root/radiance/src/common/bsdf_m.h
Revision: 3.8
Committed: Thu Aug 27 04:33:31 2015 UTC (10 years, 1 month ago) by greg
CVS Tags: rad5R0, rad5R1
Changes since 3.7: +2 -1 lines
Added mBSDF_chroma() macro
1 /* RCSid $Id: bsdf_m.h,v 3.7 2015/04/02 16:40:32 greg Exp $ */
2 /*
3 * bsdf_m.h
4 *
5 * Support for BSDF matrices.
6 * Assumes "bsdf.h" already included.
7 * Include after "ezxml.h" for SDloadMtx() declaration.
8 *
9 * Created by Greg Ward on 2/2/11.
10 *
11 */
12
13 #ifndef _BSDF_M_H_
14 #define _BSDF_M_H_
15
16 #ifdef __cplusplus
17 extern "C" {
18 #endif
19 /* Fixed-position coordinate functions */
20 typedef int b_vecf(FVECT vec, double ndxr, void *c_data);
21 typedef int b_ndxf(const FVECT vec, void *c_data);
22 typedef double b_ohmf(int ndx, void *c_data);
23
24 /* Rectangular matrix format BSDF */
25 typedef struct {
26 int ninc; /* number of incoming directions */
27 int nout; /* number of outgoing directions */
28 void *ib_priv; /* input basis private data */
29 b_vecf *ib_vec; /* get input vector from index */
30 b_ndxf *ib_ndx; /* get input index from vector */
31 b_ohmf *ib_ohm; /* get input proj. SA for index */
32 void *ob_priv; /* output basis private data */
33 b_vecf *ob_vec; /* get output vector from index */
34 b_ndxf *ob_ndx; /* get output index from vector */
35 b_ohmf *ob_ohm; /* get output proj. SA for index */
36 C_CHROMA *chroma; /* chromaticity data */
37 float bsdf[1]; /* scattering data (extends struct) */
38 } SDMat;
39
40 /* Matrix BSDF accessors */
41 #define mBSDF_incvec(v,b,ix) (*(b)->ib_vec)(v,ix,(b)->ib_priv)
42 #define mBSDF_incndx(b,v) (*(b)->ib_ndx)(v,(b)->ib_priv)
43 #define mBSDF_incohm(b,i) (*(b)->ib_ohm)(i,(b)->ib_priv)
44 #define mBSDF_outvec(v,b,ox) (*(b)->ob_vec)(v,ox,(b)->ob_priv)
45 #define mBSDF_outndx(b,v) (*(b)->ob_ndx)(v,(b)->ob_priv)
46 #define mBSDF_outohm(b,o) (*(b)->ob_ohm)(o,(b)->ob_priv)
47 #define mBSDF_value(b,i,o) (b)->bsdf[(o)*(b)->ninc + (i)]
48 #define mBSDF_chroma(b,i,o) (b)->chroma[(o)*(b)->ninc + (i)]
49
50 /* Holder for cumulative distribution (sum of BSDF * projSA) */
51 typedef struct SDMatCDst_s {
52 SD_CDIST_BASE(SDMatCDst_s); /* base fields; must come first */
53 int indx; /* incident angle index */
54 void *ob_priv; /* private data for generator */
55 b_vecf *ob_vec; /* outbound vector generator */
56 int calen; /* cumulative array length */
57 unsigned carr[1]; /* cumulative array (extends struct) */
58 } SDMatCDst;
59
60 #ifdef _EZXML_H
61 /* Load a set of BSDF matrices from an open XML file */
62 extern SDError SDloadMtx(SDData *sd, ezxml_t wtl);
63 #endif
64
65 /* Our matrix handling routines */
66 extern SDFunc SDhandleMtx;
67
68 /******** Klems basis declarations for more intimate access ********/
69
70 #define MAXLATS 46 /* maximum number of latitudes */
71
72 /* BSDF angle specification */
73 typedef struct {
74 char name[64]; /* basis name */
75 int nangles; /* total number of directions */
76 struct {
77 float tmin; /* starting theta */
78 int nphis; /* number of phis (0 term) */
79 } lat[MAXLATS+1]; /* latitudes */
80 } ANGLE_BASIS;
81
82 #define MAXABASES 7 /* limit on defined bases */
83
84 extern ANGLE_BASIS abase_list[MAXABASES];
85
86 extern int nabases; /* current number of defined bases */
87
88 extern C_COLOR mtx_RGB_prim[3]; /* matrix RGB primaries */
89 extern float mtx_RGB_coef[3]; /* corresponding Y coefficients */
90
91 /* Get color or grayscale value for BSDF in the given directions */
92 extern int mBSDF_color(float coef[], const SDMat *b, int i, int o);
93
94 /* Get vector for this angle basis index (front exiting) */
95 extern b_vecf fo_getvec;
96
97 /* Get index corresponding to the given vector (front exiting) */
98 extern b_ndxf fo_getndx;
99
100 /* Get projected solid angle for this angle basis index (universal) */
101 extern b_ohmf io_getohm;
102
103 /* Get vector for this angle basis index (back incident) */
104 extern b_vecf bi_getvec;
105
106 /* Get index corresponding to the vector (back incident) */
107 extern b_ndxf bi_getndx;
108
109 /* Get vector for this angle basis index (back exiting) */
110 extern b_vecf bo_getvec;
111
112 /* Get index corresponding to the vector (back exiting) */
113 extern b_ndxf bo_getndx;
114
115 /* Get vector for this angle basis index (front incident) */
116 extern b_vecf fi_getvec;
117
118 /* Get index corresponding to the vector (front incident) */
119 extern b_ndxf fi_getndx;
120
121 #ifdef __cplusplus
122 }
123 #endif
124 #endif /* ! _BSDF_M_H_ */
