| 1 |
from __future__ import division, print_function, unicode_literals |
| 2 |
| 3 |
import os |
| 4 |
| 5 |
Import('env') |
| 6 |
| 7 |
# compose paths |
| 8 |
def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name) |
| 9 |
| 10 |
# custom flags |
| 11 |
getlibpath = env.StaticObject(source='getlibpath.c', |
| 12 |
CPPFLAGS='-DDEFPATH="\\"%s\\""' % env['RAD_RLIBDIR'].replace('\\','/')) |
| 13 |
tmapcolrs = env.StaticObject(source='tmapcolrs.c', |
| 14 |
CPPFLAGS='-DPCOND=\\"pcond\\"') |
| 15 |
ezxml = env.StaticObject('ezxml.c', |
| 16 |
CPPDEFINES=env.get('CPPDEFINES',[]) + env.get('EZXML_CPPDEFINES',[])) |
| 17 |
objs = [getlibpath, tmapcolrs, ezxml] |
| 18 |
| 19 |
# the definition of addobjnotify conflicts with definitions in other files |
| 20 |
# that are more essential to the library. |
| 21 |
# We need to pass this one around and include it individually |
| 22 |
addobjn = env.StaticObject(source='addobjnotify.c') |
| 23 |
env['ADDOBJNOTIFY'] = addobjn |
| 24 |
| 25 |
# source and object dependencies |
| 26 |
RTSCENE = Split('''cone.c face.c free_os.c instance.c readobj.c readoct.c |
| 27 |
otypes.c objset.c octree.c readfargs.c modobject.c |
| 28 |
font.c mesh.c readmesh.c tmesh.c sceneio.c xf.c''') |
| 29 |
RTPIC = Split('''color.c colrops.c resolu.c image.c bmpfile.c falsecolor.c |
| 30 |
tonemap.c tmapluv.c tmap16bit.c tmaptiff.c''') |
| 31 |
RTERROR = Split('''error.c eputs.c wputs.c quit.c''') |
| 32 |
RTCONT = Split('''lookup.c savestr.c savqstr.c ccolor.c ccyrgb.c |
| 33 |
spec_rgb.c bsdf.c bsdf_m.c bsdf_t.c loadbsdf.c |
| 34 |
disk2square.c hilbert.c interp2d.c triangulate.c''') |
| 35 |
RTMATH = Split('''fvect.c invmat4.c linregr.c mat4.c tcos.c urand.c urind.c |
| 36 |
zeroes.c dircode.c clip.c multisamp.c plocate.c byteswap.c''' |
| 37 |
) + env.get('RAD_MATHCOMPAT', []) |
| 38 |
RTFUNC = Split('''biggerlib.c caldefn.c calexpr.c calfunc.c calprnt.c |
| 39 |
chanvalue.c''') |
| 40 |
RTIO = Split('''fdate.c fgetline.c fgetval.c fgetword.c fputword.c loadvars.c |
| 41 |
portio.c wordfile.c words.c header.c timegm.c cvtcmd.c''') |
| 42 |
RTARGS = Split('''badarg.c expandarg.c''') + env.get('RAD_ARGSCOMPAT', []) |
| 43 |
RTPATH = Split('''getpath.c gethomedir.c paths.c''') |
| 44 |
RTLAMPS = Split('''fropen.c rexpr.c lamps.c''') |
| 45 |
RTPROC = Split('''process.c''') + env.get('RAD_PROCESS', []) |
| 46 |
RTMEM = Split('ealloc.c bmalloc.c') |
| 47 |
RTNET = Split('myhostname.c') |
| 48 |
| 49 |
librtrad = env.StaticLibrary(target=radlib('rtrad'), |
| 50 |
source=RTERROR + RTPATH + RTARGS + RTIO + RTMATH + RTCONT + RTMEM |
| 51 |
+ RTFUNC + RTPROC + RTLAMPS + RTSCENE + RTPIC + RTNET + objs) |
| 52 |
| 53 |
MGF = Split('''mgf_parser.c mgf_object.c mgf_xf.c mgf_context.c''') |
| 54 |
libmgf = env.StaticLibrary(target=radlib('mgf'), source=MGF) |
| 55 |
| 56 |
REETZ = Split('g3affine.c g3flist.c g3sphere.c g3vector.c gbasic.c maxheap.c muc_randvar.c') |
| 57 |
libreetz = env.StaticLibrary(target=radlib('reetz'), source=REETZ) |
| 58 |
| 59 |
LIBFILES = Split('tmesh.cal') |
| 60 |
env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES)) |
| 61 |
| 62 |
if env.has_key('OGL'): |
| 63 |
oglincl = env.get('CPPPATH', []) + env.get('OGLINCLUDE', []) |
| 64 |
RGL = Split('rglfile.c rglmat.c rgldomat.c rglsurf.c rglinst.c rglsrc.c') |
| 65 |
librgl = env.StaticLibrary(target=radlib('rgl'), source=RGL, |
| 66 |
CPPPATH=oglincl) |
| 67 |
Default(librgl) |
| 68 |
| 69 |
# vim: set syntax=python: |
| 70 |
# vi: set ts=4 sw=4 : |
| 71 |
