root/radiance/src/common/CMakeLists.txt
Thu Jul 24 01:24:01 2025 UTC (2 months, 3 weeks ago) by greg
Diff to previous 1.24 , to selected 1.1
chore: Added version string to all CMakeLists.txt files
Sat Mar 1 00:51:26 2025 UTC (7 months, 2 weeks ago) by greg
CVS Tags: rad6R0
Changes since 1.23: +1 -1 lines
Diff to previous 1.23 , to selected 1.1
chore: Added missing strncasecmp() library call for Windows
Sun Dec 8 18:19:40 2024 UTC (10 months, 1 week ago) by greg
Changes since 1.22: +1 -1 lines
Diff to previous 1.22 , to selected 1.1
chore: Fixed entry for strnstr.c
Tue Dec 3 01:11:43 2024 UTC (10 months, 2 weeks ago) by greg
Diff to previous 1.21 , to selected 1.1
Mon Aug 19 20:21:08 2024 UTC (13 months, 4 weeks ago) by greg
Changes since 1.20: +1 -1 lines
Diff to previous 1.20 , to selected 1.1
chore: Fixed extra comma
Wed Aug 14 20:05:23 2024 UTC (14 months ago) by greg
Changes since 1.19: +7 -9 lines
Diff to previous 1.19 , to selected 1.1
Fri Aug 2 18:47:25 2024 UTC (14 months, 2 weeks ago) by greg
Changes since 1.18: +1 -0 lines
Diff to previous 1.18 , to selected 1.1
feat(gensdaymtx,epw2wea,genssky): Taoning added new gensdaymtx and updated others
Fri Dec 3 18:10:48 2021 UTC (3 years, 10 months ago) by greg
Changes since 1.17: +1 -0 lines
Diff to previous 1.17 , to selected 1.1
refactor: moved depth-of-field sampling to separate module
Mon Oct 18 16:20:21 2021 UTC (4 years ago) by greg
Diff to previous 1.16 , to selected 1.1
chore(evalglare): Changed libreetz to just reetz
Mon Mar 22 00:52:54 2021 UTC (4 years, 6 months ago) by greg
Changes since 1.15: +1 -0 lines
Diff to previous 1.15 , to selected 1.1
chore: added forgotton new module
Mon Jun 8 16:27:05 2020 UTC (5 years, 4 months ago) by greg
Diff to previous 1.14 , to selected 1.1
Added strlcpy.c module to Linux builds
Mon Mar 30 18:28:35 2020 UTC (5 years, 6 months ago) by greg
Changes since 1.13: +7 -0 lines
Diff to previous 1.13 , to selected 1.1
Thu Nov 7 23:20:28 2019 UTC (5 years, 11 months ago) by greg
Diff to previous 1.12 , to selected 1.1
Fri Jul 26 16:18:06 2019 UTC (6 years, 2 months ago) by greg
Diff to previous 1.11 , to selected 1.1
Thu Apr 19 15:31:27 2018 UTC (7 years, 6 months ago) by greg
Changes since 1.10: +0 -2 lines
Diff to previous 1.10 , to selected 1.1
Changed HUGE reference to FHUGE + removed references to unused module maxheap.c
Wed Mar 21 19:59:07 2018 UTC (7 years, 7 months ago) by greg
Diff to previous 1.9 , to selected 1.1
Added win_usleep.c to Windows library build
Thu Jan 18 20:24:34 2018 UTC (7 years, 9 months ago) by greg
Diff to previous 1.8 , to selected 1.1
Updated inclusion of strlcpy
Mon Jan 8 16:51:32 2018 UTC (7 years, 9 months ago) by greg
Changes since 1.7: +143 -25 lines
Diff to previous 1.7 , to selected 1.1
Update to CMake build system from Rob G. and Alex S., adding test cases
Thu Jul 14 17:32:12 2016 UTC (9 years, 3 months ago) by greg
Diff to previous 1.6 , to selected 1.1
Changes to evalglare by Jan Wienold
Wed Feb 3 22:54:01 2016 UTC (9 years, 8 months ago) by greg
Changes since 1.5: +6 -1 lines
Diff to previous 1.5 , to selected 1.1
Fixes in cmake build for last changes (thanks to Rob G.)
Tue Aug 18 17:28:11 2015 UTC (10 years, 2 months ago) by greg
Diff to previous 1.4 , to selected 1.1
Commit to support evalglare in cmake build system (Rob G.)
Fri Feb 7 19:00:45 2014 UTC (11 years, 8 months ago) by greg
Diff to previous 1.3 , to selected 1.1
Updated with dependency on triangulate.{c,h}
Fri Aug 10 21:18:19 2012 UTC (13 years, 2 months ago) by greg
Diff to previous 1.2 , to selected 1.1
Build fixes for cmake
Wed Apr 25 22:21:06 2012 UTC (13 years, 5 months ago) by greg
Revision 1.1 - (view) (download) (annotate) - [selected]
Sat Oct 22 22:38:10 2011 UTC (13 years, 11 months ago) by greg
Added qt interface for rvu and cmake files from Bill Hoffman
