root/radiance/ray/test/util/Makefile
Revision: 1.11
Committed: Mon Mar 21 01:17:18 2022 UTC (3 years, 4 months ago) by greg
CVS Tags: rad6R0, rad5R4, HEAD
test(rcollate): Added -c option to test-rcollate
1 # RCSid $Id: Makefile,v 1.10 2022/03/15 20:37:02 greg Exp $
2 #
3 # Unit tests for tools built in src/util but not covered by test/renders
4 #
5
6 all: test-vwright test-getinfo test-rcollate test-rmtxop test-dctimestep \
7 test-genskyvec test-vwrays test-glarendx test-rcode_norm test-rcode_depth \
8 test-rcode_ident test-wrapBSDF test-rttree_reduce test-rcrop
9
10 clean:
11 rm -f test.mtx cropped.mtx ttree.txt vwrays.txt
12
13 test-vwright: test.vf
14 vwright -vf test.vf 3.5 > vwright.txt
15 radcompare ref/vwright.txt vwright.txt
16 rm -f vwright.txt
17
18 test-vwrays: vwrays.txt
19 radcompare ref/vwrays.txt vwrays.txt
20
21 test-getinfo: test.mtx
22 getinfo -a Guppies "Fredo the Frog" < test.mtx | getinfo > getinfo.txt
23 radcompare ref/getinfo.txt getinfo.txt
24 rm -f getinfo.txt
25
26 test-rmtxop: test.mtx
27 rmtxop -ff -c .3 .9 .2 test.mtx -c .7 .2 .3 -t test.mtx | radcompare ref/rmtxop.mtx -
28
29 test-rcollate: test.mtx
30 radcompare ref/test.mtx test.mtx
31
32 test-rcode_ident: idents.txt
33 rcode_ident -8 -x 20 -y 10 idents.txt | radcompare ref/idents.idx -
34 rcode_ident -r -H ref/idents.idx | radcompare idents.txt -
35
36 test-rcode_norm: vwrays.txt
37 rcode_norm -hi -x 40 -y 15 vwrays.txt | radcompare ref/norms.nrm -
38
39 test-rcode_depth: depths.txt
40 rcode_depth -x 20 -y 10 -d 150/inch depths.txt | radcompare -h ref/depths.dpt -
41 rcode_depth -r -Ho ref/depths.dpt | radcompare -w depths.txt -
42
43 test-glarendx: glaresrc.txt
44 glarendx -t guth_vcp glaresrc.txt | radcompare ref/guth_vcp.txt -
45 glarendx -t cie_cgi glaresrc.txt | radcompare ref/cie_cgi.txt -
46 glarendx -t ugr glaresrc.txt | radcompare ref/ugr.txt -
47 glarendx -t brs_gi glaresrc.txt | radcompare ref/brs_gi.txt -
48 glarendx -t dgi glaresrc.txt | radcompare ref/dgi.txt -
49 glarendx -t guth_dgr glaresrc.txt | radcompare ref/guth_dgr.txt -
50 glarendx -t vert_dir glaresrc.txt | radcompare ref/vert_dir.txt -
51 glarendx -t vert_ill glaresrc.txt | radcompare ref/vert_ill.txt -
52 glarendx -t vert_ind glaresrc.txt | radcompare ref/vert_ind.txt -
53
54 test-rttree_reduce: ttree.txt
55 radcompare ref/ttree.txt ttree.txt
56
57 test-wrapBSDF: ttree.txt
58 wrapBSDF -a t3 -u centimeter -f 'm=Test Guys;n=Bogus;t=2.54;h=20;w=45;' \
59 -rb ttree.txt > testBSDF.xml
60 radcompare ref/testBSDF.xml testBSDF.xml
61 rm -f testBSDF.xml
62
63 test.mtx: ../renders/ref/rfmirror.mtx
64 rcollate -c -t ../renders/ref/rfmirror.mtx > test.mtx
65
66 ttree.txt:
67 cnt 256 | rcalc -e '$$1=floor(sin(PI/256*recno)*40)' \
68 | rttree_reduce -h -g 3 -r 3 -t 95 > ttree.txt
69
70 vwrays.txt:
71 vwrays -vts -vp 100 50 -75 -vo 10 -va 1000 -vh 160 -vv 130 \
72 -x 20 -y 20 -vu 0 -1 0 -vd .358 -.8851 1.152 > vwrays.txt
73
74 test-genskyvec: test-dctimestep
75
76 test-dctimestep: test.mtx
77 gensky 3 21 10:15PST +s -g .3 -g 2.5 -a 36 -o 124 \
78 | genskyvec -m 1 -c .92 1.03 1.2 \
79 | dctimestep '!rmtxop -ff -t test.mtx' > dctimestep.mtx
80 radcompare ref/dctimestep.mtx dctimestep.mtx
81 rm -f dctimestep.mtx
82
83 test-rcrop: test.mtx
84 rcrop 15 31 75 19 test.mtx > cropped.mtx
85 radcompare ref/cropped.mtx cropped.mtx
86 rm -f cropped.mtx
