++] = nextc;
470 scan();
471 if ((nextc == '-' || nextc == '+') && i < MAXWORD) {
472 str[i++] = nextc;
473 scan();
474 }
475 while (isdigit(nextc) && i < MAXWORD) {
476 str[i++] = nextc;
477 scan();
478 }
479 }
480 str[i] = '\0';
481
482 return(atof(str));
483 }
484
485
486 EPNODE *
487 getE1() /* E1 -> E1 ADDOP E2 */
488 /* E2 */
489 {
490 register EPNODE *ep1, *ep2;
491
492 ep1 = getE2();
493 while (nextc == '+' || nextc == '-') {
494 ep2 = newnode();
495 ep2->type = nextc;
496 scan();
497 addekid(ep2, ep1);
498 addekid(ep2, getE2());
499 #ifdef RCONST
500 if (ep1->type == NUM && ep1->sibling->type == NUM)
501 ep2 = rconst(ep2);
502 #endif
503 ep1 = ep2;
504 }
505 return(ep1);
506 }
507
508
509 EPNODE *
510 getE2() /* E2 -> E2 MULOP E3 */
511 /* E3 */
512 {
513 register EPNODE *ep1, *ep2;
514
515 ep1 = getE3();
516 while (nextc == '*' || nextc == '/') {
517 ep2 = newnode();
518 ep2->type = nextc;
519 scan();
520 addekid(ep2, ep1);
521 addekid(ep2, getE3());
522 #ifdef RCONST
523 if (ep1->type == NUM && ep1->sibling->type == NUM)
524 ep2 = rconst(ep2);
525 #endif
526 ep1 = ep2;
527 }
528 return(ep1);
529 }
530
531
532 EPNODE *
533 getE3() /* E3 -> E4 ^ E3 */
534 /* E4 */
535 {
536 register EPNODE *ep1, *ep2;
537
538 ep1 = getE4();
539 if (nextc == '^') {
540 ep2 = newnode();
541 ep2->type = nextc;
542 scan();
543 addekid(ep2, ep1);
544 addekid(ep2, getE3());
545 #ifdef RCONST
546 if (ep1->type == NUM && ep1->sibling->type == NUM)
547 ep2 = rconst(ep2);
548 #endif
549 return(ep2);
550 }
551 return(ep1);
552 }
553
554
555 EPNODE *
556 getE4() /* E4 -> ADDOP E5 */
557 /* E5 */
558 {
559 register EPNODE *ep1, *ep2;
560
561 if (nextc == '-') {
562 scan();
563 ep2 = getE5();
564 if (ep2->type == NUM) {
565 ep2->v.num = -ep2->v.num;
566 return(ep2);
567 }
568 ep1 = newnode();
569 ep1->type = UMINUS;
570 addekid(ep1, ep2);
571 return(ep1);
572 }
573 if (nextc == '+')
574 scan();
575 return(getE5());
576 }
577
578
579 EPNODE *
580 getE5() /* E5 -> (E1) */
581 /* VAR */
582 /* NUM */
583 /* $N */
584 /* FUNC(E1,..) */
585 /* ARG */
586 {
587 int i;
588 register EPNODE *ep1, *ep2;
589
590 if (nextc == '(') {
591 scan();
592 ep1 = getE1();
593 if (nextc != ')')
594 syntax("')' expected");
595 scan();
596 return(ep1);
597 }
598
599 #ifdef INCHAN
600 if (nextc == '$') {
601 scan();
602 ep1 = newnode();
603 ep1->type = CHAN;
604 ep1->v.chan = getinum();
605 return(ep1);
606 }
607 #endif
608
609 #if defined(VARIABLE) || defined(FUNCTION)
610 if (isalpha(nextc)) {
611 ep1 = newnode();
612 ep1->type = VAR;
613 ep1->v.ln = varinsert(getname());
614
615 #if defined(VARIABLE) && defined(FUNCTION)
616 if (curfunc != NULL)
617 for (i = 1, ep2 = curfunc->v.kid->sibling;
618 ep2 != NULL; i++, ep2 = ep2->sibling)
619 if (!strcmp(ep2->v.name, ep1->v.ln->name)) {
620 epfree(ep1);
621 ep1 = newnode();
622 ep1->type = ARG;
623 ep1->v.chan = i;
624 break;
625 }
626 #endif
627 #ifdef FUNCTION
628 if (nextc == '(') {
629 ep2 = newnode();
630 ep2->type = FUNC;
631 addekid(ep2, ep1);
632 ep1 = ep2;
633 do {
634 scan();
635 addekid(ep1, getE1());
636 } while (nextc == ',');
637 if (nextc != ')')
638 syntax("')' expected");
639 scan();
640 }
641 #ifndef VARIABLE
642 else
643 syntax("'(' expected");
644 #endif
645 #endif
646 #ifdef RCONST
647 if (isconstvar(ep1))
648 ep1 = rconst(ep1);
649 #endif
650 return(ep1);
651 }
652 #endif
653
654 if (isdecimal(nextc)) {
655 ep1 = newnode();
656 ep1->type = NUM;
657 ep1->v.num = getnum();
658 return(ep1);
659 }
660 syntax("unexpected character");
661 }
662
663
664 #ifdef RCONST
665 EPNODE *
666 rconst(epar) /* reduce a constant expression */
667 register EPNODE *epar;
668 {
669 register EPNODE *ep;
670
671 ep = newnode();
672 ep->type = NUM;
673 errno = 0;
674 ep->v.num = evalue(epar);
675 if (errno)
676 syntax("bad constant expression");
677 epfree(epar);
678
679 return(ep);
680 }
681
682
683 isconstvar(ep) /* is ep linked to a constant expression? */
684 register EPNODE *ep;
685 {
686 #ifdef VARIABLE
687 register EPNODE *ep1;
688 #ifdef FUNCTION
689
690 if (ep->type == FUNC) {
691 if (!isconstfun(ep->v.kid))
692 return(0);
693 for (ep1 = ep->v.kid->sibling; ep1 != NULL; ep1 = ep1->sibling)
694 if (ep1->type != NUM && !isconstfun(ep1))
695 return(0);
696 return(1);
697 }
698 #endif
699 if (ep->type != VAR)
700 return(0);
701 ep1 = ep->v.ln->def;
702 if (ep1 == NULL || ep1->type != ':')
703 return(0);
704 #ifdef FUNCTION
705 if (ep1->v.kid->type != SYM)
706 return(0);
707 #endif
708 return(1);
709 #else
710 return(ep->type == FUNC);
711 #endif
712 }
713
714
715 #if defined(FUNCTION) && defined(VARIABLE)
716 isconstfun(ep) /* is ep linked to a constant function? */
717 register EPNODE *ep;
718 {
719 register EPNODE *dp;
720 register LIBR *lp;
721
722 if (ep->type != VAR)
723 return(0);
724 dp = ep->v.ln->def;
725 if (dp != NULL && dp->type != ':')
726 return(0);
727 if ((dp == NULL || dp->v.kid->type != FUNC)
728 && ((lp = liblookup(ep->v.ln->name)) == NULL
729 || lp->atyp != ':'))
730 return(0);
731 return(1);
732 }
733 #endif
734 #endif
