root/radiance/resources/cmake_tests/CMakeLists.txt
Revision: 1.2
Committed: Mon Jan 8 16:51:31 2018 UTC (7 years, 9 months ago) by greg
Changes since 1.1: +35 -35 lines
Update to CMake build system from Rob G. and Alex S., adding test cases
1 include(FindPerl)
2
3 set(resources_dir "${CMAKE_SOURCE_DIR}/resources")
4
5 configure_file(setup_paths.cmake.in setup_paths.cmake @ONLY)
6 # configure these files so that they will be in the binary
7 # directory. This will allow them to include setup_paths.cmake
8 # from the binary directory and just use regular variables in the
9 # configured files.
10 configure_file(test_setup.cmake test_setup.cmake COPYONLY)
11 configure_file(test_rtrace.cmake test_rtrace.cmake COPYONLY)
12 configure_file(test_rpict.cmake test_rpict.cmake COPYONLY)
13 configure_file(test_getinfo.cmake test_getinfo.cmake COPYONLY)
14 configure_file(test_pcond.cmake test_pcond.cmake COPYONLY)
15 configure_file(test_falsecolor.cmake test_falsecolor.cmake COPYONLY)
16 configure_file(test_DC.cmake test_DC.cmake COPYONLY)
17 configure_file(test_evalglare.cmake test_evalglare.cmake COPYONLY)
18
19 add_test(test_setup ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_setup.cmake)
20
21 add_test(test_rtrace ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_rtrace.cmake)
22 set_tests_properties(test_rtrace PROPERTIES
23 PASS_REGULAR_EXPRESSION "passed"
24 FAIL_REGULAR_EXPRESSION "failed"
25 )
26
27 add_test(test_rpict ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_rpict.cmake)
28 set_tests_properties(test_rpict PROPERTIES
29 PASS_REGULAR_EXPRESSION "passed"
30 FAIL_REGULAR_EXPRESSION "failed"
31 )
32
33 add_test(test_getinfo ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_getinfo.cmake)
34
35 add_test(test_pcond ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_pcond.cmake)
36 set_tests_properties(test_pcond PROPERTIES
37 PASS_REGULAR_EXPRESSION "passed"
38 FAIL_REGULAR_EXPRESSION "failed"
39 )
40
41 add_test(test_evalglare ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_evalglare.cmake)
42 set_tests_properties(test_evalglare PROPERTIES
43 PASS_REGULAR_EXPRESSION "passed"
44 FAIL_REGULAR_EXPRESSION "failed"
45 )
46
47 if(PERL_FOUND)
48 add_test(test_falsecolor ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_falsecolor.cmake)
49 set_tests_properties(test_falsecolor PROPERTIES
50 PASS_REGULAR_EXPRESSION "passed"
51 FAIL_REGULAR_EXPRESSION "failed"
52 )
53 endif()
