root/radiance/resources/cmake_tests/CMakeLists.txt
Revision: 1.4
Committed: Thu Jul 24 01:24:01 2025 UTC (2 months, 3 weeks ago) by greg
Changes since 1.3: +2 -0 lines
Error occurred while calculating annotation data.
chore: Added version string to all CMakeLists.txt files
1 # RCSid $Id$
2
3 include(FindPerl)
4
5 set(resources_dir "${CMAKE_SOURCE_DIR}/resources")
6 set(rad_test_dir "${CMAKE_SOURCE_DIR}/test")
7
8 ### CONFIGURE TESTS
9
10 configure_file(setup_paths.cmake.in setup_paths.cmake @ONLY)
11 # configure these files so that they will be in the binary
12 # directory. This will allow them to include setup_paths.cmake
13 # from the binary directory and just use regular variables in the
14 # configured files.
15 configure_file(test_setup.cmake test_setup.cmake COPYONLY)
16 configure_file(test_rtrace.cmake test_rtrace.cmake COPYONLY)
17 configure_file(test_rpict.cmake test_rpict.cmake COPYONLY)
18 configure_file(test_pcond.cmake test_pcond.cmake COPYONLY)
19 configure_file(test_falsecolor.cmake test_falsecolor.cmake COPYONLY)
20 configure_file(test_DC.cmake test_DC.cmake COPYONLY)
21 configure_file(test_evalglare.cmake test_evalglare.cmake COPYONLY)
22
23 ### ADD TESTS
24
25 add_test(test_setup ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_setup.cmake)
26
27 add_test(test_rtrace ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_rtrace.cmake)
28 set_tests_properties(test_rtrace PROPERTIES
29 PASS_REGULAR_EXPRESSION "passed"
30 FAIL_REGULAR_EXPRESSION "failed"
31 )
32
33 add_test(test_rpict ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_rpict.cmake)
34 set_tests_properties(test_rpict PROPERTIES
35 PASS_REGULAR_EXPRESSION "passed"
36 FAIL_REGULAR_EXPRESSION "failed"
37 )
38
39 add_test(test_pcond ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_pcond.cmake)
40 set_tests_properties(test_pcond PROPERTIES
41 PASS_REGULAR_EXPRESSION "passed"
42 FAIL_REGULAR_EXPRESSION "failed"
43 )
44
45 add_test(test_evalglare ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_evalglare.cmake)
46 set_tests_properties(test_evalglare PROPERTIES
47 PASS_REGULAR_EXPRESSION "passed"
48 FAIL_REGULAR_EXPRESSION "failed"
49 )
50
51
52 if(PERL_FOUND)
53 add_test(test_falsecolor ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_falsecolor.cmake)
54 set_tests_properties(test_falsecolor PROPERTIES
55 PASS_REGULAR_EXPRESSION "passed"
56 FAIL_REGULAR_EXPRESSION "failed"
57 )
58 endif()
