| 1 | #ifndef lint |
| 2 | static const char RCSid[] = "$Id: bsdf.c,v 2.61 2021/12/07 23:49:50 greg Exp $"; |
| 3 | #endif |
| 4 | /* |
| 5 | *  bsdf.c |
| 6 | * |
| 7 | *  Definitions for bidirectional scattering distribution functions. |
| 8 | * |
| 9 | *  Created by Greg Ward on 1/10/11. |
| 10 | * |
| 11 | */ |
| 12 |  |
| 13 | #define _USE_MATH_DEFINES |
| 14 | #include <stdio.h> |
| 15 | #include <stdlib.h> |
| 16 | #include <string.h> |
| 17 | #include <math.h> |
| 18 | #include <ctype.h> |
| 19 | #include "ezxml.h" |
| 20 | #include "hilbert.h" |
| 21 | #include "bsdf.h" |
| 22 | #include "bsdf_m.h" |
| 23 | #include "bsdf_t.h" |
| 24 |  |
| 25 | /* English ASCII strings corresponding to ennumerated errors */ |
| 26 | const char              *SDerrorEnglish[] = { |
| 27 | "No error", |
| 28 | "Memory error", |
| 29 | "File input/output error", |
| 30 | "File format error", |
| 31 | "Illegal argument", |
| 32 | "Invalid data", |
| 33 | "Unsupported feature", |
| 34 | "Internal program error", |
| 35 | "Unknown error" |
| 36 | }; |
| 37 |  |
| 38 | /* Pointer to error list in preferred language */ |
| 39 | const char              **SDerrorList = SDerrorEnglish; |
| 40 |  |
| 41 | /* Additional information on last error (ASCII English) */ |
| 42 | char                    SDerrorDetail[256]; |
| 43 |  |
| 44 | /* Empty distribution for getCDist() calls that fail for some reason */ |
| 45 | const SDCDst            SDemptyCD; |
| 46 |  |
| 47 | /* Cache of loaded BSDFs */ |
| 48 | struct SDCache_s        *SDcacheList = NULL; |
| 49 |  |
| 50 | /* Retain BSDFs in cache list? */ |
| 51 | int                     SDretainSet = SDretainNone; |
| 52 |  |
| 53 | /* Maximum cache size for any given BSDF? */ |
| 54 | unsigned long           SDmaxCache = 0;         /* 0 == unlimited */ |
| 55 |  |
| 56 | /* Report any error to the indicated stream */ |
| 57 | SDError |
| 58 | SDreportError(SDError ec, FILE *fp) |
| 59 | { |
| 60 | if (!ec) |
| 61 | return SDEnone; |
| 62 | if ((ec < SDEnone) | (ec > SDEunknown)) { |
| 63 | SDerrorDetail[0] = '\0'; |
| 64 | ec = SDEunknown; |
| 65 | } |
| 66 | if (fp == NULL) |
| 67 | return ec; |
| 68 | fputs(SDerrorList[ec], fp); |
| 69 | if (SDerrorDetail[0]) { |
| 70 | fputs(": ", fp); |
| 71 | fputs(SDerrorDetail, fp); |
| 72 | } |
| 73 | fputc('\n', fp); |
| 74 | if (fp != stderr) |
| 75 | fflush(fp); |
| 76 | return ec; |
| 77 | } |
| 78 |  |
| 79 | static double |
| 80 | to_meters(              /* return factor to convert given unit to meters */ |
| 81 | const char *unit |
| 82 | ) |
| 83 | { |
| 84 | if (unit == NULL) return(1.);           /* safe assumption? */ |
| 85 | if (!strcasecmp(unit, "Meter")) return(1.); |
| 86 | if (!strcasecmp(unit, "Foot")) return(.3048); |
| 87 | if (!strcasecmp(unit, "Inch")) return(.0254); |
| 88 | if (!strcasecmp(unit, "Centimeter")) return(.01); |
| 89 | if (!strcasecmp(unit, "Millimeter")) return(.001); |
| 90 | sprintf(SDerrorDetail, "Unknown dimensional unit '%s'", unit); |
| 91 | return(-1.); |
| 92 | } |
| 93 |  |
| 94 | /* Load geometric dimensions and description (if any) */ |
| 95 | static SDError |
| 96 | SDloadGeometry(SDData *sd, ezxml_t wtl) |
| 97 | { |
| 98 | ezxml_t         node, matl, geom; |
| 99 | double          cfact; |
| 100 | const char      *fmt = NULL, *mgfstr; |
| 101 |  |
| 102 | SDerrorDetail[0] = '\0'; |
| 103 | sd->matn[0] = '\0'; sd->makr[0] = '\0'; |
| 104 | sd->dim[0] = sd->dim[1] = sd->dim[2] = 0; |
| 105 | matl = ezxml_child(wtl, "Material"); |
| 106 | if (matl != NULL) {                     /* get material info. */ |
| 107 | if ((node = ezxml_child(matl, "Name")) != NULL) { |
| 108 | strncpy(sd->matn, ezxml_txt(node), SDnameLn); |
| 109 | if (sd->matn[SDnameLn-1]) |
| 110 | strcpy(sd->matn+(SDnameLn-4), "..."); |
| 111 | } |
| 112 | if ((node = ezxml_child(matl, "Manufacturer")) != NULL) { |
| 113 | strncpy(sd->makr, ezxml_txt(node), SDnameLn); |
| 114 | if (sd->makr[SDnameLn-1]) |
| 115 | strcpy(sd->makr+(SDnameLn-4), "..."); |
| 116 | } |
| 117 | if ((node = ezxml_child(matl, "Width")) != NULL) |
| 118 | sd->dim[0] = atof(ezxml_txt(node)) * |
| 119 | to_meters(ezxml_attr(node, "unit")); |
| 120 | if ((node = ezxml_child(matl, "Height")) != NULL) |
| 121 | sd->dim[1] = atof(ezxml_txt(node)) * |
| 122 | to_meters(ezxml_attr(node, "unit")); |
| 123 | if ((node = ezxml_child(matl, "Thickness")) != NULL) |
| 124 | sd->dim[2] = atof(ezxml_txt(node)) * |
| 125 | to_meters(ezxml_attr(node, "unit")); |
| 126 | if ((sd->dim[0] < 0) | (sd->dim[1] < 0) | (sd->dim[2] < 0)) { |
| 127 | if (!SDerrorDetail[0]) |
| 128 | sprintf(SDerrorDetail, "Negative dimension in \"%s\"", |
| 129 | sd->name); |
| 130 | return SDEdata; |
| 131 | } |
| 132 | } |
| 133 | sd->mgf = NULL; |
| 134 | geom = ezxml_child(wtl, "Geometry"); |
| 135 | if (geom == NULL)                       /* no actual geometry? */ |
| 136 | return SDEnone; |
| 137 | fmt = ezxml_attr(geom, "format"); |
| 138 | if (fmt != NULL && strcasecmp(fmt, "MGF")) { |
| 139 | sprintf(SDerrorDetail, |
| 140 | "Unrecognized geometry format '%s' in \"%s\"", |
| 141 | fmt, sd->name); |
| 142 | return SDEsupport; |
| 143 | } |
| 144 | if ((node = ezxml_child(geom, "MGFblock")) == NULL || |
| 145 | (mgfstr = ezxml_txt(node)) == NULL) |
| 146 | return SDEnone; |
| 147 | while (isspace(*mgfstr)) |
| 148 | ++mgfstr; |
| 149 | if (!*mgfstr) |
| 150 | return SDEnone; |
| 151 | cfact = to_meters(ezxml_attr(node, "unit")); |
| 152 | if (cfact <= 0) |
| 153 | return SDEformat; |
| 154 | sd->mgf = (char *)malloc(strlen(mgfstr)+32); |
| 155 | if (sd->mgf == NULL) { |
| 156 | strcpy(SDerrorDetail, "Out of memory in SDloadGeometry"); |
| 157 | return SDEmemory; |
| 158 | } |
| 159 | if (cfact < 0.99 || cfact > 1.01) |
| 160 | sprintf(sd->mgf, "xf -s %.5f\n%s\nxf\n", cfact, mgfstr); |
| 161 | else |
| 162 | strcpy(sd->mgf, mgfstr); |
| 163 | return SDEnone; |
| 164 | } |
| 165 |  |
| 166 | /* Load a BSDF struct from the given file (free first and keep name) */ |
| 167 | SDError |
| 168 | SDloadFile(SDData *sd, const char *fname) |
| 169 | { |
| 170 | SDError         lastErr; |
| 171 | ezxml_t         fl, wtl; |
| 172 |  |
| 173 | if ((sd == NULL) | (fname == NULL || !*fname)) |
| 174 | return SDEargument; |
| 175 | /* free old data, keeping name */ |
| 176 | SDfreeBSDF(sd); |
| 177 | /* parse XML file */ |
| 178 | fl = ezxml_parse_file(fname); |
| 179 | if (fl == NULL) { |
| 180 | sprintf(SDerrorDetail, "Cannot open BSDF \"%s\"", fname); |
| 181 | return SDEfile; |
| 182 | } |
| 183 | if (ezxml_error(fl)[0]) { |
| 184 | sprintf(SDerrorDetail, "BSDF \"%s\" %s", fname, ezxml_error(fl)); |
| 185 | ezxml_free(fl); |
| 186 | return SDEformat; |
| 187 | } |
| 188 | if (strcmp(ezxml_name(fl), "WindowElement")) { |
| 189 | sprintf(SDerrorDetail, |
| 190 | "BSDF \"%s\": top level node not 'WindowElement'", |
| 191 | sd->name); |
| 192 | ezxml_free(fl); |
| 193 | return SDEformat; |
| 194 | } |
| 195 | wtl = ezxml_child(fl, "FileType"); |
| 196 | if (wtl != NULL && strcmp(ezxml_txt(wtl), "BSDF")) { |
| 197 | sprintf(SDerrorDetail, |
| 198 | "XML \"%s\": wrong FileType (must be 'BSDF')", |
| 199 | sd->name); |
| 200 | ezxml_free(fl); |
| 201 | return SDEformat; |
| 202 | } |
| 203 | wtl = ezxml_child(ezxml_child(fl, "Optical"), "Layer"); |
| 204 | if (wtl == NULL) { |
| 205 | sprintf(SDerrorDetail, "BSDF \"%s\": no optical layers", |
| 206 | sd->name); |
| 207 | ezxml_free(fl); |
| 208 | return SDEformat; |
| 209 | } |
| 210 | /* load geometry if present */ |
| 211 | lastErr = SDloadGeometry(sd, wtl); |
| 212 | if (lastErr) { |
| 213 | ezxml_free(fl); |
| 214 | return lastErr; |
| 215 | } |
| 216 | /* try loading variable resolution data */ |
| 217 | lastErr = SDloadTre(sd, wtl); |
| 218 | /* check our result */ |
| 219 | if (lastErr == SDEsupport)      /* try matrix BSDF if not tree data */ |
| 220 | lastErr = SDloadMtx(sd, wtl); |
| 221 |  |
| 222 | /* done with XML file */ |
| 223 | ezxml_free(fl); |
| 224 |  |
| 225 | if (lastErr) {          /* was there a load error? */ |
| 226 | SDfreeBSDF(sd); |
| 227 | return lastErr; |
| 228 | } |
| 229 | /* remove any insignificant components */ |
| 230 | if (sd->rf != NULL && sd->rf->maxHemi <= .001) { |
| 231 | SDfreeSpectralDF(sd->rf); sd->rf = NULL; |
| 232 | } |
| 233 | if (sd->rb != NULL && sd->rb->maxHemi <= .001) { |
| 234 | SDfreeSpectralDF(sd->rb); sd->rb = NULL; |
| 235 | } |
| 236 | if (sd->tf != NULL && sd->tf->maxHemi <= .001) { |
| 237 | SDfreeSpectralDF(sd->tf); sd->tf = NULL; |
| 238 | } |
| 239 | if (sd->tb != NULL && sd->tb->maxHemi <= .001) { |
| 240 | SDfreeSpectralDF(sd->tb); sd->tb = NULL; |
| 241 | } |
| 242 | /* return success */ |
| 243 | return SDEnone; |
| 244 | } |
| 245 |  |
| 246 | /* Allocate new spectral distribution function */ |
| 247 | SDSpectralDF * |
| 248 | SDnewSpectralDF(int nc) |
| 249 | { |
| 250 | SDSpectralDF    *df; |
| 251 |  |
| 252 | if (nc <= 0) { |
| 253 | strcpy(SDerrorDetail, "Zero component spectral DF request"); |
| 254 | return NULL; |
| 255 | } |
| 256 | df = (SDSpectralDF *)malloc(sizeof(SDSpectralDF) + |
| 257 | (nc-1)*sizeof(SDComponent)); |
| 258 | if (df == NULL) { |
| 259 | sprintf(SDerrorDetail, |
| 260 | "Cannot allocate %d component spectral DF", nc); |
| 261 | return NULL; |
| 262 | } |
| 263 | df->minProjSA = .0; |
| 264 | df->maxHemi = .0; |
| 265 | df->ncomp = nc; |
| 266 | memset(df->comp, 0, nc*sizeof(SDComponent)); |
| 267 | return df; |
| 268 | } |
| 269 |  |
| 270 | /* Add component(s) to spectral distribution function */ |
| 271 | SDSpectralDF * |
| 272 | SDaddComponent(SDSpectralDF *odf, int nadd) |
| 273 | { |
| 274 | SDSpectralDF    *df; |
| 275 |  |
| 276 | if (odf == NULL) |
| 277 | return SDnewSpectralDF(nadd); |
| 278 | if (nadd <= 0) |
| 279 | return odf; |
| 280 | df = (SDSpectralDF *)realloc(odf, sizeof(SDSpectralDF) + |
| 281 | (odf->ncomp+nadd-1)*sizeof(SDComponent)); |
| 282 | if (df == NULL) { |
| 283 | sprintf(SDerrorDetail, |
| 284 | "Cannot add %d component(s) to spectral DF", nadd); |
| 285 | SDfreeSpectralDF(odf); |
| 286 | return NULL; |
| 287 | } |
| 288 | memset(df->comp+df->ncomp, 0, nadd*sizeof(SDComponent)); |
| 289 | df->ncomp += nadd; |
| 290 | return df; |
| 291 | } |
| 292 |  |
| 293 | /* Free cached cumulative distributions for BSDF component */ |
| 294 | void |
| 295 | SDfreeCumulativeCache(SDSpectralDF *df) |
| 296 | { |
| 297 | int     n; |
| 298 | SDCDst  *cdp; |
| 299 |  |
| 300 | if (df == NULL) |
| 301 | return; |
| 302 | for (n = df->ncomp; n-- > 0; ) |
| 303 | while ((cdp = df->comp[n].cdList) != NULL) { |
| 304 | df->comp[n].cdList = cdp->next; |
| 305 | free(cdp); |
| 306 | } |
| 307 | } |
| 308 |  |
| 309 | /* Free a spectral distribution function */ |
| 310 | void |
| 311 | SDfreeSpectralDF(SDSpectralDF *df) |
| 312 | { |
| 313 | int     n; |
| 314 |  |
| 315 | if (df == NULL) |
| 316 | return; |
| 317 | SDfreeCumulativeCache(df); |
| 318 | for (n = df->ncomp; n-- > 0; ) |
| 319 | if (df->comp[n].dist != NULL) |
| 320 | (*df->comp[n].func->freeSC)(df->comp[n].dist); |
| 321 | free(df); |
| 322 | } |
| 323 |  |
| 324 | /* Shorten file path to useable BSDF name, removing suffix */ |
| 325 | void |
| 326 | SDclipName(char *res, const char *fname) |
| 327 | { |
| 328 | const char      *cp, *dot = NULL; |
| 329 |  |
| 330 | for (cp = fname; *cp; cp++) |
| 331 | if (*cp == '.') |
| 332 | dot = cp; |
| 333 | else if (*cp == '/') |
| 334 | dot = NULL; |
| 335 | if ((dot == NULL) | (dot < fname+2)) |
| 336 | dot = cp; |
| 337 | if (dot - fname >= SDnameLn) |
| 338 | fname = dot - SDnameLn + 1; |
| 339 | while (fname < dot) |
| 340 | *res++ = *fname++; |
| 341 | *res = '\0'; |
| 342 | } |
| 343 |  |
| 344 | /* Initialize an unused BSDF struct (simply clears to zeroes) */ |
| 345 | void |
| 346 | SDclearBSDF(SDData *sd, const char *fname) |
| 347 | { |
| 348 | if (sd == NULL) |
| 349 | return; |
| 350 | memset(sd, 0, sizeof(SDData)); |
| 351 | if (fname == NULL) |
| 352 | return; |
| 353 | SDclipName(sd->name, fname); |
| 354 | } |
| 355 |  |
| 356 | /* Free data associated with BSDF struct */ |
| 357 | void |
| 358 | SDfreeBSDF(SDData *sd) |
| 359 | { |
| 360 | if (sd == NULL) |
| 361 | return; |
| 362 | if (sd->mgf != NULL) { |
| 363 | free(sd->mgf); |
| 364 | sd->mgf = NULL; |
| 365 | } |
| 366 | if (sd->rf != NULL) { |
| 367 | SDfreeSpectralDF(sd->rf); |
| 368 | sd->rf = NULL; |
| 369 | } |
| 370 | if (sd->rb != NULL) { |
| 371 | SDfreeSpectralDF(sd->rb); |
| 372 | sd->rb = NULL; |
| 373 | } |
| 374 | if (sd->tf != NULL) { |
| 375 | SDfreeSpectralDF(sd->tf); |
| 376 | sd->tf = NULL; |
| 377 | } |
| 378 | if (sd->tb != NULL) { |
| 379 | SDfreeSpectralDF(sd->tb); |
| 380 | sd->tb = NULL; |
| 381 | } |
| 382 | sd->rLambFront.cieY = .0; |
| 383 | sd->rLambFront.spec.flags = 0; |
| 384 | sd->rLambBack.cieY = .0; |
| 385 | sd->rLambBack.spec.flags = 0; |
| 386 | sd->tLambFront.cieY = .0; |
| 387 | sd->tLambFront.spec.flags = 0; |
| 388 | sd->tLambBack.cieY = .0; |
| 389 | sd->tLambBack.spec.flags = 0; |
| 390 | } |
| 391 |  |
| 392 | /* Find writeable BSDF by name, or allocate new cache entry if absent */ |
| 393 | SDData * |
| 394 | SDgetCache(const char *bname) |
| 395 | { |
| 396 | struct SDCache_s        *sdl; |
| 397 | char                    sdnam[SDnameLn]; |
| 398 |  |
| 399 | if (bname == NULL) |
| 400 | return NULL; |
| 401 |  |
| 402 | SDclipName(sdnam, bname); |
| 403 | for (sdl = SDcacheList; sdl != NULL; sdl = sdl->next) |
| 404 | if (!strcmp(sdl->bsdf.name, sdnam)) { |
| 405 | sdl->refcnt++; |
| 406 | return &sdl->bsdf; |
| 407 | } |
| 408 |  |
| 409 | sdl = (struct SDCache_s *)calloc(1, sizeof(struct SDCache_s)); |
| 410 | if (sdl == NULL) |
| 411 | return NULL; |
| 412 |  |
| 413 | strcpy(sdl->bsdf.name, sdnam); |
| 414 | sdl->next = SDcacheList; |
| 415 | SDcacheList = sdl; |
| 416 |  |
| 417 | sdl->refcnt = 1; |
| 418 | return &sdl->bsdf; |
| 419 | } |
| 420 |  |
| 421 | /* Get loaded BSDF from cache (or load and cache it on first call) */ |
| 422 | /* Report any problem to stderr and return NULL on failure */ |
| 423 | const SDData * |
| 424 | SDcacheFile(const char *fname) |
| 425 | { |
| 426 | SDData          *sd; |
| 427 | SDError         ec; |
| 428 |  |
| 429 | if (fname == NULL || !*fname) |
| 430 | return NULL; |
| 431 | SDerrorDetail[0] = '\0'; |
| 432 | /* PLACE MUTEX LOCK HERE FOR THREAD-SAFE */ |
| 433 | if ((sd = SDgetCache(fname)) == NULL) { |
| 434 | SDreportError(SDEmemory, stderr); |
| 435 | return NULL; |
| 436 | } |
| 437 | if (!SDisLoaded(sd) && (ec = SDloadFile(sd, fname))) { |
| 438 | SDreportError(ec, stderr); |
| 439 | SDfreeCache(sd); |
| 440 | sd = NULL; |
| 441 | } |
| 442 | /* END MUTEX LOCK */ |
| 443 | return sd; |
| 444 | } |
| 445 |  |
| 446 | /* Free a BSDF from our cache (clear all if NULL) */ |
| 447 | void |
| 448 | SDfreeCache(const SDData *sd) |
| 449 | { |
| 450 | struct SDCache_s        *sdl, *sdLast = NULL; |
| 451 |  |
| 452 | if (sd == NULL) {               /* free entire list */ |
| 453 | while ((sdl = SDcacheList) != NULL) { |
| 454 | SDcacheList = sdl->next; |
| 455 | SDfreeBSDF(&sdl->bsdf); |
| 456 | free(sdl); |
| 457 | } |
| 458 | return; |
| 459 | } |
| 460 | for (sdl = SDcacheList; sdl != NULL; sdl = (sdLast=sdl)->next) |
| 461 | if (&sdl->bsdf == sd) |
| 462 | break; |
| 463 | if (sdl == NULL || (sdl->refcnt -= (sdl->refcnt > 0))) |
| 464 | return;                 /* missing or still in use */ |
| 465 | /* keep unreferenced data? */ |
| 466 | if (SDisLoaded(sd) && SDretainSet) { |
| 467 | if (SDretainSet == SDretainAll) |
| 468 | return;         /* keep everything */ |
| 469 | /* else free cumulative data */ |
| 470 | SDfreeCumulativeCache(sd->rf); |
| 471 | SDfreeCumulativeCache(sd->rb); |
| 472 | SDfreeCumulativeCache(sd->tf); |
| 473 | SDfreeCumulativeCache(sd->tb); |
| 474 | return; |
| 475 | } |
| 476 | /* remove from list and free */ |
| 477 | if (sdLast == NULL) |
| 478 | SDcacheList = sdl->next; |
| 479 | else |
| 480 | sdLast->next = sdl->next; |
| 481 | SDfreeBSDF(&sdl->bsdf); |
| 482 | free(sdl); |
| 483 | } |
| 484 |  |
| 485 | /* Sample an individual BSDF component */ |
| 486 | SDError |
| 487 | SDsampComponent(SDValue *sv, FVECT ioVec, double randX, SDComponent *sdc) |
| 488 | { |
| 489 | float           coef[SDmaxCh]; |
| 490 | SDError         ec; |
| 491 | FVECT           inVec; |
| 492 | const SDCDst    *cd; |
| 493 | double          d; |
| 494 | int             n; |
| 495 | /* check arguments */ |
| 496 | if ((sv == NULL) | (ioVec == NULL) | (sdc == NULL)) |
| 497 | return SDEargument; |
| 498 | /* get cumulative distribution */ |
| 499 | VCOPY(inVec, ioVec); |
| 500 | sv->cieY = 0; |
| 501 | cd = (*sdc->func->getCDist)(inVec, sdc); |
| 502 | if (cd != NULL) |
| 503 | sv->cieY = cd->cTotal; |
| 504 | if (sv->cieY <= 1e-6) {         /* nothing to sample? */ |
| 505 | sv->spec = c_dfcolor; |
| 506 | memset(ioVec, 0, sizeof(FVECT)); |
| 507 | return SDEnone; |
| 508 | } |
| 509 | /* compute sample direction */ |
| 510 | ec = (*sdc->func->sampCDist)(ioVec, randX, cd); |
| 511 | if (ec) |
| 512 | return ec; |
| 513 | /* get BSDF color */ |
| 514 | n = (*sdc->func->getBSDFs)(coef, inVec, ioVec, sdc); |
| 515 | if (n <= 0) { |
| 516 | strcpy(SDerrorDetail, "BSDF sample value error"); |
| 517 | return SDEinternal; |
| 518 | } |
| 519 | sv->spec = sdc->cspec[0]; |
| 520 | d = coef[0]; |
| 521 | while (--n) { |
| 522 | c_cmix(&sv->spec, d, &sv->spec, coef[n], &sdc->cspec[n]); |
| 523 | d += coef[n]; |
| 524 | } |
| 525 | c_ccvt(&sv->spec, C_CSXY);      /* make sure (x,y) is set */ |
| 526 | return SDEnone; |
| 527 | } |
| 528 |  |
| 529 | #define MS_MAXDIM       15 |
| 530 |  |
| 531 | /* Convert 1-dimensional random variable to N-dimensional */ |
| 532 | void |
| 533 | SDmultiSamp(RREAL t[], int n, double randX) |
| 534 | { |
| 535 | unsigned        nBits; |
| 536 | double          scale; |
| 537 | bitmask_t       ndx, coord[MS_MAXDIM]; |
| 538 |  |
| 539 | if (n <= 0)                     /* check corner cases */ |
| 540 | return; |
| 541 | if (randX < 0) randX = 0; |
| 542 | else if (randX >= 1.) randX = 0.999999999999999; |
| 543 | if (n == 1) { |
| 544 | t[0] = randX; |
| 545 | return; |
| 546 | } |
| 547 | while (n > MS_MAXDIM)           /* punt for higher dimensions */ |
| 548 | t[--n] = rand()*(1./(RAND_MAX+.5)); |
| 549 | nBits = (8*sizeof(bitmask_t) - 1) / n; |
| 550 | ndx = randX * (double)((bitmask_t)1 << (nBits*n)); |
| 551 | /* get coordinate on Hilbert curve */ |
| 552 | hilbert_i2c(n, nBits, ndx, coord); |
| 553 | /* convert back to [0,1) range */ |
| 554 | scale = 1. / (double)((bitmask_t)1 << nBits); |
| 555 | while (n--) |
| 556 | t[n] = scale * ((double)coord[n] + rand()*(1./(RAND_MAX+.5))); |
| 557 | } |
| 558 |  |
| 559 | #undef MS_MAXDIM |
| 560 |  |
| 561 | /* Generate diffuse hemispherical sample */ |
| 562 | static void |
| 563 | SDdiffuseSamp(FVECT ioVec, int outFront, double randX) |
| 564 | { |
| 565 | /* convert to position on hemisphere */ |
| 566 | SDmultiSamp(ioVec, 2, randX); |
| 567 | square2disk(ioVec, ioVec[0], ioVec[1]); |
| 568 | ioVec[2] = 1. - ioVec[0]*ioVec[0] - ioVec[1]*ioVec[1]; |
| 569 | ioVec[2] = sqrt(ioVec[2]*(ioVec[2]>0)); |
| 570 | if (!outFront)                  /* going out back? */ |
| 571 | ioVec[2] = -ioVec[2]; |
| 572 | } |
| 573 |  |
| 574 | /* Query projected solid angle coverage for non-diffuse BSDF direction */ |
| 575 | SDError |
| 576 | SDsizeBSDF(double *projSA, const FVECT v1, const RREAL *v2, |
| 577 | int qflags, const SDData *sd) |
| 578 | { |
| 579 | SDSpectralDF    *rdf, *tdf; |
| 580 | SDError         ec; |
| 581 | int             i; |
| 582 | /* check arguments */ |
| 583 | if ((projSA == NULL) | (v1 == NULL) | (sd == NULL)) |
| 584 | return SDEargument; |
| 585 | /* initialize extrema */ |
| 586 | switch (qflags) { |
| 587 | case SDqueryMax: |
| 588 | projSA[0] = .0; |
| 589 | break; |
| 590 | case SDqueryMin+SDqueryMax: |
| 591 | projSA[1] = .0; |
| 592 | /* fall through */ |
| 593 | case SDqueryMin: |
| 594 | projSA[0] = 10.; |
| 595 | break; |
| 596 | case 0: |
| 597 | return SDEargument; |
| 598 | } |
| 599 | if (v1[2] > 0) {                /* front surface query? */ |
| 600 | rdf = sd->rf; |
| 601 | tdf = (sd->tf != NULL) ? sd->tf : sd->tb; |
| 602 | } else { |
| 603 | rdf = sd->rb; |
| 604 | tdf = (sd->tb != NULL) ? sd->tb : sd->tf; |
| 605 | } |
| 606 | if (v2 != NULL) {               /* bidirectional? */ |
| 607 | if (v1[2] > 0 ^ v2[2] > 0) |
| 608 | rdf = NULL; |
| 609 | else |
| 610 | tdf = NULL; |
| 611 | } |
| 612 | ec = SDEdata;                   /* run through components */ |
| 613 | for (i = (rdf==NULL) ? 0 : rdf->ncomp; i--; ) { |
| 614 | ec = (*rdf->comp[i].func->queryProjSA)(projSA, v1, v2, |
| 615 | qflags, &rdf->comp[i]); |
| 616 | if (ec) |
| 617 | return ec; |
| 618 | } |
| 619 | for (i = (tdf==NULL) ? 0 : tdf->ncomp; i--; ) { |
| 620 | ec = (*tdf->comp[i].func->queryProjSA)(projSA, v1, v2, |
| 621 | qflags, &tdf->comp[i]); |
| 622 | if (ec) |
| 623 | return ec; |
| 624 | } |
| 625 | if (ec) {                       /* all diffuse? */ |
| 626 | projSA[0] = M_PI; |
| 627 | if (qflags == SDqueryMin+SDqueryMax) |
| 628 | projSA[1] = M_PI; |
| 629 | } else if (qflags == SDqueryMin+SDqueryMax && projSA[0] > projSA[1]) |
| 630 | projSA[0] = projSA[1]; |
| 631 | return SDEnone; |
| 632 | } |
| 633 |  |
| 634 | /* Return BSDF for the given incident and scattered ray vectors */ |
| 635 | SDError |
| 636 | SDevalBSDF(SDValue *sv, const FVECT inVec, const FVECT outVec, const SDData *sd) |
| 637 | { |
| 638 | int             inFront, outFront; |
| 639 | SDSpectralDF    *sdf; |
| 640 | float           coef[SDmaxCh]; |
| 641 | int             nch, i; |
| 642 | /* check arguments */ |
| 643 | if ((sv == NULL) | (outVec == NULL) | (inVec == NULL) | (sd == NULL)) |
| 644 | return SDEargument; |
| 645 | /* whose side are we on? */ |
| 646 | inFront = (inVec[2] > 0); |
| 647 | outFront = (outVec[2] > 0); |
| 648 | /* start with diffuse portion */ |
| 649 | if (inFront & outFront) { |
| 650 | *sv = sd->rLambFront; |
| 651 | sdf = sd->rf; |
| 652 | } else if (!(inFront | outFront)) { |
| 653 | *sv = sd->rLambBack; |
| 654 | sdf = sd->rb; |
| 655 | } else if (inFront) { |
| 656 | *sv = sd->tLambFront; |
| 657 | sdf = (sd->tf != NULL) ? sd->tf : sd->tb; |
| 658 | } else /* outFront & !inFront */ { |
| 659 | *sv = sd->tLambBack; |
| 660 | sdf = (sd->tb != NULL) ? sd->tb : sd->tf; |
| 661 | } |
| 662 | sv->cieY *= 1./M_PI; |
| 663 | /* add non-diffuse components */ |
| 664 | i = (sdf != NULL) ? sdf->ncomp : 0; |
| 665 | while (i-- > 0) { |
| 666 | nch = (*sdf->comp[i].func->getBSDFs)(coef, inVec, outVec, |
| 667 | &sdf->comp[i]); |
| 668 | while (nch-- > 0) { |
| 669 | c_cmix(&sv->spec, sv->cieY, &sv->spec, |
| 670 | coef[nch], &sdf->comp[i].cspec[nch]); |
| 671 | sv->cieY += coef[nch]; |
| 672 | } |
| 673 | } |
| 674 | c_ccvt(&sv->spec, C_CSXY);      /* make sure (x,y) is set */ |
| 675 | return SDEnone; |
| 676 | } |
| 677 |  |
| 678 | /* Compute directional hemispherical scattering at this incident angle */ |
| 679 | double |
| 680 | SDdirectHemi(const FVECT inVec, int sflags, const SDData *sd) |
| 681 | { |
| 682 | double          hsum; |
| 683 | SDSpectralDF    *rdf, *tdf; |
| 684 | const SDCDst    *cd; |
| 685 | int             i; |
| 686 | /* check arguments */ |
| 687 | if ((inVec == NULL) | (sd == NULL)) |
| 688 | return .0; |
| 689 | /* gather diffuse components */ |
| 690 | if (inVec[2] > 0) { |
| 691 | hsum = sd->rLambFront.cieY; |
| 692 | rdf = sd->rf; |
| 693 | tdf = (sd->tf != NULL) ? sd->tf : sd->tb; |
| 694 | } else /* !inFront */ { |
| 695 | hsum = sd->rLambBack.cieY; |
| 696 | rdf = sd->rb; |
| 697 | tdf = (sd->tb != NULL) ? sd->tb : sd->tf; |
| 698 | } |
| 699 | if ((sflags & SDsampDf+SDsampR) != SDsampDf+SDsampR) |
| 700 | hsum = .0; |
| 701 | if ((sflags & SDsampDf+SDsampT) == SDsampDf+SDsampT) |
| 702 | hsum += (inVec[2] > 0) ? |
| 703 | sd->tLambFront.cieY : sd->tLambBack.cieY; |
| 704 | /* gather non-diffuse components */ |
| 705 | i = (((sflags & SDsampSp+SDsampR) == SDsampSp+SDsampR) & |
| 706 | (rdf != NULL)) ? rdf->ncomp : 0; |
| 707 | while (i-- > 0) {               /* non-diffuse reflection */ |
| 708 | cd = (*rdf->comp[i].func->getCDist)(inVec, &rdf->comp[i]); |
| 709 | if (cd != NULL) |
| 710 | hsum += cd->cTotal; |
| 711 | } |
| 712 | i = (((sflags & SDsampSp+SDsampT) == SDsampSp+SDsampT) & |
| 713 | (tdf != NULL)) ? tdf->ncomp : 0; |
| 714 | while (i-- > 0) {               /* non-diffuse transmission */ |
| 715 | cd = (*tdf->comp[i].func->getCDist)(inVec, &tdf->comp[i]); |
| 716 | if (cd != NULL) |
| 717 | hsum += cd->cTotal; |
| 718 | } |
| 719 | return hsum; |
| 720 | } |
| 721 |  |
| 722 | /* Sample BSDF direction based on the given random variable */ |
| 723 | SDError |
| 724 | SDsampBSDF(SDValue *sv, FVECT ioVec, double randX, int sflags, const SDData *sd) |
| 725 | { |
| 726 | SDError         ec; |
| 727 | FVECT           inVec; |
| 728 | int             inFront; |
| 729 | SDSpectralDF    *rdf, *tdf; |
| 730 | double          rdiff; |
| 731 | float           coef[SDmaxCh]; |
| 732 | int             i, j, n, nr; |
| 733 | SDComponent     *sdc; |
| 734 | const SDCDst    **cdarr = NULL; |
| 735 | /* check arguments */ |
| 736 | if ((sv == NULL) | (ioVec == NULL) | (sd == NULL) | |
| 737 | (randX < 0) | (randX >= 1.)) |
| 738 | return SDEargument; |
| 739 | /* whose side are we on? */ |
| 740 | VCOPY(inVec, ioVec); |
| 741 | inFront = (inVec[2] > 0); |
| 742 | /* remember diffuse portions */ |
| 743 | if (inFront) { |
| 744 | *sv = sd->rLambFront; |
| 745 | rdf = sd->rf; |
| 746 | tdf = (sd->tf != NULL) ? sd->tf : sd->tb; |
| 747 | } else /* !inFront */ { |
| 748 | *sv = sd->rLambBack; |
| 749 | rdf = sd->rb; |
| 750 | tdf = (sd->tb != NULL) ? sd->tb : sd->tf; |
| 751 | } |
| 752 | if ((sflags & SDsampDf+SDsampR) != SDsampDf+SDsampR) |
| 753 | sv->cieY = .0; |
| 754 | rdiff = sv->cieY; |
| 755 | if ((sflags & SDsampDf+SDsampT) == SDsampDf+SDsampT) |
| 756 | sv->cieY += inFront ? sd->tLambFront.cieY : sd->tLambBack.cieY; |
| 757 | /* gather non-diffuse components */ |
| 758 | i = nr = (((sflags & SDsampSp+SDsampR) == SDsampSp+SDsampR) & |
| 759 | (rdf != NULL)) ? rdf->ncomp : 0; |
| 760 | j = (((sflags & SDsampSp+SDsampT) == SDsampSp+SDsampT) & |
| 761 | (tdf != NULL)) ? tdf->ncomp : 0; |
| 762 | n = i + j; |
| 763 | if (n > 0 && (cdarr = (const SDCDst **)malloc(n*sizeof(SDCDst *))) == NULL) |
| 764 | return SDEmemory; |
| 765 | while (j-- > 0) {               /* non-diffuse transmission */ |
| 766 | cdarr[i+j] = (*tdf->comp[j].func->getCDist)(inVec, &tdf->comp[j]); |
| 767 | if (cdarr[i+j] == NULL) |
| 768 | cdarr[i+j] = &SDemptyCD; |
| 769 | sv->cieY += cdarr[i+j]->cTotal; |
| 770 | } |
| 771 | while (i-- > 0) {               /* non-diffuse reflection */ |
| 772 | cdarr[i] = (*rdf->comp[i].func->getCDist)(inVec, &rdf->comp[i]); |
| 773 | if (cdarr[i] == NULL) |
| 774 | cdarr[i] = &SDemptyCD; |
| 775 | sv->cieY += cdarr[i]->cTotal; |
| 776 | } |
| 777 | if (sv->cieY <= 1e-6) {         /* anything to sample? */ |
| 778 | sv->cieY = .0; |
| 779 | memset(ioVec, 0, sizeof(FVECT)); |
| 780 | return SDEnone; |
| 781 | } |
| 782 | /* scale random variable */ |
| 783 | randX *= sv->cieY; |
| 784 | /* diffuse reflection? */ |
| 785 | if (randX < rdiff) { |
| 786 | SDdiffuseSamp(ioVec, inFront, randX/rdiff); |
| 787 | goto done; |
| 788 | } |
| 789 | randX -= rdiff; |
| 790 | /* diffuse transmission? */ |
| 791 | if ((sflags & SDsampDf+SDsampT) == SDsampDf+SDsampT) { |
| 792 | const SDValue   *sdt = inFront ? &sd->tLambFront : &sd->tLambBack; |
| 793 | if (randX < sdt->cieY) { |
| 794 | sv->spec = sdt->spec; |
| 795 | SDdiffuseSamp(ioVec, !inFront, randX/sdt->cieY); |
| 796 | goto done; |
| 797 | } |
| 798 | randX -= sdt->cieY; |
| 799 | } |
| 800 | /* else one of cumulative dist. */ |
| 801 | for (i = 0; i < n && randX >= cdarr[i]->cTotal; i++) |
| 802 | randX -= cdarr[i]->cTotal; |
| 803 | if (i >= n) |
| 804 | return SDEinternal; |
| 805 | /* compute sample direction */ |
| 806 | sdc = (i < nr) ? &rdf->comp[i] : &tdf->comp[i-nr]; |
| 807 | ec = (*sdc->func->sampCDist)(ioVec, randX/cdarr[i]->cTotal, cdarr[i]); |
| 808 | if (ec) |
| 809 | return ec; |
| 810 | /* compute color */ |
| 811 | j = (*sdc->func->getBSDFs)(coef, inVec, ioVec, sdc); |
| 812 | if (j <= 0) { |
| 813 | sprintf(SDerrorDetail, "BSDF \"%s\" sampling value error", |
| 814 | sd->name); |
| 815 | return SDEinternal; |
| 816 | } |
| 817 | sv->spec = sdc->cspec[0]; |
| 818 | rdiff = coef[0]; |
| 819 | while (--j) { |
| 820 | c_cmix(&sv->spec, rdiff, &sv->spec, coef[j], &sdc->cspec[j]); |
| 821 | rdiff += coef[j]; |
| 822 | } |
| 823 | done: |
| 824 | if (cdarr != NULL) |
| 825 | free(cdarr); |
| 826 | c_ccvt(&sv->spec, C_CSXY);      /* make sure (x,y) is set */ |
| 827 | return SDEnone; |
| 828 | } |
| 829 |  |
| 830 | /* Compute World->BSDF transform from surface normal and up (Y) vector */ |
| 831 | SDError |
| 832 | SDcompXform(RREAL vMtx[3][3], const FVECT sNrm, const FVECT uVec) |
| 833 | { |
| 834 | if ((vMtx == NULL) | (sNrm == NULL) | (uVec == NULL)) |
| 835 | return SDEargument; |
| 836 | VCOPY(vMtx[2], sNrm); |
| 837 | if (normalize(vMtx[2]) == 0) |
| 838 | return SDEargument; |
| 839 | fcross(vMtx[0], uVec, vMtx[2]); |
| 840 | if (normalize(vMtx[0]) == 0) |
| 841 | return SDEargument; |
| 842 | fcross(vMtx[1], vMtx[2], vMtx[0]); |
| 843 | return SDEnone; |
| 844 | } |
| 845 |  |
| 846 | /* Compute inverse transform */ |
| 847 | SDError |
| 848 | SDinvXform(RREAL iMtx[3][3], RREAL vMtx[3][3]) |
| 849 | { |
| 850 | RREAL   mTmp[3][3]; |
| 851 | double  d; |
| 852 |  |
| 853 | if ((iMtx == NULL) | (vMtx == NULL)) |
| 854 | return SDEargument; |
| 855 | /* compute determinant */ |
| 856 | mTmp[0][0] = vMtx[2][2]*vMtx[1][1] - vMtx[2][1]*vMtx[1][2]; |
| 857 | mTmp[0][1] = vMtx[2][1]*vMtx[0][2] - vMtx[2][2]*vMtx[0][1]; |
| 858 | mTmp[0][2] = vMtx[1][2]*vMtx[0][1] - vMtx[1][1]*vMtx[0][2]; |
| 859 | d = vMtx[0][0]*mTmp[0][0] + vMtx[1][0]*mTmp[0][1] + vMtx[2][0]*mTmp[0][2]; |
| 860 | if (d == 0) { |
| 861 | strcpy(SDerrorDetail, "Zero determinant in matrix inversion"); |
| 862 | return SDEargument; |
| 863 | } |
| 864 | d = 1./d;                       /* invert matrix */ |
| 865 | mTmp[0][0] *= d; mTmp[0][1] *= d; mTmp[0][2] *= d; |
| 866 | mTmp[1][0] = d*(vMtx[2][0]*vMtx[1][2] - vMtx[2][2]*vMtx[1][0]); |
| 867 | mTmp[1][1] = d*(vMtx[2][2]*vMtx[0][0] - vMtx[2][0]*vMtx[0][2]); |
| 868 | mTmp[1][2] = d*(vMtx[1][0]*vMtx[0][2] - vMtx[1][2]*vMtx[0][0]); |
| 869 | mTmp[2][0] = d*(vMtx[2][1]*vMtx[1][0] - vMtx[2][0]*vMtx[1][1]); |
| 870 | mTmp[2][1] = d*(vMtx[2][0]*vMtx[0][1] - vMtx[2][1]*vMtx[0][0]); |
| 871 | mTmp[2][2] = d*(vMtx[1][1]*vMtx[0][0] - vMtx[1][0]*vMtx[0][1]); |
| 872 | memcpy(iMtx, mTmp, sizeof(mTmp)); |
| 873 | return SDEnone; |
| 874 | } |
| 875 |  |
| 876 | /* Transform and normalize direction (column) vector */ |
| 877 | SDError |
| 878 | SDmapDir(FVECT resVec, RREAL vMtx[3][3], const FVECT inpVec) |
| 879 | { |
| 880 | FVECT   vTmp; |
| 881 |  |
| 882 | if ((resVec == NULL) | (inpVec == NULL)) |
| 883 | return SDEargument; |
| 884 | if (vMtx == NULL) {             /* assume they just want to normalize */ |
| 885 | if (resVec != inpVec) |
| 886 | VCOPY(resVec, inpVec); |
| 887 | return (normalize(resVec) > 0) ? SDEnone : SDEargument; |
| 888 | } |
| 889 | vTmp[0] = DOT(vMtx[0], inpVec); |
| 890 | vTmp[1] = DOT(vMtx[1], inpVec); |
| 891 | vTmp[2] = DOT(vMtx[2], inpVec); |
| 892 | if (normalize(vTmp) == 0) |
| 893 | return SDEargument; |
| 894 | VCOPY(resVec, vTmp); |
| 895 | return SDEnone; |
| 896 | } |
