root/radiance/src/cal/lam.c
Revision: 1.14
Committed: Sun Mar 9 20:07:27 2014 UTC (11 years, 7 months ago) by greg
CVS Tags: rad5R0, rad4R2, rad4R2P1, rad4R2P2
Changes since 1.13: +12 -2 lines
Added flockfile calls and fixed SET_FILE_BINARY usage for consistency
2 static const char RCSid[] = "$Id: lam.c,v 1.13 2014/02/11 17:05:00 greg Exp $";
5 * lam.c - simple program to laminate files.
6 *
7 * 7/14/88 Greg Ward
8 */
9
10 #include <stdlib.h>
11 #include <string.h>
12 #include <stdio.h>
13 #include <ctype.h>
14
15 #include "platform.h"
16 #include "rtprocess.h"
17
18 #define MAXFILE 512 /* maximum number of files */
19
20 #define MAXLINE 65536 /* maximum input line */
21
22 FILE *input[MAXFILE];
23 int bytsiz[MAXFILE];
24 char *tabc[MAXFILE];
25 int nfiles;
26
27 char buf[MAXLINE];
28
29 int
30 main(argc, argv)
31 int argc;
32 char *argv[];
33 {
34 int unbuff = 0;
35 int binout = 0;
36 int i;
37 char *curtab;
38 int curbytes;
39 int puteol;
40
41 curtab = "\t";
42 curbytes = 0;
43 nfiles = 0;
44 for (i = 1; i < argc; i++) {
45 if (argv[i][0] == '-') {
46 switch (argv[i][1]) {
47 case 't':
48 curtab = argv[i]+2;
49 break;
50 case 'u':
51 unbuff = !unbuff;
52 break;
53 case 'i':
54 switch (argv[i][2]) {
55 case 'f':
56 curbytes = sizeof(float);
57 break;
58 case 'd':
59 curbytes = sizeof(double);
60 break;
61 case 'i':
62 curbytes = sizeof(int);
63 break;
64 case 'w':
65 curbytes = 2;
66 break;
67 case 'b':
68 curbytes = 1;
69 break;
70 case 'a':
71 curbytes = argv[i][3] ? -1 : 0;
72 break;
73 default:
74 goto badopt;
75 }
76 if (isdigit(argv[i][3]))
77 curbytes *= atoi(argv[i]+3);
78 if (abs(curbytes) > MAXLINE) {
79 fputs(argv[0], stderr);
80 fputs(": input size too big\n", stderr);
81 exit(1);
82 }
83 if (curbytes) {
84 curtab = "";
85 ++binout;
86 }
87 break;
88 case '\0':
89 tabc[nfiles] = curtab;
90 input[nfiles] = stdin;
91 if (curbytes > 0)
92 SET_FILE_BINARY(input[nfiles]);
93 else
94 curbytes = -curbytes;
95 bytsiz[nfiles++] = curbytes;
96 break;
97 badopt:;
98 default:
99 fputs(argv[0], stderr);
100 fputs(": bad option\n", stderr);
101 exit(1);
102 }
103 } else if (argv[i][0] == '!') {
104 tabc[nfiles] = curtab;
105 if ((input[nfiles] = popen(argv[i]+1, "r")) == NULL) {
106 fputs(argv[i], stderr);
107 fputs(": cannot start command\n", stderr);
108 exit(1);
109 }
110 if (curbytes > 0)
111 SET_FILE_BINARY(input[nfiles]);
112 else
113 curbytes = -curbytes;
114 bytsiz[nfiles++] = curbytes;
115 } else {
116 tabc[nfiles] = curtab;
117 if ((input[nfiles] = fopen(argv[i], "r")) == NULL) {
118 fputs(argv[i], stderr);
119 fputs(": cannot open file\n", stderr);
120 exit(1);
121 }
122 if (curbytes > 0)
123 SET_FILE_BINARY(input[nfiles]);
124 else
125 curbytes = -curbytes;
126 bytsiz[nfiles++] = curbytes;
127 }
128 if (nfiles >= MAXFILE) {
129 fputs(argv[0], stderr);
130 fputs(": too many input streams\n", stderr);
131 exit(1);
132 }
133 }
134 if (binout) /* binary output? */
135 SET_FILE_BINARY(stdout);
136 #ifdef getc_unlocked /* avoid lock/unlock overhead */
137 for (i = nfiles; i--; )
138 flockfile(input[i]);
139 flockfile(stdout);
140 #endif
141 puteol = 0; /* check for ASCII output */
142 for (i = nfiles; i--; )
143 if (!bytsiz[i] || isprint(tabc[i][0]) || tabc[i][0] == '\t') {
144 puteol++;
145 break;
146 }
147 for ( ; ; ) { /* main loop */
148 for (i = 0; i < nfiles; i++) {
149 if (bytsiz[i]) { /* binary file */
150 if (fread(buf, bytsiz[i], 1, input[i]) < 1)
151 break;
152 if (i)
153 fputs(tabc[i], stdout);
154 fwrite(buf, bytsiz[i], 1, stdout);
155 } else {
156 if (fgets(buf, MAXLINE, input[i]) == NULL)
157 break;
158 if (i)
159 fputs(tabc[i], stdout);
160 buf[strlen(buf)-1] = '\0';
161 fputs(buf, stdout);
162 }
163 }
164 if (i < nfiles)
165 break;
166 if (puteol)
167 putchar('\n');
168 if (unbuff)
169 fflush(stdout);
170 }
171 return(0);
172 }
