| 1 |
/* RCSid $Id: bsdf_t.h,v 3.12 2015/04/05 01:32:01 greg Exp $ */ |
| 2 |
| 3 |
* bsdf_t.h |
| 4 |
| 5 |
* Support for variable-resolution BSDF trees. |
| 6 |
* Assumes "bsdf.h" already included. |
| 7 |
* Include after "ezxml.h" for SDloadTre() declaration. |
| 8 |
| 9 |
* Created by Greg Ward on 2/2/11. |
| 10 |
| 11 |
| 12 |
| 13 |
#ifndef _BSDF_T_H_ |
| 14 |
#define _BSDF_T_H_ |
| 15 |
| 16 |
#ifdef __cplusplus |
| 17 |
extern "C" { |
| 18 |
#endif |
| 19 |
| 20 |
#define SD_MAXDIM 4 /* maximum expected # dimensions */ |
| 21 |
| 22 |
/* Basic node structure for variable-resolution BSDF data */ |
| 23 |
typedef struct SDNode_s { |
| 24 |
short ndim; /* number of dimensions */ |
| 25 |
short log2GR; /* log(2) of grid resolution (< 0 for tree) */ |
| 26 |
union { |
| 27 |
struct SDNode_s *t[1]; /* subtree pointers */ |
| 28 |
float v[1]; /* scattering value(s) */ |
| 29 |
} u; /* subtrees or values (extends struct) */ |
| 30 |
} SDNode; |
| 31 |
| 32 |
#define SD_FREFL 1 /* component reflects off front side */ |
| 33 |
#define SD_BREFL 2 /* component reflects off back side */ |
| 34 |
#define SD_FXMIT 3 /* component transmits through front side */ |
| 35 |
#define SD_BXMIT 4 /* component transmits through back side */ |
| 36 |
| 37 |
/* Variable-resolution BSDF holder */ |
| 38 |
typedef struct { |
| 39 |
int sidef; /* which component */ |
| 40 |
SDNode *stc[3]; /* BSDF (Y,u,v) trees */ |
| 41 |
} SDTre; |
| 42 |
| 43 |
/* Holder for cumulative distribution (sum of BSDF * projSA) */ |
| 44 |
typedef struct SDTreCDst_s { |
| 45 |
/* base fields; must come first */ |
| 46 |
SD_CDIST_BASE(SDTreCDst_s); |
| 47 |
double clim[2][2]; /* input coordinate limits */ |
| 48 |
double max_psa; /* maximum projected solid angle */ |
| 49 |
short sidef; /* which mode is in play */ |
| 50 |
short isodist; /* isotropic distribution? */ |
| 51 |
int calen; /* cumulative array length */ |
| 52 |
struct { |
| 53 |
unsigned hndx; /* hilbert index */ |
| 54 |
unsigned cuml; /* cumulative value */ |
| 55 |
} carr[1]; /* cumulative array (extends struct) */ |
| 56 |
} SDTreCDst; |
| 57 |
| 58 |
#ifdef _EZXML_H |
| 59 |
/* Load a variable-resolution BSDF tree from an open XML file */ |
| 60 |
extern SDError SDloadTre(SDData *sd, ezxml_t wtl); |
| 61 |
#endif |
| 62 |
| 63 |
/* Our matrix handling routines */ |
| 64 |
extern const SDFunc SDhandleTre; |
| 65 |
| 66 |
| 67 |
| 68 |
#endif |
| 69 |
#endif /* ! _BSDF_T_H_ */ |
