root/radiance/ray/test/util/Makefile
Mon Mar 21 01:17:18 2022 UTC (3 years, 4 months ago) by greg
Diff to previous 1.10 , to selected 1.2
test(rcollate): Added -c option to test-rcollate
Tue Mar 15 20:37:02 2022 UTC (3 years, 5 months ago) by greg
Diff to previous 1.9 , to selected 1.2
test: Removed -v option from radcompare
Tue Mar 15 00:25:50 2022 UTC (3 years, 5 months ago) by greg
Changes since 1.8: +8 -3 lines
Diff to previous 1.8 , to selected 1.2
feat(rcrop): Created simple cropping utility for matrices and pictures
Tue Aug 18 19:33:58 2020 UTC (4 years, 11 months ago) by greg
Diff to previous 1.7 , to selected 1.2
chore: added custom Windows compilation of Perl scripts
Fri Jul 17 23:02:10 2020 UTC (5 years, 1 month ago) by greg
test(genskyvec, falsecolr): changed to call perl for Windows
Tue Jun 30 18:00:19 2020 UTC (5 years, 1 month ago) by greg
Changes since 1.5: +3 -3 lines
test(wrapBSDF,rttree_reduce): added missing tests in Makefile and test data
Tue Jun 30 17:51:34 2020 UTC (5 years, 1 month ago) by greg
Changes since 1.4: +16 -5 lines
test(rttree_reduce,wrapBSDF): added missing unit tests
Tue Jun 30 03:34:15 2020 UTC (5 years, 1 month ago) by greg
feat(rcode_depth,rcode_ident): Added reverse-conversion tests
Tue Jun 30 01:23:03 2020 UTC (5 years, 1 month ago) by greg
Changes since 1.2: +31 -3 lines
Diff to previous 1.2
feat(vwrays,glarendx,rcode_norm,rcode_depth,rcode_ident): added tool tests
Sat Jan 26 00:55:50 2019 UTC (6 years, 6 months ago) by greg
Changes since 1.1: +5 -1 lines
Added target for genskyvec
Sat Jan 26 00:50:47 2019 UTC (6 years, 6 months ago) by greg
Diff to selected 1.2
Low-hanging fruit from util directory
