root/radiance/src/common/bsdf.c
Revision: 2.62
Committed: Wed Dec 15 01:38:50 2021 UTC (3 years, 10 months ago) by greg
CVS Tags: rad5R4, rad6R0, HEAD
Changes since 2.61: +3 -3 lines
refactor: removed prefix from SDdisk2square() and SDsquare2disk() & made consistent
2 static const char RCSid[] = "$Id: bsdf.c,v 2.61 2021/12/07 23:49:50 greg Exp $";
5 * bsdf.c
6 *
7 * Definitions for bidirectional scattering distribution functions.
8 *
9 * Created by Greg Ward on 1/10/11.
10 *
11 */
12
13 #define _USE_MATH_DEFINES
14 #include <stdio.h>
15 #include <stdlib.h>
16 #include <string.h>
17 #include <math.h>
18 #include <ctype.h>
19 #include "ezxml.h"
20 #include "hilbert.h"
21 #include "bsdf.h"
22 #include "bsdf_m.h"
23 #include "bsdf_t.h"
24
25 /* English ASCII strings corresponding to ennumerated errors */
26 const char *SDerrorEnglish[] = {
27 "No error",
28 "Memory error",
29 "File input/output error",
30 "File format error",
31 "Illegal argument",
32 "Invalid data",
33 "Unsupported feature",
34 "Internal program error",
35 "Unknown error"
36 };
37
38 /* Pointer to error list in preferred language */
39 const char **SDerrorList = SDerrorEnglish;
40
41 /* Additional information on last error (ASCII English) */
42 char SDerrorDetail[256];
43
44 /* Empty distribution for getCDist() calls that fail for some reason */
45 const SDCDst SDemptyCD;
46
47 /* Cache of loaded BSDFs */
48 struct SDCache_s *SDcacheList = NULL;
49
50 /* Retain BSDFs in cache list? */
51 int SDretainSet = SDretainNone;
52
53 /* Maximum cache size for any given BSDF? */
54 unsigned long SDmaxCache = 0; /* 0 == unlimited */
55
56 /* Report any error to the indicated stream */
57 SDError
58 SDreportError(SDError ec, FILE *fp)
59 {
60 if (!ec)
61 return SDEnone;
62 if ((ec < SDEnone) | (ec > SDEunknown)) {
63 SDerrorDetail[0] = '\0';
64 ec = SDEunknown;
65 }
66 if (fp == NULL)
67 return ec;
68 fputs(SDerrorList[ec], fp);
69 if (SDerrorDetail[0]) {
70 fputs(": ", fp);
71 fputs(SDerrorDetail, fp);
72 }
73 fputc('\n', fp);
74 if (fp != stderr)
75 fflush(fp);
76 return ec;
77 }
78
79 static double
80 to_meters( /* return factor to convert given unit to meters */
81 const char *unit
82 )
83 {
84 if (unit == NULL) return(1.); /* safe assumption? */
85 if (!strcasecmp(unit, "Meter")) return(1.);
86 if (!strcasecmp(unit, "Foot")) return(.3048);
87 if (!strcasecmp(unit, "Inch")) return(.0254);
88 if (!strcasecmp(unit, "Centimeter")) return(.01);
89 if (!strcasecmp(unit, "Millimeter")) return(.001);
90 sprintf(SDerrorDetail, "Unknown dimensional unit '%s'", unit);
91 return(-1.);
92 }
93
94 /* Load geometric dimensions and description (if any) */
95 static SDError
96 SDloadGeometry(SDData *sd, ezxml_t wtl)
97 {
98 ezxml_t node, matl, geom;
99 double cfact;
100 const char *fmt = NULL, *mgfstr;
101
102 SDerrorDetail[0] = '\0';
103 sd->matn[0] = '\0'; sd->makr[0] = '\0';
104 sd->dim[0] = sd->dim[1] = sd->dim[2] = 0;
105 matl = ezxml_child(wtl, "Material");
106 if (matl != NULL) { /* get material info. */
107 if ((node = ezxml_child(matl, "Name")) != NULL) {
108 strncpy(sd->matn, ezxml_txt(node), SDnameLn);
109 if (sd->matn[SDnameLn-1])
110 strcpy(sd->matn+(SDnameLn-4), "...");
111 }
112 if ((node = ezxml_child(matl, "Manufacturer")) != NULL) {
113 strncpy(sd->makr, ezxml_txt(node), SDnameLn);
114 if (sd->makr[SDnameLn-1])
115 strcpy(sd->makr+(SDnameLn-4), "...");
116 }
117 if ((node = ezxml_child(matl, "Width")) != NULL)
118 sd->dim[0] = atof(ezxml_txt(node)) *
119 to_meters(ezxml_attr(node, "unit"));
120 if ((node = ezxml_child(matl, "Height")) != NULL)
121 sd->dim[1] = atof(ezxml_txt(node)) *
122 to_meters(ezxml_attr(node, "unit"));
123 if ((node = ezxml_child(matl, "Thickness")) != NULL)
124 sd->dim[2] = atof(ezxml_txt(node)) *
125 to_meters(ezxml_attr(node, "unit"));
126 if ((sd->dim[0] < 0) | (sd->dim[1] < 0) | (sd->dim[2] < 0)) {
127 if (!SDerrorDetail[0])
128 sprintf(SDerrorDetail, "Negative dimension in \"%s\"",
129 sd->name);
130 return SDEdata;
131 }
132 }
133 sd->mgf = NULL;
134 geom = ezxml_child(wtl, "Geometry");
135 if (geom == NULL) /* no actual geometry? */
136 return SDEnone;
137 fmt = ezxml_attr(geom, "format");
138 if (fmt != NULL && strcasecmp(fmt, "MGF")) {
139 sprintf(SDerrorDetail,
140 "Unrecognized geometry format '%s' in \"%s\"",
141 fmt, sd->name);
142 return SDEsupport;
143 }
144 if ((node = ezxml_child(geom, "MGFblock")) == NULL ||
145 (mgfstr = ezxml_txt(node)) == NULL)
146 return SDEnone;
147 while (isspace(*mgfstr))
148 ++mgfstr;
149 if (!*mgfstr)
150 return SDEnone;
151 cfact = to_meters(ezxml_attr(node, "unit"));
152 if (cfact <= 0)
153 return SDEformat;
154 sd->mgf = (char *)malloc(strlen(mgfstr)+32);
155 if (sd->mgf == NULL) {
156 strcpy(SDerrorDetail, "Out of memory in SDloadGeometry");
157 return SDEmemory;
158 }
159 if (cfact < 0.99 || cfact > 1.01)
160 sprintf(sd->mgf, "xf -s %.5f\n%s\nxf\n", cfact, mgfstr);
161 else
162 strcpy(sd->mgf, mgfstr);
163 return SDEnone;
164 }
165
166 /* Load a BSDF struct from the given file (free first and keep name) */
167 SDError
168 SDloadFile(SDData *sd, const char *fname)
169 {
170 SDError lastErr;
171 ezxml_t fl, wtl;
172
173 if ((sd == NULL) | (fname == NULL || !*fname))
174 return SDEargument;
175 /* free old data, keeping name */
176 SDfreeBSDF(sd);
177 /* parse XML file */
178 fl = ezxml_parse_file(fname);
179 if (fl == NULL) {
180 sprintf(SDerrorDetail, "Cannot open BSDF \"%s\"", fname);
181 return SDEfile;
182 }
183 if (ezxml_error(fl)[0]) {
184 sprintf(SDerrorDetail, "BSDF \"%s\" %s", fname, ezxml_error(fl));
185 ezxml_free(fl);
186 return SDEformat;
187 }
188 if (strcmp(ezxml_name(fl), "WindowElement")) {
189 sprintf(SDerrorDetail,
190 "BSDF \"%s\": top level node not 'WindowElement'",
191 sd->name);
192 ezxml_free(fl);
193 return SDEformat;
194 }
195 wtl = ezxml_child(fl, "FileType");
196 if (wtl != NULL && strcmp(ezxml_txt(wtl), "BSDF")) {
197 sprintf(SDerrorDetail,
198 "XML \"%s\": wrong FileType (must be 'BSDF')",
199 sd->name);
200 ezxml_free(fl);
201 return SDEformat;
202 }
203 wtl = ezxml_child(ezxml_child(fl, "Optical"), "Layer");
204 if (wtl == NULL) {
205 sprintf(SDerrorDetail, "BSDF \"%s\": no optical layers",
206 sd->name);
207 ezxml_free(fl);
208 return SDEformat;
209 }
210 /* load geometry if present */
211 lastErr = SDloadGeometry(sd, wtl);
212 if (lastErr) {
213 ezxml_free(fl);
214 return lastErr;
215 }
216 /* try loading variable resolution data */
217 lastErr = SDloadTre(sd, wtl);
218 /* check our result */
219 if (lastErr == SDEsupport) /* try matrix BSDF if not tree data */
220 lastErr = SDloadMtx(sd, wtl);
221
222 /* done with XML file */
223 ezxml_free(fl);
224
225 if (lastErr) { /* was there a load error? */
226 SDfreeBSDF(sd);
227 return lastErr;
228 }
229 /* remove any insignificant components */
230 if (sd->rf != NULL && sd->rf->maxHemi <= .001) {
231 SDfreeSpectralDF(sd->rf); sd->rf = NULL;
232 }
233 if (sd->rb != NULL && sd->rb->maxHemi <= .001) {
234 SDfreeSpectralDF(sd->rb); sd->rb = NULL;
235 }
236 if (sd->tf != NULL && sd->tf->maxHemi <= .001) {
237 SDfreeSpectralDF(sd->tf); sd->tf = NULL;
238 }
239 if (sd->tb != NULL && sd->tb->maxHemi <= .001) {
240 SDfreeSpectralDF(sd->tb); sd->tb = NULL;
241 }
242 /* return success */
243 return SDEnone;
244 }
245
246 /* Allocate new spectral distribution function */
247 SDSpectralDF *
248 SDnewSpectralDF(int nc)
249 {
250 SDSpectralDF *df;
251
252 if (nc <= 0) {
253 strcpy(SDerrorDetail, "Zero component spectral DF request");
254 return NULL;
255 }
256 df = (SDSpectralDF *)malloc(sizeof(SDSpectralDF) +
257 (nc-1)*sizeof(SDComponent));
258 if (df == NULL) {
259 sprintf(SDerrorDetail,
260 "Cannot allocate %d component spectral DF", nc);
261 return NULL;
262 }
263 df->minProjSA = .0;
264 df->maxHemi = .0;
265 df->ncomp = nc;
266 memset(df->comp, 0, nc*sizeof(SDComponent));
267 return df;
268 }
269
270 /* Add component(s) to spectral distribution function */
271 SDSpectralDF *
272 SDaddComponent(SDSpectralDF *odf, int nadd)
273 {
274 SDSpectralDF *df;
275
276 if (odf == NULL)
277 return SDnewSpectralDF(nadd);
278 if (nadd <= 0)
279 return odf;
280 df = (SDSpectralDF *)realloc(odf, sizeof(SDSpectralDF) +
281 (odf->ncomp+nadd-1)*sizeof(SDComponent));
282 if (df == NULL) {
283 sprintf(SDerrorDetail,
284 "Cannot add %d component(s) to spectral DF", nadd);
285 SDfreeSpectralDF(odf);
286 return NULL;
287 }
288 memset(df->comp+df->ncomp, 0, nadd*sizeof(SDComponent));
289 df->ncomp += nadd;
290 return df;
291 }
292
293 /* Free cached cumulative distributions for BSDF component */
294 void
295 SDfreeCumulativeCache(SDSpectralDF *df)
296 {
297 int n;
298 SDCDst *cdp;
299
300 if (df == NULL)
301 return;
302 for (n = df->ncomp; n-- > 0; )
303 while ((cdp = df->comp[n].cdList) != NULL) {
304 df->comp[n].cdList = cdp->next;
305 free(cdp);
306 }
307 }
308
309 /* Free a spectral distribution function */
310 void
311 SDfreeSpectralDF(SDSpectralDF *df)
312 {
313 int n;
314
315 if (df == NULL)
316 return;
317 SDfreeCumulativeCache(df);
318 for (n = df->ncomp; n-- > 0; )
319 if (df->comp[n].dist != NULL)
320 (*df->comp[n].func->freeSC)(df->comp[n].dist);
321 free(df);
322 }
323
324 /* Shorten file path to useable BSDF name, removing suffix */
325 void
326 SDclipName(char *res, const char *fname)
327 {
328 const char *cp, *dot = NULL;
329
330 for (cp = fname; *cp; cp++)
331 if (*cp == '.')
332 dot = cp;
333 else if (*cp == '/')
334 dot = NULL;
335 if ((dot == NULL) | (dot < fname+2))
336 dot = cp;
337 if (dot - fname >= SDnameLn)
338 fname = dot - SDnameLn + 1;
339 while (fname < dot)
340 *res++ = *fname++;
341 *res = '\0';
342 }
343
344 /* Initialize an unused BSDF struct (simply clears to zeroes) */
345 void
346 SDclearBSDF(SDData *sd, const char *fname)
347 {
348 if (sd == NULL)
349 return;
350 memset(sd, 0, sizeof(SDData));
351 if (fname == NULL)
352 return;
353 SDclipName(sd->name, fname);
354 }
355
356 /* Free data associated with BSDF struct */
357 void
358 SDfreeBSDF(SDData *sd)
359 {
360 if (sd == NULL)
361 return;
362 if (sd->mgf != NULL) {
363 free(sd->mgf);
364 sd->mgf = NULL;
365 }
366 if (sd->rf != NULL) {
367 SDfreeSpectralDF(sd->rf);
368 sd->rf = NULL;
369 }
370 if (sd->rb != NULL) {
371 SDfreeSpectralDF(sd->rb);
372 sd->rb = NULL;
373 }
374 if (sd->tf != NULL) {
375 SDfreeSpectralDF(sd->tf);
376 sd->tf = NULL;
377 }
378 if (sd->tb != NULL) {
379 SDfreeSpectralDF(sd->tb);
380 sd->tb = NULL;
381 }
382 sd->rLambFront.cieY = .0;
383 sd->rLambFront.spec.flags = 0;
384 sd->rLambBack.cieY = .0;
385 sd->rLambBack.spec.flags = 0;
386 sd->tLambFront.cieY = .0;
387 sd->tLambFront.spec.flags = 0;
388 sd->tLambBack.cieY = .0;
389 sd->tLambBack.spec.flags = 0;
390 }
391
392 /* Find writeable BSDF by name, or allocate new cache entry if absent */
393 SDData *
394 SDgetCache(const char *bname)
395 {
396 struct SDCache_s *sdl;
397 char sdnam[SDnameLn];
398
399 if (bname == NULL)
400 return NULL;
401
402 SDclipName(sdnam, bname);
403 for (sdl = SDcacheList; sdl != NULL; sdl = sdl->next)
404 if (!strcmp(sdl->bsdf.name, sdnam)) {
405 sdl->refcnt++;
406 return &sdl->bsdf;
407 }
408
409 sdl = (struct SDCache_s *)calloc(1, sizeof(struct SDCache_s));
410 if (sdl == NULL)
411 return NULL;
412
413 strcpy(sdl->bsdf.name, sdnam);
414 sdl->next = SDcacheList;
415 SDcacheList = sdl;
416
417 sdl->refcnt = 1;
418 return &sdl->bsdf;
419 }
420
421 /* Get loaded BSDF from cache (or load and cache it on first call) */
422 /* Report any problem to stderr and return NULL on failure */
423 const SDData *
424 SDcacheFile(const char *fname)
425 {
426 SDData *sd;
427 SDError ec;
428
429 if (fname == NULL || !*fname)
430 return NULL;
431 SDerrorDetail[0] = '\0';
432 /* PLACE MUTEX LOCK HERE FOR THREAD-SAFE */
433 if ((sd = SDgetCache(fname)) == NULL) {
434 SDreportError(SDEmemory, stderr);
435 return NULL;
436 }
437 if (!SDisLoaded(sd) && (ec = SDloadFile(sd, fname))) {
438 SDreportError(ec, stderr);
439 SDfreeCache(sd);
440 sd = NULL;
441 }
442 /* END MUTEX LOCK */
443 return sd;
444 }
445
446 /* Free a BSDF from our cache (clear all if NULL) */
447 void
448 SDfreeCache(const SDData *sd)
449 {
450 struct SDCache_s *sdl, *sdLast = NULL;
451
452 if (sd == NULL) { /* free entire list */
453 while ((sdl = SDcacheList) != NULL) {
454 SDcacheList = sdl->next;
455 SDfreeBSDF(&sdl->bsdf);
456 free(sdl);
457 }
458 return;
459 }
460 for (sdl = SDcacheList; sdl != NULL; sdl = (sdLast=sdl)->next)
461 if (&sdl->bsdf == sd)
462 break;
463 if (sdl == NULL || (sdl->refcnt -= (sdl->refcnt > 0)))
464 return; /* missing or still in use */
465 /* keep unreferenced data? */
466 if (SDisLoaded(sd) && SDretainSet) {
467 if (SDretainSet == SDretainAll)
468 return; /* keep everything */
469 /* else free cumulative data */
470 SDfreeCumulativeCache(sd->rf);
471 SDfreeCumulativeCache(sd->rb);
472 SDfreeCumulativeCache(sd->tf);
473 SDfreeCumulativeCache(sd->tb);
474 return;
475 }
476 /* remove from list and free */
477 if (sdLast == NULL)
478 SDcacheList = sdl->next;
479 else
480 sdLast->next = sdl->next;
481 SDfreeBSDF(&sdl->bsdf);
482 free(sdl);
483 }
484
485 /* Sample an individual BSDF component */
486 SDError
487 SDsampComponent(SDValue *sv, FVECT ioVec, double randX, SDComponent *sdc)
488 {
489 float coef[SDmaxCh];
490 SDError ec;
491 FVECT inVec;
492 const SDCDst *cd;
493 double d;
494 int n;
495 /* check arguments */
496 if ((sv == NULL) | (ioVec == NULL) | (sdc == NULL))
497 return SDEargument;
498 /* get cumulative distribution */
499 VCOPY(inVec, ioVec);
500 sv->cieY = 0;
501 cd = (*sdc->func->getCDist)(inVec, sdc);
502 if (cd != NULL)
503 sv->cieY = cd->cTotal;
504 if (sv->cieY <= 1e-6) { /* nothing to sample? */
505 sv->spec = c_dfcolor;
506 memset(ioVec, 0, sizeof(FVECT));
507 return SDEnone;
508 }
509 /* compute sample direction */
510 ec = (*sdc->func->sampCDist)(ioVec, randX, cd);
511 if (ec)
512 return ec;
513 /* get BSDF color */
514 n = (*sdc->func->getBSDFs)(coef, inVec, ioVec, sdc);
515 if (n <= 0) {
516 strcpy(SDerrorDetail, "BSDF sample value error");
517 return SDEinternal;
518 }
519 sv->spec = sdc->cspec[0];
520 d = coef[0];
521 while (--n) {
522 c_cmix(&sv->spec, d, &sv->spec, coef[n], &sdc->cspec[n]);
523 d += coef[n];
524 }
525 c_ccvt(&sv->spec, C_CSXY); /* make sure (x,y) is set */
526 return SDEnone;
527 }
528
529 #define MS_MAXDIM 15
530
531 /* Convert 1-dimensional random variable to N-dimensional */
532 void
533 SDmultiSamp(RREAL t[], int n, double randX)
534 {
535 unsigned nBits;
536 double scale;
537 bitmask_t ndx, coord[MS_MAXDIM];
538
539 if (n <= 0) /* check corner cases */
540 return;
541 if (randX < 0) randX = 0;
542 else if (randX >= 1.) randX = 0.999999999999999;
543 if (n == 1) {
544 t[0] = randX;
545 return;
546 }
547 while (n > MS_MAXDIM) /* punt for higher dimensions */
548 t[--n] = rand()*(1./(RAND_MAX+.5));
549 nBits = (8*sizeof(bitmask_t) - 1) / n;
550 ndx = randX * (double)((bitmask_t)1 << (nBits*n));
551 /* get coordinate on Hilbert curve */
552 hilbert_i2c(n, nBits, ndx, coord);
553 /* convert back to [0,1) range */
554 scale = 1. / (double)((bitmask_t)1 << nBits);
555 while (n--)
556 t[n] = scale * ((double)coord[n] + rand()*(1./(RAND_MAX+.5)));
557 }
558
559 #undef MS_MAXDIM
560
561 /* Generate diffuse hemispherical sample */
562 static void
563 SDdiffuseSamp(FVECT ioVec, int outFront, double randX)
564 {
565 /* convert to position on hemisphere */
566 SDmultiSamp(ioVec, 2, randX);
567 square2disk(ioVec, ioVec[0], ioVec[1]);
568 ioVec[2] = 1. - ioVec[0]*ioVec[0] - ioVec[1]*ioVec[1];
569 ioVec[2] = sqrt(ioVec[2]*(ioVec[2]>0));
570 if (!outFront) /* going out back? */
571 ioVec[2] = -ioVec[2];
572 }
573
574 /* Query projected solid angle coverage for non-diffuse BSDF direction */
575 SDError
576 SDsizeBSDF(double *projSA, const FVECT v1, const RREAL *v2,
577 int qflags, const SDData *sd)
578 {
579 SDSpectralDF *rdf, *tdf;
580 SDError ec;
581 int i;
582 /* check arguments */
583 if ((projSA == NULL) | (v1 == NULL) | (sd == NULL))
584 return SDEargument;
585 /* initialize extrema */
586 switch (qflags) {
587 case SDqueryMax:
588 projSA[0] = .0;
589 break;
590 case SDqueryMin+SDqueryMax:
591 projSA[1] = .0;
592 /* fall through */
593 case SDqueryMin:
594 projSA[0] = 10.;
595 break;
596 case 0:
597 return SDEargument;
598 }
599 if (v1[2] > 0) { /* front surface query? */
600 rdf = sd->rf;
601 tdf = (sd->tf != NULL) ? sd->tf : sd->tb;
602 } else {
603 rdf = sd->rb;
604 tdf = (sd->tb != NULL) ? sd->tb : sd->tf;
605 }
606 if (v2 != NULL) { /* bidirectional? */
607 if (v1[2] > 0 ^ v2[2] > 0)
608 rdf = NULL;
609 else
610 tdf = NULL;
611 }
612 ec = SDEdata; /* run through components */
613 for (i = (rdf==NULL) ? 0 : rdf->ncomp; i--; ) {
614 ec = (*rdf->comp[i].func->queryProjSA)(projSA, v1, v2,
615 qflags, &rdf->comp[i]);
616 if (ec)
617 return ec;
618 }
619 for (i = (tdf==NULL) ? 0 : tdf->ncomp; i--; ) {
620 ec = (*tdf->comp[i].func->queryProjSA)(projSA, v1, v2,
621 qflags, &tdf->comp[i]);
622 if (ec)
623 return ec;
624 }
625 if (ec) { /* all diffuse? */
626 projSA[0] = M_PI;
627 if (qflags == SDqueryMin+SDqueryMax)
628 projSA[1] = M_PI;
629 } else if (qflags == SDqueryMin+SDqueryMax && projSA[0] > projSA[1])
630 projSA[0] = projSA[1];
631 return SDEnone;
632 }
633
634 /* Return BSDF for the given incident and scattered ray vectors */
635 SDError
636 SDevalBSDF(SDValue *sv, const FVECT inVec, const FVECT outVec, const SDData *sd)
637 {
638 int inFront, outFront;
639 SDSpectralDF *sdf;
640 float coef[SDmaxCh];
641 int nch, i;
642 /* check arguments */
643 if ((sv == NULL) | (outVec == NULL) | (inVec == NULL) | (sd == NULL))
644 return SDEargument;
645 /* whose side are we on? */
646 inFront = (inVec[2] > 0);
647 outFront = (outVec[2] > 0);
648 /* start with diffuse portion */
649 if (inFront & outFront) {
650 *sv = sd->rLambFront;
651 sdf = sd->rf;
652 } else if (!(inFront | outFront)) {
653 *sv = sd->rLambBack;
654 sdf = sd->rb;
655 } else if (inFront) {
656 *sv = sd->tLambFront;
657 sdf = (sd->tf != NULL) ? sd->tf : sd->tb;
658 } else /* outFront & !inFront */ {
659 *sv = sd->tLambBack;
660 sdf = (sd->tb != NULL) ? sd->tb : sd->tf;
661 }
662 sv->cieY *= 1./M_PI;
663 /* add non-diffuse components */
664 i = (sdf != NULL) ? sdf->ncomp : 0;
665 while (i-- > 0) {
666 nch = (*sdf->comp[i].func->getBSDFs)(coef, inVec, outVec,
667 &sdf->comp[i]);
668 while (nch-- > 0) {
669 c_cmix(&sv->spec, sv->cieY, &sv->spec,
670 coef[nch], &sdf->comp[i].cspec[nch]);
671 sv->cieY += coef[nch];
672 }
673 }
674 c_ccvt(&sv->spec, C_CSXY); /* make sure (x,y) is set */
675 return SDEnone;
676 }
677
678 /* Compute directional hemispherical scattering at this incident angle */
679 double
680 SDdirectHemi(const FVECT inVec, int sflags, const SDData *sd)
681 {
682 double hsum;
683 SDSpectralDF *rdf, *tdf;
684 const SDCDst *cd;
685 int i;
686 /* check arguments */
687 if ((inVec == NULL) | (sd == NULL))
688 return .0;
689 /* gather diffuse components */
690 if (inVec[2] > 0) {
691 hsum = sd->rLambFront.cieY;
692 rdf = sd->rf;
693 tdf = (sd->tf != NULL) ? sd->tf : sd->tb;
694 } else /* !inFront */ {
695 hsum = sd->rLambBack.cieY;
696 rdf = sd->rb;
697 tdf = (sd->tb != NULL) ? sd->tb : sd->tf;
698 }
699 if ((sflags & SDsampDf+SDsampR) != SDsampDf+SDsampR)
700 hsum = .0;
701 if ((sflags & SDsampDf+SDsampT) == SDsampDf+SDsampT)
702 hsum += (inVec[2] > 0) ?
703 sd->tLambFront.cieY : sd->tLambBack.cieY;
704 /* gather non-diffuse components */
705 i = (((sflags & SDsampSp+SDsampR) == SDsampSp+SDsampR) &
706 (rdf != NULL)) ? rdf->ncomp : 0;
707 while (i-- > 0) { /* non-diffuse reflection */
708 cd = (*rdf->comp[i].func->getCDist)(inVec, &rdf->comp[i]);
709 if (cd != NULL)
710 hsum += cd->cTotal;
711 }
712 i = (((sflags & SDsampSp+SDsampT) == SDsampSp+SDsampT) &
713 (tdf != NULL)) ? tdf->ncomp : 0;
714 while (i-- > 0) { /* non-diffuse transmission */
715 cd = (*tdf->comp[i].func->getCDist)(inVec, &tdf->comp[i]);
716 if (cd != NULL)
717 hsum += cd->cTotal;
718 }
719 return hsum;
720 }
721
722 /* Sample BSDF direction based on the given random variable */
723 SDError
724 SDsampBSDF(SDValue *sv, FVECT ioVec, double randX, int sflags, const SDData *sd)
725 {
726 SDError ec;
727 FVECT inVec;
728 int inFront;
729 SDSpectralDF *rdf, *tdf;
730 double rdiff;
731 float coef[SDmaxCh];
732 int i, j, n, nr;
733 SDComponent *sdc;
734 const SDCDst **cdarr = NULL;
735 /* check arguments */
736 if ((sv == NULL) | (ioVec == NULL) | (sd == NULL) |
737 (randX < 0) | (randX >= 1.))
738 return SDEargument;
739 /* whose side are we on? */
740 VCOPY(inVec, ioVec);
741 inFront = (inVec[2] > 0);
742 /* remember diffuse portions */
743 if (inFront) {
744 *sv = sd->rLambFront;
745 rdf = sd->rf;
746 tdf = (sd->tf != NULL) ? sd->tf : sd->tb;
747 } else /* !inFront */ {
748 *sv = sd->rLambBack;
749 rdf = sd->rb;
750 tdf = (sd->tb != NULL) ? sd->tb : sd->tf;
751 }
752 if ((sflags & SDsampDf+SDsampR) != SDsampDf+SDsampR)
753 sv->cieY = .0;
754 rdiff = sv->cieY;
755 if ((sflags & SDsampDf+SDsampT) == SDsampDf+SDsampT)
756 sv->cieY += inFront ? sd->tLambFront.cieY : sd->tLambBack.cieY;
757 /* gather non-diffuse components */
758 i = nr = (((sflags & SDsampSp+SDsampR) == SDsampSp+SDsampR) &
759 (rdf != NULL)) ? rdf->ncomp : 0;
760 j = (((sflags & SDsampSp+SDsampT) == SDsampSp+SDsampT) &
761 (tdf != NULL)) ? tdf->ncomp : 0;
762 n = i + j;
763 if (n > 0 && (cdarr = (const SDCDst **)malloc(n*sizeof(SDCDst *))) == NULL)
764 return SDEmemory;
765 while (j-- > 0) { /* non-diffuse transmission */
766 cdarr[i+j] = (*tdf->comp[j].func->getCDist)(inVec, &tdf->comp[j]);
767 if (cdarr[i+j] == NULL)
768 cdarr[i+j] = &SDemptyCD;
769 sv->cieY += cdarr[i+j]->cTotal;
770 }
771 while (i-- > 0) { /* non-diffuse reflection */
772 cdarr[i] = (*rdf->comp[i].func->getCDist)(inVec, &rdf->comp[i]);
773 if (cdarr[i] == NULL)
774 cdarr[i] = &SDemptyCD;
775 sv->cieY += cdarr[i]->cTotal;
776 }
777 if (sv->cieY <= 1e-6) { /* anything to sample? */
778 sv->cieY = .0;
779 memset(ioVec, 0, sizeof(FVECT));
780 return SDEnone;
781 }
782 /* scale random variable */
783 randX *= sv->cieY;
784 /* diffuse reflection? */
785 if (randX < rdiff) {
786 SDdiffuseSamp(ioVec, inFront, randX/rdiff);
787 goto done;
788 }
789 randX -= rdiff;
790 /* diffuse transmission? */
791 if ((sflags & SDsampDf+SDsampT) == SDsampDf+SDsampT) {
792 const SDValue *sdt = inFront ? &sd->tLambFront : &sd->tLambBack;
793 if (randX < sdt->cieY) {
794 sv->spec = sdt->spec;
795 SDdiffuseSamp(ioVec, !inFront, randX/sdt->cieY);
796 goto done;
797 }
798 randX -= sdt->cieY;
799 }
800 /* else one of cumulative dist. */
801 for (i = 0; i < n && randX >= cdarr[i]->cTotal; i++)
802 randX -= cdarr[i]->cTotal;
803 if (i >= n)
804 return SDEinternal;
805 /* compute sample direction */
806 sdc = (i < nr) ? &rdf->comp[i] : &tdf->comp[i-nr];
807 ec = (*sdc->func->sampCDist)(ioVec, randX/cdarr[i]->cTotal, cdarr[i]);
808 if (ec)
809 return ec;
810 /* compute color */
811 j = (*sdc->func->getBSDFs)(coef, inVec, ioVec, sdc);
812 if (j <= 0) {
813 sprintf(SDerrorDetail, "BSDF \"%s\" sampling value error",
814 sd->name);
815 return SDEinternal;
816 }
817 sv->spec = sdc->cspec[0];
818 rdiff = coef[0];
819 while (--j) {
820 c_cmix(&sv->spec, rdiff, &sv->spec, coef[j], &sdc->cspec[j]);
821 rdiff += coef[j];
822 }
823 done:
824 if (cdarr != NULL)
825 free(cdarr);
826 c_ccvt(&sv->spec, C_CSXY); /* make sure (x,y) is set */
827 return SDEnone;
828 }
829
830 /* Compute World->BSDF transform from surface normal and up (Y) vector */
831 SDError
832 SDcompXform(RREAL vMtx[3][3], const FVECT sNrm, const FVECT uVec)
833 {
834 if ((vMtx == NULL) | (sNrm == NULL) | (uVec == NULL))
835 return SDEargument;
836 VCOPY(vMtx[2], sNrm);
837 if (normalize(vMtx[2]) == 0)
838 return SDEargument;
839 fcross(vMtx[0], uVec, vMtx[2]);
840 if (normalize(vMtx[0]) == 0)
841 return SDEargument;
842 fcross(vMtx[1], vMtx[2], vMtx[0]);
843 return SDEnone;
844 }
845
846 /* Compute inverse transform */
847 SDError
848 SDinvXform(RREAL iMtx[3][3], RREAL vMtx[3][3])
849 {
850 RREAL mTmp[3][3];
851 double d;
852
853 if ((iMtx == NULL) | (vMtx == NULL))
854 return SDEargument;
855 /* compute determinant */
856 mTmp[0][0] = vMtx[2][2]*vMtx[1][1] - vMtx[2][1]*vMtx[1][2];
857 mTmp[0][1] = vMtx[2][1]*vMtx[0][2] - vMtx[2][2]*vMtx[0][1];
858 mTmp[0][2] = vMtx[1][2]*vMtx[0][1] - vMtx[1][1]*vMtx[0][2];
859 d = vMtx[0][0]*mTmp[0][0] + vMtx[1][0]*mTmp[0][1] + vMtx[2][0]*mTmp[0][2];
860 if (d == 0) {
861 strcpy(SDerrorDetail, "Zero determinant in matrix inversion");
862 return SDEargument;
863 }
864 d = 1./d; /* invert matrix */
865 mTmp[0][0] *= d; mTmp[0][1] *= d; mTmp[0][2] *= d;
866 mTmp[1][0] = d*(vMtx[2][0]*vMtx[1][2] - vMtx[2][2]*vMtx[1][0]);
867 mTmp[1][1] = d*(vMtx[2][2]*vMtx[0][0] - vMtx[2][0]*vMtx[0][2]);
868 mTmp[1][2] = d*(vMtx[1][0]*vMtx[0][2] - vMtx[1][2]*vMtx[0][0]);
869 mTmp[2][0] = d*(vMtx[2][1]*vMtx[1][0] - vMtx[2][0]*vMtx[1][1]);
870 mTmp[2][1] = d*(vMtx[2][0]*vMtx[0][1] - vMtx[2][1]*vMtx[0][0]);
871 mTmp[2][2] = d*(vMtx[1][1]*vMtx[0][0] - vMtx[1][0]*vMtx[0][1]);
872 memcpy(iMtx, mTmp, sizeof(mTmp));
873 return SDEnone;
874 }
875
876 /* Transform and normalize direction (column) vector */
877 SDError
878 SDmapDir(FVECT resVec, RREAL vMtx[3][3], const FVECT inpVec)
879 {
880 FVECT vTmp;
881
882 if ((resVec == NULL) | (inpVec == NULL))
883 return SDEargument;
884 if (vMtx == NULL) { /* assume they just want to normalize */
885 if (resVec != inpVec)
886 VCOPY(resVec, inpVec);
887 return (normalize(resVec) > 0) ? SDEnone : SDEargument;
888 }
889 vTmp[0] = DOT(vMtx[0], inpVec);
890 vTmp[1] = DOT(vMtx[1], inpVec);
891 vTmp[2] = DOT(vMtx[2], inpVec);
892 if (normalize(vTmp) == 0)
893 return SDEargument;
894 VCOPY(resVec, vTmp);
895 return SDEnone;
896 }
