root/radiance/src/common/bsdf_m.c
Thu May 10 22:55:35 2018 UTC (7 years, 5 months ago) by greg
Changes since 3.37: +3 -3 lines
Diff to previous 3.37
Eliminated expensive and unnecessary spectral curve hallucination
Fri Jan 5 21:00:24 2018 UTC (7 years, 9 months ago) by greg
Diff to previous 3.36
Fix for C++ compilers, which don't like "typedef const struct"
Fri Oct 14 00:54:21 2016 UTC (9 years ago) by greg
Changes since 3.35: +4 -2 lines
Diff to previous 3.35
Thu Aug 27 04:33:31 2015 UTC (10 years, 1 month ago) by greg
Changes since 3.34: +3 -3 lines
Diff to previous 3.34
Added mBSDF_chroma() macro
Sun Aug 23 00:56:00 2015 UTC (10 years, 2 months ago) by greg
Changes since 3.33: +3 -1 lines
Diff to previous 3.33
Added comments for placement of mutex locks to support multi-threading
Wed Apr 8 16:10:47 2015 UTC (10 years, 6 months ago) by greg
Changes since 3.32: +3 -3 lines
Diff to previous 3.32
Corrected error in last check-in
Wed Apr 8 02:41:02 2015 UTC (10 years, 6 months ago) by greg
Changes since 3.31: +8 -8 lines
Diff to previous 3.31
Fixed bug in randomization of vectors near surface normal (front or back)
Mon Apr 6 16:00:15 2015 UTC (10 years, 6 months ago) by greg
Changes since 3.30: +9 -9 lines
Diff to previous 3.30
Increased minimum threshold for diffuse scattering extraction to 1%
Sun Apr 5 01:32:01 2015 UTC (10 years, 6 months ago) by greg
Changes since 3.29: +8 -8 lines
Diff to previous 3.29
Added color rendering to tensor tree and minor fixes to Klems color rendering
Thu Apr 2 16:40:32 2015 UTC (10 years, 6 months ago) by greg
Changes since 3.28: +172 -70 lines
Diff to previous 3.28
Support for color BSDF rendering using Klems representation
Fri Mar 21 17:49:53 2014 UTC (11 years, 7 months ago) by greg
Changes since 3.27: +7 -4 lines
Diff to previous 3.27
Added protection against negative BSDF values
Sat Jun 29 21:03:44 2013 UTC (12 years, 3 months ago) by greg
Changes since 3.26: +2 -2 lines
Diff to previous 3.26
Tue Apr 23 17:25:23 2013 UTC (12 years, 6 months ago) by greg
Changes since 3.25: +5 -2 lines
Diff to previous 3.25
Fixed bug in accounting of diffuse transmitted component
Sun Apr 21 22:58:40 2013 UTC (12 years, 6 months ago) by greg
Changes since 3.24: +21 -35 lines
Diff to previous 3.24
Exposed functions and data structures needed by bsdf2klems
Mon Sep 10 18:06:08 2012 UTC (13 years, 1 month ago) by greg
Changes since 3.23: +9 -9 lines
Diff to previous 3.23
Hopeful fixes to tensor tree reciprocity and orientation
Sun Sep 2 15:33:15 2012 UTC (13 years, 1 month ago) by greg
Changes since 3.22: +18 -18 lines
Diff to previous 3.22
Mon May 7 23:17:59 2012 UTC (13 years, 5 months ago) by greg
Changes since 3.21: +4 -4 lines
Diff to previous 3.21
Fixed bug in bug fix (thanks to Andy McNeil)
Wed May 2 16:28:45 2012 UTC (13 years, 5 months ago) by greg
Changes since 3.20: +3 -6 lines
Diff to previous 3.20
Fixed bug for matrix BSDFs with more than one phi angle around zenith
Sun Aug 21 22:38:12 2011 UTC (14 years, 2 months ago) by greg
Changes since 3.19: +3 -3 lines
Diff to previous 3.19
Minor improvements to direct specular sampling
Thu Jul 7 15:48:00 2011 UTC (14 years, 3 months ago) by greg
Changes since 3.18: +3 -3 lines
Diff to previous 3.18
Removed unnecessary restriction on reciprocity
Thu Jul 7 15:25:09 2011 UTC (14 years, 3 months ago) by greg
Changes since 3.17: +11 -9 lines
Diff to previous 3.17
Fixed bug for MING32 and non-square matrices, allowing multiple angle bases
Tue Jun 28 21:13:46 2011 UTC (14 years, 3 months ago) by greg
Changes since 3.16: +2 -14 lines
Diff to previous 3.16
Minor compile fixes
Thu Jun 9 17:09:39 2011 UTC (14 years, 4 months ago) by greg
Changes since 3.15: +3 -2 lines
Diff to previous 3.15
Fixes for Windows and bug fix in bsdf_m.c
Wed Apr 27 20:03:25 2011 UTC (14 years, 5 months ago) by greg
Changes since 3.14: +19 -14 lines
Diff to previous 3.14
Initial untested variable-resolution BSDF
Mon Apr 25 15:48:05 2011 UTC (14 years, 6 months ago) by greg
Changes since 3.13: +6 -7 lines
Diff to previous 3.13
Fix from last change
Sun Apr 24 20:16:52 2011 UTC (14 years, 6 months ago) by greg
Changes since 3.12: +3 -3 lines
Diff to previous 3.12
Bug fixes to last change
Sun Apr 24 19:39:21 2011 UTC (14 years, 6 months ago) by greg
Changes since 3.11: +25 -19 lines
Diff to previous 3.11
Partial implementation of variable-resolution BSDFs
Wed Apr 20 14:44:05 2011 UTC (14 years, 6 months ago) by greg
Changes since 3.10: +5 -1 lines
Diff to previous 3.10
Fixes to last change -- tested
Tue Apr 19 21:31:22 2011 UTC (14 years, 6 months ago) by greg
Changes since 3.9: +14 -11 lines
Diff to previous 3.9
Fixed interface for determining BSDF solid angles
Fri Apr 8 18:13:48 2011 UTC (14 years, 6 months ago) by greg
Changes since 3.8: +20 -17 lines
Diff to previous 3.8
Thu Feb 24 20:14:26 2011 UTC (14 years, 7 months ago) by greg
Changes since 3.7: +88 -36 lines
Diff to previous 3.7
Wed Feb 23 21:58:31 2011 UTC (14 years, 8 months ago) by greg
Changes since 3.6: +16 -7 lines
Diff to previous 3.6
Fixed issue with coordinate orientation for front transmission
Mon Feb 21 22:50:37 2011 UTC (14 years, 8 months ago) by greg
Changes since 3.5: +10 -9 lines
Diff to previous 3.5
Corrected notion of "front" and "back" to coincide with surface normals
Sat Feb 19 23:42:09 2011 UTC (14 years, 8 months ago) by greg
Changes since 3.4: +53 -66 lines
Diff to previous 3.4
Fixes to BSDF including blurring of angle boundaries
Sat Feb 19 01:48:59 2011 UTC (14 years, 8 months ago) by greg
Changes since 3.3: +16 -43 lines
Minor changes and fixes -- first working version of BSDF material
Fri Feb 18 02:41:55 2011 UTC (14 years, 8 months ago) by greg
Changes since 3.2: +3 -45 lines
Minor fixes and adjustments
Fri Feb 18 00:41:44 2011 UTC (14 years, 8 months ago) by greg
Changes since 3.1: +3 -0 lines
Added missing RCS tags
Fri Feb 18 00:40:25 2011 UTC (14 years, 8 months ago) by greg
