root/radiance/src/common/calcomp.h
Revision: 2.27
Committed: Mon Sep 16 17:31:14 2024 UTC (13 months ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.26: +14 -14 lines
refactor: Changed too-generic symbol names in calcomp.h
1 /* RCSid $Id: calcomp.h,v 2.26 2024/02/26 18:16:35 greg Exp $ */
2 /*
3 * calcomp.h - header file for expression parser.
4 */
5 #ifndef _RAD_CALCOMP_H_
6 #define _RAD_CALCOMP_H_
7
8 #include <stdio.h>
9
10 #ifdef __cplusplus
11 extern "C" {
12 #endif
13
14 #define VAR 1
15 #define NUM 2
16 #define UMINUS 3
17 #define CHAN 4
18 #define FUNC 5
19 #define ARG 6
20 #define CLKT 7
21 #define SYM 8
22 /* also: '+', '-', '*', '/', '^', '=', ':' */
23
24 typedef struct {
25 char *fname; /* function name */
26 short nargs; /* # of required arguments */
27 short atyp; /* assignment type (':' or '=') */
28 double (*f)(char *); /* pointer to function */
29 } ELIBR; /* a library function */
30
31 typedef struct epnode {
32 union {
33 struct epnode *kid; /* first child */
34 double num; /* number */
35 char *name; /* symbol name */
36 int chan; /* channel number */
37 unsigned long tick; /* timestamp */
38 struct vardef {
39 char *name; /* variable name */
40 int nlinks; /* number of references */
41 struct epnode *def; /* definition */
42 ELIBR *lib; /* library definition */
43 struct vardef *next; /* next in hash list */
44 } *ln; /* link */
45 } v; /* value */
46 struct epnode *sibling; /* next child this level */
47 short type; /* node type */
48 short nkids; /* child count (neg if array) */
49 } EPNODE; /* an expression node */
50
51 typedef struct vardef VARDEF; /* a variable definition */
52
53 #define nekids(ep) abs((ep)->nkids)
54
55 #define RMAXWORD 127 /* maximum word/id length */
56 #define CNTXMARK '`' /* context mark */
57
58 #define isid(c) (isalnum(c) || (c) == '_' || \
59 (c) == '.' || (c) == CNTXMARK)
60
61 #define evalue(ep) (*eoper[(ep)->type])(ep)
62
63 #define dfn_name(ep) ((ep)->v.kid->type == SYM ? \
64 (ep)->v.kid->v.name : \
65 (ep)->v.kid->v.kid->v.name)
66
67 /* flags to set in esupport */
68 #define E_VARIABLE 001
69 #define E_FUNCTION 002
70 #define E_INCHAN 004
71 #define E_OUTCHAN 010
72 #define E_RCONST 020
73 #define E_REDEFW 040
74
75 extern double (*eoper[])(EPNODE *);
76 extern unsigned long eclock;
77 extern unsigned int esupport;
78 extern EPNODE *ecurfunc;
79 extern int nextc;
80 extern int eofc;
81 /* defined in biggerlib.c */
82 extern void biggerlib(void);
83 /* defined in caldefn.c */
84 extern void fcompile(char *fname);
85 extern void scompile(char *str, char *fname, int ln);
86 extern double varvalue(char *vname);
87 extern double evariable(EPNODE *ep);
88 extern void varset(char *vname, int assign, double val);
89 extern void dclear(char *name);
90 extern void dremove(char *name);
91 extern int vardefined(char *name);
92 extern char *calcontext(char *ctx);
93 extern char *pushcontext(char *ctx);
94 extern char *popcontext(void);
95 extern char *qualname(char *nam, int lvl);
96 extern int incontext(char *qn);
97 extern void chanout(void (*cs)(int n, double v));
98 extern void doptimize(int activate);
99 extern void dcleanup(int lvl);
100 extern EPNODE *dlookup(char *name);
101 extern VARDEF *varlookup(char *name);
102 extern VARDEF *varinsert(char *name);
103 extern void varfree(VARDEF *ln);
104 extern EPNODE *dfirst(void);
105 extern EPNODE *dnext(void);
106 extern EPNODE *dpop(char *name);
107 extern void dpush(char *nm, EPNODE *ep);
108 extern void eaddchan(EPNODE *sp);
109 extern void egetstatement(void);
110 extern EPNODE *egetdefn(void);
111 extern EPNODE *egetchan(void);
112 /* defined in calexpr.c */
113 extern EPNODE *eparse(char *expr);
114 extern double eval(char *expr);
115 extern int epcmp(EPNODE *ep1, EPNODE *ep2);
116 extern void epfree(EPNODE *epar, int frep);
117 extern void epoptimize(EPNODE *epar);
118 extern EPNODE *ekid(EPNODE *ep, int n);
119 extern void initfile(FILE *fp, char *fn, int ln);
120 extern void initstr(char *s, char *fn, int ln);
121 extern void getscanpos(char **fnp, int *lnp, char **spp, FILE **fpp);
122 extern int escan(void);
123 extern char *long2ascii(long l);
124 extern void esyntax(char *err);
125 extern void addekid(EPNODE *ep, EPNODE *ek);
126 extern char *getname(void);
127 extern int getinum(void);
128 extern double getnum(void);
129 extern EPNODE *getE1(void);
130 extern EPNODE *getE2(void);
131 extern EPNODE *getE3(void);
132 extern EPNODE *getE4(void);
133 extern EPNODE *getE5(void);
134 extern EPNODE *rconst(EPNODE *epar);
135 extern int isconstvar(EPNODE *ep);
136 extern int isconstfun(EPNODE *ep);
137 /* defined in calfunc.c */
138 extern int fundefined(char *fname);
139 extern double funvalue(char *fname, int n, double *a);
140 extern void funset(char *fname, int nargs, int assign,
141 double (*fptr)(char *));
142 extern int nargum(void);
143 extern double argument(int n);
144 extern VARDEF *eargf(int n);
145 extern char *eargfun(int n);
146 extern double efunc(EPNODE *ep);
147 extern double eargument(EPNODE *ep);
148 extern ELIBR *eliblookup(char *fname);
149 extern void elibupdate(char *fn);
150 /* defined in calprnt.c */
151 extern void eprint(EPNODE *ep, FILE *fp);
152 extern void dprint(char *name, FILE *fp);
153 /* defined by client */
154 extern double chanvalue(int n);
155
156 #ifdef __cplusplus
157 }
158 #endif
159 #endif /* _RAD_CALCOMP_H_ */
160
